Calabar Posted April 11, 2010 Posted April 11, 2010 (edited) [Rules of the Topic] [Statistics] - - - - - - - - - - [Not Indexed Yet Entries] [Themes A-C] - - - - [Themes D-M] - - - - [Themes N-S] - - - - [Themes T-Z] [Begin of the entries] - - - - - - - - - - [Last Update Point] Rules of the Topic (Please read these guidelines before posting) Here are some guidelines created in order to help to maintain this topic well ordered and help to built the index! Allowed Sets Set that has been officially released by LEGO and available for the purchase. Set whose Official Instructions has been released from TLG and are available in LEGO website. IMPORTANT NOTE: if building instructions or set's references are not easily available on common sources, please report that. The Set have to be constructed using official LEGO instructions and not interpreting preliminary or official images. The Set have to contain something you can build. Sets with scattered parts or single or few minifigures are not allowed. Irregular Posts Important NOTE: Irregular entries (inserted in posts that don't respect the Topic's Rules) won't be indexed. When you fix an irregular post, inform the indexer, so that he can update the index database. Good habits Avoid unnecessary posts inside this topic, if possible. Always use a new post to add new entry/entries. Don't add (or remove!) models to any existing post. If you think to build more sets in a short period of time, don't post them one by one but amass a bit of them and then post them together. Try to avoid to post more than one time in a single day. For any question/explanation/request/communication contact the indexer using private messages, when possible. Use of images in the topic [Guide] Only images related to posted sets (and then lxf file) are allowed, as a preview. Only one image for each set is allowed. Don't quote images from other posts. Any other image can be inserted as text link. Images should be simple and clear: no "creative" images are allowed, but simple screenshots. Avoid compositions (more images in one), images with another image as background, animated images, 3D images, renderings with external software, image with custom added parts, etc... Try to place objects inside the image so that the image results compact (i.e. avoid internal large blank space if possible) but clear. Try to place the camera so that the set results well visible. Avoid flat framing but choose a good 3D angle. As images are for preview purpose only, should be not too big! Maximum size allowed is 512x512 pixels for big sets (such as castles, modular buildings, stations, large space ships, etc...). Use intermediate sizes (for example 448px, 384px, 320px, ...) for smaller models. The 256x256px size or lower is often good for small sets. Crop images completely removing horizontal and vertical blank stripes around the subject (zero-pixles margins). Insert a model Report set's data and emphasize that in bold. Set's data include set Number, set official Name and set's Theme and subtheme if any. For example: 5988 - Pharaoh's Forbidden Ruins - Theme: Adventure If the set has more "configurations" (different models), please specify which one you are reproducing with LDD (Model A, Model B, etc...). NOTE: Alternate Versions (official different configurations for the same set) are counted as separate sets. If the set has been Re-Released with an identical or similar version, report the alternate Set ID(s). Report both the version of LDD and the brickset used to build the model. Insert a screenshot of your creation, in order to provide a preview. One screenshot for each set (see the rules about images above). Write an Error List, reporting if the model is complete or some element is missing or replaced (by a similar part, a brick assembly or any custom solution). Use part IDs to identify the bricks. Don't divide a single set in more than one post. Put a single set in a single .lxf file. You are encouraged to use LDD groups function to separate different elements in complex sets. LDD model should be similar to the original model as much as possible. Include minifigs, if any. Replace missing decorations with suitable ones, if possible.Modified models are welcome, but in different .lxf files, as an "extra". Every personalization (personal logos, additions, changes) makes a model a "Modified Model". and obviously... Share you lxf file! Update a set Update the post where you originally inserted the set. Report the update in the Upgrade Topic. Be care to follow the rules of the Upgrade Topic. [Sets created by other users] If the set has been built by another user, contact him and ask him to update his entry. Provide some help, if you find a way to solve some issue. If contact model's builder is not possible or he don't want to update it, insert the updated model in a new post as if it is a new model, but specify it is an update and insert the link to the original model's post. Inform the indexer before posting. Use of the new bricks from the custom LDD updates [new!] A model without custom bricks is necessary to the entry to be accepted as regular. A model with custom bricks is allowed as an extra. You are encouraged to publish both the models for your entries. Book or Request a set Refer to "Official Lego sets - Book, WIP, Requests" Topic. NOTE: you can ever choose to make an already made or booked set, if you want. Besides You are encouraged to inform an LDD file maker if you notice an adjustable defect in his/her LDD file! If you notice something wrong in the index, please report it to the indexer. If you use custom pieces to replace missing bricks in LDD, please post it in the "LDD custom bricks" Topic! Rules in brief Read the rules before posting here. Only regular entries will be indexed. Allowed sets: instructions officially released, no spared parts. Report references if necessary.Insert a model General rules: don't split model in more posts, don't add or remove entries to an existing post, group entries. Don't add personalizations to the model (except in order to replace missing parts). Use Groups. Extra are allowed, as text links. Models containing custom parts are allowed ad extra only. Necessary content: Set's Data, Image, LXF File, Error List. - Set's data: Set's ID, Set's name, Theme/Subtheme, alternative model (Model A, B, ...), alternative Set IDs if any. - Image: one for each set, simple screenshots, PNG with Alpha channel, maximum size 512x (big sets), crop (zero-pixles margins), not scattered, no flat view. - LXF file: one for each entry, direct link, report LDD and brickset version. - Error List: missing bricks/decorations, replaced brick/decorations, brick made replacements. Various: minimal quotes, don't quote images, report errors. (index/other entries). Edited March 18, 2021 by Calabar Quote
Calabar Posted April 17, 2010 Author Posted April 17, 2010 (edited) Statistics Last Index Update Date: 2021/03/18 Page: 202 Post: #5026 Indexed Sets - Total Number: 6412 - Alternatives: 794 - Duplicates: 717 - Incomplete: 35 Un-Indexed Sets - Irregular Posts: 88 - Not Allowed Sets: 6 The list of irregular entries is available in the last update point post. Top contributors vean - 596 sets ADHO15 - 554 sets Gnac - 513 sets Stephan - 469 sets PeabodySam - 443 sets AndyC - 344 sets penguinz - 291 sets marco9999 - 268 sets Edited March 18, 2021 by Calabar Quote
Calabar Posted April 18, 2010 Author Posted April 18, 2010 (edited) Not Indexed Yet Entries Last Update Date: 2021/11/13Page: 202Post: #5035 42116 - Skid Steer Loader - by Migui94 - <LDD 4.3.11> 42116 - Skid Steer Loader (B model) - by Migui94 - <LDD 4.3.11> 42117 - Race Plane - by Migui94 - <LDD 4.3.11> 42117 - Race Plane (B model) - by Migui94 - <LDD 4.3.11> 42118 - Monster Jam Grave Digger - by Migui94 - <LDD 4.3.11> 42118 - Monster Jam Grave Digger (B model) - by Migui94 - <LDD 4.3.11> 42119 - Monster Jam Max-D - by Migui94 - <LDD 4.3.11> 42119 - Monster Jam Max-D (B model) - by Migui94 - <LDD 4.3.11> [IRREGULAR] - 60288 - Race Buggy Transporter - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60285 - Sports Car - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60305 - Car Transporter - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60275 - Police Helicopter - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60276 - Police Prisoner Transport - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60277 - Police Patrol Boat - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60292 - Town Center - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60306 - Shopping Street - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60291 - Family House - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60290 - Skate Park - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60304 - Road Plates - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 40373 - Fairground Accessory Set blister pack - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60289 - Airshow Jet Transporter - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60286 - Beach Rescue ATV - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60284 - Roadwork Truck - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60287 - Tractor - by kovalscky - <LDD 4.3.11> - Irregular Image [IRREGULAR] - 60283 - Holiday Camper Van - by kovalscky - <LDD 4.3.11> - Irregular Image 60287 - Tractor - by vean - <LDD 4.3.11> 60288 - Race Buggy Transporter - by vean - <LDD 4.3.11> 60285 - Sports Car - by vean - <LDD 4.3.11> 60305 - Car Transporter - by vean - <LDD 4.3.11> 40488 - Coffee Cart - by vean - <LDD 4.3.11> NEWSSTAND-1 - Newstand - by vean - <LDD 4.3.11> Edited November 13, 2021 by Calabar Quote
Calabar Posted April 18, 2010 Author Posted April 18, 2010 (edited) INDEX of Official LEGO sets made in LDD [ HINT: use Browser's search function (usually CTRL+F, or command+F for MAC) to search a set in the index ][ Don't stop at the first entry: different versions of a set have the same name and number ] Adventurers 1094 - Johnny Thunder - by ThorsHammer9999 - <LDD 4.3.11> - Comment: aka 5900 1182 - Adventurer's Raft - by AndyC - <LDD 4> 1182 - Adventurers Raft - by ThorsHammer9999 - <LDD 4.3.11> - Comment: aka 3020 "Jones' Raft" 1183 - Mummy and Cart - by PeabodySam - <LDD 4.3.9> 2541 - Adventurers Car - by PeabodySam - <LDD 4.3.5> 2542 - Adventurers Aeroplane - by PeabodySam - <LDD 4.3.5> 2879 - Desert Expedition - by AndyC - <LDD 4> 2995 - Adventurer's Car - by AndyC - <LDD 4> 2996 - Adventurer's Tomb - by AndyC - <LDD 4> 3022 - Plane of Hurrykain - by AndyC - <LDD 4> 3023 - Slyboot Car - by pbat - <LDD 4.3.6> 5901 - River Raft - by AndyC - <LDD 4> 5903 - Johnny Thunder and Baby T - by PeabodySam - <LDD 4.3.5> 5904 - Microcopter - by PeabodySam - <LDD 4.3.5> 5905 - Hidden Treasure - by PeabodySam - <LDD 4.3.8> 5906 - Ruler of the Jungle - by AndyC - <LDD 4> 5909 - Treasure Raiders set with Mummy Storage Container (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Mummy's Transport" 5911 - Johnny Thunder's Plane - by PeabodySam - <LDD 4.3.5> 5912 - Hydrofoil - by PeabodySam - <LDD 4.3.5> 5913 - Dr. Lightning's Car - by PeabodySam - <LDD 4.3.5> 5914 - Baby T-Rex Trap - by PeabodySam - <LDD 4.3.8> 5918 - Scorpion Tracker - by AndyC - <LDD 4> 5918 - Desert Buggy (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Desert Buggy" 5919 - In the Valley of the Kings - by petero - <LDD 4> - Comment: Similar to 3722 5920 - Island Racer - by ChristopherLee - <LDD 4.3.8> 5920 - Island Racer - by Jaymercury - <LDD 4> 5921 - Research Glider - by PeabodySam - <LDD 4.3.5> 5925 - Pontoon Plane (A model) - by Jaymercury - <LDD 4> 5925 - Pontoon Plane (B model) - by PeabodySam - <LDD 4.3.5> - Comment: Adventurer Hovercraft 5928 - Bi-Wing Baron - by Calabar - <LDD 4> 5934 - Track Master - Dino Explorer - by Jaymercury - <LDD 4> 5935 - Island Hopper (A model) - by Jaymercury - <LDD 4> 5935 - Island Hopper (B model) - by PeabodySam - <LDD 4.3.8> 5935 - Island Hopper (C model) - by PeabodySam - <LDD 4.3.8> - Comment: HelioRaptor 5936 - Spider's Secret - by Daedalus304 - <LDD 4> 5936 - Spider's Secret (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Jungle Explorer" 5938 - Oasis Ambush - by bischen - <LDD 4> 5938 - Oasis Ambush - by petero - <LDD 4> 5955 - All Terrain Trapper (A model) - by PeabodySam - <LDD 4.3.8> 5955 - All Terrain Trapper (B model) - by PeabodySam - <LDD 4.3.8> 5955 - All Terrain Trapper (C model) - by PeabodySam - <LDD 4.3.5> 5956 - Expedition Balloon - by PeabodySam - <LDD 4.3.8> 5958 - Mummy's Tomb - by petero - <LDD 4> 5975 - T-Rex Transport - by AndyC - <LDD 4> 5975 - T-Rex Transport (B model) - by PeabodySam - <LDD 4.3.8> 5976 - River Expedition - by PeabodySam - <LDD 4.3.8> 5978 - Sphinx Secret Surprise - by penguinz - <LDD 4.3.6> 5978 - Sphinx Secret Surprise - by petero - <LDD 4> 5986 - Amazon Ancient Ruins - by penguinz - <LDD 4.3.8> 5987 - Dino Research Compound (A model) - by AndyC - <LDD 4> 5987 - Dino Research Compound (B model) - by PeabodySam - <LDD 4.3.5> 5987 - Dino Research Compound (C model) - by PeabodySam - <LDD 4.3.6> 5987 - Dino Research Compound (D model) - by PeabodySam - <LDD 4.3.5> 5988 - Pharaoh's Forbidden Ruins - by petero - <LDD 4> 7409 - Secret of the tomb - by Jaymercury - <LDD 4> 7410 - Jungle River - by Jaymercury - <LDD 4> 7411 - Tygurah's Roar - by Jaymercury - <LDD 4> 7412 - Yeti's Hideout - by Jaymercury - <LDD 4> 7413 - Passage of Jun-Chi - by Jaymercury - <LDD 4> 7414 - Elephant Caravan - by Jaymercury - <LDD 4> 7415 - Aero Nomad - by Jaymercury - <LDD 4> 7415 - Aero Nomad - by JopieK - <LDD 3> 7416 - Emperor's Ship - by PeabodySam - <LDD 4.3.8> 7417 - Temple of Mount Everest - by penguinz - <LDD 4.3.8> 7417 - Temple of the Mountain (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Race to Burning Mountain" 7418 - Scorpion Palace - by PeabodySam - <LDD 4.3.9> 7418 - Scorpion Palace and Foam Scimitar (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Secret of the Jungle Shrine" 7419 - Dragon Fortress - by penguinz - <LDD 4.3.8> 7420 - Thunder Blazer - by Jaymercury - <LDD 4> 7422 - Red Eagle - by Jaymercury - <LDD 4> 7423 - Mountain Sleigh - by Jaymercury - <LDD 4> 7424 - Black Cruiser - by Jaymercury - <LDD 4> 1278+1279+1280+1281 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 3020+3021+3022+3023 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 5911+5912+5913+5914 - Super Flying Machine - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Agents 8630 - Gold Hunt - by Aanchir - <LDD 4> 8631 - Mission 1: Jetpack Pursuit - by PeabodySam - <LDD 4.3.8> 8632 - Swamp Raid - by Aanchir - <LDD 4> 8633 - Speedboat Rescue - by Aanchir - <LDD 4> 8634 - Turbocar Chase - by Aanchir - <LDD 4> 8635 - Mobile Command Center - by Aanchir - <LDD 4> 8635 - Mission 6: Mobile Command Center (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Agents HQ" 8636 - Deep Sea Quest - by Aanchir - <LDD 4> 8637 - Mission 8: Volcano Base - by obsidianheart - <LDD 4.3.5> 8967 - Gold Tooth's Getaway - by Aanchir - <LDD 4> 8968 - River Heist - by PeabodySam - <LDD 4.3.9> 8969 - 4-Wheeling Pursuit - by Aanchir - <LDD 4> 8970 - Robo Attack - by prateek - <LDD 3> 8971 - Aerial Defense Unit - by obsidianheart - <LDD 4> 8968+8969 - Covert Spy Tank - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Alpha Team 1425 - Dash Jet Sub - by ashir - <LDD 4.3.6> 1425 - AT Jet Sub - by Sjuip - <LDD 4.3.5> - Comment: aka 4800 1426 - Cam Wing Diver - by PeabodySam - <LDD 4.3.5> 1427 - Ogel Marine Slizer - by pbat - <LDD 4.3.6> 4742 - Chill Speeder - by PeabodySam - <LDD 4.3.5> 4743 - Ice Blade - by PeabodySam - <LDD 4.3.8> 4744 - Tundra Tracker - by PeabodySam - <LDD 4.3.10> 4745 - Blue Eagle vs. Snow Crawler - by PeabodySam - <LDD 4.3.8> 4746 - Mobile Command Center - by PeabodySam - <LDD 4.3.8> 4748 - Ogel's Mountain Fortress - by PeabodySam - <LDD 4.3.9> 4770 - Blizzard Blaster - by penguinz - <LDD 4.3.8> 4770 - Blizzard Blaster (B model) - by PeabodySam - <LDD 4.3.8> 4770 - Blizzard Blaster (C model) - by PeabodySam - <LDD 4.3.8> 4770 - Blizzard Blaster (D model) - by PeabodySam - <LDD 4.3.8> 4774 - Scorpion Orb Launcher - by PeabodySam - <LDD 4.3.8> 4774 - Scorpion Orb Launcher (B model) - by PeabodySam - <LDD 4.3.8> 4774 - Scorpion Orb Launcher (C model) - by PeabodySam - <LDD 4.3.8> 4774 - Scorpion Orb Launcher (D model) - by PeabodySam - <LDD 4.3.8> 4774 - Scorpion Orb Launcher (E model) - by PeabodySam - <LDD 4.3.8> 4788 - Ogel Mutant Ray - by PeabodySam - <LDD 4.3.8> 4789 - Alpha Team Aquatic Mech - by PeabodySam - <LDD 4.3.5> 4790 - Alpha Team Deep Sea Robot Diver - by PeabodySam - <LDD 4.3.6> 4791 - Alpha Team Sub-Surface Scooter (A model) - by PeabodySam - <LDD 4.3.5> 4791 - Alpha Team Sub-Surface Scooter (B model) - by PeabodySam - <LDD 4.3.5> - Comment: HydroJet 4792 - Alpha Team Navigator and ROV - by PeabodySam - <LDD 4.3.5> 4793 - Ogel Sub Shark - by PeabodySam - <LDD 4.3.9> 4794 - Alpha Team Command Sub - by PeabodySam - <LDD 4.3.5> 4795 - Ogel Underwater Base and AT Sub - by penguinz - <LDD 4.3.8> 4796 - Ogel Mutant Squid - by PeabodySam - <LDD 4.3.8> 4797 - Ogel Mutant Killer Whale - by PeabodySam - <LDD 4.3.8> 4798 - Evil Ogel Attack - by PeabodySam - <LDD 4.3.5> 4799 - Ogel Drone Octopus - by PeabodySam - <LDD 4.3.5> 6771 - Ogel Command Striker - by PeabodySam - <LDD 4.3.8> 6772 - Alpha Team Cruiser - by PeabodySam - <LDD 4.3.8> 6773 - Alpha Team Helicopter - by PeabodySam - <LDD 4.3.8> 6773 - Alpha Team Helicopter - by Daedalus304 - <LDD 4> 6774 - Alpha Team ATV - by PeabodySam - <LDD 4.3.8> 6775 - Alpha Team Bomb Squad - by PeabodySam - <LDD 4.3.5> 6776 - Ogel Command Centre - by penguinz - <LDD 4.3.8> 1425+1426 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1425+1426+1427 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1425+1427 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1426+1427 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 4743+4744 - Quad Cannon - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 4793+4797 - Ogel's Undersea Serpent - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 6772+6773 - Super Stealth Jet - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Aquazone 1095 - Super Sub - by Shine - <LDD 4.3.8> - Comment: aka 6100 1749 - Paravane - by marco9999 - <LDD 4.3.8> - Comment: aka 1806 1822 - Sea Claw 7 / Neptune III - by marco9999 - <LDD 4.3.8> 2160 - Crystal Scavenger - by marco9999 - <LDD 4.3.8> 2161 - Aqua Dozer - by PeabodySam - <LDD 4.3.8> 2162 - Hydro Reef Wrecker - by marco9999 - <LDD 4.3.8> 6115 - Shark Scout - by Aanchir - <LDD 4> 6125 - Sea Sprint 9 - by Toa_Of_Justice - <LDD 4> 6135 - Spy Shark - by Aanchir - <LDD 4> 6145 - Crystal Crawler - by Toa_Of_Justice - <LDD 4> 6155 - Deep Sea Predator - by desrs6 - <LDD 4.3.5> 6175 - Crystal Explorer Sub - by marco9999 - <LDD 4.3.8> 6190 - Shark's Crystal Cave - by marco9999 - <LDD 4.3.8> 6195 - Neptune Discovery Lab - by marco9999 - <LDD 4.3.8> 6198 - Sting Ray Stormer - by Shine - <LDD 4> 6199 - Hydro Crystalization Station - by penguinz - <LDD 4.3.6> 7770 - Deep Sea Treasure Hunter - by PeabodySam - <LDD 4.3.8> 7771 - Angler Ambush - by Costy - <LDD 4.3.5> 7772 - Lobster Strike - by penguinz - <LDD 4.3.8> 7773 - Tiger Shark Attack - by Costy - <LDD 4.3.5> 7774 - Crab Crusher - by Costy - <LDD 4.3.5> 7775 - Aquabase Invasion - by penguinz - <LDD 4.3.8> 7776 - The Shipwreck - by penguinz - <LDD 4.3.8> Architecture 21000 - Willis Tower (formerly Sears Tower) - by ADHO15 - <LDD 4.3.5> 21000 - Sears Tower - by Henni - <LDD 4.3.9> 21001 - John Hancock Center - by ADHO15 - <LDD 4.3.5> 21001 - John Hancock Center - by Henni - <LDD 4.3.9> 21002 - Empire State Building - by Henni - <LDD 4.3.9> 21002 - Empire State Building - by ADHO15 - <LDD 4.3.5> 21003 - Seattle Space Needle - by ADHO15 - <LDD 4.3.5> 21003 - Seattle Space Needle - by Henni - <LDD 4.3.9> 21004 - Solomon R. Guggenheim Museum - by ADHO15 - <LDD 4.3.5> 21004 - Solomon R. Guggenheim Museum - by Henni - <LDD 4.3.9> 21005 - Fallingwater - by Henni - <LDD 4.3.9> 21005 - Fallingwater - by ADHO15 - <LDD 4.3.5> 21005 - Fallingwater - by Superkalle - <LDD 3> - Comment: Mod 21006 - The White House - by Henni - <LDD 4.3.9> 21006 - The White House - by ADHO15 - <LDD 4.3.5> 21006 - The White House - by Aanchir - <LDD 4> 21006 - The White House - by AndyC - <LDD 4> 21007 - Rockefeller Center - by Henni - <LDD 4.3.9> 21007 - Rockerfeller Center - by ADHO15 - <LDD 4.3.5> 21007 - Rockerfeller Center - by C3POwen - <LDD 4> 21007 - Rockerfeller Center - by Captain Becker - <LDD 4> 21008 - Burj Khalifa - by Henni - <LDD 4.3.9> 21008 - Burj Khalifa - by ADHO15 - <LDD 4> 21009 - Farnsworth House - by Henni - <LDD 4.3.9> 21009 - Farnsworth House - by ADHO15 - <LDD 4.3.5> 21010 - Robie House - by Henni - <LDD 4.3.9> 21010 - Robie House - by ADHO15 - <LDD 4> 21011 - Brandenburg Gate - by Henni - <LDD 4.3.9> 21011 - Brandenburg Gate - by BrickWild - <LDD 4> 21011 - Brandenburg Gate - by ADHO15 - <LDD 4.3.5> 21012 - Sydney Opera House - by Henni - <LDD 4.3.9> 21012 - Sydney Opera House - by ADHO15 - <LDD 4.3.5> 21012 - Sydney Opera House - by Stephan - <LDD 4> 21013 - Big Ben - by Henni - <LDD 4.3.9> 21013 - Big Ben - by iSware - <LDD 4.3.11> 21013 - Big Ben - by ADHO15 - <LDD 4> 21014 - Villa Savoye - by Henni - <LDD 4.3.9> 21014 - Villa Savoye - by ADHO15 - <LDD 4> 21015 - The Leaning Tower of Pisa - by Henni - <LDD 4.3.9> 21015 - The Leaning Tower of Pisa - by Stephan - <LDD 4.3.6> 21015 - The Leaning Tower of Pisa - by ADHO15 - <LDD 4.3.6> 21016 - Sungnyemun - by Henni - <LDD 4.3.9> 21016 - Sungnyemun - by Graysmith - <LDD n/a> 21016 - Sungnyemun - by ADHO15 - <LDD 4.3.5> 21017 - Imperial Hotel - by Stephan - <LDD 4.3.6> 21017 - Imperial Hotel - by Henni - <LDD 4.3.9> 21017 - Imperial Hotel - by ADHO15 - <LDD 4.3.6> 21018 - United Nations Headquarters - by ADHO15 - <LDD 4.3.6> 21018 - United Nations Headquarters - by Henni - <LDD 4.3.9> 21019 - The Eiffel Tower - by Stephan - <LDD 4.3.9> 21019 - The Eiffel Tower - by Henni - <LDD 4.3.9> 21020 - Trevi Fountain - by Stephan - <LDD 4.3.8> 21020 - Trevi Fountain - by Henni - <LDD 4.3.9> 21021 - Marina Bay Sands - by Henni - <LDD 4.3.9> 21021 - Marina Bay Sands - by Stephan - <LDD 4.3.6> 21022 - Lincoln Memorial - by Henni - <LDD 4.3.9> 21022 - Lincoln Memorial - by Stephan - <LDD 4.3.8> 21023 - Flatiron Building - by Stephan - <LDD 4.3.8> 21023 - Flatiron Building - by Henni - <LDD 4.3.9> 21024 - Louvre - by Henni - <LDD 4.3.9> 21024 - Louvre - by Stephan - <LDD 4.3.8> 21026 - Venice - by Stephan - <LDD 4.3.8> 21026 - Venice - by Henni - <LDD 4.3.9> 21027 - Berlin - by Stephan - <LDD 4.3.9> 21027 - Berlin - by Henni - <LDD 4.3.9> 21028 - New York City - by Henni - <LDD 4.3.9> 21028 - New York City - by Stephan - <LDD 4.3.9> 21029 - Buckingham Palace - by Stephan - <LDD 4.3.9> 21030 - United States Capitol Building - by Stephan - <LDD 4.3.9> 21031 - Burj Khalifa - by Stephan - <LDD 4.3.9> 21031 - Burj Khalifa - by Henni - <LDD 4.3.9> 21032 - Sydney - by Stephan - <LDD 4.3.10> 21033 - Chicago - by Stephan - <LDD 4.3.10> 21034 - London - by Stephan - <LDD 4.3.11> 21035 - Solomon R. Guggenheim Museum - by t12ung - <LDD 4.3.10> 21035 - Solomon R. Guggenheim Museum - by ChristopherLee - <LDD 4.3.10> 21035 - Solomon R. Guggenheim Museum - by Stephan - <LDD 4.3.11> 21036 - Arc De Triomphe - by Henni - <LDD 4.3.10> 21036 - Arc De Triomphe - by Stephan - <LDD 4.3.11> 21037 - Lego House - by Stephan - <LDD 4.3.10> 21037 - Lego House - by JunkstyleGio - <LDD 4.3.11> 21039 - Shanghai - by Stephan - <LDD 4.3.11> 21041 - Great Wall of China - by Stephan - <LDD 4.3.11> 21042 - Statue of Liberty - by Stephan - <LDD 4.3.11> 21042 - Statue of Liberty - by BrickWild - <LDD 4.3.11> Atlantis 7976 - Ocean Speeder - by Giovanne - <LDD 4> 7977 - Seabed Strider - by Giovanne - <LDD 4> 7978 - Angler Attack - by prateek - <LDD 4> 7984 - Deep Sea Raider - by KartoffelViking - <LDD 4> 7985 - City of Atlantis - by penguinz - <LDD 4.3.8> 8056 - Monster Crab Clash - by Aanchir - <LDD 4> 8057 - Wreck Raider - by Randal - <LDD 3> 8058 - Guardian of the Deep - by Aanchir - <LDD 4> 8059 - Seabed Scavenger - by Toa_Of_Justice - <LDD 4> 8060 - Typhoon Turbo Sub - by Randal - <LDD 3> 8061 - Gateway of the Squid - by Aanchir - <LDD 4> 8072 - Sea Jet - by Randal - <LDD 3> 8073 - Manta Warrior - by prateek - <LDD 3> 8075 - Neptune Carrier - by Randal - <LDD 3> 8076 - Deep Sea Striker - by marco9999 - <LDD 4.3.6> 8077 - Atlantis Exploration HQ - by penguinz - <LDD 4.3.8> 8077 - Atlantis Exploration HQ - by AndyC - <LDD 4> 8078 - Portal of Atlantis - by Aanchir - <LDD 4> 8079 - Shadow Snapper - by Randal - <LDD 3> 8079 - Shadow Snapper - by PeabodySam - <LDD 4.3.9> - Comment: "Crushtacean" 8080 - Undersea Explorer - by Randal - <LDD 3> 20013 - Neptune Microsub - by Randal - <LDD 3> 30040 - Octopus - by ILikePi - <LDD 3> 30041 - Piranha - by ILikePi - <LDD 3> 30042 - Mini Sub - by ILikePi - <LDD 3> 30042 - Mini Sub - by Randal - <LDD 3> Avatar 3828 - Air Temple - by penguinz - <LDD 4.3.8> 3829 - Fire Nation Ship - by marco9999 - <LDD 4> Batman I 7779 - The Batman Dragster - Catwoman Pursuit [DC Heroes] - by ADHO15 - <LDD 4> 7780 - The Batboat - Hunt for Killer Croc [DC Heroes] - by ADHO15 - <LDD 4> 7783 - The Batcave: The Penguin and Mr. Freeze's Invasion - by penguinz - <LDD 4.3.8> 7784 - The Batmobile UCS [DC Heroes] - by bbqqq - <LDD 4> 7784 - The Batmobile UCS [DC Heroes] - by AndyC - <LDD 4> 7786 - The Batcopter: The Chase for the Scarecrow [DC Heroes] - by ADHO15 - <LDD 4> 7787 - The Bat-Tank: The Riddler and Bane's Hideout [DC Heroes] - by ADHO15 - <LDD 4> 7884 - Batman's Buggy: Escape of Mr Freeze [DC Heroes] - by ADHO15 - <LDD 4> 7885 - Robin's Scuba Jet - Attack of The Penguin [DC Heroes] - by ADHO15 - <LDD 4> 7886 - The Batcycle: Harley Quinn's Hammer Truck [DC Heroes] - by ADHO15 - <LDD 4> 7888 - The Tumbler: Joker's Ice Cream Surprise [DC Heroes] - by Randal - <LDD 3> - [INCOMPLETE] - Comment: Batmobile only 7888 - The Tumbler: Joker's Ice Cream Surprise [DC Heroes] - by ADHO15 - <LDD 4> Belville 5872 - Golden Land Promo (Polybag) - by Gnac - <LDD 4.3.6> 5873 - Fairyland Promo (Polybag) - by Gnac - <LDD 4.3.6> 7579 - Blossom Fairy - by Sjuip - <LDD 4.3.8> 7583 - Playful Puppy - by Sjuip - <LDD 4.3.8> 7585 - Pony Stable - by Sjuip - <LDD 4.3.8> - [INCOMPLETE] - Comment: Replacemente for figures missing 7586 - Sunshine Home - by Sjuip - <LDD 4.3.8> - [INCOMPLETE] - Comment: Replacemente for figures missing Bionicle 4868 - Rahaga Gaaki - by PeabodySam - <LDD 4.3.8> 4869 - Rahaga Pouks - by PeabodySam - <LDD 4.3.8> 4870 - Rahaga Kualus - by PeabodySam - <LDD 4.3.8> 4877 - Rahaga Norik - by PeabodySam - <LDD 4.3.8> 4878 - Rahaga Bomonga - by PeabodySam - <LDD 4.3.8> 4879 - Rahaga Iruini - by PeabodySam - <LDD 4.3.8> 6126 - Good Guy 2008 - by PeabodySam - <LDD 4.3.8> 6127 - Bad Guy 2008 - by PeabodySam - <LDD 4.3.8> 6128 - Function 2008 - by PeabodySam - <LDD 4.3.8> 6936 - Piraka & Catapult - by PeabodySam - <LDD 4.3.8> 6945 - Bad Guy 07 - by PeabodySam - <LDD 4.3.8> 6946 - Squid Launcher Function polybag - by PeabodySam - <LDD 4.3.8> 8531 - Pohatu - by PeabodySam - <LDD 4.3.8> 8532 - Onua - by PeabodySam - <LDD 4.3.8> 8533 - Gali - by PeabodySam - <LDD 4.3.8> 8534 - Tahu - by PeabodySam - <LDD 4.3.8> 8535 - Lewa - by PeabodySam - <LDD 4.3.8> 8536 - Kopaka - by PeabodySam - <LDD 4.3.8> 8537 - Nui-Rama (A model) - by PeabodySam - <LDD 4.3.8> 8537 - Nui-Rama (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Nui-Kopen" 8538 - Muaka & Kane-Ra (A model) - by PeabodySam - <LDD 4.3.9> 8538 - Muaka & Kane-Ra (B model) - by PeabodySam - <LDD 4.3.9> - Comment: "Kuma-Nui" 8539 - Manas (A model) - by PeabodySam - <LDD 4.3.8> 8539 - Manas (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Mana Ko" 8540 - Vakama - by PeabodySam - <LDD 4.3.8> 8541 - Matau - by PeabodySam - <LDD 4.3.8> 8542 - Onewa - by PeabodySam - <LDD 4.3.8> 8543 - Nokama - by PeabodySam - <LDD 4.3.10> 8544 - Nuju - by PeabodySam - <LDD 4.3.8> 8545 - Whenua - by PeabodySam - <LDD 4.3.8> 8548 - Nui-Jaga (A model) - by PeabodySam - <LDD 4.3.6> 8548 - Nui-Jaga (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Kahu" 8549 - Tarakava (A model) - by PeabodySam - <LDD 4.3.9> 8549 - Tarakava (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Tarakava-Nui" 8550 - Gahlok Va - by PeabodySam - <LDD 4.3.8> 8551 - Kohrak Va - by PeabodySam - <LDD 4.3.8> 8552 - Lehvak Va - by PeabodySam - <LDD 4.3.8> 8553 - Pahrak Va - by PeabodySam - <LDD 4.3.8> 8554 - Tahnok Va - by PeabodySam - <LDD 4.3.8> 8555 - Nuhvok Va - by PeabodySam - <LDD 4.3.8> 8556 - Boxor - by PeabodySam - <LDD 4.3.9> 8556 - Boxor (B model) - by PeabodySam - <LDD 4.3.9> 8557 - Exo-Toa - by PeabodySam - <LDD 4.3.11> 8557 - Exo-Toa (B model) - by PeabodySam - <LDD 4.3.11> 8558 - Cahdok & Gahdok - by PeabodySam - <LDD 4.3.11> 8558 - Cahdok & Gahdok (B model) - by PeabodySam - <LDD 4.3.10> 8621 - Turaga Dume & Nivawk - by PeabodySam - <LDD 4.3.10> 8622 - Nidhiki - by PeabodySam - <LDD 4.3.10> 8623 - Krekka - by PeabodySam - <LDD 4.3.10> 8624 - Race for the Mask of Life - by PeabodySam - <LDD 4.3.8> 8695 - Gorast - by PeabodySam - <LDD 4.3.11> 8698 - Vultraz - by PeabodySam - <LDD 4.3.8> 8699 - Takanuva - by PeabodySam - <LDD 4.3.8> 8755 - Keetongu - by PeabodySam - <LDD 4.3.9> 8756 - Sidorak - by PeabodySam - <LDD 4.3.10> 8757 - Visorak Battle Ram - by PeabodySam - <LDD 4.3.8> 8758 - Tower of Toa - by PeabodySam - <LDD 4.3.8> 8759 - Battle of Metru Nui - by PeabodySam - <LDD 4.3.9> 8761 - Roodaka - by PeabodySam - <LDD 4.3.10> 8769 - Visorak's Gate - by PeabodySam - <LDD 4.3.8> 8892 - Piraka Outpost - by PeabodySam - <LDD 4.3.8> 8893 - Lava Chamber Gate - by penguinz - <LDD 4.3.8> 8894 - Piraka Stronghold - by PeabodySam - <LDD 4.3.8> 8915 - Toa Mahri Matoro - by PeabodySam - <LDD 4.3.11> 8916 - Takadox - by PeabodySam - <LDD 4.3.8> 8920 - Ehlek - by PeabodySam - <LDD 4.3.8> 8921 - Pridak - by PeabodySam - <LDD 4.3.8> 8923 - Hydraxon - by PeabodySam - <LDD 4.3.8> 8925 - Barraki Deepsea Patrol - by PeabodySam - <LDD 4.3.8> 8926 - Toa Undersea Attack - by PeabodySam - <LDD 4.3.8> 8927 - Toa Terrain Crawler - by PeabodySam - <LDD 4.3.8> 8941 - Rockoh T3 - by PeabodySam - <LDD 4.3.8> 8942 - Jetrax T6 Limited Edition (A model) - by PeabodySam - <LDD 4.3.8> - Comment: Alternate version with Yellow parts 8942 - Jetrax T6 Edition (A model) - by PeabodySam - <LDD 4.3.10> 8942 - Jetrax T6 Limited Edition (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Destral Cycle" 8943 - Axalara T9 - by PeabodySam - <LDD 4.3.8> 8954 - Mazeka - by PeabodySam - <LDD 4.3.8> 8983 - Vorox - by PeabodySam - <LDD 4.3.8> 8986 - Vastus - by PeabodySam - <LDD 4.3.11> 8987 - Kiina - by Costy - <LDD 4.3.6> 8991 - Tuma - by PeabodySam - <LDD 4.3.8> 8992 - Cendox V1 - by PeabodySam - <LDD 4.3.8> 8993 - Kaxium V3 - by PeabodySam - <LDD 4.3.9> 8994 - Baranus V7 - by PeabodySam - <LDD 4.3.8> 8995 - Thornatus V9 - by PeabodySam - <LDD 4.3.8> 8996 - Skopio XV-1 - by PeabodySam - <LDD 4.3.8> 10023 - Master Builder Set - by Aanchir - <LDD 4> 10023 - Master Builder Set (A model) - by PeabodySam - <LDD 4.3.8> - Comment: "Kojo-Jaga" 10023 - Master Builder Set (E model) - by PeabodySam - <LDD 4.3.8> - Comment: "Fikou" 10023 - Master Builder Set (F model) - by PeabodySam - <LDD 4.3.6> - Comment: "Hoi" 10023 - Master Builder Set (G model) - by PeabodySam - <LDD 4.3.8> - Comment: "Kewa" 10023 - Master Builder Set (H model) - by PeabodySam - <LDD 4.3.8> - Comment: "Husi" 10023 - Master Builder Set (I model) - by PeabodySam - <LDD 4.3.8> - Comment: "Ussal" 10023 - Master Builder Set (K model) - by PeabodySam - <LDD 4.3.8> - Comment: "Vako" 10023 - Master Builder Set (L model) - by PeabodySam - <LDD 4.3.8> - Comment: "Makika" 10023 - Master Builder Set (M model) - by PeabodySam - <LDD 4.3.9> - Comment: "Hikaki" 10023 - Master Builder Set (O model) - by PeabodySam - <LDD 4.3.8> - Comment: "Fusa" 20012 - Click - by Costy - <LDD 4.3.5> 70778 - Protector of Jungle - by PeabodySam - <LDD 4.3.11> 70779 - Protector of Stone - by PeabodySam - <LDD 4.3.11> 70780 - Protector of Water - by PeabodySam - <LDD 4.3.11> 70781 - Protector of Earth - by PeabodySam - <LDD 4.3.10> 70782 - Protector of Ice - by PeabodySam - <LDD 4.3.11> 70783 - Protector of Fire - by PeabodySam - <LDD 4.3.11> 70784 - Lewa Master of Jungle - by PeabodySam - <LDD 4.3.11> 70785 - Pohatu Master of Stone - by PeabodySam - <LDD 4.3.11> 70786 - Gali Master of Water - by PeabodySam - <LDD 4.3.11> 70787 - Tahu Master of Fire - by PeabodySam - <LDD 4.3.11> 70788 - Kopaka Master of Ice - by PeabodySam - <LDD 4.3.10> 70789 - Onua Master of Earth - by PeabodySam - <LDD 4.3.11> 70790 - Lord of Skull Spiders - by ArmstrongYong - <LDD 4.3.8> 70791 - Skull Warrior - by PeabodySam - <LDD 4.3.10> 70792 - Skull Slicer - by PeabodySam - <LDD 4.3.10> 70793 - Skull Basher - by PeabodySam - <LDD 4.3.11> 70794 - Skull Scorpio - by PeabodySam - <LDD 4.3.10> 70795 - Mask Maker vs. Skull Grinder - by PeabodySam - <LDD 4.3.11> 71314 - Storm Beast - by PeabodySam - <LDD 4.3.11> 71315 - Quake Beast - by PeabodySam - <LDD 4.3.11> 1417+1418+1419+1420 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1431+1432+1433+1434 - n/a - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 4868+4869+4870 - Ice Vermin - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 4877+4878+4879 - Colony Drone - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 70778+70784 - Powered-Up Lewa - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70779+70785 - Powered-Up Pohatu - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70780+70786 - Powered-Up Gali - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70781+70789 - Powered-Up Onua - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70782+70788 - Powered-Up Kopaka - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70782+70788 - Special Kopaka - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70783+70787 - Special Tahu - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70783+70787 - Powered-Up Tahu - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70791+70792+70793 - Powered-Up Skull Warrior - by PeabodySam - <LDD 4.3.11> - Comment: Combines multiple sets 70794+70795 - Powered-Up Skull Grinder - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 8531+8532 - Fikou - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8531+8532+8534 - Akamai - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8531+8533 - Mukau - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8531+8542 - Dikapi - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8533+8535+8536 - Wairuha - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8550+8551 - Hapaka - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8550+8551+8552 - Bohrok Va Kaita - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8551+8555 - Mata Nui Fishing Bird - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8552+8554 - Pokawi - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8553+8554 - Infernavika - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8553+8554+8555 - Bohrok Va Kaita - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 8621+8622 - Lohrak - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 8621+8622+8623 - Ultimate Dume - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 8755+8756 - Sentrakh - by PeabodySam - <LDD 4.3.8> 8755+8761 - The Shadowed One - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 8892+8893 - Caravan Crawler - by PeabodySam - <LDD 4.3.9> - Comment: Combines multiple sets n/a - Ranama - by PeabodySam - <LDD 4.3.8> Boat 7244 - Speedboat - by JC75 - <LDD 4.3.8> 40227 - MSC Meraviglia - by KamalMYafi - <LDD 4.3.9> BrickHeadz 41585 - Batman - by vean - <LDD 4.3.10> 41586 - Batgirl - by vean - <LDD 4.3.10> 41587 - Robin - by vean - <LDD 4.3.10> 41588 - Joker - by vean - <LDD 4.3.10> 41589 - Captain America - by vean - <LDD 4.3.10> 41590 - Iron Man - by vean - <LDD 4.3.10> 41591 - Black Widow - by vean - <LDD 4.3.10> 41592 - The Hulk - by vean - <LDD 4.3.10> 41593 - Captain Jack Sparrow - by vean - <LDD 4.3.10> 41594 - Captain Armando Salazar - by vean - <LDD 4.3.10> 41595 - Belle - by vean - <LDD 4.3.10> 41596 - Beast - by vean - <LDD 4.3.10> 41612 - Steve & Creeper - by PicnicBasketSam - <LDD 4.3.11> 41622 - Peter Venkman & Slimer - by PicnicBasketSam - <LDD 4.3.11> 41623 - Ariel & Ursula - by PicnicBasketSam - <LDD 4.3.11> 41624 - Mickey - by PicnicBasketSam - <LDD 4.3.11> 41625 - Minnie - by PicnicBasketSam - <LDD 4.3.11> Build Together n/a - Pickup Truck - by BrickWild - <LDD 4> n/a - Golf Cart - by BrickWild - <LDD 4> n/a - Road Trip RV - by legolijntje - <LDD 4> n/a - Barry Elephante - by legolijntje - <LDD 4> Building Set with People 196 - Antique Car - by vean - <LDD 4.3.8> Cars 8200 - Radiator Springs Lightning McQueen - by Instructions archiver - <LDD 4.3.6> 8201 - Classic Mater - by Instructions archiver - <LDD 4.3.6> 8426 - Escape at Sea - by vean - <LDD 4.3.6> 8484 - Ultimate Build Lightning McQueen - by Stephan - <LDD 4.3.5> 8487 - Flo's V8 Cafe (Flo's V8 Café) - by vean - <LDD 4.3.6> 8638 - Spy Jet Escape - by pbat - <LDD 4.3.6> 8639 - Big Bentley Bust Out - by vean - <LDD 4.3.6> 8677 - Ultimate Build Mater - by Stephan - <LDD 4.3.5> 8679 - Tokyo International Circuit - by vean - <LDD 4.3.6> 9479 - Ivan Mater - by Instructions archiver - <LDD 4.3.6> 9484 - Red's Water Rescue - by EM4CZ - <LDD 4> 9486 - Oil Rig Escape - by vean - <LDD 4.3.6> 30120 - Guido - by vean - <LDD 4.3.6> 30121 - Grem - by vean - <LDD 4.3.6> Castle 383 - Knight's tournament - by marco9999 - <LDD 4> 383 - Knight's Tournament - by AndyC - <LDD 4> 677 - Knight's procession - by marco9999 - <LDD 4> 1286 - King Leo's Cart - by PeabodySam - <LDD 4.3.8> 1287 - Crossbows - by PeabodySam - <LDD 4.3.8> - Comment: "Richard's Arrowseat" 1288 - Fire Cart - by PeabodySam - <LDD 4.3.8> - Comment: "Bull's Fire Attacker" 1289 - Catapult - by PeabodySam - <LDD 4.3.8> - Comment: "Weezil's Stone Bomber" 1547 - Black Knight's Boat - by AndyC - <LDD 4> 1596 - Ghost with Wolfman - by AndyC - <LDD 4> 1624 - King's Archer - by AndyC - <LDD 4> 1695 - Treasure Cart - by AndyC - <LDD 4> 1877 - Crusader's Cart - by AndyC - <LDD 4> - Comment: Similar to 1680 1906 - Majisto's Tower - by chiklets - <LDD 4> 1974 - Smuggler's Hayride - by AndyC - <LDD 4> 2538 - Fright Knights Fire Cart - by PeabodySam - <LDD 4.3.8> 2539 - Fright Knights Flying Machine - by PeabodySam - <LDD 4.3.8> 2540 - Fright Knights Catapult Cart - by PeabodySam - <LDD 4.3.8> 2586 - Chess King [Promo] - by Aanchir - <LDD 4> 2872 - Witch and the Fireplace - by Captain Becker - <LDD 4> 2892 - Thunder Arrow Boat - by AndyC - <LDD 4> 3739 - Blacksmith Shop - by Lego Otaku - <LDD 3> 3739 - Blacksmith Shop - by Giovanne - <LDD 4> 3739 - Blacksmith Shop - by AndyC - <LDD 4> 4819 - Rebel Chariot - by Happy SDE - <LDD 4.3.8> 5614 - The Good Wizard - by Sjuip - <LDD 4> 5615 - The Knight - by Sjuip - <LDD 4.3.5> 5994 - Catapult - by Toa_Of_Justice - <LDD 4> 6009 - Black Knight - by KielDaMan - <LDD 4> 6012 - Siege Cart - by AndyC - <LDD 4> 6016 - Knight's Arsenal - by AndyC - <LDD 4> 6017 - King's Oarsmen - by AndyC - <LDD 4> 6020 - Magic Shop - by Instructions archiver - <LDD 4.3.5> 6023 - Maiden's Cart - by AndyC - <LDD 4> 6024 - Bandit Ambush - by Lego Otaku - <LDD 4.3.8> 6035 - Castle Guard - by AndyC - <LDD 4> 6036 - Skeleton Surprise - by Aanchir - <LDD 4> 6037 - Witch's Windship - by PeabodySam - <LDD 4.3.8> 6040 - Blacksmith Shop (A model) - by Calabar - <LDD 4> 6040 - Blacksmith Shop (B model) - by Calabar - <LDD 4> 6041 - Armor Shop - by AndyC - <LDD 4> 6043 - Dragon Defender - by PeabodySam - <LDD 4.3.6> 6046 - Hemlock Stronghold - by Lego Otaku - <LDD 4.3.8> 6048 - Majisto's Magical Workshop - by AndyC - <LDD 4> 6048 - Majisto's Magical Workshop - by Aanchir - <LDD 4> 6049 - Viking Voyager - by AndyC - <LDD 4> 6054 - Forestmen's Hideout - by Forneiro - <LDD 3> - [INCOMPLETE] - Comment: Minifigs missing 6057 - Sea Serpent - by Skipper - <LDD 4> 6060 - Knight's Challenge - by AndyC - <LDD 4> 6061 - Siege Tower - by Calabar - <LDD 4> 6062 - Battering Ram - by AndyC - <LDD 4> 6066 - Camouflaged Outpost - by Zeya - <LDD 4> 6066 - Camouflaged Outpost - by C3POwen - <LDD 4> 6067 - Guarded Inn - by Calabar - <LDD 4> - Comment: aka 10000 6067 - Guarded Inn - by AndyC - <LDD 4> - Comment: aka 10000 6071 - Forestmen's Crossing - by Zeya - <LDD 4> 6073 - Knight's Castle - by Calabar - <LDD 4> 6073 - Knight's Castle - by AndyC - <LDD 4> 6074 - Black Falcon's Fortress - by AndyC - <LDD 4> - Comment: aka 10039 6074 - Black Falcon's Fortress - by Calabar - <LDD 4> - Comment: aka 10039 6075 - Wolfpack Tower - by AndyC - <LDD 4> 6075 - Yellow Castle - by Calabar - <LDD 4> - Comment: aka 375 6076 - Dark Dragon's Den - by Elog - <LDD 4.3.8> 6077 - Forestmen's River Fortress - by AndyC - <LDD 4> 6078 - Royal Drawbridge - by AndyC - <LDD 4> 6079 - Dark Forest Fortress - by Lego Otaku - <LDD 4.3.8> 6080 - King's Castle - by AndyC - <LDD 4> 6081 - King's Mountain Fortress - by penguinz - <LDD 4.3.6> 6082 - Fire Breathing Fortress - by penguinz - <LDD 4.3.6> 6085 - Black Monarch's Castle - by Calabar - <LDD 4.3.5> 6086 - Black Knight's Castle - by AndyC - <LDD 4> 6086 - Black Knight's Castle - by penguinz - <LDD 4.3.6> 6087 - Witch's Magic Manor - by Instructions archiver - <LDD 4.3.5> 6090 - Royal King's Castle - by AndyC - <LDD 4> 6091 - King Leo's Castle - by penguinz - <LDD 4.3.8> - Comment: aka 6098 6096 - Bull's Attack - by Calabar - <LDD 4.3.5> 6097 - Night Lord's Castle - by professor flitwick - <LDD 3> 6918 - Blacksmith Attack - by ADHO15 - <LDD 4.3.5> 7009 - The Final Joust - by prateek - <LDD 3> 7009 - The Final Joust - by AndyC - <LDD 4> 7029 - Skeleton Ship Attack - by prateek - <LDD 3> 7036 - Dwarves' Mine - by marco9999 - <LDD 4.3.5> 7037 - Tower Raid - by marco9999 - <LDD 4.3.5> 7040 - Dwarves Mine Defender - by Sjuip - <LDD 4.3.8> 7041 - Troll Battle Wheel - by marco9999 - <LDD 4.3.5> 7048 - Troll Warship - by penguinz - <LDD 4.3.8> 7078 - King's Battle Chariot - by prateek - <LDD 3> 7079 - Drawbridge Defence - by prateek - <LDD 3> 7093 - Skeleton Tower - by SpiderSpaceman - <LDD 4> 7094 - King's Castle Siege - by marco9999 - <LDD 4.3.5> 7097 - Troll's Mountain Fortress - by AndyC - <LDD 4> 7187 - Escape from Dragon's Prison - by ADHO15 - <LDD 4> 7188 - King's Carriage Ambush - by ADHO15 - <LDD 4> 7188 - King's Carriage Ambush - by AndyC - <LDD 4> 7189 - Mill Village Raid - by ADHO15 - <LDD 4> 7946 - King's Castle - by Wynd - <LDD 3> 7946 - King's Castle - by penguinz - <LDD 4.3.8> 7946 - King's Castle - by AndyC - <LDD 4> 7947 - Prison Tower Rescue - by Captain Becker - <LDD 4> 7947 - Prison Tower Rescue - by AndyC - <LDD 4> 7947 - Prison Tower Rescue - by Zeya - <LDD 4> 7948 - Outpost Attack - by C3POwen - <LDD 4> 7949 - Prison Carriage Rescue - by prateek - <LDD 3> 7950 - Knight's Showdown - by Yooha - <LDD 4> 7953 - Jester - by Sjuip - <LDD 4.3.5> 8777 - Vladek Encounter - by PeabodySam - <LDD 4.3.8> 8778 - Border Ambush - by professor flitwick - <LDD 3> 8779 - The Grand Tournament - by marco9999 - <LDD 4.3.5> 8780 - Citadel of Orlan - by penguinz - <LDD 4.3.8> 8781 - Castle of Morica - by penguinz - <LDD 4.3.8> 8799 - Knights' Castle Wall - by penguinz - <LDD 4.3.8> 8800 - Vladek's Siege Engine - by marco9999 - <LDD 4.3.5> 8813 - Battle at the Pass - by PeabodySam - <LDD 4.3.8> 8821 - Rogue Knight Battleship - by PeabodySam - <LDD 4.3.8> 8822 - Gargoyle Bridge - by PeabodySam - <LDD 4.3.8> 8823 - Mistlands Tower - by marco9999 - <LDD 4.3.5> 8873 - Fireball Catapult - by PeabodySam - <LDD 4.3.8> 8874 - Battle Wagon - by PeabodySam - <LDD 4.3.8> 8875 - King's Siege Tower - by PeabodySam - <LDD 4.3.8> 8876 - Scorpion Prison Cave - by penguinz - <LDD 4.3.8> 8877 - Vladek's Dark Fortress - by penguinz - <LDD 4.3.8> 10000 - Guarded Inn - by Lego Otaku - <LDD 4> - Comment: aka 6067 10176 - Royal King's Castle - by penguinz - <LDD 4.3.8> 10193 - Medieval Market Village - by Johnnhiszippy3 - <LDD 3> 10193 - Medieval Market Village - by prateek - <LDD 4> 10223 - Kingdom's Joust - by AndyC - <LDD 4> 10223 - Kingdom's Joust - by ADHO15 - <LDD 4> 30061 - Attack Wagon - by ILikePi - <LDD 3> 30062 - Target Practice - by ILikePi - <LDD 3> 65767 - Attack from the Sea - by SpiderSpaceman - <LDD 4> - Comment: Includes sets 8801 + 8802 70400 - Forest Ambush - by CM4S - <LDD 4.3.6> 70401 - Gold Getaway - by vean - <LDD 4.3.6> 70402 - The Gatehouse Raid - by CM4S - <LDD 4.3.6> 70403 - Dragon Mountain - by penguinz - <LDD 4.3.6> 70404 - King's Castle - by vean - <LDD 4.3.6> 1286+1287 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1286+1287+1288+1289 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1286+1288 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 1286+1289 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets City 3365 - Space Moon Buggy - by BrickWild - <LDD 4> 3365 - Space Moon Buggy - by Giovanne - <LDD 4> 3366 - Satellite Launch Pad - by BrickWild - <LDD 4> - [INCOMPLETE] - Comment: Van not included 3366 - Satellite Launch Pad - by Giovanne - <LDD 4> 3367 - Space Shuttle - by zinfinion - <LDD 4.3.5> 3368 - Rocket Launch Center - by Tore M - <LDD 4> 30016 - Satellite - by Toa_Of_Justice - <LDD 4> 30224 - Lawn Mower - by CM4S - <LDD 4.3.6> 30229 - Repair Lift - by Sjuip - <LDD 4.3.8> 30310 - Arctic Scout [Promo] - by vean - <LDD 4.3.8> 30349 - Sports Car polybag - by KamalMYafi - <LDD 4.3.9> 30364 - Popcorn Cart polybag - by vean - <LDD 4.3.11> 40302 - Become My City Hero polybag - by vean - <LDD 4.3.10> 60023 - City Starter Set - by Sjuip - <LDD 4.3.9> 60025 - Grand Prix Truck - by Sjuip - <LDD 4.3.6> 60032 - Arctic Snowmobile - by penguinz - <LDD 4.3.8> 60033 - Arctic Ice Crawler - by penguinz - <LDD 4.3.8> 60034 - Arctic Helicrane - by penguinz - <LDD 4.3.8> 60035 - Arctic Outpost - by penguinz - <LDD 4.3.8> 60036 - Arctic Base Camp - by penguinz - <LDD 4.3.8> 60053 - Race Car - by vean - <LDD 4.3.8> 60055 - Monster Truck - by Stephan - <LDD 4.3.6> 60056 - Tow Truck - by Stephan - <LDD 4.3.6> 60057 - Camper Van - by vean - <LDD 4.3.6> 60058 - SUV with Watercraft - by vean - <LDD 4.3.6> 60059 - Logging Truck - by Stephan - <LDD 4.3.9> 60060 - Auto Transporter - by vean - <LDD 4.3.8> 60062 - Arctic Ice Breaker - by penguinz - <LDD 4.3.8> 60064 - Arctic Supply Plane - by penguinz - <LDD 4.3.8> 60081 - Pickup Tow Truck - by Stephan - <LDD 4.3.8> 60082 - Dune Buggy Trailer - by Stephan - <LDD 4.3.8> 60086 - City Starter Set - by Stephan - <LDD 4.3.9> 60097 - City Square - by Stephan - <LDD 4.3.9> City / Airport 2928 - Airline Promo Set [Promo] - by AndyC - <LDD 4> 3181 - Passenger Plane - by marco9999 - <LDD 3> 3181 - Passenger Plane - by AndyC - <LDD 4> 3182 - Airport - by winsrp - <LDD 4> 3182 - Airport - by AndyC - <LDD 4> 3222 - Helicopter and Limousine - by KielDaMan - <LDD 4> 3367 - Space Shuttle - by JC75 - <LDD 4.3.8> 4442 - Glider - by PsyKater - <LDD 4.3.5> 7643 - Air Show Plane - by KielDaMan - <LDD 4> 7688 - Sports Plane - by KielDaMan - <LDD 4> 7696 - Commuter Jet - by AndyC - <LDD 4> 7696 - Commuter Jet - by prateek - <LDD 4> 7891 - Firetruck - by Jey_Bee - <LDD 3> 7893 - Passenger Plane - by Sjuip - <LDD 4.3.8> 7894 - Airport - by AndyC - <LDD 4> 7901 - Aircraft Maintenance - by Sjuip - <LDD 4.3.5> 30012 - Microlight - by Toa_Of_Justice - <LDD 4> 30012 - Microlight - by AndyC - <LDD 4> 30315 - Space Utility Vehicle polybag - by Stephan - <LDD 4.3.9> 60019 - Stunt Plane - by Sjuip - <LDD 4.3.8> 60021 - Cargo Heliplane - by Stephan - <LDD 4.3.6> 60022 - Cargo Terminal - by Stephan - <LDD 4.3.6> 60077 - Space Starter Set - by Stephan - <LDD 4.3.8> 60078 - Utility Shuttle - by Stephan - <LDD 4.3.9> 60079 - Training Jet Transporter - by Stephan - <LDD 4.3.9> 60080 - Spaceport - by Stephan - <LDD 4.3.9> 60100 - Airport Starter Set - by PicnicBasketSam - <LDD 4.3.9> 60101 - Airport Cargo Plane - by PicnicBasketSam - <LDD 4.3.9> 60102 - Airport VIP Service - by PicnicBasketSam - <LDD 4.3.9> 60103 - Airport Air Show - by PicnicBasketSam - <LDD 4.3.9> 60104 - Airport Passenger Terminal - by PicnicBasketSam - <LDD 4.3.9> 60144 - Race Plane - by vean - <LDD 4.3.10> 60177 - Airshow Jet - by vean - <LDD 4.3.10> City / Arctic 60193 - Arctic Air Transport - by zweifuss - <LDD 4.3.11> 60196 - Arctic Supply Plane - by zweifuss - <LDD 4.3.11> City / Building 8403 - City House - by BrickWild - <LDD 3> 8403 - City House - by tikicult - <LDD 4> City / Cargo 7733 - Cargo Truck - by prateek - <LDD 3> 7734 - Cargo Plane - by AndyC - <LDD 4> 7992 - Container Stacker - by Sjuip - <LDD 4.3.5> 60020 - Cargo Truck - by Stephan - <LDD 4.3.6> City / Coast Guard 4210 - Coast Guard Platform - by Sjuip - <LDD 4.3.9> 4898 - Coast Guard Boat - by AndyC - <LDD 4> 4937 - Life Guard - Quick Magic Box Promotional - by Sjuip - <LDD 4.3.6> 5621 - Coast Guard Kayak - by KielDaMan - <LDD 4> 5621 - Coast Guard Kayak - by AndyC - <LDD 4> 5626 - Coast Guard Bike [Promo] - by KielDaMan - <LDD 4> 5626 - Coast Guard Bike [Promo] - by AndyC - <LDD 4> 7726 - Coast Guard Truck with Speedboat - by KielDaMan - <LDD 4> 7736 - Coast Guard Quad Bike - by KielDaMan - <LDD 4> 7737 - Coast Guard 4WD and Jet Scooter - by KielDaMan - <LDD 4> 7738 - Coast Guard Helicopter and Life Raft - by AndyC - <LDD 4> 7738 - Coast Guard Helicopter and Life Raft - by KielDaMan - <LDD 4> 7739 - Coast Guard Patrol Boat and Tower - by AndyC - <LDD 4> 30225 - Seaplane - by Sjuip - <LDD 4.3.8> 60011 - Surfer Rescue - by Sjuip - <LDD 4.3.6> 60012 - Coast Guard 4 x 4 - by Sjuip - <LDD 4.3.8> 60013 - Coast Guard Helicopter - by Sjuip - <LDD 4.3.8> 60014 - Coast Guard Patrol - by Sjuip - <LDD 4.3.9> 60015 - Coast Guard Plane - by Sjuip - <LDD 4.3.8> City / Construction 4200 - Mining 4 x 4 - by Sjuip - <LDD 4.3.5> 4201 - Loader and Tipper - by Sjuip - <LDD 4.3.5> 4202 - Mining Truck - by Sjuip - <LDD 4.3.5> 4203 - Excavator Transporter - by Sjuip - <LDD 4.3.5> 4204 - The Mine - by Sjuip - <LDD 4.3.5> 4434 - Tipper Truck - by Sjuip - <LDD 4.3.5> 5610 - Builder - by KielDaMan - <LDD 4> 5627 - Mini Bulldozer - by KielDaMan - <LDD 4> 5642 - Tipper Truck - by KielDaMan - <LDD 4> 7243 - Construction Site - by Sjuip - <LDD 4.3.5> 7246 - Mini Digger - by ok13 - <LDD 4> 7248 - Digger - by Sjuip - <LDD 4.3.5> 7249 - XXL Mobile Crane - by marco9999 - <LDD 4.3.5> 7344 - Dump Truck - by Sjuip - <LDD 4> 7630 - Front-End Loader - by KielDaMan - <LDD 4> 7631 - Dump Truck - by KielDaMan - <LDD 4> 7632 - Crawler Crane - by BasOne - <LDD 4> 7633 - Construction Site - by Aanchir - <LDD 4> 7685 - Dozer - by BasOne - <LDD 4> 7685 - Dozer - by Tore M - <LDD 4.3.5> 7746 - Single-Drum Roller - by Aanchir - <LDD 4> 7900 - Heavy Loader - by marco9999 - <LDD 4.3.6> 7905 - Building Crane - by AndyC - <LDD 4> 7990 - Cement Mixer - by pacc - <LDD 4> 7998 - Heavy Hauler - by AndyC - <LDD 4> 7998 - Heavy Hauler - by JunkstyleGio - <LDD 3> 30003 - Road Roller - by AndyC - <LDD 4> 30151 - Mining Dozer - by Sjuip - <LDD 4.3.5> 30152 - Mining Quad - by Sjuip - <LDD 4.3.5> 30312 - Demolition Driller polybag - by Stephan - <LDD 4.3.8> 30348 - Mini Dumper polybag - by KamalMYafi - <LDD 4.3.9> 30353 - Tractor polybag - by vean - <LDD 4.3.10> 30357 - Road Worker polybag - by vean - <LDD 4.3.10> 60018 - Cement Mixer - by PsyKater - <LDD 4.3.5> 60072 - Demolition Starter Set - by mzoli - <LDD 4.3.8> 60072 - Demolition Starter Set - by Stephan - <LDD 4.3.9> 60073 - Service Truck - by mzoli - <LDD 4.3.8> 60073 - Service Truck - by Stephan - <LDD 4.3.9> 60074 - Bulldozer - by Stephan - <LDD 4.3.9> 60075 - Excavator and Truck - by Stephan - <LDD 4.3.9> 60076 - Demolition Site - by Stephan - <LDD 4.3.9> 60152 - Sweeper & Excavator - by vean - <LDD 4.3.10> 60184 - Mining Team - by vean - <LDD 4.3.11> 60185 - Mining Power Splitter - by vean - <LDD 4.3.11> 60252 - Construction Bulldozer - by vean - <LDD 4.3.11> City / Deep Sea Explorers 60090 - Deep Sea Scuba Scooter - by Stephan - <LDD 4.3.8> 60091 - Deep Sea Starter Set - by Stephan - <LDD 4.3.8> 60092 - Deep Sea Submarine - by Stephan - <LDD 4.3.9> 60093 - Deep Sea Helicopter - by Stephan - <LDD 4.3.9> 60095 - Deep Sea Exploration Vessel - by vean - <LDD 4.3.8> 60095 - Deep Sea Exploration Vessel - by Stephan - <LDD 4.3.9> 60096 - Deep Sea Operation Base - by Stephan - <LDD 4.3.9> 60096 - Deep Sea Operation Base - by vean - <LDD 4.3.9> City / Farm 4899 - Tractor [Promo] - by AndyC - <LDD 4> 4899 - Tractor [Promo] - by KielDaMan - <LDD 4> 7566 - Farmer - by KielDaMan - <LDD 4> 7634 - Tractor - by prateek - <LDD 3> 7634 - Tractor - by JunkstyleGio - <LDD 3> 7635 - 4WD with Horse Trailer - by JunkstyleGio - <LDD 3> 7636 - Combine Harvester - by Anders Nolberger - <LDD 4> 7637 - Farm - by JunkstyleGio - <LDD 3> 7684 - Pig Farm & Tractor - by JunkstyleGio - <LDD 3> 60181 - Forest Tractor - by Migui94 - <LDD 4.3.10> City / Fire 4208 - 4 x 4 Fire Truck - by Tontus - <LDD 4.3.11> 4208 - 4x4 Fire Truck - by Sjuip - <LDD 4.3.5> 4209 - Fire Plane - by Costy - <LDD 4.3.6> 4427 - Fire ATV - by Tontus - <LDD 4> 4430 - Mobile Fire Command Center - by Happy SDE - <LDD 4.3.8> 4430 - Fire Transporter - by zinfinion - <LDD 4> 4900 - Fire Helicopter - by Commander_Rob - <LDD 4> 4938 - Fire 4 x 4 - by Sjuip - <LDD 4.3.5> 4992 - Fire Boat - by PsyKater - <LDD 4.3.5> 5532 - Fire Car - by Sjuip - <LDD 4.3.6> 5613 - Firefighter - by Costy - <LDD 4> 7206 - Fire Helicopter - by Sjuip - <LDD 4.3.6> 7207 - Fire Boat - by BrickWild - <LDD 3> 7208 - Fire Station - by Costy - <LDD 4> 7208 - Fire Station - by SpeedySC1978 - <LDD 4.3.11> 7213 - Off-Road Truck & Fireboat - by KielDaMan - <LDD 4> 7238 - Fire Helicopter - by Sjuip - <LDD 4.3.8> 7239 - Fire Truck - by roamingstudio - <LDD 4> 7240 - Fire Station - by professor flitwick - <LDD 3> 7241 - Fire Car - by KielDaMan - <LDD 4> 7266 - Fireman - by Sjuip - <LDD 4.3.8> 7906 - Fireboat - by Jey_Bee - <LDD 3> 7942 - Off Road Fire Rescue - by prateek - <LDD 4> 7944 - Fire Hovercraft - by Sjuip - <LDD 4.3.5> 7945 - Fire Station - by BrickWild - <LDD 3> 20002 - 4x4 Fire Truck - by Aanchir - <LDD 4> 20002 - 4x4 Fire Truck - by AndyC - <LDD 4> 30001 - Fireman's Car - by C3POwen - <LDD 4> 30001 - Fireman's Car - by AndyC - <LDD 4> 30010 - Fire Chief - by AndyC - <LDD 4> 30019 - Fire Helicopter - by Sjuip - <LDD 4.3.8> 30220 - Fire Speedboat - by Sjuip - <LDD 4.3.9> 30221 - Fire Car - by Sjuip - <LDD 4.3.9> 30347 - Fire Car polybag - by legoboyvdlp - <LDD 4.3.9> 30347 - Fire Car polybag - by KamalMYafi - <LDD 4.3.9> 30368 - Fire Rescue Water Scooter polybag - by vean - <LDD 4.3.11> 60000 - Fire Motorcycle - by Sjuip - <LDD 4.3.8> 60001 - Fire Rescue - by Sjuip - <LDD 4.3.9> 60002 - Fire Truck - by Sjuip - <LDD 4.3.9> 60003 - Fire Emergency - by Sjuip - <LDD 4.3.8> 60004 - Fire Station - by Sjuip - <LDD 4.3.8> 60005 - Fire Boat - by Sjuip - <LDD 4.3.8> 60010 - Fire Helicopter - by Amte - <LDD 4.3.6> 60010 - Fire Helicopter - by Sjuip - <LDD 4.3.8> 60061 - Airport Fire Truck - by Stephan - <LDD 4.3.8> 60088 - Fire Starter Set - by Stephan - <LDD 4.3.8> 60105 - Fire ATV - by Sjuip - <LDD 4.3.9> 60106 - Fire Starter Set - by Sjuip - <LDD 4.3.9> 60107 - Fire Ladder Truck - by Sjuip - <LDD 4.3.11> 60108 - Fire Response Unit - by Sjuip - <LDD 4.3.9> 60109 - Fire Boat - by Sjuip - <LDD 4.3.11> 60110 - Fire Station - by Sjuip - <LDD 4.3.11> 60111 - Fire Utility Truck - by LegoPegasister2015 - <LDD 4.3.8> 60112 - Fire Engine - by LegoPegasister2015 - <LDD 4.3.8> 853378 - City Firemen Minifigure Pack - by Sjuip - <LDD 4.3.8> City / Food & Drink 8398 - BBQ Stand - by KielDaMan - <LDD 4> 30356 - Hot Dog Stand polybag - by vean - <LDD 4.3.11> City / Gas Station 3180 - Tank Truck - by Jay Sathe - <LDD 3> 3180 - Tank Truck - by Navy Trooper Fenson - <LDD 4.3.10> 7993 - Service Station - by KielDaMan - <LDD 4> 60132 - Service Station (A model) - by Sjuip - <LDD 4.3.9> 60132 - Service Station (A model) - by PicnicBasketSam - <LDD 4.3.9> 60132 - Service Station (B model) - by PicnicBasketSam - <LDD 4.3.9> 60132 - Service Station (B model) - by Sjuip - <LDD 4.3.9> 60257 - Service Station - by vean - <LDD 4.3.11> City / Harbor 2230 - Airline Promo Set - by Costy - <LDD 4> 3178 - Seaplane - by Happy SDE - <LDD 4.3.8> 3178 - Seaplane - by marco9999 - <LDD 4> 3178 - Seaplane - by AndyC - <LDD 4> 4641 - Speed Boat - by Giovanne - <LDD 4> 4642 - Fishing Boat - by Tontus - <LDD 4> 4643 - Power Boat Transporter - by zinfinion - <LDD 4> 4643 - Power Boat Transporter - by JC75 - <LDD 4.3.8> 4644 - Marina - by Sjuip - <LDD 4.3.6> 4645 - Harbour - by Sjuip - <LDD 4.3.9> 7994 - LEGO City Harbor - by Sjuip - <LDD 4.3.8> 30015 - Jet Ski - by Toa_Of_Justice - <LDD 4> 30363 - Jet-Ski polybag - by vean - <LDD 4.3.11> 60085 - 4x4 with Powerboat - by Stephan - <LDD 4.3.8> 60085 - 4x4 with Powerboat - by JC75 - <LDD 4.3.8> 60114 - Race Boat - by KamalMYafi - <LDD 4.3.9> 60119 - Ferry - by LegoPegasister2015 - <LDD 4.3.8> 60147 - Fishing Boat - by vean - <LDD 4.3.10> 60254 - Race Boat Transporter - by vean - <LDD 4.3.11> City / Hospital 2064 - Air Ambulance - by AndyC - <LDD 4> 2064 - Air Ambulance - by KielDaMan - <LDD 4> 4429 - Helicopter Rescue - by PsyKater - <LDD 4.3.5> 4431 - Ambulance - by Tontus - <LDD 4> 4936 - Doc & Patient - by PsyKater - <LDD 4.3.5> 7267 - Paramedic - by PsyKater - <LDD 4.3.5> 7890 - Ambulance - by Jey_Bee - <LDD 3> 7892 - Hospital - by EM4CZ - <LDD 4.3.5> 7902 - Doctor's Car - by Sjuip - <LDD 4.3.5> 7903 - Rescue Helicopter - by Sjuip - <LDD 4.3.5> 30000 - Medic's Car - by AndyC - <LDD 4> 60116 - Ambulance Plane - by KamalMYafi - <LDD 4.3.9> 60179 - Ambulance Helicopter - by vean - <LDD 4.3.10> City / Off-Road 4433 - Dirt Bike Transporter - by Tontus - <LDD 4> 60027 - Monster Truck Transporter - by Sjuip - <LDD 4.3.6> 60148 - ATV Race Team - by vean - <LDD 4.3.10> City / Police 3648 - Police Chase - by AndyC - <LDD 4> 3658 - Police Helicopter - by AndyC - <LDD 4> 3661 - Bank and Money Transfer - by prateek - <LDD 4> 4205 - Off Road Command Center - by Happy SDE - <LDD 4.3.8> 4205 - Off-Road Command Centre - by zinfinion - <LDD 4> 4436 - Patrol Car - by PsyKater - <LDD 4.3.5> 4437 - Police Pursuit - by Costy - <LDD 4> 4438 - Robbers' Hideout - by Sjuip - <LDD 4.3.5> 4439 - Heavy-Duty Helicopter - by Happy SDE - <LDD 4.3.8> 4439 - Heavy-Duty Helicopter - by zinfinion - <LDD 4> 4440 - Forest Rangers Station - by EM4CZ - <LDD 4> 4441 - Police Dog Van - by Tontus - <LDD 4.3.5> 4473 - Police Helicopter - by Sjuip - <LDD 4.3.5> 4897 - Police Trike - by AndyC - <LDD 4> 4912 - Police Jet Ski - by AndyC - <LDD 4> 4934 - Police Swamp Boat - by luwenzheng - <LDD 4.3.5> 4991 - Police Helicopter - by Sjuip - <LDD 4.3.5> 5531 - Police Motorcycle - by Sjuip - <LDD 4.3.6> 5612 - Police Officer - by KielDaMan - <LDD 4> 5625 - Police 4X4 [Promo] - by KielDaMan - <LDD 4> 7235 - Police Motorcycle - by KielDaMan - <LDD 4> 7236 - Police Car - by KielDaMan - <LDD 4> 7237 - Police Station - by Sjuip - <LDD 4.3.5> 7245 - Prisoner Transport - by professor flitwick - <LDD 3> 7279 - Police Minifigure Collection - by Captain Becker - <LDD 4> 7285 - Police Dog Unit - by C3POwen - <LDD 4> 7286 - Prison Transport - by Giovanne - <LDD 4> 7287 - Police Boat - by Tontus - <LDD 4> 7288 - Mobile Police Unit - by AndyC - <LDD 4> 7498 - Police Station - by AndyC - <LDD 4> 7723 - Police Seaplane - by luwenzheng - <LDD 4.3.5> 7741 - Police Helicopter - by winsrp - <LDD 4> 7743 - Police Command Center - by KielDaMan - <LDD 4> 7744 - Police HQ - by Jay Sathe - <LDD 3> 7899 - Police Boat - by Sjuip - <LDD 4.3.5> 30002 - Police Boat - by AndyC - <LDD 4> 30011 - Police Boat - by Toa_Of_Justice - <LDD 4> 30011 - Police Boat - by AndyC - <LDD 4> 30013 - Police Buggy - by Toa_Of_Justice - <LDD 4> 30013 - Police Buggy - by AndyC - <LDD 4> 30014 - Police Helicopter - by Captain Becker - <LDD 4> 30014 - Police Helicopter - by Toa_Of_Justice - <LDD 4> 30017 - Police Boat - by Sjuip - <LDD 4.3.5> 30018 - Police Plane - by Sjuip - <LDD 4.3.5> 30222 - Police Helicopter polybag - by Happy SDE - <LDD 4.3.8> 30226 - Police Helicopter - by Sjuip - <LDD 4.3.8> 30227 - {Police Chase} - by Sjuip - <LDD 4.3.8> 30228 - Police ATV - by Sjuip - <LDD 4.3.8> 30311 - Swamp Police Helicopter Polybag - by Stephan - <LDD 4.3.8> 30346 - Prison Island Helicopter polybag - by lipanz - <LDD 4.3.9> 30351 - Police Helicopter polybag - by vean - <LDD 4.3.10> 30352 - Police Car polybag - by vean - <LDD 4.3.10> 30359 - Police Water Plane polybag - by vean - <LDD 4.3.11> 30362 - Sky Police Jetpack polybag - by vean - <LDD 4.3.11> 30366 - Police Car polybag - by vean - <LDD 4.3.11> 30367 - Police Helicopter polybag - by vean - <LDD 4.3.11> 40110 - City Coin Bank - by Stephan - <LDD 4.3.8> 60006 - Police ATV - by Sjuip - <LDD 4.3.8> 60007 - High Speed Chase - by Sjuip - <LDD 4.3.8> 60008 - Museum Break-in - by Sjuip - <LDD 4.3.8> 60008 - Museum Break-in - by Instructions archiver - <LDD 4.3.6> 60009 - Helicopter Arrest - by PsyKater - <LDD 4.3.5> 60041 - Crook Pursuit - by Stephan - <LDD 4.3.6> 60042 - High Speed Police Chase - by Stephan - <LDD 4.3.8> 60043 - Prisoner Transporter - by Sjuip - <LDD 4.3.8> 60044 - Mobile Police Unit - by Sjuip - <LDD 4.3.8> 60045 - Police Patrol - by Sjuip - <LDD 4.3.8> 60046 - Helicopter Surveillance - by Sjuip - <LDD 4.3.8> 60047 - Police Station - by Sjuip - <LDD 4.3.8> 60048 - Robbers' Hideout - by Sjuip - <LDD 4.3.8> 60049 - Helicopter Transporter - by Sjuip - <LDD 4.3.8> 60065 - ATV Patrol - by Sjuip - <LDD 4.3.8> 60065 - ATV Patrol - by Stephan - <LDD 4.3.8> 60066 - Swamp Police Starter Set - by Stephan - <LDD 4.3.9> 60067 - Helicopter Pursuit - by Stephan - <LDD 4.3.9> 60068 - Crooks' Hideout - by Stephan - <LDD 4.3.9> 60069 - Swamp Police Station - by Stephan - <LDD 4.3.9> 60070 - Water Plane Chase - by Stephan - <LDD 4.3.9> 60070 - Water Plane Chase - by vean - <LDD 4.3.8> 60071 - Hovercraft Arrest - by Stephan - <LDD 4.3.9> 60126 - Tire Escape - by Sjuip - <LDD 4.3.9> 60127 - Prison Island Starter Set - by Sjuip - <LDD 4.3.9> 60128 - Police Pursuit - by LegoPegasister2015 - <LDD 4.3.8> 60129 - Police Patrol Boat - by LegoPegasister2015 - <LDD 4.3.8> 60130 - Prison Island - by LegoPegasister2015 - <LDD 4.3.8> 60131 - Crooks Island - by LegoPegasister2015 - <LDD 4.3.8> 60135 - ATV Arrest - by vean - <LDD 4.3.10> 60136 - Police Starter Set - by vean - <LDD 4.3.10> 60137 - Tow Truck Trouble - by vean - <LDD 4.3.10> 60138 - High-speed Chase - by vean - <LDD 4.3.10> 60139 - Mobile Command Center - by vean - <LDD 4.3.10> 60140 - Bulldozer Break-in - by vean - <LDD 4.3.10> 60141 - Police Station - by vean - <LDD 4.3.10> 60142 - Money Transporter - by koalayummies - <LDD 4.3.10> 60143 - Auto Transport Heist - by vean - <LDD 4.3.10> 60170 - Off-Road Chase - by vean - <LDD 4.3.11> 60171 - Mountain Fugitives - by vean - <LDD 4.3.11> 60172 - Dirt Road Pursuit - by vean - <LDD 4.3.11> 60173 - Mountain Arrest - by vean - <LDD 4.3.11> 60174 - Mountain Police Headquarters - by vean - <LDD 4.3.11> 60175 - Mountain River Heist - by vean - <LDD 4.3.11> 60176 - Wild River Escape - by vean - <LDD 4.3.11> 60239 - Police Patrol Car - by vean - <LDD 4.3.11> City / Post Office 7731 - Mail Van - by KielDaMan - <LDD 4> 7732 - Air Mail - by KielDaMan - <LDD 4> 60250 - Mail Plane - by vean - <LDD 4.3.11> City / Race 30314 - Go-Kart Racer polybag - by vean - <LDD 4.3.8> 30358 - Dragster polybag - by vean - <LDD 4.3.11> 60084 - Racing Bike Transporter - by Stephan - <LDD 4.3.9> 60115 - 4 x 4 Off Roader - by KamalMYafi - <LDD 4.3.9> 60145 - Buggy - by vean - <LDD 4.3.10> 60146 - Stunt Truck - by vean - <LDD 4.3.10> 60151 - Dragster Transporter - by vean - <LDD 4.3.10> 60178 - Speed Record Car - by vean - <LDD 4.3.11> 60180 - Monster Truck - by Migui94 - <LDD 4.3.10> 60251 - Monster Truck - by vean - <LDD 4.3.11> 60256 - Racing Cars - by vean - <LDD 4.3.11> 60258 - Tuning Workshop - by vean - <LDD 4.3.11> 60113 Year - Rally Car - by KamalMYafi - <LDD 4.3.9> City / Recreation 7639 - Camper - by Happy SDE - <LDD 4.3.8> 30369 - Beach Buggy polybag - by vean - <LDD 4.3.11> 60117 - Van & Caravan - by KamalMYafi - <LDD 4.3.9> 60134 - Fun in the park - City People Pack - by PicnicBasketSam - <LDD 4.3.9> 60149 - 4X4 with Catamaran - by vean - <LDD 4.3.10> 60182 - Pickup & Caravan - by Migui94 - <LDD 4.3.10> 60240 - Kayak Adventure - by marv - <LDD 4.3.11> 60267 - Safari Off-roader - by vean - <LDD 4.3.11> City / Space Port 60224 - Satellite Service Mission - by Four_Lokos_Basilisk - <LDD 4.3.11> City / Traffic 3177 - Small Car - by AndyC - <LDD 4> 3179 - Repair Truck - by prateek - <LDD 3> 3221 - LEGO Truck - by JediCharles - <LDD 4.3.8> 3221 - LEGO Truck - by JunkstyleGio - <LDD 3> 4206 - Recycling Truck - by SpeedySC1978 - <LDD 4.3.11> 4206 - Recycling Truck - by zinfinion - <LDD 4> 4207 - City Garage - by Sjuip - <LDD 4.3.6> 4432 - Garbage Truck - by Costy - <LDD 4> 4435 - Car and Camper - by Costy - <LDD n/a> 4933 - Street Sweeper - by Sjuip - <LDD 4.3.5> 5611 - Public Works - by Sjuip - <LDD 4.3.5> 5620 - Street Cleaner - by KielDaMan - <LDD 4> 7242 - Street Sweeper - by Sjuip - <LDD 4.3.5> 7567 - Traveller - by KielDaMan - <LDD 4> 7638 - Tow Truck - by AndyC - <LDD 4> 7639 - Camper - by JunkstyleGio - <LDD 3> 7641 - City Corner - by JunkstyleGio - <LDD 4.3.6> - Comment: aka 60031 7642 - Garage - by Costy - <LDD 4> 7642 - Garage - by BrickWild - <LDD 4> 7686 - Helicopter Transport - by prateek - <LDD 3> 7747 - Wind Turbine Transport - by JunkstyleGio - <LDD 3> 7747 - Wind Turbine Transport - by prateek - <LDD 3> 7848 - Toys 'R Us Truck - by KielDaMan - <LDD 4> 7991 - Recycle Truck - by adello25 - <LDD 4> 8402 - Sports Car - by KielDaMan - <LDD 4> 8404 - Public Transport - by KielDaMan - <LDD 4> 30150 - Race Car - by Sjuip - <LDD 4.3.5> 30313 - City Refuse Vehicle - by Stephan - <LDD 4.3.8> 30354 - Hot Rod polybag - by vean - <LDD 4.3.10> 60016 - Tanker Truck - by PsyKater - <LDD 4.3.5> 60017 - Flatbed Truck - by PsyKater - <LDD 4.3.5> 60026 - Town Square - by Stephan - <LDD 4.3.6> 60031 - City Corner - by Sjuip - <LDD 4.3.6> - Comment: Re-Release of 7641 60054 - Light Repair Truck - by Stephan - <LDD 4.3.6> 60083 - Snowplow Truck - by Stephan - <LDD 4.3.8> 60118 - Garbage Truck - by KamalMYafi - <LDD 4.3.9> 60150 - Pizza Van - by koalayummies - <LDD 4.3.10> 60154 - Bus Station - by vean - <LDD 4.3.10> 60183 - Heavy Cargo Transport - by Migui94 - <LDD 4.3.10> 60249 - Street Sweeper - by vean - <LDD 4.3.11> 60253 - Ice-cream Truck - by vean - <LDD 4.3.11> City / Volcano Explorers 30350 - Volcano Jackhammer - by KamalMYafi - <LDD 4.3.9> 60120 - Volcano Starter Set - by PicnicBasketSam - <LDD 4.3.9> 60121 - Volcano Exploration Truck - by PicnicBasketSam - <LDD 4.3.9> 60122 - Volcano Crawler - by PicnicBasketSam - <LDD 4.3.9> 60123 - Volcano Supply Helicopter - by PicnicBasketSam - <LDD 4.3.9> 60124 - Volcano Exploration Base - by PicnicBasketSam - <LDD 4.3.9> 60125 - Volcano Heavy-lift Helicopter - by PicnicBasketSam - <LDD 4.3.9> Classic 315 - European Taxie - by Calabar - <LDD 4> 316 - Farm Tractor - by marco9999 - <LDD 4> 320 - Two Engine Plane - by marco9999 - <LDD 4> 325 - Shell Service Station - by EM4CZ - <LDD 4> 328 - Biplane - by Stephan - <LDD 4> 329 - Antique Car - by Stephan - <LDD 4> 330 - Jeep - by Stephan - <LDD 4> 340 - Signal Box - by Stephan - <LDD 4.3.8> 341 - Warehouse - by Stephan - <LDD 4> 342 - Station - by Stephan - <LDD 4.3.8> 10692 - Creative Bricks (A model) - by Gnac - <LDD 4.3.9> 10692 - Creative Bricks (B model) - by Gnac - <LDD 4.3.8> 10692 - Creative Bricks (C model) - by Gnac - <LDD 4.3.8> 10692 - Creative Bricks (D model) - by Gnac - <LDD 4.3.8> 10692 - Creative Bricks (E model) - by Gnac - <LDD 4.3.8> 10692 - Creative Bricks (F model) - by Gnac - <LDD 4.3.8> 10692 - Creative Bricks (G model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (A model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (B model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (C model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (D model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (E model) - by Gnac - <LDD 4,3,9> 10693 - Creative Supplement (F model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (G model) - by Gnac - <LDD 4.3.8> 10693 - Creative Supplement (H model) - by Gnac - <LDD 4.3.8> 10694 - Creative Supplement Bright (A model) - by Gnac - <LDD 4.3.8> 10694 - Creative Supplement Bright (B model) - by Gnac - <LDD 4.3.8> 10694 - Creative Supplement Bright (C model) - by Gnac - <LDD 4.3.8> 10694 - Creative Supplement Bright (D model) - by Gnac - <LDD 4.3.9> 10694 - Creative Supplement Bright (E model) - by Gnac - <LDD 4.3.9> 10694 - Creative Supplement Bright (F model) - by Gnac - <LDD 4.3.8> 10694 - Creative Supplement Bright (G model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (A model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (B model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (C model) - by Gnac - <LDD 4.3.9> 10695 - Creative Building Box (D model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (E model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (F model) - by Gnac - <LDD 4.3.9> 10695 - Creative Building Box (G model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (H model) - by Gnac - <LDD 4.3.8> 10695 - Creative Building Box (I model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (A model) - by Gnac - <LDD 4.3.9> 10696 - Medium Creative Brick Box (B model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (C model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (D model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (E model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (F model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (G model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (H model) - by Gnac - <LDD 4.3.9> 10696 - Medium Creative Brick Box (I model) - by Gnac - <LDD 4.3.8> 10696 - Medium Creative Brick Box (J model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (A model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (B model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (C model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (D model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (E model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (F model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (G model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (H model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (I model) - by Gnac - <LDD 4.3.8> 10697 - XXL Creative Brick Box (J model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (A model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (B model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (C model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (D model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (E model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (F model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (G model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (H model) - by Gnac - <LDD 4.3.8> 10698 - Large Creative Brick Box (I model) - by Gnac - <LDD 4.3.9> 10702 - Creative Building Set (A model) - by Gnac - <LDD 4.3.9> 10702 - Creative Building Set (B model) - by Gnac - <LDD 4.3.8> 10702 - Creative Building Set (C model) - by Gnac - <LDD 4.3.8> 10702 - Creative Building Set (D model) - by Gnac - <LDD 4.3.8> 10702 - Creative Building Set (E model) - by Gnac - <LDD 4.3.8> 10702 - Creative Building Set (F model) - by Gnac - <LDD 4.3.8> 10702 - Creative Building Set (G model) - by Gnac - <LDD 4.3.9> 10702 - Creative Building Set (H model) - by Gnac - <LDD 4.3.9> 10702 - Creative Building Set (I model) - by Gnac - <LDD 4.3.9> 40290 - 60 Years of the LEGO Brick - by vean - <LDD 4.3.11> 40290 - 60 Years of the LEGO Brick - by Stephan - <LDD 4.3.11> Coin and Coin Bank 40155 - Piggy Coin Bank - by vean - <LDD 4.3.8> Collectible Minifigures 8683 - Minifigure Series 1 - by Commander Uno - <LDD 4> - [INCOMPLETE] - Comment: Minifigs missing 8683 - Minifigure Series 1 - by ADHO15 - <LDD 4> 8684 - Minifigure Series 2 - by ADHO15 - <LDD 4.3.5> 8803 - Minifigure Series 3 - by ADHO15 - <LDD 4.3.5> 8804 - Minifigure Series 4 - by ADHO15 - <LDD 4.3.5> 8805 - Minifigure Series 5 - by ADHO15 - <LDD 4.3.5> 8827 - Minifigure Series 6 - by ADHO15 - <LDD 4.3.5> 8831 - Minifigure Series 7 - by ADHO15 - <LDD 4.3.5> 8833 - Minifigure Series 8 - by ADHO15 - <LDD 4.3.5> 8909 - Minifigure Team GB Complete Random Set - by ADHO15 - <LDD 4> 71000 - Minifigure Series 9 - by ADHO15 - <LDD 4.3.5> 71000 - Minifigure Series 9 - by CM4S - <LDD 4.3.5> 71000 - Minifigure Series 9 - by Instructions archiver - <LDD 4.3.6> 71001 - Minifigure Series 10 - by ADHO15 - <LDD 4.3.6> 850449 - Minifigure Beach Accessory Pack - by ok13 - <LDD 4> 850486 - Rock Band - by Holodoc - <LDD 4.3.8> Creator 4016 - Racer [Promo] - by Gnac - <LDD 4.3.5> 4017 - Sea Helicopter [Promo] - by Gnac - <LDD 4.3.5> 4018 - Ship [Promo] - by Gnac - <LDD 4.3.5> 4019 - Aeroplane [Promo] - by Gnac - <LDD 4.3.5> 4625 - Pink Brick Box - by ok13 - <LDD 4.3.11> 4837 - Mini trains (A model) - by marco9999 - <LDD 3> 4837 - Mini trains (B model) - by marco9999 - <LDD 3> 4837 - Mini trains (C model) - by marco9999 - <LDD 3> 4838 - Mini Vehicles (A model) - by Tore M - <LDD 4> 4838 - Mini Vehicles (B model) - by Tore M - <LDD 4> 4838 - Mini Vehicles (C model) - by Tore M - <LDD 4> 4891 - Highway Haulers (A model) - by JunkstyleGio - <LDD 3> 4892 - Prehistoric Power (A model) - by C3POwen - <LDD 4> 4892 - Prehistoric Power (B model) - by Gnac - <LDD 4.3.5> 4892 - Prehistoric Power (C model) - by Gnac - <LDD 4.3.5> 4892 - Prehistoric Power (D model) - by Gnac - <LDD 4.3.5> 4892 - Prehistoric Power (E model) - by Gnac - <LDD 4.3.5> 4892 - Prehistoric Power (F model) - by C3POwen - <LDD 4> 4892 - Prehistoric Power (G model) - by C3POwen - <LDD 4> 4892 - Prehistoric Power (H model) - by Gnac - <LDD 4.3.5> 4893 - Revvin' Riders (A model) - by Sjuip - <LDD 4> 4893 - Revvin' Riders (B model) - by Sjuip - <LDD 4.3.5> 4893 - Revvin' Riders (C model) - by Sjuip - <LDD 4.3.5> 4893 - Revvin' Riders (D model) - by Sjuip - <LDD 4.3.5> 4893 - Revvin' Riders (E model) - by Sjuip - <LDD 4.3.5> 4893 - Revvin' Riders (F model) - by Sjuip - <LDD 4.3.5> 4893 - Revvin' Riders (G model) - by Sjuip - <LDD 4.3.5> 4893 - Revvin' Riders (H model) - by Sjuip - <LDD 4.3.5> 4894 - Mythical Creatures (A model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (B model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (C model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (D model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (E model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (F model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (G model) - by Sjuip - <LDD 4.3.6> 4894 - Mythical Creatures (H model) - by Sjuip - <LDD 4.3.6> 4895 - Motion Power (A model) - by JC75 - <LDD 4.3.8> - Comment: "Missile Spider" 4895 - Motion Power (B model) - by JC75 - <LDD 4.3.8> - Comment: "Sports Car" 4895 - Motion Power (C model) - by JC75 - <LDD 4.3.8> - Comment: "Attack Helicopter" 4896 - Roaring Roadsters (A model) - by JC75 - <LDD 4.3.8> 4896 - Roaring Roadsters (B model) - by marco9999 - <LDD 4.3.5> 4896 - Roaring Roadsters (C model) - by marco9999 - <LDD 4.3.5> 4915 - Mini construction (A model) - by marco9999 - <LDD 4> 4915 - Mini construction (B model) - by marco9999 - <LDD 4> 4915 - Mini construction (C model) - by marco9999 - <LDD 4> 4916 - Mini Animals (A model) - by zinfinion - <LDD 4.3.5> 4916 - Mini Animals (A model) - by Happy SDE - <LDD 4.3.8> 4916 - Mini Animals (B model) - by zinfinion - <LDD 4> 4916 - Mini Animals (B model) - by Happy SDE - <LDD 4.3.8> 4916 - Mini Animals (C model) - by Happy SDE - <LDD 4.3.8> 4916 - Mini Animals (C model) - by zinfinion - <LDD 4> 4917 - Mini Robots (A model) - by zinfinion - <LDD 4> 4917 - Mini Robots (A model) - by Happy SDE - <LDD 4.3.8> 4917 - Mini Robots (B model) - by zinfinion - <LDD 4> 4917 - Mini Robots (B model) - by Happy SDE - <LDD 4.3.8> 4917 - Mini Robots (C model) - by zinfinion - <LDD 4> 4917 - Mini Robots (C model) - by Happy SDE - <LDD 4.3.8> 4918 - Mini flyers (A model) - by marco9999 - <LDD 4> 4918 - Mini flyers (B model) - by marco9999 - <LDD 4> 4918 - Mini flyers (C model) - by marco9999 - <LDD 4> 4939 - Cool Cars (A model) - by Aanchir - <LDD 4> 4939 - Cool Cars (A model) - by JunkstyleGio - <LDD 3> 4939 - Cool Cars (B model) - by Aanchir - <LDD 4> 4939 - Cool Cars (B model) - by JunkstyleGio - <LDD 3> 4939 - Cool Cars (C model) - by Aanchir - <LDD 4> 4939 - Cool Cars (C model) - by JunkstyleGio - <LDD 3> 4953 - Fast Flyers (A model) - by Aanchir - <LDD 4> 4953 - Fast Flyers (A model) - by JunkstyleGio - <LDD 3> 4953 - Fast Flyers (A model) - by Gnac - <LDD 4.3.6> 4953 - Fast Flyers (B model) - by JunkstyleGio - <LDD 3> 4953 - Fast Flyers (B model) - by Aanchir - <LDD 4> 4953 - Fast Flyers (C model) - by JunkstyleGio - <LDD 3> 4953 - Fast Flyers (C model) - by Aanchir - <LDD 4> 4954 - Model Town House (A model) - by Johnnhiszippy3 - <LDD 3> 4954 - Model Town House (B model) - by Aanchir - <LDD 4> 4954 - Model Town House (C model) - by Aanchir - <LDD 4> 4955 - Big Rig (A model) - by JunkstyleGio - <LDD 3> 4955 - Big Rig (A model) - by P4trickvH - <LDD 4> 4955 - Big Rig (B model) - by JunkstyleGio - <LDD 3> 4955 - Big Rig (C model) - by P4trickvH - <LDD 4> 4955 - Big Rig (C model) - by JunkstyleGio - <LDD 3> 4956 - House (A model) - by Aanchir - <LDD 4> 4956 - House (B model) - by Calabar - <LDD 4> 4956 - House (C model) - by Aanchir - <LDD 4> 4957 - Ferris Wheel (A model) - by Sjuip - <LDD 4> 4957 - Ferris Wheel (B model) - by marco9999 - <LDD 4.3.5> 4957 - Ferris Wheel (C model) - by marco9999 - <LDD 4.3.5> 4958 - Monster Dino (A model) - by hrontos - <LDD 4> 4958 - Monster Dino (B model) - by marco9999 - <LDD 4.3.5> 4958 - Monster Dino (C model) - by marco9999 - <LDD 4.3.5> 4993 - Cool Convertible (A model) - by Aanchir - <LDD 4> 4993 - Cool Convertible (B model) - by Aanchir - <LDD 4> 4993 - Cool Convertible (C model) - by Aanchir - <LDD 4> 4994 - Fierce Creatures (A model) - by legolijntje - <LDD 4> 4994 - Fierce Creatures (B model) - by Sjuip - <LDD 4.3.6> 4994 - Fierce Creatures (C model) - by Sjuip - <LDD 4.3.6> 4995 - Cargo Copter (A model) - by Gnac - <LDD 4.3.5> 4995 - Cargo Copter (B model) - by Gnac - <LDD 4.3.5> 4995 - Cargo Copter (C model) - by Gnac - <LDD 4.3.5> 4995 - Cargo Copter (D model) - by Gnac - <LDD 4.3.5> - Comment: Lego Club Exclusive Build 4996 - Beach house (A model) - by Calabar - <LDD 4> 4996 - Beach House (B model) - by Aanchir - <LDD 4> 4996 - Beach House (C model) - by Aanchir - <LDD 4> 4997 - Transport Ferry (A model) - by Tore M - <LDD 4> 4997 - Transport Ferry (B model) - by Tore M - <LDD 4> 4997 - Transport Ferry (C model) - by Gnac - <LDD 4.3.5> 4998 - Stegosaurus (A model) - by legolijntje - <LDD 4> 4998 - Stegosaurus (B model) - by marco9999 - <LDD 4> 4998 - Stegosaurus (C model) - by marco9999 - <LDD 4> 5761 - Mini Digger (A model) - by Happy SDE - <LDD 4.3.8> 5761 - Mini Digger (A model) - by zinfinion - <LDD 4> 5761 - Mini Digger (B model) - by Happy SDE - <LDD 4.3.8> 5761 - Mini Digger (B model) - by zinfinion - <LDD 4> 5761 - Mini Digger (C model) - by zinfinion - <LDD 4> 5761 - Mini Digger (C model) - by Happy SDE - <LDD 4.3.8> 5762 - Mini Plane (A model) - by Happy SDE - <LDD 4.3.8> 5762 - Mini Plane (A model) - by zinfinion - <LDD 4> 5762 - Mini Plane (B model) - by zinfinion - <LDD 4> 5762 - Mini Plane (B model) - by Happy SDE - <LDD 4.3.8> 5762 - Mini Plane (C model) - by zinfinion - <LDD 4> 5762 - Mini Plane (C model) - by Happy SDE - <LDD 4.3.8> 5763 - Dune Hopper (A model) - by marco9999 - <LDD 4.3.5> 5763 - Dune Hopper (B model) - by marco9999 - <LDD 4> 5763 - Dune Hopper (C model) - by marco9999 - <LDD 4> 5764 - Rescue Robot (A model) - by Aanchir - <LDD 4> 5764 - Rescue Robot (B model) - by Aanchir - <LDD 4> 5764 - Rescue Robot (C model) - by Aanchir - <LDD 4> 5765 - Transport Truck (A model) - by Aanchir - <LDD 4.3.8> 5765 - Transport Truck (B model) - by Aanchir - <LDD 4.3.8> 5765 - Transport Truck (C model) - by C3POwen - <LDD 4> 5765 - Transport Truck (C model) - by Aanchir - <LDD 4.3.8> 5766 - Log Cabin (A model) - by ok13 - <LDD 4> 5766 - Log Cabin (A model) - by Artuax - <LDD 4> 5766 - Log Cabin (A model) - by Gear_tooth - <LDD 4> 5766 - Log Cabin (A model) - by nicoga3000 - <LDD 4> 5766 - Log Cabin (B model) - by Tontus - <LDD 4> 5766 - Log Cabin (C model) - by Tontus - <LDD 4> 5767 - Cool Cruiser (A model) - by Gnac - <LDD 4.3.8> 5767 - Cool Cruiser (B model) - by marco9999 - <LDD 4.3.5> 5767 - Cool Cruiser (C model) - by marco9999 - <LDD 4.3.5> 5770 - Lighthouse Island (A model) - by BrickWild - <LDD 4> 5770 - Lighthouse Island (B model) - by tikicult - <LDD 4> 5770 - Lighthouse Island (C model) - by tikicult - <LDD 4> 5771 - Hillside House (A model) - by BrickWild - <LDD 4> 5771 - Hillside House (B model) - by Gnac - <LDD 4.3.5> 5771 - Hillside House (C model) - by Gnac - <LDD 4.3.5> 5864 - Mini Helicopter (A model) - by zinfinion - <LDD 4> 5864 - Mini Helicopter (A model) - by Happy SDE - <LDD 4.3.8> 5864 - Mini Helicopter (B model) - by Happy SDE - <LDD 4.3.8> 5864 - Mini Helicopter (B model) - by zinfinion - <LDD 4> 5864 - Mini Helicopter (C model) - by zinfinion - <LDD 4> 5864 - Mini Helicopter (C model) - by Happy SDE - <LDD 4.3.8> 5865 - Mini Dumper (A model) - by Tore M - <LDD 4> 5865 - Mini Dumper (B model) - by Tore M - <LDD 4> 5865 - Mini Dumper (C model) - by Tore M - <LDD 4> 5866 - Rotor rescue (A model) - by marco9999 - <LDD 4> 5866 - Rotor rescue (B model) - by marco9999 - <LDD 4> 5866 - Rotor rescue (C model) - by marco9999 - <LDD 4> 5866 - Rotor Rescue (D model) - by Toa_Of_Justice - <LDD 4> 5867 - Super Speedster (A model) - by JunkstyleGio - <LDD 3> 5867 - Super Speedster (A model) - by AndyC - <LDD 4> 5867 - Super Speedster (B model) - by JunkstyleGio - <LDD 3> 5867 - Super Speedster (B model) - by AndyC - <LDD 4> 5867 - Super Speedster (C model) - by JunkstyleGio - <LDD 3> 5867 - Super Speedster (C model) - by AndyC - <LDD 4> 5867 - Super Speedster (D model) - by Toa_Of_Justice - <LDD 4> 5867 - Super Speedster (D model) - by Sjuip - <LDD 4> 5868 - Ferocious Creatures (A model) - by Aanchir - <LDD 4> 5868 - Ferocious Creatures (B model) - by Aanchir - <LDD 4> 5868 - Ferocious Creatures (C model) - by Aanchir - <LDD 4> 5891 - Apple Tree House (A model) - by Johnnhiszippy3 - <LDD 3> 5891 - Apple Tree House (A model) - by ashir - <LDD 4> 5891 - Apple Tree House (B model) - by Aanchir - <LDD 4> 5891 - Apple Tree House (C model) - by Aanchir - <LDD 4> 5892 - Sonic Boom (A model) - by prateek - <LDD 3> 5892 - Sonic Boom (A model) - by Aanchir - <LDD 4> 5892 - Sonic Boom (B model) - by Aanchir - <LDD 4> 5892 - Sonic Boom (C model) - by Aanchir - <LDD 4> 5893 - Offroad Power (A model) - by Gnac - <LDD 4.3.5> 5893 - Off Road Power (A model) - by JunkstyleGio - <LDD 3> - [INCOMPLETE] - Comment: Unfinished Model 5893 - Off Road Power (B model) - by marco9999 - <LDD 4> 5893 - Off Road Power (C model) - by marco9999 - <LDD 4> 6741 - Mini Jet (A model) - by Tore M - <LDD 4> 6741 - Mini Jet (B model) - by Tore M - <LDD 4> 6741 - Mini Jet (C model) - by Tore M - <LDD 4> 6742 - Mini Off-Roader (A model) - by Tore M - <LDD 4> 6742 - Mini Off-Roader (B model) - by Tore M - <LDD 4> 6742 - Mini Off-Roader (C model) - by Tore M - <LDD 4> 6743 - Street Speeder (A model) - by JunkstyleGio - <LDD 3> 6743 - Street speeder (B model) - by marco9999 - <LDD 4> 6743 - Street speeder (C model) - by marco9999 - <LDD 4> 6745 - Propellor Power (A model) - by marco9999 - <LDD 3> 6745 - Propellor Power (B model) - by marco9999 - <LDD 4> 6745 - Propellor Power (C model) - by marco9999 - <LDD 3> 6747 - Race Riders (A model) - by marco9999 - <LDD 3> 6747 - Race Riders (B model) - by marco9999 - <LDD 3> 6747 - Race Riders (C model) - by marco9999 - <LDD 3> 6751 - Fiery Legend (A model) - by Aanchir - <LDD 4> 6751 - Fiery Legend (B model) - by Aanchir - <LDD 4> 6751 - Fiery Legend (C model) - by Aanchir - <LDD 4> 6752 - Fire Rescue (A model) - by Tore M - <LDD 4> 6752 - Fire Rescue (A model) - by BasOne - <LDD 4> 6752 - Fire Rescue (B model) - by JunkstyleGio - <LDD 3> 6752 - Fire Rescue (C model) - by Tore M - <LDD 4> 6753 - Highway Transport (A model) - by JunkstyleGio - <LDD 3> - [INCOMPLETE] - Comment: One car missing 6753 - Highway Transport (A model) - by Gnac - <LDD 4.3.5> 6753 - Highway Transport (B model) - by Sjuip - <LDD 4> 6753 - Highway Transport (C model) - by Sjuip - <LDD 4.3.5> 6754 - Family Home (A model) - by AndyC - <LDD 4> 6754 - Family Home (A model) - by Johnnhiszippy3 - <LDD 3> 6754 - Family Home (B model) - by AndyC - <LDD 4> 6754 - Family Home (C model) - by AndyC - <LDD 4> 6910 - Mini Sports Car (A model) - by zinfinion - <LDD 4> 6910 - Mini Sports Car (A model) - by Happy SDE - <LDD 4.3.8> 6910 - Mini Sports Car (B model) - by Happy SDE - <LDD 4.3.8> 6910 - Mini Sports Car (B model) - by zinfinion - <LDD 4> 6910 - Mini Sports Car (C model) - by Happy SDE - <LDD 4.3.8> 6910 - Mini Sports Car (C model) - by zinfinion - <LDD 4> 6911 - Mini Fire Truck (A model) - by zinfinion - <LDD 4> 6911 - Mini Fire Rescue (A model) - by Happy SDE - <LDD 4.3.8> 6911 - Mini Fire Truck (B model) - by zinfinion - <LDD 4> 6911 - Mini Fire Rescue (B model) - by Happy SDE - <LDD 4.3.8> 6911 - Mini Fire Rescue (C model) - by Happy SDE - <LDD 4.3.8> 6911 - Mini Fire Truck (C model) - by zinfinion - <LDD 4> 6912 - Super Soarer (A model) - by zinfinion - <LDD 4> 6912 - Super Soarer (A model) - by Happy SDE - <LDD 4.3.8> 6912 - Super Soarer (A model) - by PsyKater - <LDD 4> 6912 - Super Soarer (A model) - by zinfinion - <LDD 4.3.5> 6912 - Super Soarer (B model) - by zinfinion - <LDD 4> 6912 - Super Soarer (B model) - by Happy SDE - <LDD 4.3.8> 6912 - Super Soarer (C model) - by Happy SDE - <LDD 4.3.8> 6912 - Super Soarer (C model) - by zinfinion - <LDD 4> 6912 - Super Soarer (C model) - by zinfinion - <LDD 4> 6913 - Blue Roadster (A model) - by Sjuip - <LDD 4> 6913 - Blue Roadster (B model) - by Sjuip - <LDD 4.3.5> 6913 - Blue Roadster (C model) - by Sjuip - <LDD 4.3.5> 6913 - Blue Roadster (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Web extra model 6914 - Prehistoric Hunters (A model) - by marco9999 - <LDD 4> 6914 - Prehistoric Hunters (B model) - by marco9999 - <LDD 4> 6914 - Prehistoric Hunters (C model) - by marco9999 - <LDD 4> 7172 - Apple - Capespan Promotional - by Gnac - <LDD 4.3.6> 7173 - Pear - Capespan Promotional - by Gnac - <LDD 4.3.6> 7174 - Banana - Capespan Promotional - by Gnac - <LDD 4.3.6> 7175 - Grapes - Capespan Promotional - by Gnac - <LDD 4.3.6> 7176 - Watermelon - Capespan Promotional - by Gnac - <LDD 4.3.6> 7177 - Orange - Capespan Promotional - by Gnac - <LDD 4.3.6> 7271 - Apple - Suntory Promotional - by Gnac - <LDD 4.3.6> 7272 - Pear - Suntory Promotional - by Gnac - <LDD 4.3.6> 7274 - Orange - Suntory Promotional - by Gnac - <LDD 4.3.6> 7275 - Cherry - Suntory Promotional - by Gnac - <LDD 4.3.6> 7276 - Mango - Suntory Promotional - by Gnac - <LDD 4.3.6> 7278 - Melon - Suntory Promotional - by Gnac - <LDD 4.3.6> 7291 - Street Rebel (A model) - by zinfinion - <LDD 4> 7291 - Street Rebel (A model) - by JC75 - <LDD 4.3.8> - Comment: "Street Bike" 7291 - Street Rebel (B model) - by JC75 - <LDD 4.3.8> - Comment: "Chopper" 7291 - Street Rebel (B model) - by zinfinion - <LDD 4> 7291 - Street Rebel (C model) - by zinfinion - <LDD 4> 7291 - Street Rebel (C model) - by JC75 - <LDD 4.3.8> - Comment: "Moped" 7291 - Street Rebel (D model) - by Gnac - <LDD 4> 7292 - Propeller Adventures (A model) - by zinfinion - <LDD 4> 7292 - Propeller Adventures (A model) - by Happy SDE - <LDD 4.3.8> 7292 - Propeller Adventures (B model) - by zinfinion - <LDD 4> 7292 - Propeller Adventures (B model) - by Happy SDE - <LDD 4.3.8> 7292 - Propeller Adventures (C model) - by zinfinion - <LDD 4> 7292 - Propeller Adventures (C model) - by Happy SDE - <LDD 4.3.8> 7292 - Propeller Adventures (D model) - by Gnac - <LDD 4> 7345 - Transport Chopper (A model) - by Gnac - <LDD 4> 7345 - Transport Chopper (B model) - by Gnac - <LDD 4> 7345 - Transport Chopper (C model) - by Gnac - <LDD 4> 7346 - Seaside House (A model) - by ok13 - <LDD 4> 7346 - Seaside House (B model) - by Gnac - <LDD 4.3.5> 7346 - Seaside House (C model) - by Gnac - <LDD 4.3.5> 7347 - Highway Pickup (A model) - by Gnac - <LDD 4.3.5> 7347 - Highway Pickup (B model) - by Gnac - <LDD 4.3.5> 7347 - Highway Pickup (C model) - by Gnac - <LDD 4.3.5> 7601 - Go-Kart - by AndyC - <LDD 4> 7602 - Black SUV - by KartoffelViking - <LDD 4> 7603 - Dump Truck - by Happy SDE - <LDD 4.3.8> 7604 - Triceratops - by KartoffelViking - <LDD 4> 7605 - Dinosaur [Promo] - by Gnac - <LDD 4.3.5> 7606 - Frog - by KartoffelViking - <LDD 4> 7607 - Butterfly [Promo] - by Gnac - <LDD 4.3.5> 7608 - Dolphin [Promo] - by Gnac - <LDD 4.3.5> 7609 - Helicopter - by AndyC - <LDD 4> 7610 - Speedboat [Promo] - by Gnac - <LDD 4> 7796 - House [Promo] - by Gnac - <LDD 4.3.5> 7797 - Bi-Plane [Promo] - by Gnac - <LDD 4.3.5> 7798 - Stegosaurus [Promo] - by Gnac - <LDD 4.3.5> 7799 - Cargo Chopper [Promo] - by Gnac - <LDD 4> 7799 - Cargo Chopper - by Stephan - <LDD 4.3.6> 7803 - Jeep - by Tore M - <LDD 4> 7804 - Lizard - by Toa_Of_Justice - <LDD 4> 7805 - Shark - by C3POwen - <LDD 4> 7808 - Yellow Airplane - by ILikePi - <LDD 3> 7871 - Whale [Promo] - by Gnac - <LDD 4.3.5> 7872 - Lion [Promo] - by Gnac - <LDD 4.3.5> 7873 - Jet Plane [Promo] - by Gnac - <LDD 4> 7875 - Digger [Promo] - by Gnac - <LDD 4> 7876 - Cement Truck [Promo] - by Gnac - <LDD 4> 10242 - MINI Cooper - by Gnac - <LDD 4.3.8> 10244 - Fairground Mixer - by vean - <LDD 4.3.8> 10247 - Ferris Wheel - by Stephan - <LDD 4.3.8> 10248 - Ferrari F40 - by vean - <LDD 4.3.9> 10250 - Year of the Snake - by Stephan - <LDD 4.3.5> 10257 - Carousel - by lomis - <LDD 4.3.10> 10258 - Routemaster London Bus - by Henni - <LDD 4.3.11> 10258 - Routemaster London Bus - by Stephan - <LDD 4.3.10> 10262 - James Bond Aston Martin DB5 - by PicnicBasketSam - <LDD 4.3.11> 10265 - Ford Mustang - by Migui94 - <LDD 4.3.11> 10268 - Vestas Wind Turbine - by iSware - <LDD 4.3.11> 10271 - Fiat 500 - by vean - <LDD 4.3.11> 10656 - My First LEGO Princess - by penguinz - <LDD 4.3.6> 20001 - LEGO Batbot [Promo] - by Gnac - <LDD 4.3.5> 20003 - Dinosaur - by Aanchir - <LDD 4> 20008 - Tow Truck - by Aanchir - <LDD 4> 20011 - Garbage Truck - by Aanchir - <LDD 4> 20014 - Brickmaster Quad (A model) - by JunkstyleGio - <LDD 4.3.5> 20014 - 4 x 4 Dynamo (B model) - by Stephan - <LDD 4.3.6> - Comment: Extra LEGOClub build: All Terrain Racer 20015 - Crocodile - by legolijntje - <LDD 3> 30020 - Jet - by ILikePi - <LDD 3> 30021 - Parrot - by ILikePi - <LDD 3> 30022 - Bee - by Happy SDE - <LDD 4.3.8> - Comment: Neved produced. 30023 - Lighthouse - by AndyC - <LDD 4> 30024 - Truck - by Toa_Of_Justice - <LDD 4> 30025 - Clown Fish - by AndyC - <LDD 4> 30026 - Panda - by Toa_Of_Justice - <LDD 4> 30027 - Reindeer - by Costy - <LDD 4> 30180 - Twin Prop - by Gnac - <LDD 4.3.6> 30181 - Helicopter - by Gnac - <LDD 4.3.6> 30183 - Little Car - by Gnac - <LDD 4.3.5> 30184 - Little Helicopter - by Stephan - <LDD 4.3.6> 30185 - Little Eagle - by Stephan - <LDD 4.3.5> 30186 - Christmas Tree - by Gnac - <LDD 4.3.6> 30187 - Fast Car [Promo] - by Gnac - <LDD 4.3.8> 30188 - Cute Kitten [Promo] - by Gnac - <LDD 4.3.8> 30189 - Transport Plane [Promo] - by Gnac - <LDD 4.3.8> 30283 - Off-Road [Promo] - by Gnac - <LDD 4.3.8> 30284 - Tractor [Promo] - by Gnac - <LDD 4.3.8> 30285 - Tiger [Promo] - by Gnac - <LDD 4.3.8> 30471 - Helicopter polybag - by Gnac - <LDD 4.3.8> 30472 - Parrot polybag - by Gnac - <LDD 4.3.8> 30475 - Off Roader polybag - by vean - <LDD 4.3.10> 30476 - Happy Turtle polybag - by vean - <LDD 4.3.10> 30477 - Chameleon polybag - by vean - <LDD 4.3.10> 31000 - Mini Speeder (A model) - by Gnac - <LDD 4.3.5> 31000 - Mini Speeder (A model) - by Wolfolo - <LDD 4.3.6> 31000 - Mini Speeder (B model) - by Gnac - <LDD 4.3.5> 31000 - Mini Speeder (C model) - by Gnac - <LDD 4.3.5> 31001 - Mini Skyfighter (A model) - by Wolfolo - <LDD 4.3.6> 31001 - Mini Skyflyer (A model) - by Gnac - <LDD 4.3.5> 31001 - Mini Skyflyer (B model) - by Gnac - <LDD 4.3.5> 31001 - Mini Skyflyer (C model) - by Gnac - <LDD 4.3.5> 31002 - Super Racer (A model) - by Gnac - <LDD 4.3.5> 31002 - Super Racer (A model) - by Wolfolo - <LDD 4.3.6> 31002 - Super Racer (B model) - by Gnac - <LDD 4.3.5> 31002 - Super Racer (C model) - by Gnac - <LDD 4.3.5> 31003 - Red Rotors (A model) - by Stephan - <LDD 4.3.5> - Comment: Cargo Helicopter 31003 - Red Rotors (A model) - by Wolfolo - <LDD 4.3.6> 31003 - Red Rotors (B model) - by Stephan - <LDD 4.3.5> - Comment: Plane 31003 - Red Rotors (C model) - by Stephan - <LDD 4.3.5> - Comment: Hovercraft 31003 - Red Rotors (D model) - by Gnac - <LDD 4.3.6> 31004 - Fierce Flyer (A model) - by Stephan - <LDD 4.3.5> - Comment: Eagle 31004 - Fierce Flyer (A model) - by Wolfolo - <LDD 4.3.6> 31004 - Fierce Flyer (B model) - by Stephan - <LDD 4.3.5> - Comment: Beaver 31004 - Fierce Flyer (C model) - by Stephan - <LDD 4.3.5> - Comment: Scorpion 31005 - Construction Hauler (A model) - by Wolfolo - <LDD 4.3.6> 31005 - Construction Hauler (A model) - by Stephan - <LDD 4.3.5> 31005 - Construction Hauler (B model) - by Stephan - <LDD 4.3.5> - Comment: Rugged Cherry Picker 31005 - Construction Hauler (C model) - by Stephan - <LDD 4.3.5> - Comment: Offroad Transporter 31006 - Highway Speedster (A model) - by Stephan - <LDD 4.3.5> - Comment: Sports Car 31006 - Highway Speedster (A model) - by Wolfolo - <LDD 4.3.6> 31006 - Highway Speedster (B model) - by Stephan - <LDD 4.3.5> - Comment: Tow Truck 31006 - Highway Speedster (C model) - by Stephan - <LDD 4.3.5> - Comment: Race Car 31007 - Power Mech (A model) - by Gnac - <LDD 4.3.5> 31007 - Power Mech (A model) - by Wolfolo - <LDD 4.3.6> 31007 - Power Mech (B model) - by Gnac - <LDD 4.3.5> 31007 - Power Mech (C model) - by Gnac - <LDD 4.3.5> 31008 - Thunder Wings (A model) - by Wolfolo - <LDD 4.3.6> 31008 - Thunder Wings (A model) - by Gnac - <LDD 4.3.5> 31008 - Thunder Wings (B model) - by Gnac - <LDD 4.3.5> 31008 - Thunder Wings (C model) - by Gnac - <LDD 4.3.5> 31009 - Small Cottage (A model) - by Stephan - <LDD 4.3.5> 31009 - Small Cottage (B model) - by Stephan - <LDD 4.3.5> - Comment: Seaside House 31009 - Small Cottage (C model) - by Stephan - <LDD 4.3.5> - Comment: Mill 31010 - Treehouse (A model) - by Stephan - <LDD 4.3.6> 31010 - Treehouse (B model) - by Stephan - <LDD 4.3.6> 31010 - Treehouse (C model) - by Stephan - <LDD 4.3.6> 31011 - Aviation Adventures (A model) - by Stephan - <LDD 4.3.6> 31011 - Aviation Adventures (A model) - by Gnac - <LDD 4.3.8> 31011 - Aviation Adventures (B model) - by Stephan - <LDD 4.3.6> 31011 - Aviation Adventures (B model) - by Gnac - <LDD 4.3.8> 31011 - Aviation Adventures (C model) - by Stephan - <LDD 4.3.6> 31011 - Aviation Adventures (C model) - by Gnac - <LDD 4.3.8> 31012 - Family House (A model) - by Stephan - <LDD 4.3.6> 31012 - Family House (B model) - by Stephan - <LDD 4.3.6> 31012 - Family House (C model) - by Stephan - <LDD 4.3.6> 31013 - Red Thunder (A model) - by Gnac - <LDD 4.3.6> 31013 - Red Thunder (A model) - by Stephan - <LDD 4.3.6> 31013 - Red Thunder (B model) - by Stephan - <LDD 4.3.6> 31013 - Red Thunder (B model) - by Gnac - <LDD 4.3.6> 31013 - Red Thunder (C model) - by Stephan - <LDD 4.3.6> 31013 - Red Thunder (C model) - by Gnac - <LDD 4.3.6> 31014 - Power Digger (A model) - by Stephan - <LDD 4.3.6> 31014 - Power Digger (A model) - by Gnac - <LDD 4.3.8> 31014 - Power Digger (B model) - by Stephan - <LDD 4.3.6> 31014 - Power Digger (B model) - by Gnac - <LDD 4.3.6> 31014 - Power Digger (C model) - by Stephan - <LDD 4.3.6> 31014 - Power Digger (C model) - by Gnac - <LDD 4.3.6> 31015 - Emerald Express (A model) - by Gnac - <LDD 4.3.6> 31015 - Emerald Express (A model) - by Stephan - <LDD 4.3.6> 31015 - Emerald Express (B model) - by Stephan - <LDD 4.3.6> 31015 - Emerald Express (B model) - by Gnac - <LDD 4.3.6> 31015 - Emerald Express (C model) - by Stephan - <LDD 4.3.6> 31015 - Emerald Express (C model) - by Gnac - <LDD 4.3.6> 31017 - Sunset Speeder (A model) - by Stephan - <LDD 4.3.6> 31017 - Sunset Speeder (A model) - by Gnac - <LDD 4.3.8> 31017 - Sunset Speeder (B model) - by Gnac - <LDD 4.3.8> 31017 - Sunset Speeder (B model) - by Stephan - <LDD 4.3.6> 31017 - Sunset Speeder (C model) - by Stephan - <LDD 4.3.6> 31017 - Sunset Speeder (C model) - by Gnac - <LDD 4.3.8> 31018 - Highway Cruiser (A model) - by Stephan - <LDD 4.3.6> 31018 - Highway Cruiser (B model) - by Stephan - <LDD 4.3.6> 31018 - Highway Cruiser (C model) - by Stephan - <LDD 4.3.6> 31019 - Forest Animals (A model) - by Gnac - <LDD 4.3.8> 31019 - Forest Animals (B model) - by Gnac - <LDD 4.3.8> 31019 - Forest Animals (C model) - by Gnac - <LDD 4.3.8> 31019 - Forest Animals (D model) - by Stephan - <LDD 4.3.8> - Comment: "Bear" 31019 - Forest Animals (E model) - by Stephan - <LDD 4.3.8> - Comment: "Monkey " 31019 - Forest Animals (F model) - by Stephan - <LDD 4.3.8> - Comment: "Squirrel" 31020 - Twinblade Adventures (A model) - by Stephan - <LDD 4.3.6> - Comment: (Heliplane) 31020 - Twinblade Adventures (B model) - by Stephan - <LDD 4.3.6> - Comment: (Propellor Plane) 31020 - Twinblade Adventures (C model) - by Stephan - <LDD 4.3.6> - Comment: (Helicopter) 31021 - Furry Creatures (A model) - by Gnac - <LDD 4.3.8> 31021 - Furry Creatures (B model) - by Gnac - <LDD 4.3.8> 31021 - Furry Creatures (C model) - by Gnac - <LDD 4.3.8> 31022 - Turbo Quad (A model) - by Gnac - <LDD 4.3.8> 31022 - Turbo Quad (B model) - by Gnac - <LDD 4.3.8> 31022 - Turbo Quad (C model) - by Gnac - <LDD 4.3.8> 31023 - Yellow Racers (A model) - by Gnac - <LDD 4.3.8> 31023 - Yellow Racers (B model) - by Gnac - <LDD 4.3.8> 31023 - Yellow Racers (C model) - by Gnac - <LDD 4.3.8> 31024 - Roaring Power (A model) - by Gnac - <LDD 4.3.8> 31024 - Roaring Power (B model) - by Gnac - <LDD 4.3.8> 31024 - Roaring Power (C model) - by Gnac - <LDD 4.3.8> 31025 - Mountain Hut (A model) - by Gnac - <LDD 4.3.8> 31025 - Mountain Hut (B model) - by Gnac - <LDD 4.3.8> 31025 - Mountain Hut (C model) - by Gnac - <LDD 4.3.8> 31026 - Bike Shop and Cafe (Bike Shop & Cafè) - by mzoli - <LDD 4.3.8> 31026 - Bike Shop and Cafe (Bike Shop & Cafè) (B model) - by mzoli - <LDD 4.3.8> - Comment: "Auto repair shop" 31026 - Bike Shop and Cafe (Bike Shop & Cafè) (C model) - by mzoli - <LDD 4.3.8> - Comment: "Flower shop" 31027 - Blue Racer (A model) - by Gnac - <LDD 4.3.8> 31027 - Blue Racer (B model) - by Gnac - <LDD 4.3.8> 31027 - Blue Racer (C model) - by Gnac - <LDD 4.3.8> 31028 - Sea Plane (A model) - by Gnac - <LDD 4.3.9> 31028 - Sea Plane (B model) - by Gnac - <LDD 4.3.9> 31028 - Sea Plane (C model) - by Gnac - <LDD 4.3.9> 31029 - Cargo Heli (A model) - by Gnac - <LDD 4.3.8> 31029 - Cargo Heli (B model) - by Gnac - <LDD 4.3.8> 31029 - Cargo Heli (C model) - by Gnac - <LDD 4.3.8> 31030 - Red Go-Kart (A model) - by Gnac - <LDD 4.3.9> 31030 - Red Go-Kart (B model) - by Gnac - <LDD 4.3.8> 31030 - Red Go-Kart (C model) - by Gnac - <LDD 4.3.8> 31031 - Rainforest Animals (A model) - by Gnac - <LDD 4.3.8> 31031 - Rainforest Animals (B model) - by Gnac - <LDD 4.3.8> 31031 - Rainforest Animals (C model) - by Gnac - <LDD 4.3.8> 31031 - Rainforest Animals (D model) - by Gnac - <LDD 4.3.8> 31032 - Red Creatures (A model) - by Gnac - <LDD 4.3.8> 31032 - Red Creatures (B model) - by Gnac - <LDD 4.3.8> 31032 - Red Creatures (C model) - by Gnac - <LDD 4.3.8> 31033 - Vehicle Transporter (A model) - by Gnac - <LDD 4.3.8> 31033 - Vehicle Transporter (B model) - by Gnac - <LDD 4.3.8> 31033 - Vehicle Transporter (C model) - by Gnac - <LDD 4.3.8> 31034 - Future flyers (A model) - by Gnac - <LDD 4.3.8> 31034 - Future flyers (B model) - by Gnac - <LDD 4.3.8> 31034 - Future flyers (C model) - by Gnac - <LDD 4.3.8> 31035 - Beach Hut (A model) - by Gnac - <LDD 4.3.8> 31035 - Beach Hut (B model) - by Gnac - <LDD 4.3.8> 31035 - Beach Hut (C model) - by Gnac - <LDD 4.3.8> 31036 - Toy & Grocery Shop (A model) - by Gnac - <LDD 4.3.8> 31036 - Toy & Grocery Shop (B model) - by Gnac - <LDD 4.3.8> 31036 - Toy & Grocery Shop (C model) - by Gnac - <LDD 4.3.8> 31037 - Adventure Vehicles (A model) - by Gnac - <LDD 4.3.9> 31037 - Adventure Vehicles (B model) - by Gnac - <LDD 4.3.9> 31037 - Adventure Vehicles (C model) - by Gnac - <LDD 4.3.8> 31038 - Changing Seasons (A model) - by Gnac - <LDD 4.3.8> 31038 - Changing Seasons (B model) - by Gnac - <LDD 4.3.8> 31038 - Changing Seasons (C model) - by Gnac - <LDD 4.3.8> 31039 - Blue Power Jet (A model) - by Gnac - <LDD 4.3.9> 31039 - Blue Power Jet (B model) - by Gnac - <LDD 4.3.8> 31039 - Blue Power Jet (C model) - by Gnac - <LDD 4.3.8> 31040 - Desert Racers (A model) - by Gnac - <LDD 4.3.8> 31040 - Desert Racers (B model) - by Gnac - <LDD 4.3.8> 31040 - Desert Racers (C model) - by Gnac - <LDD 4.3.8> 31041 - Construction Vehicles (A model) - by Gnac - <LDD 4.3.8> 31041 - Construction Vehicles (B model) - by Gnac - <LDD 4.3.8> 31041 - Construction Vehicles (C model) - by Gnac - <LDD 4.3.8> 31042 - Super Soarer (A model) - by Gnac - <LDD 4.3.9> 31042 - Super Soarer (B model) - by Gnac - <LDD 4.3.9> 31042 - Super Soarer (C model) - by Gnac - <LDD 4.3.9> 31043 - Chopper Transporter (A model) - by Gnac - <LDD 4.3.8> 31043 - Chopper Transporter (B model) - by Gnac - <LDD 4.3.8> 31043 - Chopper Transporter (C model) - by Gnac - <LDD 4.3.8> 31044 - Park Animals (A model) - by Gnac - <LDD 4.3.9> 31044 - Park Animals (B model) - by Gnac - <LDD 4.3.8> 31044 - Park Animals (C model) - by Gnac - <LDD 4.3.9> 31045 - Ocean Explorer (A model) - by Gnac - <LDD 4.3.9> 31045 - Ocean Explorer (B model) - by Gnac - <LDD 4.3.9> 31045 - Ocean Explorer (C model) - by Gnac - <LDD 4.3.9> 31045 - Ocean Explorer (D model) - by Gnac - <LDD 4.3.9> 31046 - Fast Car (A model) - by Gnac - <LDD 4.3.9> 31046 - Fast Car (B model) - by Gnac - <LDD 4.3.9> 31046 - Fast Car (C model) - by Gnac - <LDD 4.3.9> 31047 - Propeller Plane (A model) - by Gnac - <LDD 4.3.9> 31047 - Propeller Plane (B model) - by Gnac - <LDD 4.3.9> 31047 - Propeller Plane (C model) - by Gnac - <LDD 4.3.9> 31048 - Lakeside Lodge (A model) - by Gnac - <LDD 4.3.9> 31048 - Lakeside Lodge (B model) - by Gnac - <LDD 4.3.9> 31048 - Lakeside Lodge (C model) - by Gnac - <LDD 4.3.9> 31049 - Twin Spin Helicopter (A model) - by KamalMYafi - <LDD 4.3.9> 31049 - Twin Spin Helicopter (B model) - by KamalMYafi - <LDD 4.3.9> 31049 - Twin Spin Helicopter (C model) - by KamalMYafi - <LDD 4.3.9> 31050 - Corner Deli (A model) - by Gnac - <LDD 4.3.9> 31050 - Corner Deli (B model) - by Gnac - <LDD 4.3.9> 31050 - Corner Deli (C model) - by Gnac - <LDD 4.3.9> 31052 - Vacation Getaways (A model) - by Sjuip - <LDD 4.3.9> 31052 - Vacation Getaways (B model) - by Sjuip - <LDD 4.3.9> 31052 - Vacation Getaways (C model) - by Sjuip - <LDD 4.3.9> 31054 - Blue Express (A model) - by marco9999 - <LDD 4.3.10> 31054 - Blue Express (B model) - by marco9999 - <LDD 4.3.10> 31054 - Blue Express (C model) - by marco9999 - <LDD 4.3.10> 31057 - Air Blazer (A model) - by mistahfreshone - <LDD 4.3.10> 31057 - Air Blazer (B model) - by mistahfreshone - <LDD 4.3.10> 31057 - Air Blazer (C model) - by mistahfreshone - <LDD 4.3.10> 31059 - Sunset Street Bike (A model) - by mistahfreshone - <LDD 4.3.10> 31059 - Sunset Street Bike (B model) - by mistahfreshone - <LDD 4.3.10> 31059 - Sunset Street Bike (C model) - by mistahfreshone - <LDD 4.3.10> 31063 - Beachside Vacation (A model) - by yojeff - <LDD 4.3.10> 31063 - Beachside Vacation (B model) - by yojeff - <LDD 4.3.10> 31063 - Beachside Vacation (C model) - by yojeff - <LDD 4.3.10> 31065 - Park Street Townhouse (A model) - by koalayummies - <LDD 4.3.10> 31065 - Park Street Townhouse (B model) - by koalayummies - <LDD 4.3.10> 31065 - Park Street Townhouse (C model) - by koalayummies - <LDD 4.3.10> 31070 - Turbo Track Racer - by JC75 - <LDD 4.3.11> 31070 - Turbo Track Racer (A model) - by Kuramapika1 - <LDD 4.3.11> 31070 - Turbo Track Racer (B model) - by Kuramapika1 - <LDD 4.3.11> 31070 - Turbo Track Racer (C model) - by Kuramapika1 - <LDD 4.3.11> 31071 - Drone Explorer (A model) - by Kuramapika1 - <LDD 4.3.11> 31071 - Drone Explorer (B model) - by Kuramapika1 - <LDD 4.3.11> 31071 - Drone Explorer (C model) - by Kuramapika1 - <LDD 4.3.11> 31072 - Extreme Engines (A model) - by JC75 - <LDD 4.3.10> 31072 - Extreme Engines (B model) - by JC75 - <LDD 4.3.10> 31072 - Extreme Engines (C model) - by JC75 - <LDD 4.3.10> 31073 - Mythical Creatures (A model) - by Kuramapika1 - <LDD 4.3.11> 31073 - Mythical Creatures (B model) - by Kuramapika1 - <LDD 4.3.11> 31073 - Mythical Creatures (C model) - by Kuramapika1 - <LDD 4.3.11> 31073 - Mythical Creatures (D model) - by Kuramapika1 - <LDD 4.3.11> 31074 - Rocket Rally Car (A model) - by Kuramapika1 - <LDD 4.3.11> 31074 - Rocket Rally Car (B model) - by Kuramapika1 - <LDD 4.3.11> 31074 - Rocket Rally Car (C model) - by Kuramapika1 - <LDD 4.3.11> 31075 - Outback Adventures (A model) - by Kuramapika1 - <LDD 4.3.11> 31075 - Outback Adventures (B model) - by Kuramapika1 - <LDD 4.3.11> 31075 - Outback Adventures (C model) - by Kuramapika1 - <LDD 4.3.11> 31076 - Daredevil Stunt Plane (A model) - by Kuramapika1 - <LDD 4.3.11> 31076 - Daredevil Stunt Plane (B model) - by Kuramapika1 - <LDD 4.3.11> 31076 - Daredevil Stunt Plane (C model) - by Kuramapika1 - <LDD 4.3.11> 31077 - Modular Sweet Surprises (A model) - by Kuramapika1 - <LDD 4.3.11> 31077 - Modular Sweet Surprises (B model) - by Kuramapika1 - <LDD 4.3.11> 31077 - Modular Sweet Surprises (C model) - by Kuramapika1 - <LDD 4.3.11> 31078 - Tree House Treasures (A model) - by Kuramapika1 - <LDD 4.3.11> 31078 - Tree House Treasures (B model) - by Kuramapika1 - <LDD 4.3.11> 31078 - Tree House Treasures (C model) - by Kuramapika1 - <LDD 4.3.11> 31079 - Sunshine Surfer Van - by Migui94 - <LDD 4.3.11> 31079 - Sunshine Surfer Van (B model) - by Migui94 - <LDD 4.3.11> - Comment: "Beach Buggy" 31079 - Sunshine Surfer Van (C model) - by Migui94 - <LDD 4.3.11> - Comment: "Lifeguard tower" 31086 - Futuristic Flyer (A model) - by Bod9nou - <LDD 4.3.11> 31086 - Futuristic Flyer (B model) - by Bod9nou - <LDD 4.3.11> 31086 - Futuristic Flyer (C model) - by Bod9nou - <LDD 4.3.11> 31088 - Deep Sea Creatures - by therealjustin - <LDD 4.3.11> 31088 - Deep Sea Creatures (B model) - by Kuramapika1 - <LDD 4.3.11> 31088 - Deep Sea Creatures (C model) - by Kuramapika1 - <LDD 4.3.11> 31088 - Deep Sea Creatures (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Web extra model 40019 - Brickley - by ok13 - <LDD 4> 40077 - Geoffrey - by Stephan - <LDD 4.3.6> 40078 - Hot Dog Stand [Promo] - by CM4S - <LDD 4.3.6> 40079 - Mini Volkswagen T1 Camper Van (VW Bus) - by Classicsmiley - <LDD 4.3.6> 40108 - Balloon Cart - by vean - <LDD 4.3.8> 40140 - Flower Cart polybag - by Stephan - <LDD 4.3.8> 40140 - Flower Cart polybag - by Gnac - <LDD 4.3.8> 40146 - Lufthansa Plane [Promo] - by Gnac - <LDD 4.3.8> 40146 - Lufthansa Plane [Promo] - by pbat - <LDD 4.3.8> 40207 - Year of the Monkey - by KamalMYafi - <LDD 4.3.9> 40220 - Mini London Bus - by Henni - <LDD 4.3.10> 40220 - Mini London Bus - by Pasq67 - <LDD 4.3.9> 40221 - Fountain - by KamalMYafi - <LDD 4.3.9> 40228 - Geoffrey & Friends - by KamalMYafi - <LDD 4.3.9> 40234 - Year of the Rooster - by KamalMYafi - <LDD 4.3.10> 40252 - Mini VW Beetle - by KamalMYafi - <LDD 4.3.10> 3300001 - Brickley - by ok13 - <LDD 4.3.5> 4016+4017+4018+4019 - Super Vehicle - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets Edited March 18, 2021 by Calabar Quote
Calabar Posted April 18, 2010 Author Posted April 18, 2010 (edited) Designer Sets 3223 - Little Fish (A model) - by moop2000 - <LDD 4> 3223 - Little Fish (B model) - by moop2000 - <LDD 4> 3223 - Little Fish (C model) - by moop2000 - <LDD 4> 4096 - Micro Wheels (A model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (B model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (C model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (D model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (E model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (F model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (G model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (H model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (I model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (J model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (K model) - by Gnac - <LDD 4.3.5> 4096 - Micro Wheels (L model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots - by Giovanne - <LDD 4> 4097 - Mini Robots (A model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (B model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (C model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (D model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (H model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (I model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (J model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (K model) - by Gnac - <LDD 4.3.5> 4097 - Mini Robots (L model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (A model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (B model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (C model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (D model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (E model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (F model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (G model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (H model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (I model) - by Gnac - <LDD 4.3.5> 4098 - High Flyers (J model) - by Gnac - <LDD 4.3.5> 4099 - Robobots (A model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (B model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (C model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (D model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (E model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (F model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (G model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (H model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (I model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (J model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (K model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (L model) - by Gnac - <LDD 4.3.6> 4099 - Robobots (M model) - by Gnac - <LDD 4.3.6> 4100 - Maximum Wheels (A model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (B model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (C model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (D model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (E model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (F model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (G model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (H model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (I model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (J model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (K model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (L model) - by Gnac - <LDD 4.3.5> 4100 - Maximum Wheels (M model) - by Gnac - <LDD 4.3.5> 4101 - Wild Collection (A model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (B model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (C model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (D model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (E model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (F model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (G model) - by Gnac - <LDD 4.3.8> 4101 - Wild Collection (G model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (I model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (J model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (K model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (L model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (M model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (N model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (O model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (P model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (Q model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (R model) - by BEAVeR - <LDD 4.3.6> 4101 - Wild Collection (S model) - by Gnac - <LDD 4.3.8> 4101 - Wild Collection (T model) - by Gnac - <LDD 4.3.8> 4401 - Little Creations (A model) - by Gnac - <LDD 4.3.5> 4401 - Little Creations (B model) - by Gnac - <LDD 4.3.5> 4401 - Little Creations (C model) - by Gnac - <LDD 4.3.5> 4401 - Little Creations (D model) - by Gnac - <LDD 4.3.5> 4401 - Little Creations (E model) - by Gnac - <LDD 4.3.5> 4401 - Little Creations (F model) - by Gnac - <LDD 4.3.5> 4401 - Little Creations (G model) - by Gnac - <LDD 4.3.5> 4402 - Sea riders (A model) - by marco9999 - <LDD 4> 4402 - Sea riders (B model) - by marco9999 - <LDD 4> 4402 - Sea riders (C model) - by marco9999 - <LDD 4> 4403 - Air Blazers (A model) - by Gnac - <LDD 4.3.5> 4403 - Air Blazers (B model) - by Gnac - <LDD 4.3.5> 4403 - Air Blazers (C model) - by Gnac - <LDD 4.3.5> 4404 - Land Busters (A model) - by Gnac - <LDD 4.3.8> 4404 - Land Busters (A model) - by Yoshi648 - <LDD 4> 4404 - Land Busters (B model) - by Gnac - <LDD 4.3.8> 4404 - Land Busters (C model) - by Gnac - <LDD 4.3.8> 4505 - Sea Machines (A model) - by Gnac - <LDD 4.3.5> 4505 - Sea Machines (B model) - by Gnac - <LDD 4.3.5> 4505 - Sea Machines (C model) - by Gnac - <LDD 4.3.5> 4505 - Sea Machines (D model) - by Gnac - <LDD 4.3.5> 4505 - Sea Machines (E model) - by Gnac - <LDD 4.3.5> 4505 - Sea Machines (F model) - by Gnac - <LDD 4.3.5> 4506 - Deep Sea Predators - by Randal - <LDD 3> 4507 - Prehistoric Creatures (A model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (B model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (C model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (D model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (E model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (F model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (G model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (H model) - by BEAVeR - <LDD 4.3.6> 4507 - Prehistoric Creatures (I model) - by BEAVeR - <LDD 4.3.6> 4508 - Titan XP (A model) - by Gnac - <LDD 4.3.5> 4508 - Titan XP (B model) - by Gnac - <LDD 4.3.5> 4508 - Titan XP (C model) - by Gnac - <LDD 4.3.5> 4508 - Titan XP (D model) - by Gnac - <LDD 4.3.5> 4881 - Robo Platoon - by marco9999 - <LDD 4> 4881 - Robo Platoon (A model) - by Gnac - <LDD 4.3.5> 4881 - Robo Platoon (B model) - by Gnac - <LDD 4.3.5> 4881 - Robo Platoon (C model) - by Gnac - <LDD 4.3.5> 4881 - Robo Platoon (D model) - by Gnac - <LDD 4.3.5> 4881 - Robo Platoon (E model) - by Gnac - <LDD 4.3.5> 4881 - Robo Platoon (F model) - by Gnac - <LDD 4.3.5> 4882 - Speed Wings (A model) - by marco9999 - <LDD 4> 4882 - Speed Wings (B model) - by marco9999 - <LDD 4> 4882 - Speed Wings (C model) - by marco9999 - <LDD 4> 4882 - Speed Wings (D model) - by marco9999 - <LDD 4> 4882 - Speed Wings (E model) - by marco9999 - <LDD 4> 4882 - Speed Wings (F model) - by marco9999 - <LDD 4> 4882 - Speed Wings (G model) - by marco9999 - <LDD 4> 4882 - Speed Wings (H model) - by marco9999 - <LDD 4> 4882 - Speed Wings (I model) - by marco9999 - <LDD 4> 4882 - Speed Wings (J model) - by marco9999 - <LDD 4> 4882 - Speed Wings (K model) - by marco9999 - <LDD 4> 4883 - Gear Grinders (A model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (B model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (C model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (D model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (E model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (F model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (G model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (H model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (I model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (J model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (K model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (L model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (M model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (N model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (O model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (P model) - by Gnac - <LDD 4.3.5> 4883 - Gear Grinders (Q model) - by Gnac - <LDD 4.3.5> 4884 - Wild Hunters - by -R8- - <LDD 3> 4886 - Building Bonanza (A model) - by Johnnhiszippy3 - <LDD 3> 4886 - Building Bonanza (B model) - by Sjuip - <LDD 4.3.5> 4886 - Building Bonanza (C model) - by Sjuip - <LDD 4.3.5> 4888 - Underwater Exploration (A model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (B model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (C model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (D model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (E model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (F model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (G model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (H model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (I model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (J model) - by P4trickvH - <LDD 4> 4888 - Underwater Exploration (K model) - by P4trickvH - <LDD 4> 4903 - Lion - by moop2000 - <LDD 4> 4904 - Elephant - by moop2000 - <LDD 4> 4905 - Giraffe - by moop2000 - <LDD 4> 7209 - Pteranodon [Promo] - by Gnac - <LDD 4.3.5> 7210 - Apatosaurus [Promo] - by Gnac - <LDD 4.3.5> 7210 - Apatosaurus polybag - by Happy SDE - <LDD 4.3.8> 7212 - Sky Squad (A model) - by marco9999 - <LDD 4> 7212 - Sky Squad (B model) - by marco9999 - <LDD 4> 7212 - Sky Squad (C model) - by marco9999 - <LDD 4> 7218 - Orange Speedboat polybag (A model) - by Happy SDE - <LDD 4.3.8> 7218 - Orange Speedboat polybag (B model) - by Happy SDE - <LDD 4.3.8> 7218 - Orange Speedboat polybag (C model) - by Happy SDE - <LDD 4.3.8> 7219 - Dinosaur [Promo] - by Gnac - <LDD 4.3.5> 7221 - Robots [Promo] (A model) - by Gnac - <LDD 4.3.5> 7221 - Robots [Promo] (B model) - by Gnac - <LDD 4.3.5> 7222 - Small Red Helicopter [Promo] (A model) - by Gnac - <LDD 4.3.5> 7222 - Small Red Helicopter [Promo] (B model) - by Gnac - <LDD 4.3.5> 7223 - Yellow Truck - ANA [Promo] (A model) - by Gnac - <LDD 4.3.5> 7223 - Yellow Truck (Box version) - ANA Promotion (A model) - by Happy SDE - <LDD 4.3.8> 7223 - Yellow Truck (Box version) - ANA Promotion (B model) - by Happy SDE - <LDD 4.3.8> 7223 - Yellow Truck - ANA [Promo] (B model) - by Gnac - <LDD 4.3.5> 7268 - Crab [Promo] - by Calabar - <LDD 4> 7269 - Scorpion [Promo] - by Calabar - <LDD 4> 7270 - Bird [Promo] - by Calabar - <LDD 4> 7910 - Robot Promotional (Duracell) [Promo] - by Gnac - <LDD 4.3.5> 7911 - Ship Promotional (Duracell) [Promo] - by Gnac - <LDD 4.3.5> 7912 - Helicopter Promotional (Duracell) [Promo] - by Gnac - <LDD 4.3.5> 7209+7210+7219 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Dimensions 71170 - Lego Dimensions Starter Pack - PS3 - by vean - <LDD 4.3.8> 71203 - Level Pack - Portal 2 (A model) - by PeabodySam - <LDD 4.3.10> - Comment: "Companion Cube" and "Sentry Turret" 71203 - Level Pack - Portal 2 (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Laser Deflector" and "Flying Turret Carrier" 71203 - Level Pack - Portal 2 (C model) - by PeabodySam - <LDD 4.3.10> - Comment: "Gold Heart Emitter" and "Turret Striker" Dino, Dino 2010, Dino Attack 5882 - Ambush Attack - by PeabodySam - <LDD 4.3.8> 5883 - Tower Takedown - by PeabodySam - <LDD 4.3.6> 5884 - Raptor Chase - by PeabodySam - <LDD 4.3.8> 5885 - Triceratops Trapper - by Tontus - <LDD 4> 5886 - T-Rex Hunter - by Tontus - <LDD 4> 5887 - Dino Defense HQ - by PeabodySam - <LDD 4.3.8> 5887 - Dino Defense HQ - by Megaloptus - <LDD 4> 5888 - Ocean Interceptor - by PeabodySam - <LDD 4.3.5> 7294 - Dino Quad - by PeabodySam - <LDD 4.3.5> 7295 - Dino Buggy Chaser - by PeabodySam - <LDD 4.3.8> 7296 - Dino 4WD Trapper - by Randal - <LDD 3> 7297 - Dino Track Transport - by PeabodySam - <LDD 4.3.8> 7298 - Dino Air Tracker - by PeabodySam - <LDD 4.3.8> 7473 - Steel Sprinter vs. Mutant Lizard - by prateek - <LDD 3> 7474 - Urban Avenger vs. Raptor - by PeabodySam - <LDD 4.3.8> 7475 - Fire Hammer vs. Mutant Lizards - by prateek - <LDD 3> 7476 - Iron Predator vs. T-Rex - by PeabodySam - <LDD 4.3.8> 7477 - T1 Typhoon vs. T-Rex - by L-DI-EGO - <LDD 4.3.6> 5884+5887 - Mobile Command Center - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets 7475+7476 - High Voltage Half-Track - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Dinosaurs 5953 - Baby Dimetrodon polybag - by Happy SDE - <LDD 4.3.8> 6719 - Brachiosaurus (A model) - by Aanchir - <LDD 4> 6719 - Brachiosaurus (B model) - by Aanchir - <LDD 4> 6719 - Brachiosaurus (C model) - by Aanchir - <LDD 4> 6719 - Brachiosaurus (D model) - by Aanchir - <LDD 4> 6720 - Tyrannosaurus Rex (A model) - by Aanchir - <LDD 4> 6720 - Tyrannosaurus Rex (B model) - by Aanchir - <LDD 4> 6720 - Tyrannosaurus Rex (C model) - by Aanchir - <LDD 4> 6720 - Tyrannosaurus Rex (D model) - by Aanchir - <LDD 4> 6721 - Mosasaurus (A model) - by Aanchir - <LDD 4> 6721 - Mosasaurus (B model) - by Aanchir - <LDD 4> 6721 - Mosasaurus (C model) - by Aanchir - <LDD 4> 6721 - Mosasaurus (D model) - by Aanchir - <LDD 4> 7000 - Baby Ankylosaurus - by Aanchir - <LDD 4> 7001 - Baby Iguanodon - by Aanchir - <LDD 4> 7002 - Baby Brachiosaurus - by Aanchir - <LDD 4> 7003 - Baby Dimetrodon - by Aanchir - <LDD 4> Discovery 7467 - International Space Station - by PsyKater - <LDD 4.3.5> 7468 - Saturn V Moon Mission - by prateek - <LDD 3> 7469 - Mission to Mars - by moop2000 - <LDD 4> 7470 - Space Shuttle Discovery - by BrickWild - <LDD 4.3.9> 7471 - Mars Exploration Rover - by Stephan - <LDD 4> 10029 - Lunar Lander - by yellost - <LDD 3> Disney 71040 - Disney Castle - by Stephan - <LDD 4.3.11> Disney Princess 30116 - Rapunzel's Market Visit polybag - by Stephan - <LDD 4.3.8> 41050 - Ariel's Amazing Treasures - by Stephan - <LDD 4.3.8> 41050 - Ariel's Amazing Treasures - by penguinz - <LDD 4.3.8> 41051 - Merida's Highland Games - by Stephan - <LDD 4.3.8> 41051 - Merida's Highland Games - by penguinz - <LDD 4.3.8> 41052 - Ariel's Magical Kiss - by penguinz - <LDD 4.3.8> 41052 - Ariel's Magical Kiss - by Stephan - <LDD 4.3.8> 41053 - Cinderella's Dream Carriage - by Stephan - <LDD 4.3.8> 41053 - Cinderella's Dream Carriage - by penguinz - <LDD 4.3.8> 41054 - Rapunzel's Creativity Tower - by penguinz - <LDD 4.3.8> 41054 - Rapunzel's Creativity Tower - by Stephan - <LDD 4.3.8> 41055 - Cinderella's Romantic Castle - by penguinz - <LDD 4.3.8> 41055 - Cinderella's Romantic Castle - by Stephan - <LDD 4.3.8> 41060 - Sleeping Beauty's Royal Bedroom - by Stephan - <LDD 4.3.8> 41061 - Jasmine's Exotic Palace - by Stephan - <LDD 4.3.8> 41062 - Elsa's Sparkling Ice Castle - by Stephan - <LDD 4.3.8> 41063 - Ariel's Undersea Palace - by Stephan - <LDD 4.3.8> Educational & Dacta 9311 - City Buildings Set - by ok13 - <LDD 4> 9324 - Micro Building Set - by AndyC - <LDD 4> 9688 - Renewable Energy Add-On Set - by BrickWild - <LDD 4> 45544 - EV3 Core Set (A model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Color Sorter" 45544 - EV3 Core Set (B model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Gyro Boy" 45544 - EV3 Core Set (C model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Puppy" 45544 - EV3 Core Set (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Robot Arm" 45544 - EV3 Core Set (E model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Web Driving Base" 45544+45560 - Elephant (A model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 45544+45560 - Remote Control (B model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 45544+45560 - Spinner Factory (C model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 45544+45560 - Stair Climber (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 45544+45560 - Tank Bot (E model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 45544+45560 - Znap (F model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Belt-driven Colour Sorter (A model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Classic Clock (B model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Grand Four Belt Rover (C model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Humanoid (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Robot Arm (E model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Scorpion (F model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Soundbot (G model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Tribot (H model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 9695+9797 - Intelligent Car (I model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets Elves 30259 - Azari's Magic Fire polybag - by Stephan - <LDD 4.3.8> 41071 - Aira's Creative Workshop - by Stephan - <LDD 4.3.8> 41072 - Naida's Spa Secret - by Stephan - <LDD 4.3.8> 41073 - Naida's Epic Adventure Ship - by Stephan - <LDD 4.3.8> 41074 - Azari and the Magical Bakery - by Stephan - <LDD 4.3.8> 41075 - The Elves' Treetop Hideaway - by Stephan - <LDD 4.3.8> 41076 - Farran and the Crystal Hollow - by Stephan - <LDD 4.3.8> Exo-Force 3870 - Red Walker - by Costy - <LDD 4> 3871 - White Flyer - by Costy - <LDD 4> 3872 - Robo Chopper - by Costy - <LDD 4> 3885 - Mini Jet Fighter - by Costy - <LDD 4> 3886 - Green Exo Fighter - by Costy - <LDD 4> 5965 - Silver Bad Guy - by Costy - <LDD 4> 5966 - White Good Guy - by Costy - <LDD 4> 5967 - Red Good Guy - by Costy - <LDD 4> 7700 - Stealth Hunter - by Costy - <LDD 4> 7701 - Grand Titan - by Costy - <LDD 4> 7702 - Thunder Fury - by marco9999 - <LDD 4.3.6> 7703 - Fire Vulture - by marco9999 - <LDD 4.3.6> 7704 - Sonic Phantom - by marco9999 - <LDD 4.3.6> 7705 - Gate Assault - by marco9999 - <LDD 4.3.6> 7706 - Mobile Defense Tank - by marco9999 - <LDD 4.3.6> 7707 - Striking Venom - by marco9999 - <LDD 4.3.6> 7708 - Uplink - by marco9999 - <LDD 4.3.6> 7709 - Sentai Fortress - by penguinz - <LDD 4.3.8> 7709 - Sentai Fortress - by marco9999 - <LDD 4.3.6> 7711 - Sentry - by prateek - <LDD 3> 7712 - Supernova - by Toa_Of_Justice - <LDD 4.3.8> 7713 - Bridge Walker vs. White Lightning - by marco9999 - <LDD 4.3.6> 7714 - Golden Guardian (Limited Gold Edition) - by marco9999 - <LDD 4.3.6> 7721 - Combat Crawler X2 - by marco9999 - <LDD 4.3.6> 8100 - Cyclone Defender - by Stephan - <LDD 4.3.8> 8100 - Cyclone Defender - by prateek - <LDD 3> 8101 - Claw Crusher - by marco9999 - <LDD 4.3.6> 8102 - Blade Titan - by Stephan - <LDD 4.3.8> 8102 - Blade Titan - by marco9999 - <LDD 4.3.6> 8103 - Sky Guardian - by marco9999 - <LDD 4.3.6> 8103 - Sky Guardian - by Stephan - <LDD 4.3.8> 8104 - Shadow Crawler - by marco9999 - <LDD 4.3.6> 8105 - Iron Condor - by marco9999 - <LDD 4.3.6> 8106 - Aero Booster - by marco9999 - <LDD 4.3.6> 8107 - Fight for the Golden Tower - by penguinz - <LDD 4.3.8> 8108 - Mobile Devastator - by marco9999 - <LDD 4.3.6> 8111 - River Dragon - by Aanchir - <LDD 4> 8112 - Battle Arachnoid - by Aanchir - <LDD 4> 8113 - Assault Tiger - by Aanchir - <LDD 4> 8114 - Chameleon Hunter - by Aanchir - <LDD 4> 8115 - Dark Panther - by SpiderSpaceman - <LDD 4> 8117 - Storm Lasher - by Aanchir - <LDD 4> 8118 - Hybrid Rescue Tank - by Aanchir - <LDD 4> 8100+8102+8103 - Sky Titan - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets Factory 5524 - Airport - by ADHO15 - <LDD 4> 5525 - Amusement Park - by ADHO15 - <LDD 4> 5526 - Skyline - by ADHO15 - <LDD 3> 10183 - Hobby Train (A model) - by AndyC - <LDD 4> 10183 - Hobby Train (AA model) - by AndyC - <LDD 4> 10183 - Hobby Train (AB model) - by AndyC - <LDD 4> 10183 - Hobby Train (AC model) - by AndyC - <LDD 4> 10183 - Hobby Train (AD model) - by AndyC - <LDD 4> 10183 - Hobby Train (B model) - by AndyC - <LDD 4> 10183 - Hobby Train (C model) - by AndyC - <LDD 4> 10183 - Hobby Train (D model) - by AndyC - <LDD 4> 10183 - Hobby Train (E model) - by AndyC - <LDD 4> 10183 - Hobby Train (F model) - by AndyC - <LDD 4> 10183 - Hobby Train (G model) - by AndyC - <LDD 4> 10183 - Hobby Train (H model) - by AndyC - <LDD 4> 10183 - Hobby Train (I model) - by AndyC - <LDD 4> 10183 - Hobby Train (J model) - by AndyC - <LDD 4> 10183 - Hobby Train (K model) - by AndyC - <LDD 4> 10183 - Hobby Train (L model) - by AndyC - <LDD 4> 10183 - Hobby Train (M model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (N model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (O model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (P model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (Q model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (R model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (S model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (T model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (U model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (V model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (W model) - by AndyC - <LDD 4.3.5> 10183 - Hobby Train (X model) - by AndyC - <LDD 4> 10183 - Hobby Train (Y model) - by AndyC - <LDD 4> 10183 - Hobby Train (Z model) - by AndyC - <LDD 4> 10191 - Star Justice - by PeabodySam - <LDD 4.3.6> 10192 - Space Skulls - by PeabodySam - <LDD 4.3.9> 10200 - Custom Car Garage - by yellost - <LDD 4> Friends 3061 - City Park Cafe - by penguinz - <LDD 4.3.8> 3061 - City Park Café - by bbqqq - <LDD 4.3.5> 3063 - Heartlake Flying Club - by penguinz - <LDD 4.3.8> 3065 - Olivia's Tree House - by penguinz - <LDD 4.3.8> 3183 - Stephanie's Cool Convertible - by Tontus - <LDD 4> 3183 - Stephanie's Cool Convertible - by penguinz - <LDD 4.3.8> 3184 - Adventure Camper - by prateek - <LDD 4.3.6> 3184 - Adventure Camper - by penguinz - <LDD 4.3.8> 3185 - Summer Riding Camp - by penguinz - <LDD 4.3.8> 3186 - Emma's Horse Trailer - by penguinz - <LDD 4.3.8> 3187 - Butterfly Beauty Shop - by penguinz - <LDD 4.3.8> 3188 - Heartlake Vet - by penguinz - <LDD 4.3.8> 3189 - Heartlake Stables - by penguinz - <LDD 4.3.8> 3315 - Olivia's House - by penguinz - <LDD 4.3.8> 3315 - Olivia's House - by PsyKater - <LDD 4> - [INCOMPLETE] - Comment: Minifigures and other parts missing 3930 - Stephanie's Outdoor Bakery - by Tontus - <LDD 4> 3931 - Emma's Splash Pool - by Tontus - <LDD 4> 3932 - Andrea's Stage - by Tontus - <LDD 4> 3933 - Olivia's Invention Workshop - by Tontus - <LDD 4> 3934 - Mia's Puppy House - by penguinz - <LDD 4.3.8> 3935 - Stephanie's Pet Patrol - by penguinz - <LDD 4.3.8> 3936 - Emma's Fashion Design Studio - by penguinz - <LDD 4.3.8> 3937 - Olivia's Speedboat - by penguinz - <LDD 4.3.8> 3938 - Andrea's Bunny House - by penguinz - <LDD 4.3.8> 3939 - Mia's Bedroom - by ok13 - <LDD 4> 3942 - Heartlake Dog Show - by penguinz - <LDD 4.3.8> 30103 - Car - by purpleparadox - <LDD 4> 30105 - Stephanie's Mailbox - by Tontus - <LDD 4> 30396 - Cupcake Stall polybag - by KamalMYafi - <LDD 4.3.9> 30398 - Adventure Camp Bridge polybag - by KamalMYafi - <LDD 4.3.10> 30399 - Bowling Alley polybag - by KamalMYafi - <LDD 4.3.10> 40080 - Pencil Holder, Friends - by Happy SDE - <LDD 4.3.8> 40112 - Model Catwalk - by Happy SDE - <LDD 4.3.8> 40114 - Buildable Jewellery Box - by Happy SDE - <LDD 4.3.8> 41000 - Water Scooter Fun - by penguinz - <LDD 4.3.8> 41001 - Mia's Magic Tricks - by penguinz - <LDD 4.3.8> 41002 - Emma's Karate Class - by penguinz - <LDD 4.3.8> 41003 - Olivia's Newborn Foal - by penguinz - <LDD 4.3.8> 41004 - Rehearsal Stage - by penguinz - <LDD 4.3.8> 41005 - Heartlake High - by penguinz - <LDD 4.3.8> 41006 - Downtown Bakery - by Classicsmiley - <LDD 4.3.6> 41007 - Heartlake Pet Salon - by penguinz - <LDD 4.3.8> 41008 - Heartlake City Pool - by penguinz - <LDD 4.3.8> 41009 - Andrea's Bedroom - by penguinz - <LDD 4.3.8> 41010 - Olivia's Beach Buggy - by penguinz - <LDD 4.3.8> 41011 - Stephanie's Soccer Practice - by penguinz - <LDD 4.3.8> 41013 - Emma's Sports Car - by penguinz - <LDD 4.3.8> 41015 - Dolphin Cruiser - by penguinz - <LDD 4.3.8> 41017 - Squirrel's Tree House - by penguinz - <LDD 4.3.8> 41018 - Cat's Playground - by penguinz - <LDD 4.3.8> 41019 - Turtle's Little Oasis - by penguinz - <LDD 4.3.8> 41020 - Hedgehog's Hideaway - by penguinz - <LDD 4.3.8> 41021 - Poodle's Little Palace - by penguinz - <LDD 4.3.8> 41021 - Poodle's Little Palace - by Yooha - <LDD 4.3.6> 41022 - Bunny's Hutch - by penguinz - <LDD 4.3.8> 41023 - Fawn's Forest - by penguinz - <LDD 4.3.8> 41024 - Parrot's Perch - by penguinz - <LDD 4.3.8> 41025 - Puppy's Playhouse - by penguinz - <LDD 4.3.8> 41025 - Puppy's Playhouse - by Yooha - <LDD 4.3.6> 41026 - Sunshine Harvest - by penguinz - <LDD 4.3.8> 41027 - Mia's Lemonade Stand - by penguinz - <LDD 4.3.8> 41028 - Emma's Lifeguard Post - by penguinz - <LDD 4.3.8> 41029 - Stephanie's New Born Lamb - by penguinz - <LDD 4.3.8> 41030 - Olivia's Ice Cream Bike - by penguinz - <LDD 4.3.8> 41031 - Andrea's Mountain Hut - by penguinz - <LDD 4.3.8> 41032 - First Aid Jungle Bike - by penguinz - <LDD 4.3.8> 41033 - Jungle Falls Rescue - by penguinz - <LDD 4.3.8> 41034 - Summer Caravan - by penguinz - <LDD 4.3.8> 41035 - Heartlake Juice Bar - by penguinz - <LDD 4.3.8> 41036 - Jungle Bridge Rescue - by penguinz - <LDD 4.3.8> 41037 - Stephanie's Beach House - by penguinz - <LDD 4.3.8> 41038 - Jungle Rescue Base - by penguinz - <LDD 4.3.8> 41039 - Sunshine Ranch - by penguinz - <LDD 4.3.8> 41041 - Turtle's Little Paradise - by penguinz - <LDD 4.3.8> 41041 - Turtle's Little Paradise (B model) - by Stephan - <LDD 4.3.8> 41042 - Tiger's Beautiful Temple - by penguinz - <LDD 4.3.8> 41042 - Tiger's Beautiful Temple (B model) - by Stephan - <LDD 4.3.8> 41043 - Penguin's Playground - by penguinz - <LDD 4.3.8> 41043 - Penguin's Playground (B model) - by Stephan - <LDD 4.3.8> 41044 - Macaw's Fountain - by penguinz - <LDD 4.3.8> 41045 - Orangutan's Banana Tree - by penguinz - <LDD 4.3.8> 41046 - Brown Bear's River - by penguinz - <LDD 4.3.8> 41048 - Lion Cub's Savannah - by Happy SDE - <LDD 4.3.8> 41056 - Heartlake News Van - by penguinz - <LDD 4.3.8> 41057 - Heartlake Horse Show - by penguinz - <LDD 4.3.8> 41058 - Heartlake Shopping Mall - by penguinz - <LDD 4.3.8> 41059 - Jungle Tree House - by penguinz - <LDD 4.3.8> 41088 - Puppy Training - by Happy SDE - <LDD 4.3.8> 41115 - Emma's Creative Workshop - by LegoPegasister2015 - <LDD 4.3.8> 41116 - Olivia's Exploration Car - by LegoPegasister2015 - <LDD 4.3.8> 41118 - Heartlake Supermarket - by LegoPegasister2015 - <LDD 4.3.8> 41119 - Heartlake Cupcake Caf+¿ (Cafe) - by LegoPegasister2015 - <LDD 4.3.8> 41129 - Amusement Park Hot Dog Van - by Withacee - <LDD 4.3.9> - [INCOMPLETE] - Comment: Minidolls missing 41308 - Stephanie's Friendship Cakes - by uchuujin - <LDD 4.3.11> 6043173 - Friends Promotional Set polybag - by Happy SDE - <LDD 4.3.8> 41041+41042+41043 - Animals Series 4 Combination Model - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets Games 3835 - Robo Champ - by marco9999 - <LDD 4> 3836 - Magikus - by Costy - <LDD 4.3.5> 3837 - Monster 4 - by Costy - <LDD 4.3.5> 3838 - Lava Dragon - by Costy - <LDD 4.3.5> 3839 - Race 3000 - by prateek - <LDD 3> 3840 - Pirate Code - by mzoli - <LDD 4.3.8> 3841 - Minotaurus - by mzoli - <LDD 4.3.8> 3842 - Lunar Command - by penguinz - <LDD 4> 3843 - Ramses Pyramid - by penguinz - <LDD 4> 3845 - Shave-A-Sheep - by BrickWild - <LDD 4> 3846 - UFO Attack - by Costy - <LDD 4.3.5> 3847 - Magma Monster - by Costy - <LDD 4.3.5> 3848 - Pirate Plank - by Costy - <LDD 4.3.5> 3849 - Orient Bazaar - by mzoli - <LDD 4.3.8> 3850 - Meteor Strike - by penguinz - <LDD 4.3.6> 3851 - Atlantis Treasure - by penguinz - <LDD 4> 3852 - Sunblock - by penguinz - <LDD 4> 3853 - Banana Tree Balance - by BrickWild - <LDD 4> 3854 - Frog Rush - by penguinz - <LDD 4.3.8> 3854 - Frog Rush - by BrickWild - <LDD 4> 3855 - Ramses Return - by penguinz - <LDD 4> 3856 - NinjaGo - by penguinz - <LDD 4> 3857 - Draida Bay - by Costy - <LDD 4.3.5> 3858 - Waldurk Forest - by Costy - <LDD 4.3.5> 3859 - Caverns of Nathuz - by Costy - <LDD 4.3.5> 3860 - Castle Fortaan - by Costy - <LDD 4.3.5> 3862 - Hogwarts - by penguinz - <LDD 4> 3863 - Kokoriko - by mzoli - <LDD 4.3.8> 3864 - Mini Taurus - by Costy - <LDD 4.3.5> 3865 - City Alarm - by penguinz - <LDD 4.3.6> 3866 - Star Wars: The Battle of Hoth - by ADHO15 - <LDD 4.3.5> 3868 - Phineas and Ferb - by Stephan - <LDD 4.3.6> 3874 - Ilrion - by Costy - <LDD 4.3.5> 3920 - The Hobbit: An Unexpected Journey - by ADHO15 - <LDD 4.3.5> 30170 - Ganrash - by Costy - <LDD 4.3.5> 40174 - Iconic Chess Set - by Bod9nou - <LDD 4.3.11> 50003 - Batman - by CM4S - <LDD 4.3.6> 50006 - Legends of Chima - by CM4S - <LDD 4.3.6> 852293 - Castle Giant Chess Set - by Aanchir - <LDD 4> Ghostbusters 75827 - Firehouse Headquarters - by Stephan - <LDD 4.3.11> 75828 - Ecto-1 & 2 - by KamalMYafi - <LDD 4.3.10> Harry Potter 4695 - MINI Knight Bus - by ADHO15 - <LDD 4> 4695 - MINI Knight Bus - by professor flitwick - <LDD 3> 4701 - Sorting Hat - by ADHO15 - <LDD 4> 4702 - The Final Challenge - by ADHO15 - <LDD 4> 4702 - The Final Challenge - by professor flitwick - <LDD 3> 4704 - The Chamber Of The Flying Keys - by ADHO15 - <LDD 4> 4704 - The Room of the Winged Keys - by professor flitwick - <LDD 3> 4705 - Snape's Class - by ADHO15 - <LDD 4> 4706 - Forbidden Corridor - by ADHO15 - <LDD 4> 4706 - Forbidden Corridor (B model) - by PeabodySam - <LDD 4.3.9> 4706 - Forbidden Corridor (C model) - by PeabodySam - <LDD 4.3.9> 4706 - Forbidden Corridor (D model) - by PeabodySam - <LDD 4.3.9> 4707 - Hagrid's Hut - by ADHO15 - <LDD 4> 4707 - Hagrid's Hut (B model) - by PeabodySam - <LDD 4.3.9> 4707 - Hagrid's Hut (C model) - by PeabodySam - <LDD 4.3.9> 4707 - Hagrid's Hut (D model) - by PeabodySam - <LDD 4.3.9> 4707 - Hagrid's Hut (E model) - by PeabodySam - <LDD 4.3.9> 4708 - Hogwarts Express - by ADHO15 - <LDD 4> 4708 - Hogwarts Express (B model) - by PeabodySam - <LDD 4.3.9> 4708 - Hogwarts Express (C model) - by PeabodySam - <LDD 4.3.9> 4708 - Hogwarts Express (D model) - by PeabodySam - <LDD 4.3.9> 4708 - Hogwarts Express (E model) - by PeabodySam - <LDD 4.3.9> 4709 - Hogwarts Castle - by ADHO15 - <LDD 4> 4709 - Hogwarts Castle (B model) - by PeabodySam - <LDD 4.3.9> 4709 - Hogwarts Castle (C model) - by PeabodySam - <LDD 4.3.9> 4709 - Hogwarts Castle (D model) - by PeabodySam - <LDD 4.3.9> 4711 - Flying Lesson - by professor flitwick - <LDD 3> 4711 - Flying Lesson - by ADHO15 - <LDD 4> 4712 - Troll On The Loose - by ADHO15 - <LDD 4> 4714 - Gringott's Bank - by ADHO15 - <LDD 4> 4714 - Gringott's Bank (B model) - by PeabodySam - <LDD 4.3.9> 4714 - Gringott's Bank (C model) - by PeabodySam - <LDD 4.3.9> 4714 - Gringott's Bank (D model) - by PeabodySam - <LDD 4.3.9> 4714 - Gringott's Bank (E model) - by PeabodySam - <LDD 4.3.9> 4719 - Quality Quidditch Supplies - by ADHO15 - <LDD 4> 4720 - Knockturn Alley - by ADHO15 - <LDD 4> 4721 - Hogwarts Classroom - by ADHO15 - <LDD 4> 4721 - Hogwarts Classroom - by professor flitwick - <LDD 4> 4722 - Gryffindor - by ADHO15 - <LDD 4> 4723 - Diagon Alley Shops - by ADHO15 - <LDD 4> 4726 - Quidditch Practice - by ADHO15 - <LDD 4> 4726 - Quidditch Practice - by professor flitwick - <LDD 3> 4727 - Aragog In The Dark Forest - by ADHO15 - <LDD 4> 4728 - Escape from Privet Drive - by ADHO15 - <LDD 4> 4728 - Escape from Privet Drive - by professor flitwick - <LDD 3> 4728 - Escape from Privet Drive (B model) - by PeabodySam - <LDD 4.3.9> 4728 - Escape from Privet Drive (C model) - by PeabodySam - <LDD 4.3.9> 4728 - Escape from Privet Drive (D model) - by PeabodySam - <LDD 4.3.9> 4729 - Dumbledore's Office - by ADHO15 - <LDD 4> 4729 - Dumbledore's Office (B model) - by PeabodySam - <LDD 4.3.9> 4729 - Dumbledore's Office (C model) - by PeabodySam - <LDD 4.3.9> 4729 - Dumbledore's Office (D model) - by PeabodySam - <LDD 4.3.9> 4730 - Chamber Of Secrets - by ADHO15 - <LDD 4> 4730 - Chamber of Secrets (B model) - by PeabodySam - <LDD 4.3.9> 4730 - Chamber of Secrets (C model) - by PeabodySam - <LDD 4.3.9> 4730 - Chamber of Secrets (D model) - by PeabodySam - <LDD 4.3.9> 4731 - Dobby's Release - by ADHO15 - <LDD 4> 4731 - Dobby's Release - by professor flitwick - <LDD 3> 4733 - The Dueling Club - by ADHO15 - <LDD 4> 4733 - The Dueling Club - by professor flitwick - <LDD 3> 4735 - Slytherin - by ADHO15 - <LDD 4> 4736 - Freeing Dobby - by ADHO15 - <LDD 4> 4737 - Quidditch Match - by ADHO15 - <LDD 4> 4738 - Hagrid's Hut - by ADHO15 - <LDD 4> 4750 - Draco's Encounter With Buckbeak - by ADHO15 - <LDD 4> 4751 - Harry and the Marauder's Map - by ADHO15 - <LDD 4> 4751 - Harry and the Marauder's Map - by professor flitwick - <LDD 3> 4752 - Professor Lupin's Classroom - by ADHO15 - <LDD 4> 4753 - Sirius Black's Escape - by ADHO15 - <LDD 4> 4754 - Hagrids Hut - by ADHO15 - <LDD 4> 4755 - Knight Bus - by ADHO15 - <LDD 4> 4755 - Knight Bus - by professor flitwick - <LDD 3> 4756 - Shrieking Shack - by ADHO15 - <LDD 4> 4757 - Hogwarts Castle - by ADHO15 - <LDD 4> 4758 - Hogwarts Express - by ADHO15 - <LDD 4> 4762 - Rescue From The Merpeople - by ADHO15 - <LDD 4> 4766 - Graveyard Duel - by ADHO15 - <LDD 4> 4767 - Harry And The Hungarian Horntail - by ADHO15 - <LDD 4> 4768 - The Dumstrang Ship - by ADHO15 - <LDD 4.3.5> - [INCOMPLETE] - Comment: Exists a version with 4 bonus minifigures - Hull missing 4840 - The Burrow (A model) - by ADHO15 - <LDD 4> 4840 - The Burrow (B model) - by ADHO15 - <LDD 4> 4841 - Hogwarts Express (3rd edition) - by ADHO15 - <LDD 4> 4842 - Hogwarts Castle (4th edition) - by ADHO15 - <LDD 4> 4865 - The Forbidden Forest - by ADHO15 - <LDD 4> 4866 - The Knight Bus - by ADHO15 - <LDD 4> 4867 - Hogwarts - by ADHO15 - <LDD 4> 5378 - Hogwarts Castle - by ADHO15 - <LDD 4> 5378 - Hogwarts Castle - by Aanchir - <LDD 3> 10132 - Motorized Hogwarts Express - by ADHO15 - <LDD 4> 10217 - Diagon Alley - by ADHO15 - <LDD 4> 10217 - Diagon Alley - by AndyC - <LDD 4> 30110 - Trolley - by ADHO15 - <LDD 4> 30111 - The Lab - by ADHO15 - <LDD 4> 30407 - Harry's Journey to Hogwarts polybag - by PicnicBasketSam - <LDD 4.3.11> 40028 - Mini Hogwarts Express polybag - by Happy SDE - <LDD 4.3.8> 71043 - Hogwarts Castle - by Bod9nou - <LDD 4.3.11> 75950 - Aragog's Lair - by PicnicBasketSam - <LDD 4.3.11> 75951 - Grindelwald's Escape - by PicnicBasketSam - <LDD 4.3.11> 75952 - Newt's Case of Magical Creatures - by PicnicBasketSam - <LDD 4.3.11> 75953 - Hogwarts Whomping Willow - by PicnicBasketSam - <LDD 4.3.11> 75954 - Hogwarts Great Hall - by PicnicBasketSam - <LDD 4.3.11> 75955 - Hogwarts Express - by PicnicBasketSam - <LDD 4.3.11> 75956 - Quidditch Match - by PicnicBasketSam - <LDD 4.3.11> 75968 - 4 Privet Drive - by X-79 - <LDD 4.3.11> - [INCOMPLETE] - Comment: Building only Hero Factory 2063 - Stormer 2.0 - by Toa_Of_Justice - <LDD 4> 2065 - Furno 2.0 - by Toa_Of_Justice - <LDD 4> 2067 - Evo 2.0 - by Toa_Of_Justice - <LDD 4> 2068 - Nex 2.0 - by Toa_Of_Justice - <LDD 4> 2141 - Surge 2.0 - by Toa_Of_Justice - <LDD 4> 2142 - Breez 2.0 - by Toa_Of_Justice - <LDD 4> 2143 - Rocka 3.0 - by Toa_Of_Justice - <LDD 4> 2144 - Nex 3.0 - by Toa_Of_Justice - <LDD 4> 2145 - Stormer 3.0 - by Toa_Of_Justice - <LDD 4> 2182 - Bulk 3.0 - by Toa_Of_Justice - <LDD 4> 2183 - Stringer 3.0 - by Toa_Of_Justice - <LDD 4> 2191 - Furno 3.0 - by Toa_Of_Justice - <LDD 4> 2192 - Drilldozer - by Toa_Of_Justice - <LDD 4> 2193 - Jetbug - by Toa_Of_Justice - <LDD 4> 2194 - Nitroblast - by Toa_Of_Justice - <LDD 4> 2231 - Waspix - by Kuramapika1 - <LDD 4.3.11> 2232 - Raw Jaw - by Toa_Of_Justice - <LDD 4> 2233 - Fangz - by Toa_Of_Justice - <LDD 4> 2235 - Fire Lord - by Toa_Of_Justice - <LDD 4> 2236 - Scorpio - by bacem - <LDD 4.3.6> 2282 - Rocka XL - by Toa_Of_Justice - <LDD 4> 2283 - Witch Doctor - by ArmstrongYong - <LDD 4.3.8> 6200 - Evo - by Toa_Of_Justice - <LDD 4> 6201 - Toxic Reapa - by Toa_Of_Justice - <LDD 4.3.5> 6202 - Rocka - by Toa_Of_Justice - <LDD 4.3.5> 6203 - Black Phantom - by Masta' Blasta' - <LDD 4> - [INCOMPLETE] - Comment: many pieces missing in LDD 6203 - Black Phantom - by ArmstrongYong - <LDD 4.3.8> 6216 - Jawblade - by Toa_Of_Justice - <LDD 4.3.5> 6217 - Surge - by King of Nynrah - <LDD 4> 6217 - Surge - by Toa_Of_Justice - <LDD 4.3.5> 6218 - Splitface - by Kuramapika1 - <LDD 4.3.11> 6221 - Nex - by ArmstrongYong - <LDD 4.3.8> 6222 - Core Hunter - by Kuramapika1 - <LDD 4.3.11> 6223 - Bulk - by Kuramapika1 - <LDD 4.3.11> 6227 - Breez - by Toa_Of_Justice - <LDD 4.3.5> 6228 - Thornraxx - by Kuramapika1 - <LDD 4.3.11> 6229 - XT4 - by ArmstrongYong - <LDD 4.3.8> 6230 - Stormer XL - by Classicsmiley - <LDD 4.3.6> 6231 - Speeda Demon - by Toa_Of_Justice - <LDD 4.3.6> 6282 - Stringer - by Kuramapika1 - <LDD 4.3.11> 6283 - Voltix - by Kuramapika1 - <LDD 4.3.11> 6293 - Furno - by Toa_Of_Justice - <LDD 4.3.5> 7145 - Von Nebula - by Kuramapika1 - <LDD 4.3.11> 7147 - Xplode - by King of Nynrah - <LDD 4> - [INCOMPLETE] - Comment: Lots of missing parts 7147 - Xplode - by Kuramapika1 - <LDD 4.3.11> 7148 - Meltdown - by Kuramapika1 - <LDD 4.3.11> 7156 - Corroder - by ArmstrongYong - <LDD 4.3.8> 7157 - Thunder - by ArmstrongYong - <LDD 4.3.8> 7158 - Furno Bike - by Kuramapika1 - <LDD 4.3.11> 7158 - Furno Bike - by Aanchir - <LDD 4> 7160 - Drop Ship - by Aanchir - <LDD 4> 7160 - Drop Ship - by Kuramapika1 - <LDD 4.3.11> 7162 - Rotor - by Kuramapika1 - <LDD 4.3.11> 7162 - Rotor - by ArmstrongYong - <LDD 4.3.8> 7164 - Preston Stormer - by Toa_Of_Justice - <LDD 4.3.6> 7165 - Natalie Breez - by ArmstrongYong - <LDD 4.3.8> 7165 - Natalie Breez - by Costy - <LDD 4.3.6> 7167 - William Furno - by Toa_Of_Justice - <LDD 4> 7168 - Dunkan Bulk - by Kuramapika1 - <LDD 4.3.11> 7169 - Mark Surge - by ArmstrongYong - <LDD 4.3.8> 7169 - Mark Surge - by Toa_Of_Justice - <LDD 4> 7170 - Jimi Stringer - by ArmstrongYong - <LDD 4.3.8> 7179 - Dunkan Bulk and Vapour - by Kuramapika1 - <LDD 4.3.11> 40116 - Invasion from Below polybag - by TheOneVeyronian - <LDD 4.3.8> 40117 - Villains Minimodel polybag - by TheOneVeyronian - <LDD 4.3.8> 44000 - Furno XL - by bacem - <LDD 4.3.6> 44001 - Pyrox - by Kuramapika1 - <LDD 4.3.11> 44002 - Rocka - by Kuramapika1 - <LDD 4.3.11> 44003 - Scarox - by bacem - <LDD 4.3.6> 44004 - Bulk - by Kuramapika1 - <LDD 4.3.11> 44005 - Bruizer - by Kuramapika1 - <LDD 4.3.11> 44006 - Breez - by bacem - <LDD 4.3.6> 44007 - Ogrum - by bacem - <LDD 4.3.6> 44008 - Surge - by Kuramapika1 - <LDD 4.3.11> 44009 - Dragon Bolt - by SpiderBoy05 - <LDD 4.3.10> 44010 - Stormer - by Kuramapika1 - <LDD 4.3.11> 44011 - Frost Beast - by Kuramapika1 - <LDD 4.3.11> 44012 - Evo - by Kuramapika1 - <LDD 4.3.11> 44013 - Aquagon - by Kuramapika1 - <LDD 4.3.11> 44014 - Jet Rocka - by Kuramapika1 - <LDD 4.3.11> 44015 - EVO Walker - by TheOneVeyronian - <LDD 4.3.8> 44016 - JAW Beast vs. STORMER - by TheOneVeyronian - <LDD 4.3.8> 44017 - STORMER Freeze Machine - by ArmstrongYong - <LDD 4.3.8> 44019 - ROCKA Stealth Machine - by ArmstrongYong - <LDD 4.3.8> 44020 - FLYER Beast vs. BREEZ - by ArmstrongYong - <LDD 4.3.8> 44022 - EVO XL Machine - by TheOneVeyronian - <LDD 4.3.8> 44023 - ROCKA Crawler - by TheOneVeyronian - <LDD 4.3.8> 44024 - TUNNELER Beast vs. SURGE - by TheOneVeyronian - <LDD 4.3.8> 44029 - QUEEN Beast vs. FURNO, EVO & STORMER - by TheOneVeyronian - <LDD 4.3.8> 2063+2142 - Stormer 2.0 + Breeze 2.0 - by Kuramapika1 - <LDD 4.3.11> 2065+2067 - Furno 2.0 + Evo 2.0 - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 2068+2141 - Nex 2.0 + Surge 2.0 - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 2143+2145 - Rocka 3.0 + Stormer 3.0 - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 2144+2183 - Nex 3.0 + STRINGER 3.0 - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 2182+2191 - Bulk 3.0 + Furno 3.0 - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44000+44001 - Furno XL+Pyrox - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44002+44003 - Rocka+Scarox - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44004+44005 - Bulk+Bruizer - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44006+44007 - Breez+Ogrum - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44008+44009 - Surge+Dragon Bolt - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44010+44011 - Stormer+Frost Beast - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 44012+44013 - Evo+Aquagon - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6200+6201 - Evo+Toxic Reapa - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6202+6203 - Rocka+Black Phantom - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6216+6293 - Jawblade+Furno - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6217+6218 - Surge+Splitface - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6221+6229 - Nex+XT4 - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6222+6223 - Core Hunter+Bulk - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6227+6228 - Breez+Thornraxx - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6230+6231 - Stormer XL+Speeda Demon - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 6282+6283 - Stringer+Voltix - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets Hobby Sets 390 - 1913 Cadillac - by Stephan - <LDD 4> 391 - 1926 Renault - by Stephan - <LDD 4.3.8> 392 - Formula 1 - by Stephan - <LDD 4> 392 - Formula 1 - by marco9999 - <LDD 4> 393 - Norton Motorcycle - by Stephan - <LDD 4> 394 - Harley-Davidson 1000cc - by Stephan - <LDD 4> 395 - 1909 Rolls-Royce - by Stephan - <LDD 4> 396 - Thatcher Perkins Locomotive - by Stephan - <LDD 4.3.8> 398 - U.S.S. Constellation - by Stephan - <LDD 4> - Comment: aka 10021 10021 - U.S.S. Constellation - by marco9999 - <LDD 4> - Comment: aka 398 10021 - U.S.S. Constellation - by Stephan - <LDD 4> - Comment: aka 398 Holiday 1129 - Santa on Reindeer - by Happy SDE - <LDD 4.3.8> 1177 - Santa's Truck - by buddy - <LDD 4> 1264 - Easter Chicks - Milka Promotional - by Happy SDE - <LDD 4.3.8> 1555 - Santa Claus [Seasonal] - by AndyC - <LDD 4> 1625 - Snowman [Seasonal] - by AndyC - <LDD 4> 1626 - Angel [Seasonal] - by AndyC - <LDD 4> - Comment: aka 10080 1627 - Santa [Seasonal] - by AndyC - <LDD 4> 3316 - Advent Calender 2012, Friends - by penguinz - <LDD 4.3.8> 3731 - Pumpkin Pack polybag - by PeabodySam - <LDD 4.3.10> 4759 - Three Christmas Decorations - Santa, Tree and Snowman [Seasonal] - by legolijntje - <LDD 4> 7220 - Snowman - by Gnac - <LDD 4.3.5> 7224 - 2003 Christmas Promotional Set - by Gnac - <LDD 4.3.5> 7224 - 2003 Christmas Promotional Set polybag - by Happy SDE - <LDD 4.3.8> 7907 - Advent Calendar 2007, City - by Inferno986return - <LDD 4.3.10> 7958 - Advent Calendar 2011 - by Lego Otaku - <LDD 4> 9509 - Advent Calendar 2012, Star Wars - by BEAVeR - <LDD 4.3.8> 10042 - USA Flag - by Lego Otaku - <LDD 4> 10068 - Santa [Seasonal] - by Sjuip - <LDD 4> 10069 - Tree [Seasonal] - by Sjuip - <LDD 4.3.5> 10070 - Reindeer [Seasonal] - by Sjuip - <LDD 4.3.5> 10071 - Mr Bunny - by Lego Otaku - <LDD 4> 10079 - Snowman [Seasonal] - by Sjuip - <LDD 4.3.5> - Comment: aka 1979 10080 - Angel [Seasonal] - by Sjuip - <LDD 4.3.5> - Comment: aka 1626 10090 - Turkey - by Lego Otaku - <LDD 4> 10106 - Snowflake - by Gnac - <LDD 4.3.5> 10165 - Elf Boy [Seasonal] - by Sjuip - <LDD 4.3.5> 10166 - Elf Girl [Seasonal] - by Sjuip - <LDD 4.3.5> 10168 - Mrs Bunny - by Lego Otaku - <LDD 4> 10169 - Chickens and Chicks - by Lego Otaku - <LDD 4> 10199 - Winter Toy Shop - by prateek - <LDD 3> 10199 - Winter Toy Shop - by yellost - <LDD 3> 10216 - Winter Village Bakery - by yellost - <LDD 3> 10222 - Winter Village Post Office - by Graysmith - <LDD 4.3.5> 10229 - Winter Village Cottage - by Sjuip - <LDD 4.3.8> 10235 - Winter Village Market - by Sjuip - <LDD 4.3.9> 10245 - Santa's Workshop - by ADHO15 - <LDD 4.3.8> 10249 - Winter Toy Shop - by Migui94 - <LDD 4.3.10> 10259 - Winter Village Station - by Stephan - <LDD 4.3.11> 10259 - Winter Village Station - by Migui94 - <LDD 4.3.11> 10263 - Winter Village Fire Station - by Migui94 - <LDD 4.3.11> 30008 - Snowman - by Gnac - <LDD 4.3.5> 30009 - Christmas Tree - by Gnac - <LDD 4.3.5> 30028 - Wreath [Promo] - by Gnac - <LDD 4.3.5> 30182 - Santa - by Gnac - <LDD 4.3.5> 30197 - Snowman [Promo] - by Gnac - <LDD 4.3.8> 30286 - Christmas Tree - by Gnac - <LDD 4.3.8> 40000 - Santa Claus in the Snow - by Happy SDE - <LDD 4.3.8> 40001 - Santa Claus polybag - by Happy SDE - <LDD 4.3.8> 40002 - Christmas Tree polybag - by Happy SDE - <LDD 4.3.8> 40003 - Snowman polybag - by Happy SDE - <LDD 4.3.8> 40004 - Heart 2010 polybag - by Happy SDE - <LDD 4.3.8> 40005 - Bunny - by Happy SDE - <LDD 4.3.8> 40008 - Snowman Building Set polybag - by Happy SDE - <LDD 4.3.8> 40009 - Holiday Building Set polybag - by Happy SDE - <LDD 4.3.8> 40010 - Santa with Sleigh Building Set polybag - by Happy SDE - <LDD 4.3.8> 40011 - Thanksgiving Turkey - by Sjuip - <LDD 4.3.5> 40012 - halloween pumpkin [Seasonal] - by legolijntje - <LDD 4> 40013 - halloween ghost [Seasonal] - by legolijntje - <LDD 4> 40014 - halloween bat [Seasonal] - by legolijntje - <LDD 4> 40015 - Heart Book polybag - by Happy SDE - <LDD 4.3.8> 40016 - Valentine Letter Set polybag - by Happy SDE - <LDD 4.3.8> 40017 - Easter Basket polybag - by Happy SDE - <LDD 4.3.8> 40018 - Easter Bunny with Eggs polybag - by Happy SDE - <LDD 4.3.8> 40020 - Halloween Set - by Gnac - <LDD 4.3.6> 40021 - Spiders Set - by Gnac - <LDD 4.3.6> 40022 - Mini Santa Set polybag - by Happy SDE - <LDD 4.3.8> 40023 - Holiday Stocking polybag - by Happy SDE - <LDD 4.3.8> 40024 - Christmas Tree - by Gnac - <LDD 4.3.6> 40029 - Heart 2012 polybag - by Happy SDE - <LDD 4.3.8> 40030 - Duck with Ducklings polybag - by Happy SDE - <LDD 4.3.8> 40031 - Bunny and Chick - by Costy - <LDD 4.3.5> 40032 - Witch polybag - by Happy SDE - <LDD 4.3.8> 40033 - Turkey polybag - by Happy SDE - <LDD 4.3.8> 40034 - Christmas Train [Promo] - by Gnac - <LDD 4.3.5> 40035 - Rocking Horse [Promo] - by Gnac - <LDD 4.3.5> 40048 - Birthday Cake - by Costy - <LDD 4> 40051 - Valentine's Day Heart Box - by Stephan - <LDD 4.3.5> 40052 - Springtime Scene - by Stephan - <LDD 4.3.5> 40053 - Easter Bunny with Basket - by Stephan - <LDD 4.3.5> 40054 - Summer Scene - by Stephan - <LDD 4.3.5> 40055 - Pumpkin - by pbat - <LDD 4.3.6> 40057 - Fall Scene - by vean - <LDD 4.3.6> 40058 - Decorating the Tree - by Gnac - <LDD 4.3.6> 40059 - Santa's Sleigh - by Gnac - <LDD 4.3.6> 40082 - Christmas Tree Market - by Gnac - <LDD 4.3.6> 40083 - Christmas Tree Delivery Truck - by Gnac - <LDD 4.3.6> 40085 - {Valentines Teddy Bear} - by Stephan - <LDD 4.3.8> 40086 - LEGO Easter - by vean - <LDD 4.3.8> 40090 - Halloween Bat - by Gnac - <LDD 4.3.8> 40091 - Thanksgiving Turkey - by Gnac - <LDD 4.3.8> 40092 - Reindeer - by Gnac - <LDD 4.3.8> 40093 - Snowman - by Gnac - <LDD 4.3.8> 40106 - Toy Workshop - Limited Edition 2014 Holiday Set (1 of 2) - by Gnac - <LDD 4.3.8> 40107 - Ice Skating - Limited Edition 2014 Holiday Set (2 of 2) - by Gnac - <LDD 4.3.8> 40120 - Valentine's Day Dinner - by Gnac - <LDD 4.3.8> 40121 - Painting Easter Eggs - by Gnac - <LDD 4.3.9> 40122 - Trick or Treat - by Gnac - <LDD 4.3.8> 40123 - Thanksgiving Feast - by Gnac - <LDD 4.3.8> 40124 - Winter Fun - by Gnac - <LDD 4.3.8> 40125 - Santa's Visit - by Gnac - <LDD 4.3.9> 40138 - Candy Cane Train - by Gnac - <LDD 4.3.9> 40139 - Gingerbread House - by Gnac - <LDD 4.3.9> 40148 - Year of the Sheep - by Gnac - <LDD 4.3.8> 40153 - Birthday Table Decoration - by Calabar - <LDD 4.3.8> 40201 - Valentine's Cupid Dog - by KamalMYafi - <LDD 4.3.9> 40202 - Easter Chick - by KamalMYafi - <LDD 4.3.9> 40203 - Vampire and Bat - by KamalMYafi - <LDD 4.3.9> 40204 - Pilgrim's Feast - by KamalMYafi - <LDD 4.3.10> 40205 - Little Elf Helpers - by noppin - <LDD 4.3.10> 40206 - Santa - by noppin - <LDD 4.3.10> 40223 - Snowglobe - by noppin - <LDD 4.3.10> 40226 - Birthday Buddy - by KamalMYafi - <LDD 4.3.10> 60024 - Advent Calendar 2013, City - by Happy SDE - <LDD 4.3.10> 60155 - Advent Calendar 2017, City - by Migui94 - <LDD 4.3.11> 75023 - Advent Calendar 2013, Star Wars - by BEAVeR - <LDD 4.3.8> 75056 - Advent Calendar 2014, Star Wars - by Happy SDE - <LDD 4.3.8> 75184 - Advent Calendar 2017, Star Wars - by Migui94 - <LDD 4.3.10> 3300002 - 2011 Holiday Set 2 [Seasonal] - by ADHO15 - <LDD 4> 3300014 - Limited Edition 2012 Holiday Set - by Stephan - <LDD 4.3.8> 3300020 - 2011 Holiday Set 1 [Seasonal] - by ADHO15 - <LDD 4> 4000013 - A Lego Christmas Tale - by Lego Otaku - <LDD 4.3.8> 4659758 - Target Gift Promotion - by Tontus - <LDD 4> 3731+3731 - 3-D Pumpkin - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets Holiday & Event 30550 - Easter Bunny polybag - by vean - <LDD 4.3.11> 40371 - Easter Egg - by vean - <LDD 4.3.11> 75213 - Advent Calendar 2018, Star Wars - by Kuramapika1 - <LDD 4.3.11> 80101 - Chinese New Year's Eve Dinner - by vean - <LDD 4.3.11> 80102 - Dragon Dance - by vean - <LDD 4.3.11> Homemaker 230 - Hairdressing Salon - by vean - <LDD 4.3.8> 231 - Hospital - by vean - <LDD 4.3.8> 232 - Bungalow - by vean - <LDD 4.3.8> 260 - Dolls Living Room - by Stephan - <LDD 4> 261 - Complete Kitchen Set - by vean - <LDD 4.3.8> Idea Book 697 - AquaPod - by Toa_Of_Justice - <LDD 4> - Comment: an official LEGO Idea Book, #697 n/a - Red Factory - by Johan J - <LDD 4.3.5> - [INCOMPLETE] - Comment: Idea Book #226, pag 37 Indiana Jones 7195 - Ambush in Cairo - by ADHO15 - <LDD 4.3.6> 7195 - Ambush in Cairo - by prateek - <LDD 3> 7196 - Chauchilla Cemetery Battle - by prateek - <LDD 4> 7196 - Chauchilla Cemetery Battle - by ADHO15 - <LDD 4.3.6> 7197 - Venice Canal Chase - by penguinz - <LDD 4.3.8> 7197 - Venice Canal Chase - by ADHO15 - <LDD 4.3.6> 7198 - Fighter Plane Attack - by prateek - <LDD 3> 7198 - Fighter Plane Attack - by ADHO15 - <LDD 4.3.6> 7199 - Temple of Doom - by ADHO15 - <LDD 4.3.6> 7199 - Temple of Doom - by penguinz - <LDD 4.3.8> 7620 - Motorcycle Chase - by ADHO15 - <LDD 4.3.6> 7620 - Indiana Jones Motorcycle Chase - by prateek - <LDD 3> 7621 - Indiana Jones and the Lost Tomb - by prateek - <LDD 3> 7621 - Lost Tomb - by ADHO15 - <LDD 4.3.6> 7622 - Race for the Stolen Treasure - by prateek - <LDD 3> 7622 - Race for the Stolen Treasure - by ADHO15 - <LDD 4.3.6> 7623 - Temple Escape - by ILikePi - <LDD 4> 7623 - Temple Escape - by ADHO15 - <LDD 4.3.6> 7624 - Jungle Duel - by ADHO15 - <LDD 4.3.6> 7625 - River Chase - by prateek - <LDD 3> 7625 - River Chase - by ADHO15 - <LDD 4.3.6> 7626 - Jungle Cutter - by ADHO15 - <LDD 4.3.6> 7627 - Temple of the Crystal Skull - by ADHO15 - <LDD 4.3.6> 7627 - Temple of the Crystal Skull - by penguinz - <LDD 4.3.8> 7628 - Peril in Peru - by prateek - <LDD 3> 7628 - Peril in Peru - by ADHO15 - <LDD 4.3.6> 7682 - Shanghai Chase - by ADHO15 - <LDD 4.3.6> 7682 - Shanghai Chase - by prateek - <LDD 3> 7683 - Fight on the Flying Wing - by penguinz - <LDD 4.3.8> 7683 - Fight on the Flying Wing - by ADHO15 - <LDD 4.3.6> 7683 - Fight on the Flying Wing - by AndyC - <LDD 4> 20004 - Jeep - by Aanchir - <LDD 4> 20004 - Jungle Cruiser - by ADHO15 - <LDD 4.3.6> 7625+7626 - Crystal Cannon Truck - by PeabodySam - <LDD 4.3.9> - Comment: Combines multiple sets 7682+7683 - Indy Combo - by PeabodySam - <LDD 4.3.9> - Comment: Combines multiple sets comcon002 - Indiana Jones Brickmaster Pack - San Diego Comic-Con 2008 Exclusive - by PeabodySam - <LDD 4.3.6> Inventor 4090 - Motion Madness (A model) - by marco9999 - <LDD 4.3.6> 4090 - Motion Madness (B model) - by marco9999 - <LDD 4.3.6> 4090 - Motion Madness (C model) - by marco9999 - <LDD 4.3.6> 4090 - Motion Madness (D model) - by marco9999 - <LDD 4.3.6> 4090 - Motion Madness (E model) - by marco9999 - <LDD 4.3.6> 4090 - Motion Madness (F model) - by marco9999 - <LDD 4.3.6> 4093 - Wild Windup (A model) - by BEAVeR - <LDD 4.3.6> 4093 - Wild Windup (B model) - by BEAVeR - <LDD 4.3.6> 4093 - Wild Windup (C model) - by BEAVeR - <LDD 4.3.6> 4093 - Wild Windup (D model) - by BEAVeR - <LDD 4.3.6> 4093 - Wild Windup (E model) - by BEAVeR - <LDD 4.3.6> 4093 - Wild Windup (F model) - by BEAVeR - <LDD 4.3.6> 4094 - Motor Movers (A model) - by BEAVeR - <LDD 4.3.8> 4094 - Motor Movers (B model) - by BEAVeR - <LDD 4.3.8> 4094 - Motor Movers (C model) - by BEAVeR - <LDD 4.3.8> 4094 - Motor Movers (D model) - by BEAVeR - <LDD 4.3.8> 4094 - Motor Movers (E model) - by BEAVeR - <LDD 4.3.8> 4094 - Motor Movers (F model) - by BEAVeR - <LDD 4.3.8> 4095 - Record and Play (A model) - by marco9999 - <LDD 4.3.8> 4095 - Record and Play (B model) - by marco9999 - <LDD 4.3.8> 4095 - Record and Play (C model) - by marco9999 - <LDD 4.3.8> 4095 - Record and Play (D model) - by marco9999 - <LDD 4.3.8> 4095 - Record and Play (E model) - by marco9999 - <LDD 4.3.8> 4095 - Record and Play (F model) - by marco9999 - <LDD 4.3.8> Island Xtreme Stunts 6731 - Skateboarding Pepper - by TEH EPIC BUILDER! - <LDD 4> 6732 - Brickster's Trike - by PeabodySam - <LDD 4.3.8> 6733 - Snap's Cruiser - by PeabodySam - <LDD 4.3.8> 6734 - Beach Cruiser - by PeabodySam - <LDD 4.3.8> 6735 - Air Chase - by PeabodySam - <LDD 4.3.8> 6736 - Beach Lookout - by PeabodySam - <LDD 4.3.8> 6736 - Beach Lookout - by PeabodySam - <LDD 4.3.8> 6737 - Wake Rider (Wave Catcher) - by PeabodySam - <LDD 4.3.8> 6737 - Wake Rider (Wave Catcher) (B model) - by PeabodySam - <LDD 4.3.8> 6738 - Skateboard Challenge - by PeabodySam - <LDD 4.3.8> 6738 - Skateboard Challenge (B model) - by PeabodySam - <LDD 4.3.8> 6739 - Truck and Stunt Trikes - by PeabodySam - <LDD 4.3.8> 6739 - Truck and Stunt Trikes (B model) - by PeabodySam - <LDD 4.3.8> 6740 - Xtreme Tower (A model) - by PeabodySam - <LDD 4.3.9> 6740 - Xtreme Tower (B model) - by PeabodySam - <LDD 4.3.9> Juniors 10665 - Spider-Man: Spider-Car Pursuit - by ChristopherLee - <LDD 4.3.8> 10666 - Digger - by vean - <LDD 4.3.8> 10667 - Construction - by vean - <LDD 4.3.8> 10668 - The Princess Play Castle - by KamalMYafi - <LDD 4.3.9> 10669 - Turtle Lair - by KamalMYafi - <LDD 4.3.9> 10671 - Fire Emergency - by KamalMYafi - <LDD 4.3.9> 10672 - Batman: Defend the Batcave - by KamalMYafi - <LDD 4.3.9> 10673 - Race Car Rally - by KamalMYafi - <LDD 4.3.9> 10674 - Pony Farm - by KamalMYafi - <LDD 4.3.9> 10675 - Police ÔÇô The Big Escape - by KamalMYafi - <LDD 4.3.9> 10676 - Knights' Castle - by KamalMYafi - <LDD 4.3.9> 30338 - Fire Car polybag - by vean - <LDD 4.3.10> 30473 - Racer polybag - by KamalMYafi - <LDD 4.3.9> Jurassic World 30320 - Gallimimus Trap - by Happy SDE - <LDD 4.3.8> 75915 - Pteranodon Capture - by Happy SDE - <LDD 4.3.8> 75916 - Dilophosaurus Ambush - by PeabodySam - <LDD 4.3.9> 75917 - Raptor Rampage - by PeabodySam - <LDD 4.3.8> 75918 - T. rex Tracker - by PeabodySam - <LDD 4.3.9> 75919 - Indominus rex Breakout - by PeabodySam - <LDD 4.3.9> 75920 - Raptor Escape - by PeabodySam - <LDD 4.3.8> 75926 - Pteranodon Chase - by PeabodySam - <LDD 4.3.11> 75927 - Stygimoloch Breakout - by PeabodySam - <LDD 4.3.11> 75928 - Blue's Helicopter Pursuit - by PeabodySam - <LDD 4.3.11> 75929 - Carnotaurus Gyrosphere Escape - by PeabodySam - <LDD 4.3.11> Legends of Chima 30250 - Ewar's Acro-Fighter - by Sjuip - <LDD 4.3.8> 30251 - Winzar's Pack Patrol polybag - by Happy SDE - <LDD 4.3.8> 30252 - Crug's Swamp Jet polybag - by Happy SDE - <LDD 4.3.8> 30253 - Leonidas' Jungle Dragster polybag - by Happy SDE - <LDD 4.3.8> 30254 - Razcal's Double-Crosser polybag - by Happy SDE - <LDD 4.3.8> 30255 - Crawley polybag - by Happy SDE - <LDD 4.3.8> 30262 - Gorzan's Walker polybag - by Happy SDE - <LDD 4.3.8> 30263 - Spider Crawler polybag - by Happy SDE - <LDD 4.3.8> 30265 - Worriz' Fire Bike polybag - by Happy SDE - <LDD 4.3.8> 30266 - Sykor's Ice Cruiser polybag - by Happy SDE - <LDD 4.3.8> 70000 - Razcal's Glider - by penguinz - <LDD 4.3.8> 70001 - Crawley's Claw Ripper - by Zarkan - <LDD 4.3.5> 70001 - Crawley's Claw Ripper - by penguinz - <LDD 4.3.8> 70002 - Lennox' Lion Attack - by penguinz - <LDD 4.3.8> 70003 - Eris' Eagle Interceptor - by penguinz - <LDD 4.3.8> 70004 - Wakz' Pack Tracker - by penguinz - <LDD 4.3.8> 70005 - Laval's Royal Fighter - by penguinz - <LDD 4.3.8> 70006 - Cragger's Command Ship - by penguinz - <LDD 4.3.8> 70006 - Cragger's Command Ship - by Zarkan - <LDD 4.3.5> 70006 - Cragger's Command Ship - by CM4S - <LDD 4.3.5> 70007 - Eglor's Twin Bike - by penguinz - <LDD 4.3.6> 70008 - Gorzan's Gorilla Striker - by penguinz - <LDD 4.3.6> 70008 - Gorzan`s Gorilla Striker - by CM4S - <LDD 4.3.6> 70009 - Worriz's Combat Lair - by penguinz - <LDD 4.3.6> 70009 - Worriz's Combat Lair - by CM4S - <LDD 4.3.6> 70010 - The Lion CHI Temple - by penguinz - <LDD 4.3.6> 70010 - The Lion CHI Temple - by CM4S - <LDD 4.3.6> 70011 - Eagle's Castle - by penguinz - <LDD 4.3.8> 70012 - Razar's CHI Raider - by penguinz - <LDD 4.3.8> 70013 - Equila's Ultra Striker - by penguinz - <LDD 4.3.8> 70014 - The Croc Swamp Hideout - by CM4S - <LDD 4.3.6> 70014 - The Croc Swamp Hideout - by penguinz - <LDD 4.3.6> 70100 - Ring of Fire - by penguinz - <LDD 4.3.8> 70101 - Target Practice - by penguinz - <LDD 4.3.8> 70102 - CHI Waterfall - by penguinz - <LDD 4.3.8> 70103 - Boulder Bowling - by penguinz - <LDD 4.3.8> 70104 - Jungle Gates - by penguinz - <LDD 4.3.6> 70105 - Nest Dive - by penguinz - <LDD 4.3.6> 70106 - Ice Tower - by penguinz - <LDD 4.3.6> 70107 - Skunk Attack - by CM4S - <LDD 4.3.6> 70108 - Royal Roost - by CM4S - <LDD 4.3.6> 70109 - Whirling Vines - by CM4S - <LDD 4.3.6> 70110 - Tower Target - by Happy SDE - <LDD 4.3.8> 70111 - Swamp Jump - by Happy SDE - <LDD 4.3.8> 70112 - Croc Chomp - by Happy SDE - <LDD 4.3.8> 70113 - CHI Battles - by penguinz - <LDD 4.3.8> 70114 - Sky Joust - by CM4S - <LDD 4.3.6> 70115 - Ultimate Speedor Tournament - by penguinz - <LDD 4.3.8> 70123 - Lion Legend Beast - by Stephan - <LDD 4.3.8> 70124 - Eagle Legend Beast - by Stephan - <LDD 4.3.8> 70124 - Eagle Legend Beast - by JGW3000 - <LDD 4.3.8> 70125 - Gorilla Legend Beast - by Stephan - <LDD 4.3.8> 70126 - Crocodile Legend Beast - by Stephan - <LDD 4.3.8> 70127 - Wolf Legend Beast - by Stephan - <LDD 4.3.8> 70128 - Braptor's Wing Striker - by penguinz - <LDD 4.3.8> 70129 - Lavertus' Twin Blade - by penguinz - <LDD 4.3.8> 70130 - Sparratus' Spider Striker - by penguinz - <LDD 4.3.8> 70131 - Rogon's Rock Flinger - by penguinz - <LDD 4.3.8> 70132 - Scorm's Scorpion Stinger - by penguinz - <LDD 4.3.8> 70133 - Spinlyn's Cavern - by penguinz - <LDD 4.3.8> 70134 - Lavertus' Outland Base - by penguinz - <LDD 4.3.8> 70135 - Cragger's Fire Striker - by penguinz - <LDD 4.3.8> 70136 - Banana Bash - by penguinz - <LDD 4.3.8> 70137 - Bat Strike - by penguinz - <LDD 4.3.8> 70138 - Web Dash - by penguinz - <LDD 4.3.8> 70139 - Sky Launch - by penguinz - <LDD 4.3.8> 70140 - Stinger Duel - by penguinz - <LDD 4.3.8> 70141 - Vardy's Ice Vulture Glider - by penguinz - <LDD 4.3.8> 70142 - Eris' Fire Eagle Flyer - by penguinz - <LDD 4.3.8> 70143 - Sir Fangar's Sabre Tooth Walker - by penguinz - <LDD 4.3.8> 70144 - Laval's Fire Lion - by penguinz - <LDD 4.3.8> 70145 - Maula's Ice Mammoth Stomper - by penguinz - <LDD 4.3.8> 70146 - Flying Phoenix Fire Temple - by penguinz - <LDD 4.3.8> 70146 - Flying Phoenix Fire Temple - by penguinz - <LDD 4.3.8> 70200 - CHI Laval - by Happy SDE - <LDD 4.3.8> 70206 - CHI Laval - by TheOneVeyronian - <LDD 4.3.8> 70208 - CHI Panthar - by TheOneVeyronian - <LDD 4.3.8> 70210 - CHI Vardy - by TheOneVeyronian - <LDD 4.3.8> 70211 - CHI Fluminox - by TheOneVeyronian - <LDD 4.3.8> 70212 - CHI Sir Fangar - by TheOneVeyronian - <LDD 4.3.8> 31017+7012 - Lion Legend Beast (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets - Web extra model 31022+70124 - Eagle Legend Beast (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets - Web extra model LEGO Brand 40321 - Monthly Mini Model Build Set - 2019 01 January, Jet Fighter - by KamalMYafi - <LDD 4.3.11> 40395 - Monthly Mini Model Build Set - 2020 01 January, Chinese Dragon polybag - by vean - <LDD 4.3.11> 40396 - Monthly Mini Model Build Set - 2020 02 February, Valentine Panda polybag - by vean - <LDD 4.3.11> Lego Brand Store 40025 - New York Taxi [Promo] - by Gnac - <LDD 4.3.5> 40026 - Statue of Liberty (LEGO Store, Rockefeller Center, New York, NY) [Promo] - by Gnac - <LDD 4.3.5> 40036 - Monthly Mini Model Build Set - 2012 01 January, Cobra - by buddy - <LDD 4.3.5> 40037 - Monthly Mini Model Build Set - 2012 02 February, Hockey Player - by Stephan - <LDD 4.3.5> 40038 - Monthly Mini Model Build Set - 2012 03 March, Garden and Earthworm - by Stephan - <LDD 4.3.5> 40039 - Monthly Mini Model Build Set - 2012 05 May, Tulip - by Stephan - <LDD 4.3.5> 40040 - Monthly Mini Model Build Set - 2012 07 July, Torch (Olympic Flame) - by Stephan - <LDD 4.3.5> 40041 - Monthly Mini Model Build Set - 2012 December, Reindeer (Moose) - by buddy - <LDD 4.3.5> 40042 - Monthly Mini Model Build Set - 2012 10 October, Cat - by Stephan - <LDD 4.3.5> 40043 - Monthly Mini Model Build Set - 2012 04 April, Duck (Mallard) - by Stephan - <LDD 4.3.5> 40044 - Monthly Mini Model Build Set - 2012 06 June, Lawnmower - by Stephan - <LDD 4.3.5> 40045 - Monthly Mini Model Build Set - 2012 08 August, Shark - by Stephan - <LDD 4.3.5> 40046 - Monthly Mini Model Build Set - 2012 11 November, Pilgrim (US) - by buddy - <LDD 4.3.6> 40047 - Monthly Mini Model Build Set - 2012 09 September, Owl - by Stephan - <LDD 4.3.5> 40049 - Mini Sopwith Camel [Promo] - by Gnac - <LDD 4.3.5> 40061 - Monthly Mini Model Build Set - 2013 03 January, Igloo - by Stephan - <LDD 4.3.5> 40062 - Monthly Mini Model Build Set - 2013 02 February, (Log) Cabin - by Stephan - <LDD 4.3.6> 40063 - Monthly Mini Model Build Set - 2013 03 March, Turtle - by buddy - <LDD 4.3.6> 40063 - Monthly Mini Model Build Set - 2013 03 March, Turtle - by Stephan - <LDD 4.3.9> 40064 - Monthly Mini Model Build Set - 2013 04 April, Lamb and Sheep - by Stephan - <LDD 4.3.6> 40065 - Monthly Mini Model Build Set - 2013 05 May, Blue Bird - by Stephan - <LDD 4.3.6> 40066 - Monthly Mini Model Build Set - 2013 06 June, Fisherman - by Stephan - <LDD 4.3.6> 40067 - Monthly Mini Model Build Set - 2013 07 July, Crab - by Stephan - <LDD 4.3.6> 40068 - Monthly Mini Model Build Set - 2013 08 August, Flamingo - by vean - <LDD 4.3.6> 40069 - Monthly Mini Model Build Set - 2013 09 September, Pirate - by vean - <LDD 4.3.6> 40070 - Monthly Mini Model Build Set - 2013 10 October, Witch - by vean - <LDD 4.3.6> 40071 - Monthly Mini Model Build Set - 2013 11 November, Lawnmower/Tractor - by vean - <LDD 4.3.9> 40071 - Monthly Mini Model Build Set - 2013 11 November, Lawnmower/Tractor - by KamalMYafi - <LDD 4.3.9> 40072 - Monthly Mini Model Build Set - 2013 12 December, Toy Horse - by vean - <LDD 4.3.6> 40094 - Monthly Mini Model Build Set - 2014 01 January, Snowplow - by Stephan - <LDD 4.3.10> 40095 - Monthly Mini Model Build Set - 2014 02 February, Micro Manager - by KamalMYafi - <LDD 4.3.9> 40095 - Monthly Mini Model Build Set - 2014 02 February, Micro Manager - by Happy SDE - <LDD 4.3.8> 40096 - Monthly Mini Model Build Set - 2014 03 March, Spring Tree - by Stephan - <LDD 4.3.8> 40097 - Monthly Mini Model Build Set - 2014 04 April, Helicopter - by DawnTreader - <LDD 4.3.8> 40097 - Monthly Mini Model Build Set - 2014 04 Helicopter - by Stephan - <LDD 4.3.8> 40098 - Monthly Mini Model Build Set - 2014 05 April, Dragon - by DawnTreader - <LDD 4.3.8> 40098 - Monthly Mini Model Build Set - 2014 05 May, Dragon - by Stephan - <LDD 4.3.9> 40099 - Monthly Mini Model Build Set - 2014 06 Jet Ski - by Stephan - <LDD 4.3.8> 40100 - Monthly Mini Model Build Set - 2014 07 Beach Van - by Stephan - <LDD 4.3.8> 40101 - Monthly Mini Model Build Set - 2014 08 August, Monkey (Chimpanzee) - by Stephan - <LDD 4.3.8> 40102 - Monthly Mini Model Build Set - 2014 09 September, Racing Plane - by Stephan - <LDD 4.3.8> 40103 - Monthly Mini Model Build Set - 2014 10 October, Monster (Frankenstein) - by Stephan - <LDD 4.3.8> 40104 - Monthly Mini Model Build Set - 2014 10 October, Monster (Frankenstein) - by Stephan - <LDD 4.3.8> 40105 - Monthly Mini Model Build Set - 2014 12 December, Gingerbread House - by Stephan - <LDD 4.3.8> 40126 - Monthly Mini Model Build Set - 2015 01 January, Alien - by Stephan - <LDD 4.3.8> 40127 - Monthly Mini Model Build Set - 2015 02 February, Space Shuttle - by Happy SDE - <LDD 4.3.8> 40127 - Monthly Mini Model Build Set - 2015 02 February, Space Shuttle - by KamalMYafi - <LDD 4.3.9> 40128 - Monthly Mini Model Build Set - 2015 03 March, Robot - by KamalMYafi - <LDD 4.3.9> 40128 - Monthly Mini Model Build Set - 2015 03 March, Robot - by Happy SDE - <LDD 4.3.8> 40129 - Monthly Mini Model Build Set - 2015 04 April, UFO - by KamalMYafi - <LDD 4.3.9> 40129 - Monthly Mini Model Build Set - 2015 04 April, UFO - by Happy SDE - <LDD 4.3.8> 40130 - Monthly Mini Model Build Set - 2015 05 May, Koala - by KamalMYafi - <LDD 4.3.9> 40131 - Monthly Mini Model Build Set - 2015 06 June, Parrot - by KamalMYafi - <LDD 4.3.9> 40132 - Monthly Mini Model Build Set - 2015 07 July, Whale - by KamalMYafi - <LDD 4.3.9> 40133 - Monthly Mini Model Build Set - 2015 08 August, Kangaroo - by KamalMYafi - <LDD 4.3.9> 40133 - Monthly Mini Model Build Set - 2015 August, Kangaroo - by Happy SDE - <LDD 4.3.8> 40134 - Monthly Mini Model Build Set - 2015 09 September, Scuba Diver - by KamalMYafi - <LDD 4.3.9> 40134 - Monthly Mini Model Build Set - 2015 09 September, Scuba Diver - by Happy SDE - <LDD 4.3.8> 40135 - Monthly Mini Model Build Set - 2015 10 October, Anglerfish - by KamalMYafi - <LDD 4.3.10> 40135 - Monthly Mini Model Build Set - 2015 10 October, Anglerfish - by Happy SDE - <LDD 4.3.8> 40136 - Monthly Mini Model Build Set - 2015 11 November, Shark - by KamalMYafi - <LDD 4.3.9> 40137 - Monthly Mini Model Build Set - 2015 12 December, Submarine - by KamalMYafi - <LDD 4.3.9> 40145 - LEGO Store - by Gnac - <LDD 4.3.8> 40145 - LEGO Store - by bbqqq - <LDD 4.3.8> 40208 - Monthly Mini Model Build Set - 2016 01 January, Polar Bear - by KamalMYafi - <LDD 4.3.9> 40209 - Monthly Mini Model Build Set - 2016 02 February, Snow Scooter - by KamalMYafi - <LDD 4.3.9> 40210 - Monthly Mini Model Build Set - 2016 03 March, Easter Bunny - by lipanz - <LDD 4.3.9> 40211 - Monthly Mini Model Build Set - 2016 04 April, Bee - by lipanz - <LDD 4.3.9> 40212 - Monthly Mini Model Build Set - 2016 05 May, Hedgehog - by KamalMYafi - <LDD 4.3.9> 40213 - Monthly Mini Model Build Set - 2016 06 June, Seaplane - by KamalMYafi - <LDD 4.3.9> 40214 - Monthly Mini Model Build Set - 2016 07 July, Frog - by KamalMYafi - <LDD 4.3.9> 40215 - Monthly Mini Model Build Set - 2016 08 August, Apple - by KamalMYafi - <LDD 4.3.10> 40216 - Monthly Mini Model Build Set - 2016 09 September, School Bus - by KamalMYafi - <LDD 4.3.10> 40217 - Monthly Mini Model Build Set - 2016 10 October, Werewolf - by KamalMYafi - <LDD 4.3.10> 40218 - Monthly Mini Model Build Set - 2016 11 November, Fox - by KamalMYafi - <LDD 4.3.10> 40239 - Monthly Mini Model Build Set - 2017 01 January, Narwhal - by KamalMYafi - <LDD 4.3.10> 40240 - Monthly Mini Model Build Set - 2017 02 February, Raccoon - by KamalMYafi - <LDD 4.3.10> 40241 - Monthly Mini Model Build Set - 2017 03 March, Platypus - by KamalMYafi - <LDD 4.3.10> 40242 - Monthly Mini Model Build Set - 2017 04 April, Chick - by KamalMYafi - <LDD 4.3.10> 40243 - Monthly Mini Model Build Set - 2017 05 May, Race Car - by KamalMYafi - <LDD 4.3.10> 40244 - Monthly Mini Model Build Set - 2017 06 June, Dragonfly - by KamalMYafi - <LDD 4.3.10> 40245 - Monthly Mini Model Build Set - 2017 07 July, Octopus - by KamalMYafi - <LDD 4.3.10> 40246 - Monthly Mini Model Build Set - 2017 08 August, Rainbow Fish - by KamalMYafi - <LDD 4.3.10> 40247 - Monthly Mini Model Build Set - 2017 09 September, Dinosaur - by KamalMYafi - <LDD 4.3.10> 40248 - Monthly Mini Model Build Set - 2017 10 October, Robot - by KamalMYafi - <LDD 4.3.10> 40249 - Monthly Mini Model Build Set - 2017 11 November, St. Bernard Dog - by KamalMYafi - <LDD 4.3.10> 40250 - Monthly Mini Model Build Set - 2017 12 December, Train - by KamalMYafi - <LDD 4.3.10> 40276 - Monthly Mini Model Build Set - 2018 01 January, Walrus - by KamalMYafi - <LDD 4.3.11> 40277 - Monthly Mini Model Build Set - 2018 02 February, Car And Petrol Pump - by KamalMYafi - <LDD 4.3.11> 40278 - Monthly Mini Model Build Set - 2018 03 March, Lamb - by KamalMYafi - <LDD 4.3.11> 40279 - Monthly Mini Model Build Set - 2018 04 April, Frog - by KamalMYafi - <LDD 4.3.11> 40280 - Monthly Mini Model Build Set - 2018 05 May, Tractor - by KamalMYafi - <LDD 4.3.11> 40281 - Monthly Mini Model Build Set - 2018 06 June, Surfer Dragon - by KamalMYafi - <LDD 4.3.11> 3300000 - The Brick Apple - by JunkstyleGio - <LDD 3> 3300000 - The Brick Apple - by ILikePi - <LDD 3> 3300003 - LEGO Brand Retail Store - by zinfinion - <LDD 4> 3300003 - LEGO Brand Retail Store - by ADHO15 - <LDD 4> 3300006 - The Routemaster Bus (LEGO Store Grand Opening Set, Westfield, London, UK) - by KamalMYafi - <LDD 4.3.10> 3300006 - London Bus [LEGO Store Grand Opening] - by BrickWild - <LDD 4> 3850001 - Pick-a-Model - Crocodile - by Kuramapika1 - <LDD 4.3.11> 3850001 - Pick-a-Model - Crocodile - by KamalMYafi - <LDD 4.3.11> 3850002 - Pick-a-Model - Car - by Kuramapika1 - <LDD 4.3.11> 3850002 - Pick-a-Model - Car - by KamalMYafi - <LDD 4.3.11> 3850003 - Pick-a-Model - Giraffes - by Kuramapika1 - <LDD 4.3.11> 3850004 - Pick-a-Model - Biplane - by Kuramapika1 - <LDD 4.3.11> 3850005 - Pick-a-Model - Panda - by Kuramapika1 - <LDD 4.3.11> 3850005 - Pick-a-Model - Panda - by KamalMYafi - <LDD 4.3.11> 3850006 - Pick-a-Model - Jeep - by KamalMYafi - <LDD 4.3.11> 3850006 - Pick-a-Model - Jeep - by Kuramapika1 - <LDD 4.3.11> 3850007 - Pick-a-Model - Elephant - by Kuramapika1 - <LDD 4.3.11> 3850008 - Pick-a-Model - Jet - by Kuramapika1 - <LDD 4.3.11> 3850009 - Pick-a-Model - Aircraft - by Kuramapika1 - <LDD 4.3.11> 3850010 - Pick-a-Model - Butterfly - by KamalMYafi - <LDD 4.3.10> 3850010 - Pick-a-Model - Butterfly - by Kuramapika1 - <LDD 4.3.11> 3850011 - Pick-a-Model - Statue of Liberty - by Kuramapika1 - <LDD 4.3.11> 3850012 - Pick-a-Model - Truck - by Kuramapika1 - <LDD 4.3.11> 3850012 - Pick-a-Model - Truck - by KamalMYafi - <LDD 4.3.10> 3850013 - Pick-a-Model - Turtle - by Kuramapika1 - <LDD 4.3.11> 3850013 - Pick-a-Model - Turtle - by KamalMYafi - <LDD 4.3.10> 3850014 - Pick-a-Model - Snowplough - by Kuramapika1 - <LDD 4.3.11> 3850015 - Pick-a-Model - Penguin - by KamalMYafi - <LDD 4.3.10> 3850015 - Pick-a-Model - Penguin - by Kuramapika1 - <LDD 4.3.11> 3850016 - Pick-a-Model - Beaver - by Kuramapika1 - <LDD 4.3.11> 3850017 - Pick-a-Model - Digger - by KamalMYafi - <LDD 4.3.10> 3850017 - Pick-a-Model - Digger - by Kuramapika1 - <LDD 4.3.11> 3850031 - Pick-a-Model - Puffin - by Kuramapika1 - <LDD 4.3.11> 3850033 - Pick-a-Model - Guardsman - by Kuramapika1 - <LDD 4.3.11> 3850060 - Pick-a-Model - Fish Tank - by Kuramapika1 - <LDD 4.3.11> 3850061 - Pick-a-Model - Fish Tank - by Kuramapika1 - <LDD 4.3.11> 3850065 - Pick-a-Model - Parisian Guy - by Kuramapika1 - <LDD 4.3.11> 3850070 - Pick-a-Model - Ollie - by Kuramapika1 - <LDD 4.3.11> Braintree - Baseball Player [Promotional] - by Stephan - <LDD 4.3.5> Chandler - Cactus [Promotional] - by Stephan - <LDD 4.3.5> Duck75 - 75th Anniversary Duck on Wheels - by Stephan - <LDD 4.3.8> Houston - Space Shuttle [Promotional] - by Stephan - <LDD 4.3.5> MAY2013 - Star Wars - Holocron Droid - by Kuramapika1 - <LDD 4.3.11> MAY2013 - Holocron Droid - by Happy SDE - <LDD 4.3.11> MAY2013 - [Star Wars] Holocron Droid [Promo] - 1st May 2013. - by Stephan - <LDD 4.3.11> MMB1402 - Monthly Mini Model Build Card - 2014 02 February, Micro Manager - by Stephan - <LDD 4.3.8> MMMB0907UK - Monthly Mini Model Build Card - 2009 07 July, Ice Cream Cone (UK) - by Happy SDE - <LDD 4.3.8> MMMB1002DE - Mini-Modell des Monats-Karte - 2010 02 Februar, Rose - by moop2000 - <LDD 4.3.9> - Comment: aka MMMB020 MMMB1107 - Monthly Mini Model Build Card - 2011 07 July, Lighthouse (A model) - by Toa_Of_Justice - <LDD 4.3.9> - Comment: aka MMMB039 MMMB1107 - Monthly Mini Model Build Card - 2011 07 July, Lighthouse (B model) - by Toa_Of_Justice - <LDD 4.3.9> - Comment: aka MMMB039 n/a - Superman Brand Store Model - by Stephan - <LDD 4.3.6> Raleigh - LEGO Store Grand Opening Exclusive Set, Crabtree Valley Mall, Raleigh, NC - by Vee - <LDD 4.3.8> LEGO Club 31022+70124 - Raptor Rally Bike - by Stephan - <LDD 4.3.8> 41026+60060 - City & Friends Combi Truck - by Stephan - <LDD 4.3.8> 60056+70723 - Hydro Turbo Sky Ray - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 60061+70721 - Thermo-Bolt Fire Flyer - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 60067+60069 - Training Parcours - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 70162+70723 - Ultra Agents / Ninjago Mashup MechUltra Agents / Ninjago Mashup Mech - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 7726+8634 - Dragon-Flyer - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets n/a - Friends X-Mas - by Stephan - <LDD 4.3.8> n/a - Summer Scene - by Stephan - <LDD 4.3.8> n/a - Panda Pencil Holder - by Stephan - <LDD 4.3.8> n/a - Boat for Shark Study - by Stephan - <LDD 4.3.8> n/a - Dump Truck - by Stephan - <LDD 4.3.8> n/a - LEGO Club Door - by PeabodySam - <LDD 4.3.9> n/a - Guitar - by Stephan - <LDD 4.3.6> n/a - Snowman - by Stephan - <LDD 4.3.8> n/a - Christmas Ornaments - by Stephan - <LDD 4.3.8> n/a - Bird - by legolijntje - <LDD 4> n/a - X-Mas Tree - by Stephan - <LDD 4.3.6> n/a - Taxi Car - by legolijntje - <LDD 4> n/a - Space Shuttle - by legolijntje - <LDD 4> n/a - Iron Man's Laboratory - by Stephan - <LDD 4.3.6> n/a - Shootgame - by legolijntje - <LDD 4> n/a - Convertible - by moop2000 - <LDD 4> n/a - Elephant - by Stephan - <LDD 4.3.6> n/a - Bunny - by Stephan - <LDD 4.3.6> n/a - Undersea World - by Stephan - <LDD 4.3.6> n/a - {Basic House} - by Stephan - <LDD 4.3.6> n/a - Police Car - by Stephan - <LDD 4.3.6> n/a - Pumpkin - by Stephan - <LDD 4.3.6> n/a - Robot - by Stephan - <LDD 4.3.6> n/a - Indy Car - by C3POwen - <LDD 4> LEGO Ideas (CUUSOO) 21100 - Shinkai 6500 Submarine - by ADHO15 - <LDD 4.3.8> 21100 - Shinkai 6500 Submarine - by Gear_tooth - <LDD 4.3.8> 21100 - Shinkai 6500 Submarine - by yellost - <LDD 4.3.8> 21101 - Hayabusa - by Stephan - <LDD 4.3.8> 21102 - Minecraft Micro World - The Forest - by Costy - <LDD 4.3.8> 21103 - The DeLorean Time Machine - by bbqqq - <LDD 4.3.8> 21103 - The DeLorean Time Machine - by Canticleer blues - <LDD 4.3.8> 21104 - NASA Mars Science Laboratory Curiosity Rover - by bbqqq - <LDD 4.3.8> 21108 - Ghostbusters Ecto-1 - by orionfrg - <LDD 4.3.8> - Comment: [INACCURATE] Wrong colours and Bricks !!!! 21108 - Ghostbusters Ecto-1 - by KamalMYafi - <LDD 4.3.9> 21109 - EXO SUIT - by vean - <LDD 4.3.8> 21109 - EXO SUIT - by Stephan - <LDD 4.3.8> 21110 - Research Institute - by JGW3000 - <LDD 4.3.8> 21301 - Birds - by Stephan - <LDD 4.3.8> 21302 - The Big Bang Theory - by vean - <LDD 4.3.8> 21303 - WALL-E - by Stephan - <LDD 4.3.8> 21304 - Doctor Who - by KamalMYafi - <LDD 4.3.9> 21305 - Maze - by LegoPegasister2015 - <LDD 4.3.9> 21305 - Maze (B model) - by LegoPegasister2015 - <LDD 4.3.9> - Comment: "Medieval Maze" 21306 - Yellow Submarine - by Stephan - <LDD 4.3.11> 21307 - Caterham Seven 620R - by Stephan - <LDD 4.3.11> 21307 - Caterham Seven 620R - by Henni - <LDD 4.3.10> 21308 - Adventure Time - by Stephan - <LDD 4.3.10> 21309 - NASA Apollo Saturn V - by Stephan - <LDD 4.3.10> 21310 - Old Fishing Store - by Stephan - <LDD 4.3.11> 21311 - Voltron - by PicnicBasketSam - <LDD 4.3.11> 21312 - Women of NASA - by Stephan - <LDD 4.3.11> 21313 - Ship in a Bottle - by Stephan - <LDD 4.3.11> 21314 - TRON: Legacy Lightcycle - by BrickWild - <LDD 4.3.11> 21315 - Brick Tales Pop-Up Book - by trifalger - <LDD 4.3.11> 21317 - Steamboat Willie - by Bod9nou - <LDD 4.3.11> 21321 - International Space Station - by vean - <LDD 4.3.11> 40335 - Space Rocket Ride - by Bod9nou - <LDD 4.3.11> Legoland 00 - Weetabix Castle - by marco9999 - <LDD 3> 00 - Weetabix Castle - by Stephan - <LDD 4.3.8> 338 - Ambulance - by Stephan - <LDD 4> 344 - Bungalow - by Stephan - <LDD 4.3.8> 345 - House with Car - by Stephan - <LDD 4.3.8> 346 - House with Car - by Stephan - <LDD 4.3.8> 347 - Fire Station - by Stephan - <LDD 4.3.8> 349 - Swiss Chalet - by vean - <LDD 4.3.10> 350 - Spanish Villa - by Giovanne - <LDD 4> 351 - Loader Hopper with Truck - by vean - <LDD 4.3.10> 352 - Windmill and Lorry - by Stephan - <LDD 4.3.8> 353 - Terrace House with Car and Garage - by Stephan - <LDD 4.3.8> 354 - Police Heliport - by vean - <LDD 4.3.10> 357 - Legoland Fire House - by EM4CZ - <LDD 4.3.5> 358 - Rocket Base - by vean - <LDD 4.3.10> 360 - Gravel Quarry - by vean - <LDD 4.3.10> 361 - Tea Garden Cafe with Baker's Van - by vean - <LDD 4.3.10> 365 - Wild West Scene - by vean - <LDD 4.3.10> 367 - Moon Landing - by vean - <LDD 4.3.6> - Comment: aka 565 369 - Coast Guard Station - by vean - <LDD 4.3.10> 371 - Seaplane - by vean - <LDD 4.3.10> 372 - Texas Rangers - by vean - <LDD 4.3.10> 373 - Offshore Rig with Fuel Tanker - by Stephan - <LDD 4> 379 - Car and Caravan - by Stephan - <LDD 4> 384 - London Bus - by vean - <LDD 4.3.10> 420 - Police Car - by vean - <LDD 4.3.10> 491 - Formula 1 Racer - by Stephan - <LDD 4.3.5> 540 - Swiss Villa - by vean - <LDD 4.3.10> 555 - Hospital - by vean - <LDD 4.3.10> 600 - Ambulance - by Stephan - <LDD 4> 600 - Ambulance - by AndyC - <LDD 4> 601 - Tow Truck - by Stephan - <LDD 4> 602 - Fire Truck - by Stephan - <LDD 4> 603 - Vintage Car - by Stephan - <LDD 4> 605 - Taxi - by Stephan - <LDD 4> 606 - Tipper Lorry - by Stephan - <LDD 4> 608 - Kiosk - by Giovanne - <LDD 4> 609 - Aeroplane - by Stephan - <LDD 4> 610 - Vintage Car - by vean - <LDD 4.3.10> 613 - Biplane - by vean - <LDD 4.3.10> 617 - Cowboys - by vean - <LDD 4.3.10> 620 - Fire Truck - by Stephan - <LDD 4> 620 - Fire Truck - by C3POwen - <LDD 4> 622 - Baggage Trolley - by Stephan - <LDD 4> 623 - White Car and Camper - by Stephan - <LDD 4> 640 - Fire Truck - by Stephan - <LDD 4> 645 - Milk Truck with Trailer - by Stephan - <LDD 4> 646 - Mobile Site Office - by Stephan - <LDD 4.3.8> 646 - Mobile Site Office - by Giovanne - <LDD 4> 651 - Tow Truck and Car - by Stephan - <LDD 4> 656 - Car and Caravan - by vean - <LDD 4.3.10> 661 - Spirit of St. Louis - by vean - <LDD 4.3.10> 663 - Hovercraft - by vean - <LDD 4.3.10> 683 - Articulated Lorry - by Giovanne - <LDD 4> 685 - Legoland Truck with Trailer - by Stephan - <LDD 4> 688 - Shell Tanker - by Giovanne - <LDD 4> 697 - Stagecoach - by vean - <LDD 4.3.10> 699 - Photo Safari - by vean - <LDD 4.3.10> 1610 - Martinair Cessna - by vean - <LDD 4.3.8> 1611 - Martinair DC-9 - by pbat - <LDD 4.3.6> 6702 - Space Minifigures - by Giovanne - <LDD 4> 40306 - Legoland Castle - by vean - <LDD 4.3.11> Legoland Parks 40081 - Photo Frame Legoland - by Happy SDE - <LDD 4.3.8> 40115 - Legoland Visitors [Promo] (A model) - by Stephan - <LDD 4.3.8> - Comment: "Caucasian family" 40115 - Legoland Visitors [Promo] (B model) - by Stephan - <LDD 4.3.8> - Comment: "African-American family" 40166 - Legoland Train - by KamalMYafi - <LDD 4.3.9> LLCA53 - Han Solo on Tauntaun - Miniland Scale (LLCA Ambassador Pass Exclusive) - by JunkstyleGio - <LDD 4.3.10> - Comment: Legoland California Exclusive Magnet Set 851689 - Catwoman Minifigure Magnet Set - by ADHO15 - <LDD 4> 851869 - Catwoman Magnet Set [DC Heroes] - by ADHO15 - <LDD 4> 851939 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852085 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852086 - Darth Maul/Anakin/Naboo Pilot Magnet Set - by ADHO15 - <LDD 4> 852089 - Mr Freeze Magnet Set [DC Heroes] - by ADHO15 - <LDD 4> 852551 - Darth Maul 2009 Magnet Set - by ADHO15 - <LDD 4> 852552 - Royal Guard 2009 Magnet Set - by ADHO15 - <LDD 4> 852553 - Stormtrooper 2009 Magnet Set - by ADHO15 - <LDD 4> 852554 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852555 - CW Yoda 2009 Magnet Set - by ADHO15 - <LDD 4> 852715 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852737 - 10th Anniversary Stormtrooper Magnet - by ADHO15 - <LDD 4> 852843 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852844 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852845 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852942 - Prince of Persia Magnet Set - by ADHO15 - <LDD 4> 852947 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 852982 - Harry Potter Magnet Set - by ADHO15 - <LDD 4> 852983 - Harry Potter Magnet Set - by ADHO15 - <LDD 4> 853037 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 853126 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 853130 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 853414 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 853419 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 853421 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 4269242 - Star Wars Magnet Set - by ADHO15 - <LDD 4.3.5> 4269244 - Yoda Magnet Set - by ADHO15 - <LDD 4> 4493780 - Batman Magnet Set - by ADHO15 - <LDD 4> Master Builder Academy 20200 - Space Designer (MBA) (A model) - by PerryMakes - <LDD 4> 20200 - Space Designer (MBA) (B model) - by PerryMakes - <LDD 4> 20200 - Space Designer (MBA) (C model) - by PerryMakes - <LDD 4> Mindstorms 8527 - Mindstorms NXT (A model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Alpha Rex" 8527 - Mindstorms NXT (B model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Classic Clock" 8527 - Mindstorms NXT (C model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Soundbot" 8527 - Mindstorms NXT (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Spike" 8527 - Mindstorms NXT (E model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "T-56" 8527 - Mindstorms NXT (F model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Tribot" 8547 - Mindstorms NXT 2.0 - by AndyC - <LDD 4.3.11> 8547 - Mindstorms NXT 2.0 (A model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Alpha Rex" 8547 - Mindstorms NXT 2.0 (B model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Shooter Bot" 8547 - Mindstorms NXT 2.0 (C model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Robogator" 8547 - Mindstorms NXT 2.0 (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Color Sorter" 31313 - Mindstorms EV3 (A model) - by JGW3000 - <LDD 4.3.9> - Comment: "TRACK3R" 31313 - Mindstorms EV3 (B model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Gripper" 31313 - Mindstorms EV3 (C model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Spiker" 31313 - Mindstorms EV3 (D model) - by JGW3000 - <LDD 4.3.9> - Comment: "R3PTAR". Missions 1-4 31313 - Mindstorms EV3 (D model) - by Kuramapika1 - <LDD 4.3.11> - Comment: "Tracker" 31313 - Mindstorms EV3 (E model) - by JGW3000 - <LDD 4.3.9> - Comment: "EV3RSTORM", Missions 1-6 Minecraft 21105 - Minecraft Micro World - The Village - by Classicsmiley - <LDD 4.3.6> 21106 - Minecraft Micro World - The Nether - by Classicsmiley - <LDD 4.3.6> 21107 - Minecraft Micro World - The End - by Happy SDE - <LDD 4.3.8> 21113 - The Cave (A model) - by Stephan - <LDD 4.3.8> 21113 - The Cave (B model) - by Stephan - <LDD 4.3.8> 21114 - The Farm (A model) - by Stephan - <LDD 4.3.8> 21114 - The Farm (B model) - by Stephan - <LDD 4.3.8> 21114 - The Farm (C model) - by Stephan - <LDD 4.3.8> 21115 - The First Night (A model) - by Stephan - <LDD 4.3.8> 21115 - The First Night (B model) - by Stephan - <LDD 4.3.8> 21115 - The First Night (C model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (A model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (B model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (C model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (D model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (E model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (F model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (G model) - by Stephan - <LDD 4.3.8> 21116 - Crafting Box (H model) - by Stephan - <LDD 4.3.8> 21117 - The Ender Dragon (A model) - by Stephan - <LDD 4.3.8> 21117 - The Ender Dragon (B model) - by Stephan - <LDD 4.3.8> 21118 - The Mine (A model) - by Stephan - <LDD 4.3.8> 21118 - The Mine (B model) - by Stephan - <LDD 4.3.8> 21118 - The Mine (C model) - by LegoPegasister2015 - <LDD 4.3.8> 21119 - The Dungeon - by LegoPegasister2015 - <LDD 4.3.8> 21119 - The Dungeon (B model) - by LegoPegasister2015 - <LDD 4.3.8> 21120 - The Snow Hideout - by LegoPegasister2015 - <LDD 4.3.8> 21120 - The Snow Hideout (B model) - by LegoPegasister2015 - <LDD 4.3.8> 21121 - The Desert Outpost - by LegoPegasister2015 - <LDD 4.3.8> 21121 - The Desert Outpost (B model) - by LegoPegasister2015 - <LDD 4.3.8> 21122 - The Nether Fortress - by LegoPegasister2015 - <LDD 4.3.8> 21122 - The Nether Fortress (B model) - by LegoPegasister2015 - <LDD 4.3.8> 21123 - The Iron Golem - by LegoPegasister2015 - <LDD 4.3.8> 21123 - The Iron Golem (B model) - by LegoPegasister2015 - <LDD 4.3.8> 21124 - The End Portal - by LegoPegasister2015 - <LDD 4.3.9> 21124 - The End Portal - by KamalMYafi - <LDD 4.3.9> 21124 - The End Portal (B model) - by KamalMYafi - <LDD 4.3.9> 21125 - The Jungle Tree House - by LegoPegasister2015 - <LDD 4.3.9> 21125 - The Jungle Tree House - by KamalMYafi - <LDD 4.3.9> 21125 - The Jungle Tree House (B model) - by KamalMYafi - <LDD 4.3.9> 21126 - The Wither - by LegoPegasister2015 - <LDD 4.3.9> 21126 - The Wither - by KamalMYafi - <LDD 4.3.9> 21126 - The Wither (B model) - by KamalMYafi - <LDD 4.3.9> 21127 - The Fortress - by JudgeChuck - <LDD 4.3.10> 21127 - The Fortress (B model) - by JudgeChuck - <LDD 4.3.10> 21127 - The Fortress (C model) - by JudgeChuck - <LDD 4.3.10> 21127 - The Fortress (D model) - by JudgeChuck - <LDD 4.3.10> 21128 - The Village - by JudgeChuck - <LDD 4.3.10> 21128 - The Village (B model) - by JudgeChuck - <LDD 4.3.10> 21128 - The Village (C model) - by JudgeChuck - <LDD 4.3.10> 21128 - The Village (D model) - by JudgeChuck - <LDD 4.3.10> 21145 - The Skull Arena - by PicnicBasketSam - <LDD 4.3.11> 21146 - The Skeleton Attack - by PicnicBasketSam - <LDD 4.3.11> 21147 - The Bedrock Adventures - by PicnicBasketSam - <LDD 4.3.11> Mixels 41500 - Flain - by vean - <LDD 4.3.8> - Comment: Series 1 41501 - Vulk - by vean - <LDD 4.3.8> - Comment: Series 1 41502 - Zorch - by vean - <LDD 4.3.8> - Comment: Series 1 41503 - Krader - by vean - <LDD 4.3.8> - Comment: Series 1 41504 - Seismo - by vean - <LDD 4.3.8> - Comment: Series 1 41505 - Shuff - by vean - <LDD 4.3.8> - Comment: Series 1 41506 - Teslo - by vean - <LDD 4.3.8> - Comment: Series 1 41507 - Zaptor - by vean - <LDD 4.3.8> - Comment: Series 1 41508 - Volectro - by vean - <LDD 4.3.8> - Comment: Series 1 41509 - Slumbo - by Stephan - <LDD 4.3.8> - Comment: Series 2 41510 - Lunk - by Stephan - <LDD 4.3.8> - Comment: Series 2 41511 - Flurr - by Stephan - <LDD 4.3.8> - Comment: Series 2 41512 - Chomly - by Stephan - <LDD 4.3.8> - Comment: Series 2 41513 - Gobba - by Stephan - <LDD 4.3.8> - Comment: Series 2 41514 - Jawg - by Stephan - <LDD 4.3.8> - Comment: Series 2 41515 - Kraw - by Stephan - <LDD 4.3.8> - Comment: Series 2 41516 - Tentro - by Stephan - <LDD 4.3.8> - Comment: Series 2 41517 - Balk - by Stephan - <LDD 4.3.8> - Comment: Series 2 41518 - Glomp - by Stephan - <LDD 4.3.8> 41519 - Glurt - by Stephan - <LDD 4.3.8> 41520 - Torts - by Stephan - <LDD 4.3.8> 41521 - Footi - by Stephan - <LDD 4.3.8> 41522 - Scorpi - by Stephan - <LDD 4.3.8> 41523 - Hoogi - by Stephan - <LDD 4.3.8> 41524 - Mesmo - by Stephan - <LDD 4.3.8> 41525 - Magnifo - by Stephan - <LDD 4.3.8> 41526 - Wizwuz - by Stephan - <LDD 4.3.8> 41527 - Rokit - by Stephan - <LDD 4.3.8> 41528 - Niksput - by Stephan - <LDD 4.3.8> 41529 - Nurp-Naut - by Stephan - <LDD 4.3.8> 41530 - Meltus - by Stephan - <LDD 4.3.8> 41531 - Flamzer - by Stephan - <LDD 4.3.8> 41532 - Burnard - by Stephan - <LDD 4.3.8> 41533 - Globert - by Stephan - <LDD 4.3.8> 41534 - Vampos - by Stephan - <LDD 4.3.8> 41535 - Boogly - by Stephan - <LDD 4.3.8> 41536 - Gox - by Stephan - <LDD 4.3.8> 41537 - Jinky - by Stephan - <LDD 4.3.8> 41538 - Kamzo - by Stephan - <LDD 4.3.8> 41539 - Krog - by Stephan - <LDD 4.3.8> 41540 - Chilbo - by Stephan - <LDD 4.3.8> 41541 - Snoof - by Stephan - <LDD 4.3.8> 41542 - Spugg - by Stephan - <LDD 4.3.8> 41543 - Turg - by Stephan - <LDD 4.3.8> 41544 - Tungster - by Stephan - <LDD 4.3.8> 41545 - Kramm - by Alskadosis - <LDD 4.3.8> 41546 - Forx - by KamalMYafi - <LDD 4.3.9> 41547 - Wuzzo - by KamalMYafi - <LDD 4.3.9> 41548 - Dribbal - by KamalMYafi - <LDD 4.3.9> 41549 - Gurggle - by KamalMYafi - <LDD 4.3.9> 41550 - Slusho - by KamalMYafi - <LDD 4.3.9> 41551 - Snax - by KamalMYafi - <LDD 4.3.9> 41552 - Berp - by KamalMYafi - <LDD 4.3.9> 41553 - Vaka-Waka - by KamalMYafi - <LDD 4.3.9> 41554 - Kuffs - by lipanz - <LDD 4.3.9> 41554 - Kuffs - by Stephan - <LDD 4.3.9> 41555 - Busto - by lipanz - <LDD 4.3.9> 41555 - Busto - by Stephan - <LDD 4.3.9> 41556 - Tiketz - by lipanz - <LDD 4.3.9> 41556 - Tiketz - by Stephan - <LDD 4.3.9> 41557 - Camillot - by KamalMYafi - <LDD 4.3.9> 41557 - Camillot - by Stephan - <LDD 4.3.9> 41558 - Mixadel - by KamalMYafi - <LDD 4.3.9> 41558 - Mixadel - by Stephan - <LDD 4.3.9> 41559 - Paladum - by Stephan - <LDD 4.3.9> 41559 - Paladum - by KamalMYafi - <LDD 4.3.9> 41560 - Jamzy - by Stephan - <LDD 4.3.9> 41560 - Jamzy - by lipanz - <LDD 4.3.9> 41561 - Tapsy - by Stephan - <LDD 4.3.9> 41561 - Tapsy - by lipanz - <LDD 4.3.9> 41562 - Trumpsy - by lipanz - <LDD 4.3.9> 41562 - Trumpsy - by Stephan - <LDD 4.3.9> 41563 - Splasho - by Stephan - <LDD 4.3.9> 41564 - Aquad - by Stephan - <LDD 4.3.9> 41565 - Hydro - by Stephan - <LDD 4.3.9> 41566 - Sharx - by Stephan - <LDD 4.3.9> 41567 - Skulzy - by Stephan - <LDD 4.3.9> 41568 - Lewt - by Stephan - <LDD 4.3.9> 41569 - Surgeo - by Stephan - <LDD 4.3.9> 41570 - Skrubz - by Stephan - <LDD 4.3.9> 41571 - Tuth - by Stephan - <LDD 4.3.9> 41572 - Gobbol - by Kuramapika1 - <LDD 4.3.11> 41573 - Sweepz + Spinza Mix - by Kuramapika1 - <LDD 4.3.11> 41573 - Sweepz - by Kuramapika1 - <LDD 4.3.11> 41574 - Compax - by Kuramapika1 - <LDD 4.3.11> 41575 - Cobrax - by Kuramapika1 - <LDD 4.3.11> 41576 - Spinza - by Kuramapika1 - <LDD 4.3.11> 41577 - Mysto - by Kuramapika1 - <LDD 4.3.11> 41578 - Screeno - by Kuramapika1 - <LDD 4.3.11> 41579 - Camsta - by Kuramapika1 - <LDD 4.3.11> 41580 - Myke - by Kuramapika1 - <LDD 4.3.11> 41500+41501+41502 - Infernites Max - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41500+41504 - Flain + Seismo Mix - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41502+41508 - Zorch + Volectro Mix - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41503+41504+41505 - Cragsters Max - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41505+41507 - Shuff + Zaptor Murp - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41506+41507+41508 - Electroids Max - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41509+41510+41511 - Frosticons Max - by Stephan - <LDD 4.3.8> - Comment: Series 2 - Combines multiple sets 41510+41514 - Lunk Jawg Murp - by Stephan - <LDD 4.3.8> - Comment: Series 2 - Combines multiple sets 41511+41515 - Flurr Kraw Mix - by Stephan - <LDD 4.3.8> - Comment: Series 2 - Combines multiple sets 41512+41513+41514 - Fang Gang Max - by Stephan - <LDD 4.3.8> - Comment: Series 2 - Combines multiple sets 41513+41516 - Gobba Tentro Mix - by Stephan - <LDD 4.3.8> - Comment: Series 2 - Combines multiple sets 41515+41516+41517 - Flexers Max - by Stephan - <LDD 4.3.8> - Comment: Series 2 - Combines multiple sets 41518+41519+41520 - Glorp Corp Max - by Stephan - <LDD 4.3.8> 41521+41522+41523 - Spikels Max - by Stephan - <LDD 4.3.8> 41524+41525+41526 - Wiztastics Max - by Stephan - <LDD 4.3.8> 41527+41528+41529 - Orbitrons Max - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 41528+41532 - Niksput Burnard Mix - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 41529+41535 - Nurp-Naut Boogly Murp - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 41530+41531+41532 - Infernites Max - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 41536+41537+41538 - Klinkers Max - by Stephan - <LDD 4.3.8> 41537+41540 - Jinky Chilbo Murp - by Stephan - <LDD 4.3.8> 41538+41542 - Kamzo Spugg Mix - by Stephan - <LDD 4.3.8> 41539+41540+41541 - Frosticons Max - by Stephan - <LDD 4.3.8> 41541+41544 - Snoof Tungster Mix - by Stephan - <LDD 4.3.8> 41542+41543+41544 - Lixers Max - by Stephan - <LDD 4.3.8> 41545+41546+41547 - Weldos Max - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41545+41549 - Kramm & Gurggle Mix - by Alskadosis - <LDD 4.3.8> 41546+41553 - Forx Vaka-Waka Mix - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41548+41549+41550 - Glorp Corp Max - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41548+41551 - Dribbal Snax Murp - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41551+41552+41553 - Munchos Max - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41554+41555+41556 - MCPD MAX! - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41554+41555+41556 - MCPD Max - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41554+41558 - Mixadel Murp - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41554+41558 - Kuffs Mixadel Murp - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41556+41562 - Tiketz Trumpsy Mix - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41557+41558+41559 - Medieval Max - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41557+41558+41559 - Medivals MAX! - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41557+41561 - Camillot Tapsy Mix - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41557+41562 - Camillot Tapsy Mix - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41560+41561+41562 - Mixies Max - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41560+41561+41562 - Mixies MAX! - by KamalMYafi - <LDD 4.3.10> - Comment: Combines multiple sets 41562+41556 - Trumpsy Tiketz Mix - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41563+41564+41565 - MCFD Max - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41563+41568 - Splasho Lewt Mix - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41564+41571 - Aquad Tuth Murp - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41566+41567+41568 - Pyrratz Max - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41566+41569 - Sharx Surgeo Mix - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41569+41570+41571 - Medix Max - by Stephan - <LDD 4.3.10> - Comment: Combines multiple sets 41572+41573+41574 - Trashoz Max - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41574+41578 - Compax + Screeno Mix - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41575+41576+41577 - Nindjas Max - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41577+41580 - Mysto + Myke Murp - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets 41578+41579+41580 - Newzers Max - by Kuramapika1 - <LDD 4.3.11> - Comment: Combines multiple sets Model Team 5510 - Off-road 4x4 - by C3POwen - <LDD 4> 5521 - Sea Jet - by NeoJB - <LDD 4> 5533 - Red Fury (A model) - by Gnac - <LDD 4.3.6> 5533 - Red Fury (B model) - by Gnac - <LDD 4.3.6> 5540 - Formula 1 Racer - by Tore M - <LDD 4> 5541 - Blue Fury (Hot Rod) - by Tore M - <LDD 4> - Comment: aka 10151 5542 - Black Thunder Helicopter - by BrickWild - <LDD 3> 5550 - Custom Rally Van - by BrickWild - <LDD 4> 5550 - Custom Rally Van (A model) - by Gnac - <LDD 4.3.6> 5550 - Custom Rally Van (B model) - by Gnac - <LDD 4.3.6> 5561 - Big Foot 4x4 - by BrickWild - <LDD 4.3.9> 5563 - Racing Truck (A model) - by Gnac - <LDD 4.3.5> 5563 - Racing Truck (A model) - by C3POwen - <LDD 4> 5563 - Racing Truck (B model) - by Gnac - <LDD 4.3.5> 5571 - Black Cat Giant Truck - by BrickWild - <LDD 4> 5571 - Giant Truck (A model) - by Gnac - <LDD 4.3.8> 5571 - Giant Truck (B model) - by Gnac - <LDD 4.3.8> 5580 - Highway Rig - by mzoli - <LDD 4.3.8> 5580 - Highway Rig - by BrickWild - <LDD 4> 5580 - Highway Rig (B model) - by mzoli - <LDD 4.3.8> 5581 - Magic Flash - by BrickWild - <LDD 4> 5590 - Whirl and Wheel Super Truck - by BrickWild - <LDD 4> Modular Buildings 10182 - Cafe Corner - by Vee - <LDD 4.3.6> 10182 - Cafe Corner - by Johnnhiszippy3 - <LDD 3> 10185 - Green Grocer - by Johnnhiszippy3 - <LDD 3> 10185 - Green Grocer - by Man with a hat - <LDD 4> 10190 - Market Street - by Johnnhiszippy3 - <LDD 3> 10197 - Fire Brigade - by Man with a hat - <LDD 4> 10197 - Fire Brigade - by Johnnhiszippy3 - <LDD 3> 10211 - Grand Emporium - by Johnnhiszippy3 - <LDD 3> 10218 - Pet Shop - by P4trickvH - <LDD 4> 10224 - Town Hall - by Sjuip - <LDD 4.3.9> 10230 - Mini Modulars - by kcoon - <LDD 4.3.8> 10230 - Mini-Modulars - by AndyC - <LDD 4> 10232 - Palace Cinema - by Stephan - <LDD 4.3.6> 10243 - Parisian Restaurant - by pbat - <LDD 4.3.8> 10243 - Parisian Restaurant - by kcoon - <LDD 4.3.8> 10246 - Detective's Office - by vean - <LDD 4.3.9> 10251 - Brick Bank - by LegoPegasister2015 - <LDD 4.3.8> 10255 - Assembly Square - by Stephan - <LDD 4.3.11> 10255 - Assembly Square - by Sjuip - <LDD 4.3.11> 10255 - Assembly Square - by vean - <LDD 4.3.10> 10260 - Downtown Diner - by lomis - <LDD 4.3.10> 10260 - Downtown Diner - by Stephan - <LDD 4.3.11> 10264 - Corner Garage - by TheL390Man - <LDD 4.3.11> 10270 - Bookshop - by vean - <LDD 4.3.11> 40141 - Hotel - Bricktober 2015 - by Gnac - <LDD 4.3.8> 40142 - Train Station - Bricktober 2015 - by Gnac - <LDD 4.3.8> 40143 - Bakery - Bricktober 2015 - by Gnac - <LDD 4.3.8> 40144 - Toys 'R' Us Store - Bricktober 2015 - by Gnac - <LDD 4.3.8> 40180 - Theater - Bricktober 2014 [Promo] - by Gnac - <LDD 4.3.8> 40181 - Pizza Place - Bricktober 2014 [Promo] - by Gnac - <LDD 4.3.8> 40182 - Fire Station - Bricktober 2014 [Promo] - by Gnac - <LDD 4.3.8> 40183 - Town Hall - Bricktober 2014 [Promo] - by Gnac - <LDD 4.3.8> Monster Fighters 9461 - The Swamp Creature - by CM4S - <LDD 4> 9461 - The Swamp Creature - by ADHO15 - <LDD 4> 9462 - The Mummy - by ADHO15 - <LDD 4> 9463 - The Werewolf - by ADHO15 - <LDD 4> 9464 - The Vampire Hearse - by ADHO15 - <LDD 4> 9465 - The Zombies - by ADHO15 - <LDD 4> 9466 - The Crazy Scientist & His Monster - by ADHO15 - <LDD 4> 9467 - The Ghost Train - by Stephan - <LDD 4.3.8> 9467 - The Ghost Train - by ADHO15 - <LDD 4> 9468 - Vampyre Castle - by ADHO15 - <LDD 4> 10228 - Haunted House - by ADHO15 - <LDD 4.3.5> 30200 - Zombie Chauffeur Coffin Car polybag - by ADHO15 - <LDD 4.3.8> 30201 - Ghost - by ok13 - <LDD 4> 30201 - Ghost polybag - by ADHO15 - <LDD 4.3.8> 50006 - Monster Fighters Promotional Pack - by penguinz - <LDD 4.3.6> Edited March 18, 2021 by Calabar Quote
Calabar Posted April 18, 2010 Author Posted April 18, 2010 (edited) Nexo Knights 11913 - Nexo Knights - Build Your Own Adventure - by Kuramapika1 - <LDD 4.3.11> - Comment: TBD - On Bricklink as par 30371 - Knight's Cycle polybag - by KamalMYafi - <LDD 4.3.9> 30372 - Robin's Mini Fortrex polybag - by KamalMYafi - <LDD 4.3.9> 30373 - Knighton Hyper Cannon polybag - by KamalMYafi - <LDD 4.3.9> 30374 - The Lava Slinger polybag - by KamalMYafi - <LDD 4.3.9> 30377 - Motor Horse polybag - by vean - <LDD 4.3.10> 70310 - Knighton Battle Blaster - by Kuramapika1 - <LDD 4.3.11> 70311 - Chaos Catapult - by Kuramapika1 - <LDD 4.3.11> 70312 - Lance's Mecha Horse - by LegoPegasister2015 - <LDD 4.3.9> 70313 - Moltor's Lava Smasher - by LegoPegasister2015 - <LDD 4.3.9> 70314 - Beast Master's Chaos Chariot - by LegoPegasister2015 - <LDD 4.3.9> 70315 - Clay's Rumble Blade - by LegoPegasister2015 - <LDD 4.3.9> 70316 - Jestro's Evil Mobile - by Kuramapika1 - <LDD 4.3.11> 70317 - The Fortrex - by Kuramapika1 - <LDD 4.3.11> 70318 - The Glob Lobber - by Kuramapika1 - <LDD 4.3.11> 70319 - Macy's Thunder Mace - by Kuramapika1 - <LDD 4.3.11> 70320 - Aaron Fox's Aero Striker V2 - by Kuramapika1 - <LDD 4.3.11> 70321 - General Magmar's Siege Machine of Doom - by Kuramapika1 - <LDD 4.3.11> 70347 - King's Guard Artillery - by uchuujin - <LDD 4.3.11> 70348 - Lance's Twin Jouster - by LegoOri - <LDD 4.3.11> Ninja 1184 - Cart - by pbat - <LDD 4.3.6> - Comment: aka 1099 aka 3016 1185 - Raft - by PeabodySam - <LDD 4.3.8> 1187 - Glider - by PeabodySam - <LDD 4.3.8> 3050 - Shanghai Surprise - by marco9999 - <LDD 4.3.5> 3051 - Blaze Attack - by marco9999 - <LDD 4.3.5> 3052 - Ninja Fire Fortress - by marco9999 - <LDD 4.3.5> 3053 - Emperor's Stronghold - by marco9999 - <LDD 4.3.5> 3074 - Red Ninja's Dragon Glider - by PeabodySam - <LDD 4.3.8> 3075 - Ninja Master's Boat - by PeabodySam - <LDD 4.3.8> 3076 - White Ninja's Attack Cart - by PeabodySam - <LDD 4.3.8> 3077 - Ninja Shogun's Small Fort - by PeabodySam - <LDD 4.3.8> 6045 - Ninja Surprise - by marco9999 - <LDD 4.3.5> 6083 - Samurai Stronghold - by marco9999 - <LDD 4.3.5> 6088 - Robber's Retreat - by marco9999 - <LDD 4.3.5> 6089 - Stone Tower Bridge - by marco9999 - <LDD 4.3.5> 6093 - Flying Ninja Fortress - by Aanchir - <LDD 4> 3074+3075+3076+3077 - n/a - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Ninjago 2254 - Mountain Shrine - by Zarkan - <LDD 4.3.5> 2258 - Ninja Ambush - by Zarkan - <LDD 4.3.5> 2259 - Skull Motorbike - by Zarkan - <LDD 4.3.5> 2260 - Ice Dragon Attack - by Aanchir - <LDD 4> 2263 - Turbo Shredder - by J4ke - <LDD 4> 2504 - Spinjitzu Dojo - by penguinz - <LDD 4.3.8> 2505 - Garmadon's Dark Fortress - by penguinz - <LDD 4.3.8> 2506 - Skull Truck - by Zarkan - <LDD 4.3.5> 2507 - Fire Temple - by Tontus - <LDD 4.3.5> 2508 - Blacksmith Shop - by Zarkan - <LDD 4.3.5> 2509 - Earth Dragon Defense - by Venari - <LDD 4.3.5> 2516 - Ninja Training Outpost - by prateek - <LDD 4> 2518 - Nuckal's ATV - by Tontus - <LDD 4.3.5> 2521 - Lightning Dragon Battle - by Zarkan - <LDD 4.3.5> 9440 - Venomari Shrine - by zinfinion - <LDD 4.3.5> 9441 - Kai's Blade Cycle - by zinfinion - <LDD 4> 9442 - Jay's Storm Fighter - by zinfinion - <LDD 4> 9443 - Rattlecopter - by zinfinion - <LDD 4> 9444 - Cole's Tread Assault - by zinfinion - <LDD 4> 9445 - Fangpyre Truck Ambush - by zinfinion - <LDD 4> 9446 - Destiny's Bounty - by Zarkan - <LDD 4.3.5> 9447 - Lasha's Bite Cycle - by Zarkan - <LDD 4.3.5> 9448 - Samurai Mech - by Zarkan - <LDD 4.3.5> 9450 - Epic Dragon Battle - by penguinz - <LDD 4.3.8> 9455 - Fangpyre Mech - by Tontus - <LDD 4> 9558 - Ninja Training - by Tontus - <LDD 4> 30080 - Ninja Glider - by Aanchir - <LDD 4> 30081 - Skeleton Chopper - by Tontus - <LDD 4> 30082 - Ninja Training - by Aanchir - <LDD 4> 30083 - Dragon Fight - by Toa_Of_Justice - <LDD 4> 30085 - Jumping Snakes polybag - by Happy SDE - <LDD 4.3.8> 30086 - Hidden Sword polybag - by Happy SDE - <LDD 4.3.8> 30087 - Car polybag - by Happy SDE - <LDD 4.3.8> 30292 - Jay Nano Mech polybag - by Happy SDE - <LDD 4.3.8> 30293 - Kai Drifter polybag - by Happy SDE - <LDD 4.3.8> 30421 - Skybound Plane polybag - by KamalMYafi - <LDD 4.3.9> 30422 - Kai's Mini Dragon polybag - by KamalMYafi - <LDD 4.3.9> 30423 - Anchor-Jet - by KamalMYafi - <LDD 4.3.9> 30424 - WU-CRU Training Dojo - by PicnicBasketSam - <LDD 4.3.9> 30426 - Stealthy Swamp Airboat polybag - by vean - <LDD 4.3.10> 70500 - Kai's Fire Robot - by Zarkan - <LDD 4.3.5> 70500 - Kai's Fire Robot - by penguinz - <LDD 4.3.8> 70501 - Samurai Bike - by penguinz - <LDD 4.3.8> 70501 - Samurai Bike - by Zarkan - <LDD 4.3.5> 70502 - Cole's Power Drill - by penguinz - <LDD 4.3.8> 70503 - Golden Dragon - by penguinz - <LDD 4.3.8> 70504 - Garmatron - by penguinz - <LDD 4.3.8> 70505 - Temple of Light - by penguinz - <LDD 4.3.8> 70588 - Titanium Ninja Tumbler - by PicnicBasketSam - <LDD 4.3.9> 70589 - Rock Roader - by PicnicBasketSam - <LDD 4.3.9> 70590 - Airjitzu Battle Grounds - by PicnicBasketSam - <LDD 4.3.9> 70591 - Kryptarium Prison Breakout - by PicnicBasketSam - <LDD 4.3.9> 70592 - Salvage M.E.C. - by PicnicBasketSam - <LDD 4.3.9> 70593 - The Green NRG Dragon - by PicnicBasketSam - <LDD 4.3.9> 70594 - The Lighthouse Siege - by PicnicBasketSam - <LDD 4.3.9> 70595 - Ultra Stealth Raider - by PicnicBasketSam - <LDD 4.3.9> 70596 - Samurai X Cave Chaos - by PicnicBasketSam - <LDD 4.3.9> 70601 - Sky Shark - by LegoPegasister2015 - <LDD 4.3.8> 70603 - Raid Zeppelin - by Xenomorph - <LDD 4.3.9> 70610 - Flying Jelly Sub - by PicnicBasketSam - <LDD 4.3.10> 70613 - Garma Mecha Man - by PicnicBasketSam - <LDD 4.3.10> 70616 - Ice Tank - by PicnicBasketSam - <LDD 4.3.10> 70679 - The Ultra Dragon - by zweifuss - <LDD 4.3.11> 70720 - Hover Hunter - by penguinz - <LDD 4.3.8> 70721 - Kai's Fighter - by penguinz - <LDD 4.3.8> 70722 - The OverBorg's Attack - by penguinz - <LDD 4.3.8> 70723 - Thunder Raider - by penguinz - <LDD 4.3.8> 70724 - Ninja Copter - by penguinz - <LDD 4.3.8> 70725 - Nindroid MechDragon - by penguinz - <LDD 4.3.8> 70726 - Destructoid - by penguinz - <LDD 4.3.8> 70727 - X-1 Ninja Charger - by penguinz - <LDD 4.3.8> 70728 - Battle for Ninjago City - by penguinz - <LDD 4.3.8> 70730 - Chain Cycle Ambush - by vean - <LDD 4.3.8> 70731 - Jay Walker One - by vean - <LDD 4.3.8> 70733 - Blaster Bike - by vean - <LDD 4.3.8> 70734 - Master Wu Dragon - by vean - <LDD 4.3.8> 70751 - Temple of Airjitzu - by vean - <LDD 4.3.9> 2856134 - Card Shrine - by Tontus - <LDD 4.3.5> Overwatch 75970 - Tracer vs. Widowmaker - by Kuramapika1 - <LDD 4.3.11> 75971 - Hanzo vs. Genji - by Kuramapika1 - <LDD 4.3.11> 75972 - Dorado Showdown - by Kuramapika1 - <LDD 4.3.11> 75973 - D.Va & Reinhardt - by Kuramapika1 - <LDD 4.3.11> 75974 - Bastion - by Kuramapika1 - <LDD 4.3.11> 75975 - Watchpoint: Gibraltar - by Kuramapika1 - <LDD 4.3.11> Pharaoh's Quest 7305 - Scarab Attack - by prateek - <LDD 4> 7306 - Golden Staff Guardians - by petero - <LDD 4> 7307 - Flying Mummy Attack - by petero - <LDD 4> 7325 - Cursed Cobra Statue - by petero - <LDD 4> 7326 - Rise of the Sphinx - by petero - <LDD 4> 7327 - Scorpion Pyramid - by petero - <LDD 4> 30090 - Desert Glider - by PeabodySam - <LDD 4.3.8> 30091 - Desert Rover - by PeabodySam - <LDD 4.3.8> Pirates 1464 - Pirate Lookout - by AndyC - <LDD 4> 1481 - Desert Island - by AndyC - <LDD 4> 1492 - Battle Cove - by AndyC - <LDD 4> 1713 - Shipwrecked Pirate - by AndyC - <LDD 4> 1747 - Pirate's Treasure Surprise - by AndyC - <LDD 4> 1788 - Treasure Chest - by AndyC - <LDD 4> 1795 - Imperial Cannon - by AndyC - <LDD 4> 1871 - Pirate's Cannon - by AndyC - <LDD 4> 1872 - Soldier's Forge - by AndyC - <LDD 4> 1873 - Pirate's Treasure - by AndyC - <LDD 4> 1889 - Pirate's Treasure Hold - by AndyC - <LDD 4> 1970 - Pirate's Gun Cart - by AndyC - <LDD 4> 6232 - Skeleton Crew - by AndyC - <LDD 4> 6234 - Renegade's Raft - by AndyC - <LDD 4> 6234 - Renegade's Raft - by ashir - <LDD 4> 6235 - Buried Treasure - by AndyC - <LDD 4> 6236 - King Kahuka - by BrickWild - <LDD 4> 6239 - Cannon Battle - by Zeya - <LDD 4> 6239 - Cannon Battle - by AndyC - <LDD 4> 6240 - Kraken Attackin' - by professor flitwick - <LDD 3> 6240 - Kraken Attackin' - by AndyC - <LDD 4> 6241 - Loot Island - by Instructions archiver - <LDD 4.3.5> 6242 - Soldiers' Fort - by professor flitwick - <LDD 3> 6242 - Soldier's Fort - by AndyC - <LDD 4> 6243 - Brickbeard's Bounty - by Captain Becker - <LDD 4> 6243 - Brickbeard's Bounty - by prateek - <LDD 4> 6243 - Brickbeard's Bounty - by bbqqq - <LDD 4> 6244 - Armada Sentry - by AndyC - <LDD 4> 6245 - Harbor Sentry - by AndyC - <LDD 4> 6246 - Crocodile Cage - by AndyC - <LDD 4> 6247 - Bounty Boat - by AndyC - <LDD 4> 6248 - Volcano Island - by AndyC - <LDD 4> 6249 - Pirate's Ambush - by AndyC - <LDD 4> 6253 - Shipwreck Island - by AndyC - <LDD 4> 6254 - Rocky Reef - by AndyC - <LDD 4> 6257 - Castaway's Raft - by AndyC - <LDD 4> 6258 - Smuggler's Shanty - by AndyC - <LDD 4> 6260 - Shipwreck Island - by AndyC - <LDD 4> 6262 - King Kahuka's Throne - by Aanchir - <LDD 3> 6263 - Imperial Outpost - by AndyC - <LDD 4> 6264 - Forbidden Cove - by ok13 - <LDD 4> 6265 - Sabre Island - by AndyC - <LDD 4> 6266 - Cannon Cove - by AndyC - <LDD 4> 6266 - Cannon Cove - by ashir - <LDD 4> 6268 - Renegade Runner - by marco9999 - <LDD 4> 6270 - Forbidden Island - by Elog - <LDD 4.3.8> 6276 - Eldorado Fortress - by AndyC - <LDD 4> 6277 - Imperial Trading Post - by Instructions archiver - <LDD 4.3.6> 6279 - Skull Island - by AndyC - <LDD 4> 6281 - Pirates Perilous Pitfall - by penguinz - <LDD 4.3.6> 6292 - Enchanted Island - by ok13 - <LDD 4> - Comment: aka 6278 8396 - Soldier's Arsenal - by Captain Becker - <LDD 4> 8397 - Pirates Survival - by Captain Becker - <LDD 4> 10040 - Black Seas Barracuda - by Myles - <LDD 4> - [INCOMPLETE] - Comment: aka 6285 - Minifigs missing 10210 - Imperial Flagship - by marco9999 - <LDD 4> 40158 - Pirates Chess Set - by vean - <LDD 4.3.8> 70409 - Shipwreck Defense - by LegoPegasister2015 - <LDD 4.3.8> 70410 - Soldiers Outpost - by LegoPegasister2015 - <LDD 4.3.8> 70411 - Treasure Island - by LegoPegasister2015 - <LDD 4.3.8> 70412 - Soldiers Fort - by LegoPegasister2015 - <LDD 4.3.8> 70413 - The Brick Bounty - by bbqqq - <LDD 4.3.8> Pirates of the Caribbean 4181 - Isla De Muerta - by ADHO15 - <LDD 4> 4182 - The Cannibal Escape - by ADHO15 - <LDD 4> 4183 - The Mill - by ADHO15 - <LDD 4> 4184 - Black Pearl - by swils - <LDD 4.3.5> 4184 - Black Pearl - by penguinz - <LDD 4> 4191 - Captain's Cabin - by Captain Becker - <LDD 4> 4191 - Captain's Cabin - by ADHO15 - <LDD 4> 4192 - Fountain of Youth - by ADHO15 - <LDD 4> 4192 - Fountain of Youth - by Captain Becker - <LDD 4> 4193 - The London Escape - by ADHO15 - <LDD 4> 4194 - Whitecap Bay - by ADHO15 - <LDD 4> 4195 - Queen Anne's Revenge - by ADHO15 - <LDD 4> 30130 - MINI Black Pearl - by ADHO15 - <LDD 4> 30131 - Jack Sparrow's Boat - by ADHO15 - <LDD 4> 30132 - Captain Jack Sparrow - by ADHO15 - <LDD 4> 30133 - Jack Sparrow - by ADHO15 - <LDD 4> 71042 - Silent Mary - by Stephan - <LDD 4.3.11> 853219 - Pirates of the Caribbean Battle Pack - by ADHO15 - <LDD 4> Power Miners 8188 - Fire Blaster - by messiah1 - <LDD 4> 8189 - Magma Mech - by messiah1 - <LDD 4> 8190 - Claw Catcher - by Toa_Of_Justice - <LDD 4> 8191 - Lavatraz - by penguinz - <LDD 4.3.8> 8707 - Boulder Blaster - by Aanchir - <LDD 4> 8708 - Cave Crusher - by Aanchir - <LDD 4> 8709 - Underground Mining Base - by penguinz - <LDD 4.3.8> 8709 - Underground Mining Station (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Rubble Rescue Rover" 8907 - Rock Hacker - by PeabodySam - <LDD 4.3.6> 8908 - Monster Launcher - by PeabodySam - <LDD 4.3.6> 8956 - Stone Chopper - by prateek - <LDD 3> 8957 - Mine Mech - by prateek - <LDD 3> 8958 - Granite Grinder - by Aanchir - <LDD 4> 8959 - Claw Digger - by prateek - <LDD 3> 8960 - Thunder Driller - by obsidianheart - <LDD 4> 8961 - Crystal Sweeper - by penguinz - <LDD 4.3.8> 8962 - Crystal King - by Aanchir - <LDD 4> 8963 - Rock Wrecker - by PeabodySam - <LDD 4.3.8> 8964 - Titanium Command Rig - by PeabodySam - <LDD 4.3.8> 8964 - Titanium Command Rig (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Blast Roller" 8964 - Titanium Command Rig (C model) - by PeabodySam - <LDD 4.3.8> - Comment: "Felsenstürmer" 8956+8957 - Cave Cutter - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 8958+8960 - Aero Shredder - by Stephan - <LDD 4.3.8> - Comment: Combines multiple sets 8959+8961 - Crystal Crawler - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Powerpuff Girls 41287 - Bubbles Playground Showdown - by PicnicBasketSam - <LDD 4.3.11> 41288 - Mojo Jojo Strikes - by PicnicBasketSam - <LDD 4.3.11> Prince of Persia 7569 - Desert Attack - by ADHO15 - <LDD 4> 7570 - Ostrich Race - by prateek - <LDD 3> 7571 - Fight For The Dagger - by prateek - <LDD 4> 7572 - Quest Against Time - by ADHO15 - <LDD 4> 7573 - Battle Of Alamut - by ADHO15 - <LDD 4> 20017 - Dagger Trap - by Aanchir - <LDD 4> Promotional n/a - Star Wars - Millennium Falcon - by Kuramapika1 - <LDD 4.3.11> - Comment: Tesco Racers 4308 - Yellow Racer - by Toa_Of_Justice - <LDD 4> 4309 - Blue Racer - by Toa_Of_Justice - <LDD 4> 4310 - Orange Racer - by Toa_Of_Justice - <LDD 4> 4947 - Gray and Yellow Racer (polybag) - by Gnac - <LDD 4.3.8> 4948 - Black and Red Racer (polybag) - by Gnac - <LDD 4.3.8> 4949 - Blue and Yellow Racer (polybag) - by Gnac - <LDD 4.3.8> 7452 - Lime / Black Racer - by Gnac - <LDD 4.3.8> 7453 - Off Road - by Gnac - <LDD 4.3.8> 7611 - Police Car - by Gnac - <LDD 4.3.8> 7612 - Muscle Car - by Gnac - <LDD 4.3.8> 7613 - Track Racer - by Gnac - <LDD 4.3.8> 7800 - Off Road Racer - by Gnac - <LDD 4.3.8> 7801 - Rally Racer - by Toa_Of_Justice - <LDD 4> 7802 - Le Mans Racer - by Toa_Of_Justice - <LDD 4.3.8> 8119 - Thunder Racer - by Gnac - <LDD 4.3.8> 8120 - Rally Sprinter - by Gnac - <LDD 4.3.8> 8121 - Track Marshal - by Gnac - <LDD 4.3.8> 8122 - Desert Viper - by Gnac - <LDD 4.3.8> 8123 - Ferrari F1 Racers - by marco9999 - <LDD 4.3.8> 8124 - Ice Rally - by marco9999 - <LDD 4.3.8> 8125 - Thunder Raceway - by marco9999 - <LDD 4.3.8> 8126 - Desert Challenge - by marco9999 - <LDD 4.3.8> 8130 - Terrain Crusher - by Gnac - <LDD 4.3.8> 8131 - Raceway Rider - by Gnac - <LDD 4.3.8> 8132 - Night Driver - by Gnac - <LDD 4.3.8> 8133 - Rally Runner - by Gnac - <LDD 4.3.8> 8134 - Night Crusher - by Gnac - <LDD 4.3.8> 8135 - Bridge Chase - by marco9999 - <LDD 4.3.8> 8143 - Ferrari F430 Challenge (A model) - by marco9999 - <LDD 4.3.8> 8143 - Ferrari F430 Challenge (B model) - by marco9999 - <LDD 4.3.8> 8146 - Nitro Muscle - by Stephan - <LDD 4.3.8> 8147 - Bullet Run - by marco9999 - <LDD 4.3.8> 8148 - EZ Roadster - by prateek - <LDD 3> 8149 - Midnight Streak - by Gnac - <LDD 4.3.8> 8150 - ZX Turbo - by Gnac - <LDD 4.3.8> 8151 - Adrift Sport - by Gnac - <LDD 4.3.8> 8152 - Speed Chasing (A model) - by Gnac - <LDD 4.3.8> 8152 - Speed Chasing (B model) - by Gnac - <LDD 4.3.8> 8153 - Ferrari F1 Truck 1:55 - by marco9999 - <LDD 4> 8154 - Brick Street Customs - by marco9999 - <LDD 4.3.8> 8155 - Ferrari F1 Pitstop - by BrickWild - <LDD 3> 8156 - Ferrari FXX 1:17 - by JunkstyleGio - <LDD 3> 8156 - Ferrari FXX 1:17 - by Gnac - <LDD 4.3.8> 8157 - Ferrari F1 1:9 - by marco9999 - <LDD 4.3.8> 8158 - Speed Racer & Snake Oiler - by Randal - <LDD 3> 8159 - Racer X & Taejo Togokhan - by Randal - <LDD 3> 8159 - Racer X & Taejo Togokhan - by prateek - <LDD 3> 8160 - Cruncher Block & Racer X - by penguinz - <LDD 4.3.8> 8161 - Grand Prix Race - by penguinz - <LDD 4.3.8> 8169 - Lamborghini Gallardo LP560-4 - by prateek - <LDD 3> 8169 - Lamborghini Gallardo LP560-4 - by JunkstyleGio - <LDD 3> 8182 - Monster Crushers - by marco9999 - <LDD 4.3.8> 8183 - Track Turbo RC (A model) - by JC75 - <LDD 4.3.8> 8183 - Track Turbo RC (B model) - by JC75 - <LDD 4.3.8> 8183 - Track Turbo RC (C model) - by JC75 - <LDD 4.3.8> 8184 - Twin X-treme RC (A model) - by JC75 - <LDD 4.3.8> 8184 - Twin X-treme RC (B model) - by JC75 - <LDD 4.3.8> 8184 - Twin X-treme RC (C model) - by JC75 - <LDD 4.3.8> 8184 - Twin X-treme RC (D model) - by JC75 - <LDD 4.3.8> 8185 - Ferrari Truck - by BrickWild - <LDD 3> 8186 - Street Extreme - by marco9999 - <LDD 4.3.8> 8192 - Lime racer - by marco9999 - <LDD 4> 8193 - Blue Bullet - by Gnac - <LDD 4.3.8> 8194 - Nitro muscle - by marco9999 - <LDD 4> 8195 - Turbo Tow - by Gnac - <LDD 4.3.8> 8196 - Chopper Jump - by marco9999 - <LDD 4.3.8> 8197 - Highway Chaos - by C3POwen - <LDD 4> 8198 - Ramp Crash - by marco9999 - <LDD 4.3.8> 8199 - Security Smash - by marco9999 - <LDD 4.3.8> 8211 - Brick Street Getaway - by C3POwen - <LDD 4> 8214 - Lamborghini Policia - by Randal - <LDD 3> 8214 - Lamborghini Policia - by ILikePi - <LDD 3> 8301 - Urban Enforcer - by Aanchir - <LDD 4> 8302 - Rod Rider - by Aanchir - <LDD 4> 8303 - Demon Destroyer - by Aanchir - <LDD 4> 8304 - Smokin' Slickster - by Aanchir - <LDD 4> 8354 - Exo Force Bike - by JC75 - <LDD 4.3.8> 8355 - H.O.T. Blaster Bike - by JC75 - <LDD 4.3.8> 8356 - Jungle Monster (A model) - by JC75 - <LDD 4.3.8> - Comment: "Jungle" 8357 - Zonic Strike (A model) - by JC75 - <LDD 4.3.8> 8357 - Zonic Strike (B model) - by JC75 - <LDD 4.3.8> - Comment: "Desert" 8357 - Zonic Strike (C model) - by JC75 - <LDD 4.3.8> - Comment: "Drag" 8370 - Nitro Stunt Bike - by JC75 - <LDD 4.3.8> 8371 - Extreme Power Bike - by JC75 - <LDD 4.3.8> 8374 - Williams F1 Team Racer 1:27 - by JC75 - <LDD 4.3.8> 8389 - M. Schumacher & R. Barrichello - by Happy SDE - <LDD 4.3.8> 8461 - Williams F1 Team Racer - by Kuramapika1 - <LDD 4.3.11> 8461 - Williams F1 Team Racer - by marco9999 - <LDD 4> 8495 - Crosstown Craze - by Gnac - <LDD 4.3.8> 8641 - Flame Glider - by Gnac - <LDD 4.3.8> 8642 - Monster Crusher - by Gnac - <LDD 4.3.8> 8643 - Power Cruiser - by Gnac - <LDD 4.3.8> 8644 - Street Maniac - by Gnac - <LDD 4.3.8> 8649 - Nitro Menace - by Stephan - <LDD 4> 8650 - Furious Slammer Racer - by marco9999 - <LDD 4.3.8> 8650 - Furious Slammer Racer (B model) - by marco9999 - <LDD 4.3.8> 8652 - Enzo Ferrari 1:17 - by legolijntje - <LDD 4> 8654 - Scuderia Ferrari Truck - by primitiv - <LDD 4> 8655 - RX-Sprinter - by Gnac - <LDD 4.3.8> 8656 - F6 Truck - by Gnac - <LDD 4.3.8> 8657 - ATR 4 - by Gnac - <LDD 4.3.8> 8658 - Big Bling Wheelie - by Gnac - <LDD 4.3.8> 8661 - Carbon Star - by Gnac - <LDD 4.3.8> 8662 - Blue Renegade - by Gnac - <LDD 4.3.8> 8663 - Fat Trax - by Gnac - <LDD 4.3.8> 8664 - Road Hero - by Gnac - <LDD 4.3.8> 8665 - Highway Enforcer - by Gnac - <LDD 4.3.8> 8666 - Tuner X - by Gnac - <LDD 4.3.8> 8671 - Ferrari 430 Spider 1:17 - by Daedalus304 - <LDD 4> 8674 - Ferrari F1 Racer 1:8 - by marco9999 - <LDD 4.3.8> 8681 - Tuner Garage - by primitiv - <LDD 4> 8864 - Desert of Destruction - by Randal - <LDD 3> 8896 - Snake Canyon - by prateek - <LDD 3> 9092 - Crazy Demon - by peterski - <LDD 4.3.5> 9093 - Bone Cruncher - by peterski - <LDD 4.3.5> 9094 - Star Striker - by peterski - <LDD 4.3.5> 9095 - Nitro Predator - by peterski - <LDD 4.3.5> 30030 - Racing Car - by Gnac - <LDD 4.3.8> 30031 - World Race Powerboat - by ILikePi - <LDD 3> 30032 - World Race Buggy - by ILikePi - <LDD 3> 30033 - Racing Truck - by Gnac - <LDD 4.3.8> 30034 - Racing Tow Truck - by Gnac - <LDD 4.3.8> 30035 - Off Road Racer 2 - by Gnac - <LDD 4.3.8> 30036 - Buggy Racer - by Toa_Of_Justice - <LDD 4> 30190 - Ferrari 150 Italia - by Ham17 - <LDD 4.3.6> 30191 - Scuderia Ferrari Truck - by Ham17 - <LDD 4.3.6> 30192 - Ferrari F40 - by Ham17 - <LDD 4.3.6> 30193 - 250 GT Berlinetta - by Ham17 - <LDD 4.3.6> 30194 - 458 Italia - by Ham17 - <LDD 4.3.6> 30195 - FXX - by Ham17 - <LDD 4.3.6> 30196 - Shell F1 Team - by Ham17 - <LDD 4.3.6> 40190 - Ferrari F138 - by Gnac - <LDD 4.3.8> 40191 - Ferrari F12 Berlinetta - by Gnac - <LDD 4.3.8> 40192 - Ferrari 250 GTO - by Gnac - <LDD 4.3.9> 40193 - Ferrari 512 S - by Gnac - <LDD 4.3.8> 40194 - Finish Line & Podium - by Gnac - <LDD 4.3.8> 40195 - Shell Station - by Gnac - <LDD 4.3.8> 40196 - Shell Tanker - by Gnac - <LDD 4.3.8> 40200 - BMW [Promo] - by Gnac - <LDD 4.3.8> 4948+7452+7453 - BrickMaster Racers Exclusive 1 - by Gnac - <LDD 4.3.8> 4948+7452+7453 - BrickMaster Racers Exclusive 2 - by Gnac - <LDD 4.3.8> 4948+7452+7453 - BrickMaster Racers Exclusive 3 - by Gnac - <LDD 4.3.8> 8119+8122 - Thunder Viper - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8120+8121 - Rally Marshall - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8130+8131 - Terrain Rider - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8132+8133 - Night Rider - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8148+8149+8150+8151 - Turbo Truck - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8148+8151 - EZ-Sportster - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8149+8150 - Midnight Turbo - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8192+8193+8194+8194 - Blue Lightning - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8192+8194 - [No Official Name] - by marco9999 - <LDD 4.3.8> - Comment: Combines multiple sets 8193+8195 - Blue Tow - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8301+8304 - [No Official Name] - by Aanchir - <LDD 4.3.8> - Comment: Combines multiple sets 8302+8303 - [No Official Name] - by Aanchir - <LDD 4.3.8> - Comment: Combines multiple sets 8354+8355 - Twin Powered Street Racer - by JC75 - <LDD 4.3.8> - Comment: Combines multiple sets 8370+8371 - Twin Powered Buggy - by JC75 - <LDD 4.3.8> - Comment: Combines multiple sets 8641+8642 - Flame Crusher - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8643+8644 - Power Maniac - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8655+8658 - RX-Wheelie - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8656+8657 - F6/4 - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8661+8666 - Carbon-X - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8662+8665 - Blue Enforcer - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets 8663+8664 - Fat Hero - by Gnac - <LDD 4.3.8> - Comment: Combines multiple sets Rock Raiders 1274 - Light Hover - by PeabodySam - <LDD 4.3.5> 1275 - {Rock Saw Vehicle} - by PeabodySam - <LDD 4.3.5> 1276 - Helicopter Transport - by PeabodySam - <LDD 4.3.5> 1277 - Drill Craft - by PeabodySam - <LDD 4.3.5> 4910 - Hover Scout - by Daedalus304 - <LDD 4> 4920 - Rapid Rider - by Daedalus304 - <LDD 4> 4940 - Granite Grinder - by Daedalus304 - <LDD 4> 4940 - Granite Grinder (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Cavern Crusher" 4950 - Loader - Dozer (A model) - by PeabodySam - <LDD 4.3.8> 4950 - Loader - Dozer (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Hover Transport" 4970 - Chrome Crusher - by Daedalus304 - <LDD 4> 4980 - Tunnel Transport - by Daedalus304 - <LDD 4> 4990 - The Rock Raiders HQ - by penguinz - <LDD 4.3.8> 1274+1275+1276+1277 - [No Official Name] - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Samsonite 343 - Ferry Boat - by marco9999 - <LDD 4> 343 - Ferry Boat - by Stephan - <LDD 4.3.8> 346 - Jumbo Jet - by Giovanne - <LDD 4> 346 - Jumbo Jet - by Stephan - <LDD 4.2.5> 348 - Mini-Wheel Car and Truck Set - by Stephan - <LDD 4> Scooby-Doo 75900 - Mummy Museum Mystery - by vean - <LDD 4.3.8> 75901 - Mystery Plane Adventures - by vean - <LDD 4.3.8> 75902 - The Mystery Machine - by vean - <LDD 4.3.9> 75903 - Haunted Lighthouse - by vean - <LDD 4.3.8> 75904 - Mystery Mansion - by vean - <LDD 4.3.8> Sculptures 3450 - Statue of Liberty - by ADHO15 - <LDD 3> 3451 - Sopwith Camel - by yellost - <LDD 3> 3723 - Lego Minifigure - by AndyC - <LDD 4> 3724 - LEGO Dragon - by dluders - <LDD 3> 6163 - A World of LEGO Mosaic - by AndyC - <LDD 4> - Comment: 9+1 Versions 10024 - Red Baron - by yellost - <LDD 3> 10124 - Wright Flyer - by yellost - <LDD 3> 10155 - MAERSK Container Ship - by BrickWild - <LDD 3> - Comment: aka 10152 10177 - Boeing 787 Dreamliner - by kcoon - <LDD 4.3.8> 10177 - Boeing 787 Dreamliner - by yellost - <LDD 3> 10181 - Eiffel Tower 1:300 Scale - by kcoon - <LDD 4.3.8> 10181 - Eiffel Tower 1:300 - by Jan - <LDD 3> 10187 - Volkswagen Beetle - by ILikePi - <LDD 3> 10189 - Taj Mahal - by bbqqq - <LDD 3> - [INCOMPLETE] - Comment: NO Universe Mode 10189 - Taj Mahal - by ADHO15 - <LDD 4> 10196 - Grand Carousel - by bbqqq - <LDD 3> - [INCOMPLETE] - Comment: NO Universe Mode 10213 - Shuttle Adventure - by yellost - <LDD 3> 10213 - Shuttle Adventure - by Aanchir - <LDD 3> 10214 - Tower Bridge - by ADHO15 - <LDD 3> 10214 - Tower Bridge - by yellost - <LDD 3> 10214 - Tower Bridge - by kcoon - <LDD 4.3.8> 10220 - Volkswagon T1 Camper Van - by ADHO15 - <LDD 4> 10226 - Sopwith Camel - by JGW3000 - <LDD 4.3.8> 10226 - Sopwith Camel - by bbqqq - <LDD 4> 10231 - Shuttle Expedition - by prateek - <LDD 4> 10234 - Sydney Opera House - by pbat - <LDD 4.3.6> 10241 - Maersk Line Triple-E - by Stephan - <LDD 4.3.8> 10241 - Maersk Line Triple-E - by kcoon - <LDD 4.3.8> 10252 - Volkswagen Beetle (VW Beetle) - by Stephan - <LDD 4.3.10> 10253 - Big Ben - by Stephan - <LDD 4.3.9> 40109 - Mini MINI Cooper - by vean - <LDD 4.3.8> Space 1785 - Introducing Crater Critters - by vean - <LDD 4.3.8> Space / Alien Conquest 7049 - Alien Striker - by P4trickvH - <LDD 4> 7050 - Alien Defender - by Giovanne - <LDD 4> 7050 - Alien Defender - by P4trickvH - <LDD 4> 7051 - Tripod Invader - by P4trickvH - <LDD 4> 7052 - Alien Conquest - by P4trickvH - <LDD 4> 7065 - Alien Mothership - by marco9999 - <LDD 4.3.6> 7066 - Earth Defense HQ - by AndyC - <LDD 4> 7066 - Earth Defense HQ - by P4trickvH - <LDD 4> 7067 - Jet-Copter Encounter - by Giovanne - <LDD 4> 7067 - Jet-Copter Encounter - by P4trickvH - <LDD 4> 30140 - ADU Walker - by marco9999 - <LDD 4.3.5> 30141 - ADU Jet Pack - by marco9999 - <LDD 4> Space / Blacktron I 1875 - Meteor Monitor - by Commander Uno - <LDD 4> 6876 - Alienator - by AndyC - <LDD 4> 6876 - Alienator - by C3POwen - <LDD 4> 6894 - Invader - by zinfinion - <LDD 4> 6941 - Battrax - by obsidianheart - <LDD 4> 6954 - Renegade - by vynsane - <LDD 4> 6987 - Message Intercept Base - by Calabar - <LDD 4.3.6> Space / Blacktron II 1462 - Galactic Scout - by Plastemaurer - <LDD 4> 1479 - 2-Pilot Craft - by C3POwen - <LDD 4> 1694 - Galactic Scout - by Calabar - <LDD 4.3.6> 1887 - Scout Patrol Ship - by Plastemaurer - <LDD 4> 6812 - Grid Trekkor - by Plastemaurer - <LDD 4> 6832 - Super Nova II - by Plastemaurer - <LDD 4> 6851 - Tri-Wheeled Tyrax - by Plastemaurer - <LDD 4> 6861 - Blacktron Super Vehicle (Super Model instructions) - by zinfinion - <LDD 4> 6878 - Sub Orbital Guardian - by C3POwen - <LDD 4> 6887 - Allied Avenger - by Plastemaurer - <LDD 4> 6933 - Spectral Starguider - by Plastemaurer - <LDD 4> 6981 - Aerial Intruder - by Plastemaurer - <LDD 4> 6988 - Alpha Centaury Outpost - by Plastemaurer - <LDD 4> Space / Classic Space 442 - Space Shuttle - by AndyC - <LDD 4> 452 - Mobile Tracking Station - by Randal - <LDD 3> 452 - Mobile Ground Tracking Station - by vean - <LDD 4.3.6> 452 - Mobile Tracking Station - by AndyC - <LDD 4> 462 - Rocket Launcher - by AndyC - <LDD 4> 462 - Rocket Launcher - by marco9999 - <LDD 4.3.9> 483 - Alpha-1 Rocket Base - by AndyC - <LDD 4> 493 - Space Command Center (Flatplate version) - by AndyC - <LDD 4> 497 - Galaxy Explorer - by AndyC - <LDD 4> 885 - Space Scooter - by Cadder - <LDD 3> 886 - Space Buggy - by Cadder - <LDD 3> 889 - Radar Truck - by marco9999 - <LDD 4.3.9> 891 - Two-man Scooter - by marco9999 - <LDD 4.3.9> 918 - Space Transport - by Randal - <LDD 3> 924 - Transporter - by BrickWild - <LDD 3> 1498 - Spy-Bot - by AndyC - <LDD 4> 1499 - Twin Starfire - by AndyC - <LDD 4> 1526 - Unknown LEGO Classic Space set - by Lego Otaku - <LDD 4.3.9> 1557 - Scooter - by vean - <LDD 4.3.8> 1558 - Mobile Command Trailer - by vean - <LDD 4.3.8> 1580 - Lunar Scout - by Canticleer blues - <LDD 4> 1593 - Super Model - by vean - <LDD 4.3.8> 1968 - (Unknown) - by Lego Otaku - <LDD 4.3.9> 1968 - Unknown - by AndyC - <LDD 4> 6780 - XT Starship - by zinfinion - <LDD 4> 6783 - Sonar Transmitting Cruiser - by zinfinion - <LDD 4> 6801 - Rocket Sled - by marco9999 - <LDD 4.3.9> 6802 - Space Probe - by AndyC - <LDD 4> 6803 - Space Patrol - by Giovanne - <LDD 4> 6804 - Surface Rover - by Kerilk - <LDD 4.3.6> 6805 - Astro Dasher - by AndyC - <LDD 4> 6805 - Astro Dasher - by Giovanne - <LDD 4> 6806 - Surface Hopper - by AndyC - <LDD 4> 6807 - Space Scooter with Robot - by Giovanne - <LDD 4> 6807 - Space Scooter with Robot - by AndyC - <LDD 4> 6808 - Galaxy Trekkor - by Kerilk - <LDD 4.3.6> 6809 - XT-5 and Droid - by Plastemaurer - <LDD 4> 6820 - Starfire I - by AndyC - <LDD 4> 6821 - Crater Crawler - by zinfinion - <LDD 4> 6822 - Space Digger - by marco9999 - <LDD 4.3.9> 6822 - Space Digger - by vean - <LDD 4.3.6> 6822 - Space Digger - by AndyC - <LDD 4.3.5> 6823 - Surface Transport - by marco9999 - <LDD 4.3.9> 6824 - Space Dart - by Giovanne - <LDD 4> 6825 - Cosmic Comet - by AndyC - <LDD 4> 6826 - Crater Crawler - by mzoli - <LDD 4.3.8> 6827 - Strata Scooter - by vean - <LDD 4.3.8> 6841 - Mineral Detector - by vean - <LDD 4.3.6> 6842 - Shuttle Craft - by vean - <LDD 4.3.6> 6844 - Seismologic Vehicle - by zinfinion - <LDD 4> 6845 - Cosmic Charger - by Kerilk - <LDD 4.3.6> 6846 - Tri-Star Voyager - by vean - <LDD 4.3.8> 6847 - Space Dozer - by vean - <LDD 4.3.8> 6849 - Satellite Patroller - by vean - <LDD 4.3.8> 6861 - X1 Patrol Craft - by Lego Otaku - <LDD 4.3.9> 6870 - Space Probe Launcher - by vean - <LDD 4.3.8> 6871 - Star Patrol Launcher - by zinfinion - <LDD 4> 6872 - Lunar Patrol Craft - by zinfinion - <LDD 4> 6874 - Moonrover - by marco9999 - <LDD 4.3.9> 6880 - Surface Explorer - by Plastemaurer - <LDD 4> 6881 - Lunar Rocket Launcher - by zinfinion - <LDD 4> 6882 - Walking Astro Grappler - by vean - <LDD 4.3.8> 6883 - Terrestrial Rover - by vean - <LDD 4.3.8> 6890 - Cosmic Cruiser - by Aanchir - <LDD 4> 6891 - Gamma V Laser Craft - by zinfinion - <LDD 4> 6891 - Gamma V Laser Craft - by Canticleer blues - <LDD 4.3.6> 6892 - Modular Space Transport - by vean - <LDD 4.3.6> 6901 - Mobile Lab - by vean - <LDD 4.3.6> 6926 - Mobile Recovery Vehicle - by vean - <LDD 4.3.8> 6927 - All-Terrain Vehicle - by vean - <LDD 4.3.6> 6928 - Uranium Search Vehicle - by zinfinion - <LDD 4> 6929 - Starfleet Voyager - by Giovanne - <LDD 4> 6930 - Space Supply Station - by Calabar - <LDD 4> 6931 - FX-Star Patroller - by AndyC - <LDD 4> 6931 - FX-Star Patroller - by Giovanne - <LDD 4> 6940 - Alien Moon Stalker - by AndyC - <LDD 4> 6950 - Mobile Rocket Transport - by bublible - <LDD 4.3.6> 6950 - Mobile Rocket Transport - by bublible - <LDD 4.3.6> 6951 - Robot Command Centre - by AndyC - <LDD 4> 6952 - Solar Power Transporter - by zinfinion - <LDD 4> 6970 - Beta I Command Base - by vean - <LDD 4.3.6> 6971 - Inter-Galactic Command Base - by Canticleer blues - <LDD 4> 6972 - Polaris-I Space Lab - by Calabar - <LDD 4> 6980 - Galaxy Commander - by Kingston - <LDD 4.3.6> 6985 - Cosmic Fleet Voyager - by zinfinion - <LDD 4> 6985 - Cosmic Fleet Voyager - by Canticleer blues - <LDD 4.3.6> Space / Exploriens 1737 - Scorpion Detector - by vean - <LDD 4.3.8> 1858 - Droid Scout - by vean - <LDD 4.3.8> 6815 - Hovertron - by Happy SDE - <LDD 4.3.8> 6899 - Nebula Outpost - by ilulz - <LDD 4.3.5> 6958 - Android Base - by penguinz - <LDD 4.3.6> 6982 - Explorien Starship - by ilulz - <LDD 4.3.5> Space / Futuron 1620 - Astro Dart - by vean - <LDD 4.3.8> 1621 - Lunar MPV Vehicle - by vean - <LDD 4.3.8> 1974 - Star Quest - by vean - <LDD 4.3.8> 6770 - Lunar Transporter Patroller - by zinfinion - <LDD 4> 6810 - Laser Ranger - by Kerilk - <LDD 4.3.6> 6828 - Twin-Winged Spoiler - by vean - <LDD 4.3.8> 6830 - Space Patroller - by Plastemaurer - <LDD 4> 6848 - Strategic Pursuer - by AndyC - <LDD 4> 6850 - Auxiliary Patroller - by Plastemaurer - <LDD 4> 6875 - Hovercraft - by vean - <LDD 4.3.8> 6884 - AERO-Module - by AndyC - <LDD 4> 6884 - AERO Module - by Plastemaurer - <LDD 4> 6885 - Saturn Team Main Team (Crater Crawler) - by marco9999 - <LDD 4> 6893 - Galactic Starship - by AndyC - <LDD 4> 6925 - Interplanetary Rover - by zinfinion - <LDD 4> 6932 - Stardefender 200 - by Calabar - <LDD 4> 6953 - Cosmic Laser Launcher - by marco9999 - <LDD 4.3.5> Space / Galaxy Squad 30230 - Mini Mech - by DawnTreader - <LDD 4.3.6> 30231 - Space Insectoid polybag - by Happy SDE - <LDD 4.3.8> 70700 - Space Swarmer - by penguinz - <LDD 4.3.8> 70701 - Swarm Interceptor - by penguinz - <LDD 4.3.8> 70702 - Warp Stinger - by marco9999 - <LDD 4.3.6> 70703 - Star Slicer - by penguinz - <LDD 4.3.8> 70704 - Vermin Vaporizer - by penguinz - <LDD 4.3.8> 70705 - Bug Obliterator - by penguinz - <LDD 4.3.8> 70706 - Crater Creeper - by CM4S - <LDD 4.3.6> 70706 - Crater Creeper - by penguinz - <LDD 4.3.6> 70707 - CLS-89 Eradicator Mech - by penguinz - <LDD 4.3.6> 70708 - Hive Crawler - by penguinz - <LDD 4.3.6> 70709 - Galactic Titan - by penguinz - <LDD 4.3.6> Space / Ice Planet 2002 1704 - Ice Planet Snow Grader - by Randal - <LDD 3> 1711 - Snow Scooter/Space Diver - by zinfinion - <LDD 4> - Comment: aka 1731, 3014 6814 - Ice Tunnelator - by zinfinion - <LDD 4> 6834 - Celestial Sled - by zinfinion - <LDD 4> 6879 - Blizzard Baron - by zinfinion - <LDD 4> 6898 - Ice-Sat V - by zinfinion - <LDD 4> 6973 - Deep Freeze Defender - by Jeff - <LDD 3> 6973 - Deep Freeze Defender - by zinfinion - <LDD 4> 6983 - Ice Station Odyssey - by zinfinion - <LDD 4.3.5> Space / Insectoids 2964 - Space Spider - by vean - <LDD 4.3.8> 2965 - Hornet Scout - by vean - <LDD 4.3.8> 3070 - Mosquito - by vean - <LDD 4.3.8> 3071 - Light Flyer - by vean - <LDD 4.3.8> 3072 - Mega Tack - by vean - <LDD 4.3.8> 3073 - Booster - by vean - <LDD 4.3.8> 6817 - Beta Buzzer - by vean - <LDD 4.3.8> 6837 - Cosmic Creeper - by vean - <LDD 4.3.8> 6903 - Bug Blaster - by vean - <LDD 4.3.8> 6919 - Planetary Prowler - by Daedalus304 - <LDD 4> 6942 - Space Sled - by Daedalus304 - <LDD 4> Space / Life On Mars 1195 - Alien Encounter - by marco9999 - <LDD 4> 7300 - Double Hover - by marco9999 - <LDD 4> - Comment: aka 7308 or 1414 7301 - Rover - by marco9999 - <LDD 4> - Comment: aka 1413 7302 - Worker Robot - by marco9999 - <LDD 4.3.5> - Comment: aka 1416 7303 - Jet Scooter - by marco9999 - <LDD 4> - Comment: aka 1415 7310 - Mono Jet - by marco9999 - <LDD 4> 7311 - Red Planet Cruiser - by marco9999 - <LDD 4.3.5> 7312 - T3-Trike - by marco9999 - <LDD 4> 7312 - T3-Trike - by penguinz - <LDD 4.3.8> 7313 - Red Planet Protector - by marco9999 - <LDD 4> 7314 - Recon-Mech RP - by marco9999 - <LDD 4.3.5> 7314 - Recon-Mech RP (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Guardian Mech" 7314 - Recon-Mech RP (C model) - by PeabodySam - <LDD 4.3.8> - Comment: "Biodium Blaster" 7315 - Solar Explorer - by penguinz - <LDD 4.3.8> 7316 - Excavation Searcher - by marco9999 - <LDD 4.3.5> 7316 - Excavation Searcher (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Biodium Bug" 7317 - Aero Tube Hanger - by marco9999 - <LDD 4.3.5> Space / M:Tron 1478 - Mobile Satellite Up-Link - by zinfinion - <LDD 4> 6811 - Pulsar Charger - by zinfinion - <LDD 4> 6833 - Beacon Tracer - by Plastemaurer - <LDD 4> 6862 - Secret Space Voyager - by zinfinion - <LDD 4> 6877 - Vector Detector - by zinfinion - <LDD 4> 6896 - Celestial Forager - by zinfinion - <LDD 4> 6923 - Particle Ionizer - by zinfinion - <LDD 4> 6956 - Stellar Recon Voyager - by zinfinion - <LDD 4> 6989 - Mega Core Magnetizer - by Jeff - <LDD 3> Space / Mars Mission 5616 - Mini Robot - by Plastemaurer - <LDD 4> 5617 - Alien Jet - by Toa_Of_Justice - <LDD 4.3.8> 5619 - Crystal Hawk - by Plastemaurer - <LDD 4> 7644 - MX-81 Hypersonic Operations Aircraft - by penguinz - <LDD 4.3.8> 7644 - MX-81 Hypersonic Operations Aircraft (B model) - by PeabodySam - <LDD 4.3.9> - Comment: "MX-81-A Hypersonic Rocket" 7645 - MT-61 Crystal Reaper - by marco9999 - <LDD 4.3.6> 7646 - ETX Alien Infiltrator - by marco9999 - <LDD 4.3.6> 7647 - MX-41 Switch Fighter - by marco9999 - <LDD 4.3.6> 7648 - MT-21 Mobile Mining Unit - by marco9999 - <LDD 4.3.5> 7649 - MT-201 Ultra Drill Walker - by Plastemaurer - <LDD 4> 7690 - MB-01 Eagle Command Base - by marco9999 - <LDD 4.3.5> 7691 - ETX Alien Mothership Assault - by marco9999 - <LDD 4.3.5> 7692 - MX-71 Recon Dropship - by marco9999 - <LDD 4.3.5> 7693 - ETX Alien Strike - by SpiderSpaceman - <LDD 4> 7694 - MT-31 Trike - by Randal - <LDD 3> 7695 - MX-11 Astro Fighter - by penguinz - <LDD 4.3.8> 7697 - MT-51 Claw-Tank Ambush - by marco9999 - <LDD 4.3.5> 7699 - MT-101 Armored Drilling Unit - by marco9999 - <LDD 4.3.5> Space / RoboForce 2151 - Robo Raider - by vean - <LDD 4.3.8> 2152 - Robo Raptor - by SpiderSpaceman - <LDD 4> 2153 - Robo Stalker - by vean - <LDD 4.3.8> 2154 - Robo Master - by vean - <LDD 4.3.8> Space / Space Police I 6781 - SP-Striker - by Lego Otaku - <LDD 4.3.9> 6781 - SP-Striker - by zinfinion - <LDD 4> 6831 - Message Decoder - by Lego Otaku - <LDD 4.3.9> 6831 - Message Decoder - by zinfinion - <LDD 4> 6886 - Galactic Peace Keeper - by Calabar - <LDD 4> 6886 - Galactic Peace Keeper - by Lego Otaku - <LDD 4.3.9> 6895 - Spy-Trak I - by zinfinion - <LDD 4> 6895 - Spy-Trak I - by Lego Otaku - <LDD 4.3.9> 6955 - Space Lock-Up Isolation Base - by Lego Otaku - <LDD 4.3.9> 6955 - Lockup Isolation Base - by marco9999 - <LDD 4> 6986 - Mission Commander - by zinfinion - <LDD 4> 6986 - Mission Commander - by Lego Otaku - <LDD 4.3.9> Space / Space Police II 1916 - Starion Patrol - by zinfinion - <LDD 4> - Comment: aka 3015 1969 - Mini Robot - by zinfinion - <LDD 4> 6813 - Galatic Chief - by zinfinion - <LDD 4> 6852 - Sonar Security - by Randal - <LDD 3> 6897 - Rebel Hunter - by zinfinion - <LDD 4> 6957 - Solar Snooper - by zinfinion - <LDD 4> 6984 - Galactic Mediator - by Giovanne - <LDD 4> Space / Space Police III 5969 - Squidman Escape - by Toa_Of_Justice - <LDD 4> 5970 - Freeze Ray Frenzy - by prateek - <LDD 3> 5971 - Gold Heistu - by prateek - <LDD 3> 5972 - Space Truck Getaway - by prateek - <LDD 3> 5973 - Hyperspeed Pursuit - by Shroud - <LDD 3> - [INCOMPLETE] - Comment: One Vehicle Only 5973 - Hyperspeed Pursuit - by Randal - <LDD 3> 5974 - Galactic Enforcer - by zinfinion - <LDD 4> 5979 - Max Security Transport - by Happy SDE - <LDD 4.3.8> 5979 - Max Security Transport - by zinfinion - <LDD 4> 5980 - Squidman's Pitstop - by marco9999 - <LDD 4> 5981 - Raid VPR - by Randal - <LDD 3> 5982 - Smash 'N Grab - by Toa_Of_Justice - <LDD 4> 5983 - Undercover cruiser - by Randal - <LDD 3> 5984 - Lunar Limo - by Randal - <LDD 3> 5985 - Space Police Central - by ILikePi - <LDD 3> 8399 - K9 Bot - by Sjuip - <LDD 4.3.5> 8400 - Space Speeder - by prateek - <LDD 3> Space / Spyrius 1714 - Surveillance Scooter - by vean - <LDD 4.3.8> 3013 - Space Jet - by Happy SDE - <LDD 4.3.8> 6835 - Saucer Scout - by Aanchir - <LDD 4> 6835 - Saucer Scout - by BrickWild - <LDD 4> 6889 - Recon Robot - by BrickWild - <LDD 4> 6889 - Recon Robot - by Calabar - <LDD 4> 6939 - Saucer Centurion - by Costy - <LDD 4.3.5> 6949 - Robo-Guardian - by Cyberbricker - <LDD 4.3.8> 6959 - Lunar Launch Site - by penguinz - <LDD 4.3.6> Space / UFO 2543 - Alien Space Plane - by PeabodySam - <LDD 4.3.8> 2847 - Flyer - by bublible - <LDD 4.3.8> 3012 - Space Hover - by bublible - <LDD 4.3.8> - Comment: aka 6800, aka 6816 4305 - Xcyber - by bublible - <LDD 4.3.8> - Comment: aka 6818 6829 - Radon Rover - by bublible - <LDD 4.3.8> 6836 - V-Wing Fighter - by bublible - <LDD 4.3.8> 6900 - Cyber Saucer - by vean - <LDD 4.3.8> - Comment: aka 6999 6901 - Space Plane - by bublible - <LDD 4.3.8> - Comment: aka 6902 6915 - Warp Wing Fighter - by bublible - <LDD 4.3.8> Space / Unitron 1787 - Crater Cruiser - by vean - <LDD 4.3.8> 1789 - Star Hawk II - by vean - <LDD 4.3.8> 1793 - Space Station Zenon - by vean - <LDD 4.3.8> Speed Champions 75870 - Chevrolet Corvette Z06 - by ArmstrongYong - <LDD 4.3.9> 75871 - Ford Mustang GT - by ArmstrongYong - <LDD 4.3.9> 75872 - Audi R18 e-tron quattro - by JunkstyleGio - <LDD 4.3.9> 75873 - Audi R8 LMS ultra - by JunkstyleGio - <LDD 4.3.9> 75874 - Chevrolet Camaro Drag Race - by KamalMYafi - <LDD 4.3.9> 75875 - Ford F-150 Raptor & Ford Model A Hot Rod - by KamalMYafi - <LDD 4.3.10> 75876 - Porsche 919 Hybrid and 917K Pit Lane - by KamalMYafi - <LDD 4.3.9> 75877 - Mercedes-AMG GT3 - by Migui94 - <LDD 4.3.10> 75878 - Bugatti Chiron - by Migui94 - <LDD 4.3.10> 75879 - Scuderia Ferrari SF16-H - by Migui94 - <LDD 4.3.10> 75880 - McLaren 720S - by Migui94 - <LDD 4.3.10> 75881 - 2016 Ford GT & 1966 Ford GT40 - by vean - <LDD 4.3.10> 75882 - Ferrari FXX K & Development Center - by vean - <LDD 4.3.10> 75883 - MERCEDES AMG PETRONAS Formula One Team - by vean - <LDD 4.3.10> 75884 - 1968 Ford Mustang Fastback - by Migui94 - <LDD 4.3.11> 75885 - Ford Fiesta M-Sport WRC - by Migui94 - <LDD 4.3.11> 75886 - Ferrari 488 GT3 "Scuderia Corsa" - by Migui94 - <LDD 4.3.11> 75887 - Porsche 919 Hybrid - by Migui94 - <LDD 4.3.11> 75888 - Porsche 911 RSR + 911 Turbo - by Migui94 - <LDD 4.3.11> 75890 - Ferrari F40 Competizione (A model) - by vean - <LDD 4.3.11> 75890 - Ferrari F40 Competizione (B model) - by vean - <LDD 4.3.11> 75891 - Chevrolet Camaro ZL1 Race Car - by vean - <LDD 4.3.11> 75899 - LaFerrari - by Gnac - <LDD 4.3.9> 75908 - 458 Italia GT2 - by Gnac - <LDD 4.3.9> 75909 - McLaren P1 - by Gnac - <LDD 4.3.9> 75910 - Porsche 918 Spyder - by Gnac - <LDD 4.3.9> 75911 - McLaren Mercedes Pit Stop - by ArmstrongYong - <LDD 4.3.8> 75912 - Porsche 911 GT Finish Line - by KamalMYafi - <LDD 4.3.9> 75913 - Ferrari F14 T & Scuderia Ferrari Truck - by KamalMYafi - <LDD 4.3.9> Spider-Man 1374 - Green Goblin - by King of Nynrah - <LDD 4> 1376 - Spider-Man Action Studio - by King of Nynrah - <LDD 4> 1376 - Spider-Man Action Studio (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Harbor Pursuit" 4850 - Spider-Man's First Chase - by penguinz - <LDD 4.3.8> 4851 - The Origins - by penguinz - <LDD 4.3.8> 4852 - The Final Showdown - by penguinz - <LDD 4.3.6> 4853 - Spiderman Street Chase - by prateek - <LDD 3> 4854 - Doc Ock's Bank Robbery - by penguinz - <LDD 4.3.8> 4855 - Spider-Man's Train Rescue - by AndyC - <LDD 4> 4856 - Doc Ock's Hideout - by penguinz - <LDD 4.3.8> 4857 - Doc Ock's Fusion Lab - by penguinz - <LDD 4.3.8> 1374+1376+10075 - Spider-Man Action Pack - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets SpongeBob SquarePants 3815 - Heroic Heroes of the Deep - by LegoPegasister2015 - <LDD 4.3.9> 3816 - Glove World - by LegoPegasister2015 - <LDD 4.3.9> 3817 - The Flying Dutchman - by LegoPegasister2015 - <LDD 4.3.9> 3817 - The Flying Dutchman - by penguinz - <LDD 4.3.8> 3818 - Bikini Bottom Undersea Party - by LegoPegasister2015 - <LDD 4.3.9> 3825 - Krusty Krab - by KielDaMan - <LDD 4> 3825 - Krusty Krab - by LegoPegasister2015 - <LDD 4.3.9> 3826 - Build-A-Bob - by Stephan - <LDD 4> 3827 - Adventures in Bikini Bottom - by LegoPegasister2015 - <LDD 4.3.9> 3830 - The Bikini Bottom Express - by LegoPegasister2015 - <LDD 4.3.9> 3831 - Rocket Ride - by LegoPegasister2015 - <LDD 4.3.9> 3832 - The Emergency Room - by LegoPegasister2015 - <LDD 4.3.9> 3833 - Krusty Krab Adventures - by KielDaMan - <LDD 4> 3833 - Krusty Krab Adventures - by LegoPegasister2015 - <LDD 4.3.9> 3834 - Good Neighbors at Bikini Bottom - by LegoPegasister2015 - <LDD 4.3.9> 3834 - Good Neighbours at Bikini Bottom - by prateek - <LDD 3> 4981 - The Chum Bucket - by LegoPegasister2015 - <LDD 4.3.9> 4982 - Mrs. Puff's Boating School - by LegoPegasister2015 - <LDD 4.3.9> P2064 - SpongeBob Pen - by LegoPegasister2015 - <LDD 4.3.9> Sports 3302 - Soccer Field - by vean - <LDD 4.3.8> 3303 - Field Accessories - by Instructions archiver - <LDD 4.3.6> 3303 - Field Accessories - by vean - <LDD 4.3.8> 3308 - Tribune - by vean - <LDD 4.3.8> 3309 - Head Tribune - by vean - <LDD 4.3.8> 3310 - Commentator and Press Box - by vean - <LDD 4.3.8> 3311 - Camera Tower - by vean - <LDD 4.3.8> 3312 - Medic's Station - by vean - <LDD 4.3.8> 3313 - Light Poles - by vean - <LDD 4.3.8> 3314 - Stadium Security - by vean - <LDD 4.3.8> 3407 - Red Team Bus - by prateek - <LDD 3> 3535 - Skateboard Street Park - by PeabodySam - <LDD 4.3.8> 3538 - Snowboard Boarder Cross Race - by penguinz - <LDD 4.3.8> 3538 - Snowboard Boarder Cross Race (B model) - by PeabodySam - <LDD 4.3.9> 3578 - NHL Championship Challenge - by penguinz - <LDD 4> 3585 - Snowboard Super Pipe - by penguinz - <LDD 4.3.8> Star Wars 7748+7749+8016+8017+8018+8019+8036+8037+8038+8039 - Malevolence - by ADHO15 - <LDD 4.3.5> - Comment: Combines multiple s n/a - The Yoda Chronicles [Promo] - by vean - <LDD 4.3.6> Star Wars / Buildable Figures 75110 - Luke Skywalker - by thecrea1or - <LDD 4.3.11> 75111 - Darth Vader - by Kuramapika1 - <LDD 4.3.11> 75112 - General Grievous - by Kuramapika1 - <LDD 4.3.11> 75120 - K-2SO - by neveselov - <LDD 4.3.11> 75531 - Stormtrooper Commander - by thecrea1or - <LDD 4.3.11> Star Wars / Microfighters 75028 - Clone Turbo Tank - by kcoon - <LDD 4.3.8> 75028 - Clone Turbo Tank - by penguinz - <LDD 4.3.8> 75028 - Clone Turbo Tank - by ADHO15 - <LDD 4.3.8> 75029 - AAT - by kcoon - <LDD 4.3.8> 75029 - AAT - by penguinz - <LDD 4.3.8> 75029 - AAT - by ADHO15 - <LDD 4.3.8> 75030 - Millennium Falcon - by ADHO15 - <LDD 4.3.8> 75030 - Millennium Falcon - by kcoon - <LDD 4.3.8> 75030 - Millennium Falcon - by penguinz - <LDD 4.3.8> 75031 - TIE Interceptor - by kcoon - <LDD 4.3.8> 75031 - TIE Interceptor - by ADHO15 - <LDD 4.3.8> 75031 - TIE Interceptor - by penguinz - <LDD 4.3.8> 75032 - X-Wing Fighter - by ADHO15 - <LDD 4.3.8> 75032 - X-Wing Fighter - by penguinz - <LDD 4.3.8> 75032 - X-Wing Fighter - by kcoon - <LDD 4.3.8> 75033 - Star Destroyer - by ADHO15 - <LDD 4.3.8> 75033 - Star Destroyer - by penguinz - <LDD 4.3.8> Star Wars / Mini 3219 - MINI TIE Fighter - by ADHO15 - <LDD 4.3.5> 4484 - MINI X-Wing Fighter & TIE Advanced - by ADHO15 - <LDD 4.3.5> 4485 - MINI Sebulba's Podracer and Anakin's Podracer - by ADHO15 - <LDD 4.3.5> 4486 - MINI AT-ST & Snowspeeder - by ADHO15 - <LDD 4.3.5> 4487 - MINI Jedi Starfighter and Slave I - by ADHO15 - <LDD 4.3.5> 4488 - MINI Millenium Falcon - by ADHO15 - <LDD 4.3.5> 4489 - MINI AT-AT - by ADHO15 - <LDD 4.3.5> 4490 - MINI Republic Gunship - by ADHO15 - <LDD 4.3.5> 4491 - MINI MTT - by ADHO15 - <LDD 4.3.5> 4492 - MINI Imperial Star Destroyer - by ADHO15 - <LDD 4.3.5> 4493 - Sith Infiltrator - Mini - by ADHO15 - <LDD 4.3.5> 4494 - MINI Imperial Shuttle - by ADHO15 - <LDD 4.3.5> 4495 - MINI AT-TE - by ADHO15 - <LDD 4.3.5> 6963 - MINI X-Wing Fighter - by ADHO15 - <LDD 4.3.5> 6964 - MINI Boba Fett's Slave I - by ADHO15 - <LDD 4.3.5> 6965 - MINI TIE Interceptor - by ADHO15 - <LDD 4.3.5> 6966 - MINI Jedi Star Fighter - by ADHO15 - <LDD 4.3.5> 6967 - MINI ARC Fighter - by ADHO15 - <LDD 4.3.5> 6968 - MINI Wookiee Attack - by ADHO15 - <LDD 4.3.5> 8028 - MINI TIE Fighter - by ADHO15 - <LDD 4.3.5> 8029 - Mini Snowspeeder - by Happy SDE - <LDD 4.3.8> 8031 - MINI V-19 Torrent - by ADHO15 - <LDD 4.3.5> 8033 - MINI General Grievous Starfighter - by ADHO15 - <LDD 4.3.5> 20006 - MINI Clone Turbo Tank - by ADHO15 - <LDD 4.3.5> 20007 - MINI Republic Attack Cruiser - by ADHO15 - <LDD 4.3.5> 20009 - MINI AT-TE - by ADHO15 - <LDD 4.3.5> 20010 - MINI Republic Gunship - by ADHO15 - <LDD 4.3.5> 20016 - MINI Imperial Shuttle - by ADHO15 - <LDD 4.3.5> 20018 - MINI AT-AT - by ADHO15 - <LDD 4.3.5> 20018 - Mini AT-AT - by yellost - <LDD 3> 20019 - MINI Slave I - by ADHO15 - <LDD 4.3.5> 20019 - MINI Slave I - by C3POwen - <LDD 4> 20021 - MINI Bounty Hunter Gunship - by ADHO15 - <LDD 4.3.5> 30050 - MINI Republic Attack Shuttle - by ADHO15 - <LDD 4.3.5> 30051 - MINI X-Wing Fighter - by ADHO15 - <LDD 4.3.5> 30051 - X-Wing - by Daedalus304 - <LDD 4> 30052 - MINI AAT - by C3POwen - <LDD 4> 30052 - MINI AAT - by ADHO15 - <LDD 4.3.5> 30053 - MINI Venator Class Attack Cruiser - by yellost - <LDD 4> 30053 - MINI Venator Class Attack Cruiser - by ADHO15 - <LDD 4.3.5> 30054 - MINI AT-ST - by ADHO15 - <LDD 4.3.5> 30055 - MINI Droid Fighter - by Gear_tooth - <LDD 4> 30055 - MINI Droid Fighter - by ADHO15 - <LDD 4.3.5> 30056 - Star Destroyer - by yellost - <LDD 4> 30056 - Star Destroyer - by ADHO15 - <LDD 4.3.5> 30057 - Anakin's Pod Racer - by ADHO15 - <LDD 4.3.5> 30057 - Anakin's Pod Racer - by yellost - <LDD 4> 30059 - MTT polybag - by ADHO15 - <LDD 4.3.8> 30240 - Z-95 Headhunter polybag - by Happy SDE - <LDD 4.3.8> 30241 - Mandalorian Fighter polybag - by Happy SDE - <LDD 4.3.8> 30242 - Republic Frigate polybag - by Happy SDE - <LDD 4.3.8> 30243 - Umbaran MHC polybag - by Happy SDE - <LDD 4.3.8> 30246 - Imperial Shuttle - by ADHO15 - <LDD 4.3.8> 30246 - Imperial Shuttle - by JediCharles - <LDD 4.3.8> 30247 - ARC-170 Starfighter - by JediCharles - <LDD 4.3.8> 30247 - ARC-170 Starfighter - by ADHO15 - <LDD 4.3.8> 30272 - A-Wing Starfighter polybag - by ADHO15 - <LDD 4.3.8> 30274 - AT-DP Polybag - by ADHO15 - <LDD 4.3.8> 30275 - TIE Advanced Prototype - by ADHO15 - <LDD 4.3.8> 30276 - First Order Special Forces TIE Fighter - Mini polybag - by vean - <LDD 4.3.8> 30277 - First Order Star Destroyer - Mini polybag - by KamalMYafi - <LDD 4.3.9> 30278 - Poe's X-Wing Fighter - Mini polybag - by KamalMYafi - <LDD 4.3.9> 30279 - Kylo Ren's Command Shuttle - Mini polybag - by KamalMYafi - <LDD 4.3.9> 30386 - Poe Dameron's X-wing Fighter - Mini polybag - by vean - <LDD 4.3.11> 30496 - U-Wing Fighter - Mini polybag - by KamalMYafi - <LDD 4.3.10> 30498 - Imperial AT-Hauler polybag - by PicnicBasketSam - <LDD 4.3.11> 30611 - R2-D2 - Mini polybag - by ChristopherLee - <LDD 4.3.10> 911506 - Snowspeeder foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2015sw06de "Star Wars Magazine issue 6 2015" 911508 - Jango Fett's Slave One Micro foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2015sw02de "Star Wars Magazine issue 2 2015" 911509 - Imperial Shooter foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2015sw03de "Star Wars Magazine issue 3 2015" 911510 - Star Destroyer and TIE Fighter foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2015sw04de "Star Wars Magazine issue 4 2015" 911511 - Jedi Weapon Stand foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2015sw05de "Star Wars Magazine issue 5 2015" 911607 - Millennium Falcon foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw07de "Star Wars Magazine issue 7 2016" 911608 - Landspeeder foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw08de "Star Wars Magazine issue 8 2016" 911609 - Naboo Starfighter foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw09de "Star Wars Magazine issue 9 2016" 911610 - Probe Droid foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw10de "Star Wars Magazine issue 10 2016" 911611 - AAT foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw11de "Star Wars Magazine issue 11 2016" 911612 - Acklay foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw12de "Star Wars Magazine issue 12 2016" 911613 - Tie Bomber foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw13de "Star Wars Magazine issue 13 2016" 911614 - Yoda's Hut Foil Pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw14de "Star Wars Magazine issue 14 2016" 911615 - AT-AT foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw15de "Star Wars Magazine issue 15 2016" 911616 - MTT foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw16de "Star Wars Magazine issue 16 2016" 911617 - Palpatine's Shuttle foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw17de "Star Wars Magazine issue 17 2016" 911618 - Flash Speeder foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw18de "Star Wars Magazine issue 18 2016" 911720 - The Ghost foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw20de "Star Wars Magazine issue 20 2017" 911722 - TIE Advanced foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw22de "Star Wars Magazine issue 22 2017" 911723 - Vulture Droid foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw23de "Star Wars Magazine issue 23 2017" 911724 - A-wing foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw24de "Star Wars Magazine issue 24 2017" 911725 - Sandcrawler Mini foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw25de "Star Wars Magazine issue 25 2017" 911727 - Rey's Speeder foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw27de "Star Wars Magazine issue 27 2017" 911728 - First Order Snowspeeder foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2016sw28de "Star Wars Magazine issue 28 2017" 911729 - Droid Gunship foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2017sw29de "Star Wars Magazine issue 29 2017" 911730 - Y-wing foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2017sw30de "Star Wars Magazine issue 30 2017" 911831 - Kylo Ren's Shuttle foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2017sw31de "Star Wars Magazine issue 31 2017" 911833 - Imperial Shuttle foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw33de "Star Wars Magazine issue 33 2018" 911835 - Dwarf Spider Droid foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw35de "Star Wars Magazine issue 35 2018" 911836 - Quadjumper foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw36de "Star Wars Magazine issue 36 2018" 911837 - AT-ST foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw37de "Star Wars Magazine issue 37 2018" 911838 - Probe Droid foil pack #2 - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw38de "Star Wars Magazine issue 38 2018" 911840 - Droideka foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw40de "Star Wars Magazine issue 40 2018" 911841 - Poe Dameron's X-Wing foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2018sw41de "Star Wars Magazine issue 41 2018" 911842 - Star Destroyer foil pack - by Kuramapika1 - <LDD 4.3.11> 911944 - Resistance Bomber foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw44de "Star Wars Magazine issue 44 2019" 911945 - LegoBoba Fett's Slave I foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw45de "Star Wars Magazine issue 45 2019" 911946 - U-Wing foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw46de "Star Wars Magazine issue 46 2019" 911948 - AT-M6 foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw48de "Star Wars Magazine issue 48 2019" 911949 - Millennium Falcon foil pack #2 - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw49de "Star Wars Magazine issue 49 2019" 4484+4485+4486+4487 - MINI TIE Bomber - by ADHO15 - <LDD 4.3.5> - Comment: Combines multiple sets 4488+4489+4490+4491 - MINI Y-Wing Fighter - by ADHO15 - <LDD 4.3.5> - Comment: Combines multiple sets comcon010 - Republic Dropship - by C3POwen - <LDD 4> Swmagpromo - X-wing Micro foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: Aka 911205 - part of book mag2015sw01de "Star Wars Magazine issue 1 2015" Star Wars / Planet Series 1 9674 - Naboo Starfighter and Naboo - by ADHO15 - <LDD 4.3.5> 9675 - Sebulba's Podracer and Tatooine - by ADHO15 - <LDD 4.3.5> 9676 - Tie Interceptor and Death Star - by ADHO15 - <LDD 4.3.5> Star Wars / Planet Series 2 9677 - X-wing Starfighter & Yavin 4 - by ADHO15 - <LDD 4.3.5> 9678 - Twin-pod Cloud Car & Bespin - by ADHO15 - <LDD 4.3.5> 9679 - AT-ST & Endor - by ADHO15 - <LDD 4.3.5> Star Wars / Planet Series 3 75006 - Jedi Starfighter & Planet Kamino - by ADHO15 - <LDD 4.3.6> 75007 - Republic Assault Ship & Planet Coruscant - by ADHO15 - <LDD 4.3.6> 75008 - TIE Bomber & Asteroid Field - by ADHO15 - <LDD 4.3.6> Star Wars / Planet Series 4 75009 - Snowspeeder & Planet Hoth - by ADHO15 - <LDD 4.3.6> 75010 - B-wing Starfighter & Planet Endor - by ADHO15 - <LDD 4.3.6> 75011 - Tantive IV & Planet Alderaan - by ADHO15 - <LDD 4.3.6> Star Wars / Star Wars Battlefront 75226 - Inferno Squad Battle Pack - by Kuramapika1 - <LDD 4.3.11> Star Wars / Star Wars Clone Wars 7669 - Anakin's Jedi Starfighter - by ADHO15 - <LDD 4.3.5> 7670 - Hailfire Droid and Spider Droid - by ADHO15 - <LDD 4.3.5> 7673 - MagnaGuard Starfighter - by ADHO15 - <LDD 4.3.5> 7674 - V-19 Torrent - by ADHO15 - <LDD 4.3.5> 7675 - AT-TE Walker - by ADHO15 - <LDD 4.3.5> 7676 - Republic Attack Gunship - by ADHO15 - <LDD 4.3.5> 7679 - Republic Fighter Tank - by ADHO15 - <LDD 4.3.5> 7680 - The Twilight - by ADHO15 - <LDD 4.3.5> 7681 - Separatist Spider Droid - by ADHO15 - <LDD 4.3.5> 7748 - Corporate Alliance Tank Droid - by ADHO15 - <LDD 4.3.5> 7751 - Ahsoka's Starfighter and Vulture Droid - by prateek - <LDD 4> 7751 - Ahsoka's Starfighter and Vulture Droid - by ADHO15 - <LDD 4.3.5> 7752 - Count Dooku's Solar Sailer - by ADHO15 - <LDD 4.3.5> 7753 - Pirate Tank - by ADHO15 - <LDD 4.3.5> 7868 - Mace Windu's Jedi Starfighter - by ADHO15 - <LDD 4.3.5> 7869 - Battle for Geonosis - by ADHO15 - <LDD 4.3.5> 7913 - Clone Troopers Battle Pack - by prateek - <LDD 4> 7913 - Clone Troopers Battle Pack - by ADHO15 - <LDD 4.3.5> 7914 - Mandalorian Battle Pack - by ADHO15 - <LDD 4.3.5> 7914 - Mandalorian Battle Pack - by prateek - <LDD 4> 7915 - Imperial V-Wing Starfighter - by Giovanne - <LDD 4> 7915 - Imperial V-Wing Starfighter - by ADHO15 - <LDD 4.3.5> 7915 - Imperial V-Wing Starfighter - by Captain Becker - <LDD 4> 7930 - Bounty Hunter Assault Gunship - by ADHO15 - <LDD 4.3.5> 7931 - T-6 Jedi Shuttle - by Kuramapika1 - <LDD 4.3.11> 7931 - T-6 Jedi Shuttle (A model) - by ADHO15 - <LDD 4.3.5> 7931 - T-6 Jedi Shuttle (B model) - by ADHO15 - <LDD 4.3.5> 7957 - Sith Nightspeeder - by Giovanne - <LDD 4> 7957 - Sith Nightspeeder - by ADHO15 - <LDD 4.3.5> 7957 - Sith Nightspeeder - by P4trickvH - <LDD 4> 7959 - Geonosian Starfighter - by ADHO15 - <LDD 4.3.5> 7964 - Republic Frigate - by ADHO15 - <LDD 4.3.5> 8014 - Clone Walker Battle Pack - by ADHO15 - <LDD 4.3.5> 8015 - Assassin Droids Battle Pack - by ADHO15 - <LDD 4.3.5> 8016 - Hyena Droid Bomber - by ADHO15 - <LDD 4.3.5> 8018 - Armoured Assault Tank - by ADHO15 - <LDD 4.3.5> 8019 - Republic Attack Shuttle - by ADHO15 - <LDD 4.3.5> 8036 - Separatist Shuttle - by ADHO15 - <LDD 4.3.5> 8037 - Anakin Skywalker's Y-Wing Starfighter - by ADHO15 - <LDD 4.3.5> 8039 - Venator-Class Republic Attack Cruiser - by kcoon - <LDD 4.3.8> 8039 - Venator-class Republic Attack Cruiser - by ADHO15 - <LDD 4.3.5> 8085 - Freeco Speeder - by ADHO15 - <LDD 4.3.5> 8085 - Freeco Speeder - by C3POwen - <LDD 4> 8086 - Droid Tri-Fighter - by ADHO15 - <LDD 4.3.5> 8086 - Droid Tri-Fighter - by Randal - <LDD 3> 8088 - ARC-170 Starfighter - by ADHO15 - <LDD 4.3.5> 8091 - Republic Swamp Speeder - by ADHO15 - <LDD 4.3.5> 8095 - General Grievous' Starfighter - by AmiPolizeiFunk - <LDD 4> 8095 - General Grievous' Starfighter - by ADHO15 - <LDD 4.3.5> 8098 - Clone Turbo Tank - by ADHO15 - <LDD 4.3.5> 8128 - Cad Bane's Speeder - by ADHO15 - <LDD 4.3.5> 8128 - Cad Bane's Speeder - by prateek - <LDD 4> 9488 - Elite Clone Trooper & Commando Droid Battle Pack - by ADHO15 - <LDD 4.3.5> 9491 - Geonosian Cannon - by ADHO15 - <LDD 4.3.5> 9498 - Saesee Tiin's Jedi Starfighter - by ADHO15 - <LDD 4.3.5> 9515 - Malevolence - by ADHO15 - <LDD 4.3.5> 9525 - Pre Vizsla's Mandalorian Fighter - by ADHO15 - <LDD 4.3.5> 10195 - Republic Dropship with AT-OT - by ADHO15 - <LDD 4.3.5> 30004 - Battle Droid with STAP - by ADHO15 - <LDD 4.3.5> 30006 - Clone Walker - by ADHO15 - <LDD 4.3.5> 75002 - AT-RT - by ADHO15 - <LDD 4.3.6> 75004 - Z-95 Headhunter - by ADHO15 - <LDD 4.3.6> 75012 - BARC Speeder with Sidecar - by ADHO15 - <LDD 4.3.6> 75013 - Umbarran MHC (Mobile Heavy Cannon) - by ADHO15 - <LDD 4.3.6> 75013 - Umbarran MHC (Mobile Heavy Cannon) - by penguinz - <LDD 4.3.8> 75037 - Battle on Saleucami - by ADHO15 - <LDD 4.3.8> 75037 - Battle on Saleucami - by penguinz - <LDD 4.3.8> 75045 - Republic AV-7 Anti-Vehicle Cannon - by ADHO15 - <LDD 4.3.8> 75045 - Republic AV-7 Anti-Vehicle Cannon - by penguinz - <LDD 4.3.8> 75046 - Coruscant Police Gunship - by ADHO15 - <LDD 4.3.8> 75046 - Coruscant Police Gunship - by kcoon - <LDD 4.3.8> 75046 - Coruscant Police Gunship - by penguinz - <LDD 4.3.8> 75087 - Anakin's Custom Jedi Starfighter - by Happy SDE - <LDD 4.3.8> 75199 - General Grievous' Combat Speeder - by Kuramapika1 - <LDD 4.3.11> 75214 - Anakin's Jedi Starfighter - by PicnicBasketSam - <LDD 4.3.11> comcon012 - Cube Dudes - by roamingstudio - <LDD 4> Star Wars / Star Wars Episode 1 3340 - Sith Minifig Pack - by ADHO15 - <LDD 4.3.5> 3343 - Battle Droid Minifig Pack - by ADHO15 - <LDD 4.3.5> 7101 - Lightsaber Duel - by ADHO15 - <LDD 4.3.5> 7111 - Droid Fighter - by ADHO15 - <LDD 4.3.5> 7115 - Gungan Patrol - by ADHO15 - <LDD 4.3.5> 7121 - Naboo Swamp - by ADHO15 - <LDD 4.3.5> 7124 - Trade Federation AAT - by ADHO15 - <LDD 4.3.5> 7126 - Battle Droid Carrier - by ADHO15 - <LDD 4.3.5> 7131 - Anakin's Podracer - by ADHO15 - <LDD 4.3.5> 7141 - Naboo Fighter - by ADHO15 - <LDD 4.3.5> 7151 - Sith Infiltrator - by ADHO15 - <LDD 4.3.5> 7155 - Flash Speeder - by ADHO15 - <LDD 4.3.5> 7159 - Star Wars Bucket - by ADHO15 - <LDD 4.3.5> 7161 - Gungan Sub - by ADHO15 - <LDD 4.3.5> 7171 - Mos Espa Podrace - by ADHO15 - <LDD 4.3.5> 7184 - Trade Federation MTT - by ADHO15 - <LDD 4.3.5> 7186 - Watto's Junkyard - by ADHO15 - <LDD 4.3.5> 7203 - Jedi Defense I - by ADHO15 - <LDD 4.3.5> 7204 - Jedi Defense II - by ADHO15 - <LDD 4.3.5> 7660 - Naboo N-1 Starfighter and Vulture Droid - by ADHO15 - <LDD 4.3.5> 7662 - Trade Federation MTT - by ADHO15 - <LDD 4.3.5> 7663 - Sith Infiltrator - by ADHO15 - <LDD 4.3.5> 7665 - Republic Cruiser - by ADHO15 - <LDD 4.3.5> 7877 - Naboo Starfighter - by P4trickvH - <LDD 4> 7877 - Naboo Starfighter - by ADHO15 - <LDD 4.3.5> 7929 - The Battle of Naboo - by C3POwen - <LDD 4> 7929 - The Battle of Naboo - by ADHO15 - <LDD 4.3.5> 7961 - Sith Infiltrator - by yellost - <LDD 4> 7961 - Darth Maul's Sith Infiltrator - by ADHO15 - <LDD 4.3.5> 7962 - Anakin and Sebulba's Podracers - by Giovanne - <LDD 4> 7962 - Anakin's & Sebulba's Podracers - by ADHO15 - <LDD 4.3.5> 9499 - Gungan Sub - by ADHO15 - <LDD 4.3.5> 30058 - STAP polybag - by ADHO15 - <LDD 4.3.8> 75058 - MTT - by ADHO15 - <LDD 4.3.8> 75080 - AAT - by ADHO15 - <LDD 4.3.8> 75086 - Battle Droid Troop Carrier - by ADHO15 - <LDD 4.3.8> 75091 - Flash Speeder - by Giovanne - <LDD 4.3.8> 75092 - Naboo Starfighter - by Happy SDE - <LDD 4.3.8> 75096 - Sith Infiltrator - by ArmstrongYong - <LDD 4.3.8> comcon019 - Darth Maul's Sith Infiltrator - Mini - San Diego Comic-Con 2012 Exclusive - by ADHO15 - <LDD 4.3.8> Star Wars / Star Wars Episode 2 4478 - Geonosian Fighter, Black Box - by Giovanne - <LDD 4> 4478 - Geonosian Fighter, Black Box - by ADHO15 - <LDD 4.3.5> 4482 - AT-TE - by ADHO15 - <LDD 4.3.5> 7103 - Jedi Duel - by ADHO15 - <LDD 4.3.5> 7113 - Tusken Raider Encounter - by ADHO15 - <LDD 4.3.5> 7133 - Bounty Hunter Pursuit - by ADHO15 - <LDD 4.3.5> 7143 - Jedi Starfighter - by ADHO15 - <LDD 4.3.5> 7143 - Jedi Starfighter - by Brickdoctor - <LDD 3> 7153 - Jango Fett's Slave I - by ADHO15 - <LDD 4.3.5> 7163 - Republic Gunship - by ADHO15 - <LDD 4.3.5> 75000 - Clone Troopers vs. Droidekas - by ADHO15 - <LDD 4.3.6> 75016 - Homing Spider Droid - by penguinz - <LDD 4.3.8> 75017 - Duel on Geonosis - by BobaFonz - <LDD 4.3.6> 75017 - Duel on Geonosis - by penguinz - <LDD 4.3.8> 75019 - AT-TE - by penguinz - <LDD 4.3.8> 75021 - Republic Gunship - by penguinz - <LDD 4.3.8> 75085 - Hailfire Droid - by Happy SDE - <LDD 4.3.8> 75142 - Homing Spider Droid - by KamalMYafi - <LDD 4.3.9> 75191 - Jedi Starfighter with Hyperdrive - by UnhelpfulSpleen - <LDD 4.3.11> 75206 - Jedi and Clone Troopers Battle Pack - by Kuramapika1 - <LDD 4.3.11> Star Wars / Star Wars Episode 3 6205 - V-wing Fighter - by Brickdoctor - <LDD 3> 6205 - V-wing Fighter - by ADHO15 - <LDD 4.3.6> 7250 - Clone Scout Walker - by prateek - <LDD 3> 7250 - Clone Scout Walker - by ADHO15 - <LDD 4.3.5> 7251 - Darth Vader Transformation - by ADHO15 - <LDD 4.3.5> 7252 - Droid Tri-Fighters - by ADHO15 - <LDD 4.3.5> 7255 - General Grievous Chase - by ADHO15 - <LDD 4.3.5> 7256 - Jedi Starfighter and Vulture Droid - by ADHO15 - <LDD 4.3.5> 7257 - Ultimate Lightsaber Duel - by ADHO15 - <LDD 4.3.5> 7258 - Wookiee Attack - by ADHO15 - <LDD 4.3.5> 7259 - ARC-170 Starfighters - by Brickdoctor - <LDD 3> 7259 - ARC-170 Starfighters - by ADHO15 - <LDD 4.3.5> 7260 - Wookiee Catamaran - by ADHO15 - <LDD 4.3.5> 7260 - Wookiee Catamaran - by Brickdoctor - <LDD 3> 7261 - Clone Turbo Tank - by ADHO15 - <LDD 4.3.5> 7283 - Ultimate Space Battle - by ADHO15 - <LDD 4.3.5> 7654 - Droids Battle Pack - by ADHO15 - <LDD 4.3.5> 7655 - Clone Troopers Battle Pack - by ADHO15 - <LDD 4.3.5> 7656 - General Grievous Starfighter - by ADHO15 - <LDD 4.3.5> 7661 - Jedi Starfighter with Hyperdrive Booster Ring - by ADHO15 - <LDD 4.3.5> 7671 - AT-AP Walker - by ADHO15 - <LDD 4.3.5> 7678 - Droid Gunship - by ADHO15 - <LDD 4.3.5> 8093 - Plo Koon's Jedi Starfighter - by ADHO15 - <LDD 4.3.5> 8093 - Plo Koon's Jedi Starfighter - by JunkstyleGio - <LDD 3> 8093 - Plo Koon's Jedi Starfighter - by yellost - <LDD 3> 8096 - Emperor Palpatine's Shuttle - by ADHO15 - <LDD 4.3.5> 9494 - Anakin's Interceptor - by ADHO15 - <LDD 4.3.5> 9494 - Anakin's Interceptor - by penguinz - <LDD 4> 9526 - Palpatine's Arrest - by ADHO15 - <LDD 4.3.5> 30244 - Anakin's Jedi Intercepter - by JediCharles - <LDD 4.3.8> 30244 - Anakin's Jedi Intercepter - by ADHO15 - <LDD 4.3.8> 65771 - Episode III Collectors Set - by ADHO15 - <LDD 4.3.5> 75015 - Corporate Alliance Tank Droid - by penguinz - <LDD 4.3.8> 75035 - Kashyyyk Troopers - by ADHO15 - <LDD 4.3.8> 75035 - Kashyyyk Troopers - by penguinz - <LDD 4.3.8> 75036 - Utapau Troopers - by ADHO15 - <LDD 4.3.8> 75036 - Utapau Troopers - by penguinz - <LDD 4.3.8> 75038 - Jedi Interceptor - by ADHO15 - <LDD 4.3.8> 75038 - Jedi Interceptor - by penguinz - <LDD 4.3.8> 75039 - V-Wing Starfighter - by penguinz - <LDD 4.3.8> 75039 - V-Wing Starfighter - by ADHO15 - <LDD 4.3.8> 75040 - General Grievous' Wheel Bike - by penguinz - <LDD 4.3.8> 75040 - General Grievous' Wheel Bike - by ADHO15 - <LDD 4.3.8> 75041 - Vulture Droid - by ADHO15 - <LDD 4.3.8> 75041 - Vulture Droid - by penguinz - <LDD 4.3.8> 75042 - Droid Gunship - by penguinz - <LDD 4.3.8> 75042 - Droid Gunship - by ADHO15 - <LDD 4.3.8> 75043 - AT-AP - by penguinz - <LDD 4.3.8> 75043 - AT-AP - by ADHO15 - <LDD 4.3.8> 75044 - Droid Tri-Fighter - by ADHO15 - <LDD 4.3.8> 75044 - Droid Tri-Fighter - by penguinz - <LDD 4.3.8> 75135 - Obi-Wan's Jedi Interceptor - by UnhelpfulSpleen - <LDD 4.3.11> 75151 - Clone Turbo Tank - by LegoPegasister2015 - <LDD 4.3.9> 75182 - Republic Fighter Tank - by Navy Trooper Fenson - <LDD 4.3.10> 75233 - Droid Gunship - by vean - <LDD 4.3.11> 75233 - Droid Gunship - by Kuramapika1 - <LDD 4.3.11> 75281 - Anakin's Jedi Interceptor - by vean - <LDD 4.3.11> 75286 - General Grievous's Starfighter - by vean - <LDD 4.3.11> Star Wars / Star Wars Episode 4/5/6 3341 - Luke/Han/Boba Minifig Pack - by ADHO15 - <LDD 4.3.5> 3342 - Troopers/Chewie Minifig Pack - by ADHO15 - <LDD 4.3.5> 4475 - Jabba's Message - by ADHO15 - <LDD 4.3.5> 4476 - Jabba's Prize - by ADHO15 - <LDD 4.3.5> 4477 - T-16 Skyhopper - by ADHO15 - <LDD 4.3.5> 4479 - TIE Bomber - by ADHO15 - <LDD 4.3.5> 4479 - TIE Bomber - by Brickdoctor - <LDD 3> 4480 - Jabba's Palace - by ADHO15 - <LDD 4.3.5> 4483 - AT-AT - by Superkalle - <LDD 3> 4500 - Rebel Snowspeeder - by prateek - <LDD 3> 4500 - Rebel Snowspeeder - by ADHO15 - <LDD 4.3.5> 4501 - Mos Eisley Cantina - by ADHO15 - <LDD 4.3.5> 4502 - X-Wing Fighter - by ADHO15 - <LDD 4.3.5> 4504 - Millenium Falcon - by ADHO15 - <LDD 4.3.5> 6206 - TIE Interceptor - by ADHO15 - <LDD 4.3.5> 6207 - A-Wing Fighter - by prateek - <LDD 3> 6207 - A-Wing Fighter - by ADHO15 - <LDD 4.3.5> 6208 - B-wing Fighter - by messiah1 - <LDD 4> 6208 - B-wing Fighter - by ADHO15 - <LDD 4.3.5> 6209 - Slave I (2nd edition) - by prateek - <LDD 3> 6209 - Slave I (2nd edition) - by BobaFonz - <LDD 4.3.6> 6209 - Slave I (2nd edition) - by ADHO15 - <LDD 4.3.5> 6210 - Jabba's Sail Barge - by ADHO15 - <LDD 4.3.5> 6211 - Imperial Star Destroyer - by kcoon - <LDD 4.3.8> 6211 - Imperial Star Destroyer - by ADHO15 - <LDD 4.3.5> 6212 - X-Wing Fighter - by ADHO15 - <LDD 4.3.5> 7104 - Desert Skiff - by ADHO15 - <LDD 4.3.5> 7106 - Droid Escape - by ADHO15 - <LDD 4.3.5> 7110 - Landspeeder - by ADHO15 - <LDD 4.3.5> 7119 - Twin-Pod Cloud Car - by prateek - <LDD 3> 7119 - Twin-Pod Cloud Car - by ADHO15 - <LDD 4.3.5> 7127 - Imperial AT-ST - by ADHO15 - <LDD 4.3.5> 7128 - Speeder Bikes - by ADHO15 - <LDD 4.3.5> 7128 - Speeder Bikes - by Daedalus304 - <LDD 4> 7130 - Snowspeeder - by Daedalus304 - <LDD 4> 7130 - Snowspeeder - by ADHO15 - <LDD 4.3.5> 7134 - A-Wing Fighter - by Daedalus304 - <LDD 4> 7134 - A-Wing Fighter - by ADHO15 - <LDD 4.3.5> 7139 - Ewok Attack - by prateek - <LDD 3> 7139 - Ewok Attack - by ADHO15 - <LDD 4.3.5> 7142 - X-wing Fighter - by ADHO15 - <LDD 4.3.5> - Comment: aka 7140 7144 - Slave I - by ADHO15 - <LDD 4.3.5> 7146 - TIE Fighter - by ADHO15 - <LDD 4.3.5> 7150 - TIE Fighter & Y-wing - by RemtonDulyak - <LDD 4.3.8> 7150 - TIE Fighter and Y-wing - by ADHO15 - <LDD 4.3.5> - Comment: aka 7152 7166 - Imperial Shuttle - by ADHO15 - <LDD 4.3.5> 7166 - Imperial Shuttle - by prateek - <LDD 3> 7180 - B-wing at Rebel Control Center - by ADHO15 - <LDD 4.3.5> 7180 - B-wing at Rebel Control Center - by Daedalus304 - <LDD 4> 7190 - Millenium Falcon - by ADHO15 - <LDD 4.3.5> 7200 - Final Duel I - by ADHO15 - <LDD 4.3.5> 7201 - Final Duel II - by ADHO15 - <LDD 4.3.5> 7262 - TIE Fighter and Y-Wing - by Daedalus304 - <LDD 4> 7263 - TIE Fighter - by ADHO15 - <LDD 4.3.5> 7264 - Imperial Inspection - by ADHO15 - <LDD 4.3.5> 7657 - AT-ST - by ADHO15 - <LDD 4.3.5> 7657 - AT-ST - by prateek - <LDD 3> 7658 - Y-wing Fighter - by ADHO15 - <LDD 4.3.5> 7659 - Imperial Landing Craft - by ADHO15 - <LDD 4.3.5> 7666 - Hoth Rebel Base - by ADHO15 - <LDD 4.3.5> 7749 - Echo Base - by ADHO15 - <LDD 4.3.5> 7749 - Echo Base - by ILikePi - <LDD 3> 7754 - Home One Mon Calamari Star Cruiser - by ADHO15 - <LDD 4.3.5> 7778 - Midi-Scale Millenium Falcon - by ADHO15 - <LDD 4.3.5> 7879 - Hoth Echo Base - by P4trickvH - <LDD 4> 7879 - Hoth Echo Base - by ADHO15 - <LDD 4.3.5> 7956 - Ewok Attack - by ADHO15 - <LDD 4.3.5> 7965 - Millennium Falcon - by ADHO15 - <LDD 4.3.5> 7965 - Millenium Falcon - by penguinz - <LDD 4.3.8> 8017 - Darth Vader's TIE Fighter - by prateek - <LDD 3> 8017 - Darth Vader's TIE Fighter - by ADHO15 - <LDD 4.3.5> 8038 - Battle of Endor - by prateek - <LDD 3> 8038 - Battle of Endor - by ADHO15 - <LDD 4.3.5> 8083 - Rebel Trooper Battle Pack - by ADHO15 - <LDD 4.3.5> 8083 - Rebel Trooper Battle Pack - by prateek - <LDD 3> 8084 - Snowtrooper Battle Pack - by ADHO15 - <LDD 4.3.5> 8084 - Snowtrooper Battle Pack - by prateek - <LDD 3> 8089 - Hoth Wampa Cave - by Tontus - <LDD 4> 8089 - Hoth Wampa Cave - by ADHO15 - <LDD 4.3.5> 8092 - Luke's Landspeeder - by ADHO15 - <LDD 4.3.5> 8097 - Slave I (3rd edition) - by ADHO15 - <LDD 4.3.5> 8097 - Slave I (3rd edition) - by prateek - <LDD 4> 8097 - Slave I (3rd edition) - by Superkalle - <LDD 3> 8099 - Midi-Scale Imperial Star Destroyer - by ADHO15 - <LDD 4.3.5> 8099 - Midi-Scale Imperial Star Destroyer - by yellost - <LDD 3> 8129 - AT-AT Walker - by ADHO15 - <LDD 4.3.5> 8129 - AT-AT Walker - by yellost - <LDD 3> 8129 - AT-AT Walker - by AmiPolizeiFunk - <LDD 4> 9489 - Endor Rebel Trooper and Imperial Trooper Battle Pack - by ADHO15 - <LDD 4.3.5> 9490 - Droid Escape - by ADHO15 - <LDD 4.3.5> 9492 - Tie Fighter - by ADHO15 - <LDD 4.3.5> 9492 - Tie Fighter - by yellost - <LDD 4> 9493 - X-Wing Starfighter - by ADHO15 - <LDD 4.3.5> 9493 - X-Wing Starfighter - by penguinz - <LDD 4.3.5> 9495 - Gold Leader's Y-Wing Starfighter - by yellost - <LDD 4> 9495 - Gold Leader's Y-Wing Starfighter - by ADHO15 - <LDD 4.3.5> 9496 - Desert Skiff - by ADHO15 - <LDD 4.3.5> 9516 - Jabba's Palace - by ADHO15 - <LDD 4.3.5> 10123 - Cloud City - by ADHO15 - <LDD 4.3.5> 10131 - TIE Collection - by ADHO15 - <LDD 4.3.5> 10144 - Sandcrawler - by ADHO15 - <LDD 4.3.6> 10178 - Motorized Walking AT-AT - by penguinz - <LDD 4.3.8> 10188 - Death Star - by ADHO15 - <LDD 4.3.5> 10188 - Death Star - by bspline - <LDD 3> - [INCOMPLETE] - Comment: Minifigs missing 10188 - Death Star - by kcoon - <LDD 4.3.8> 10188 - Death Star - by bbqqq - <LDD 3> - [INCOMPLETE] - Comment: NO Universe Mode 10188 - Death Star - by yellost - <LDD 3> - [INCOMPLETE] - Comment: Tie Fighter Only 10188 - Death Star - by AmiPolizeiFunk - <LDD 4> 10198 - Tantive IV - by ADHO15 - <LDD 4.3.5> 10236 - Ewok Village - by vean - <LDD 4.3.6> 30005 - Imperial Speeder Bike - by ADHO15 - <LDD 4.3.5> 40333 - Battle of Hoth - 20th Anniversary Edition - by vean - <LDD 4.3.11> 40362 - Battle of Endor - 20th Anniversary Edition - by vean - <LDD 4.3.11> 66308 - Star Wars Super Pack 3 in 1 (7667+7668+8017) - by ADHO15 - <LDD 4.3.5> 75003 - A-wing Starfighter - by ADHO15 - <LDD 4.3.6> 75005 - Rancor Pit - by ADHO15 - <LDD 4.3.6> - [INCOMPLETE] - Comment: Lattice and Rancor missing. 75014 - Battle Of Hoth - by ADHO15 - <LDD 4.3.6> 75020 - Jabba's Sail Barge - by penguinz - <LDD 4.3.8> 75034 - Death Star Troopers - by ADHO15 - <LDD 4.3.8> 75034 - Death Star Troopers - by penguinz - <LDD 4.3.8> 75049 - Snowspeeder - by ADHO15 - <LDD 4.3.8> 75050 - B-wing - by ADHO15 - <LDD 4.3.8> 75050 - B-wing - by SWAT Strachan - <LDD 4.3.8> 75052 - Mos Eisley Cantina - by ADHO15 - <LDD 4.3.8> 75054 - AT-AT - by ADHO15 - <LDD 4.3.8> 75055 - Imperial Star Destroyer - by ADHO15 - <LDD 4.3.8> 75059 - Sandcrawler - by Elog - <LDD 4.3.8> 75081 - T-16 Skyhopper - by vean - <LDD 4.3.11> 75081 - T-16 Skyhopper - by Happy SDE - <LDD 4.3.8> 75094 - Imperial Shuttle Tydirium - by Giovanne - <LDD 4.3.8> 75137 - Carbon-Freezing Chamber - by eYoshi - <LDD 4.3.9> 75198 - Tatooine Battle Pack - by Kuramapika1 - <LDD 4.3.11> 75203 - Hoth Medical Chamber - by PicnicBasketSam - <LDD 4.3.11> 75205 - Mos Eisley Cantina - by Kuramapika1 - <LDD 4.3.11> 75208 - Yoda's Hut - by Kuramapika1 - <LDD 4.3.11> 75218 - X-Wing Starfighter - by PicnicBasketSam - <LDD 4.3.11> 75220 - Sandcrawler - by PicnicBasketSam - <LDD 4.3.11> 75221 - Imperial Landing Craft - by PicnicBasketSam - <LDD 4.3.11> 75227 - Darth Vader Bust - by Bod9nou - <LDD 4.3.11> 75229 - Death Star Escape - by Kuramapika1 - <LDD 4.3.11> 75229 - Death Star Escape - by vean - <LDD 4.3.11> 75235 - X-wing Starfighter Trench Run - by vean - <LDD 4.3.11> 75237 - TIE Fighter Attack - by vean - <LDD 4.3.11> 75247 - Rebel A-wing Starfighter - by vean - <LDD 4.3.11> 911947 - IG-88 foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw47de "Star Wars Magazine issue 47 2019" 911950 - B-wing foil pack - by Kuramapika1 - <LDD 4.3.11> - Comment: part of book mag2019sw50de "Star Wars Magazine issue 50 2019" CELEB2017 - Detention Block Rescue - by ChristopherLee - <LDD 4.3.10> celebv - Fan Celebration V CubeDudes - Bounty Hunter Edition [Star Wars] - by ILikePi - <LDD 3> comcon024 - Luke Skywalker's Landspeeder - Mini - New York Comic-Con 2012 Exclusive - by ADHO15 - <LDD 4.3.8> MayFourth - Escape the Space Slug - by LegoPegasister2015 - <LDD 4.3.9> - Comment: aka 6176782 MayFourth-1 - Escape the Space Slug - by Pasq67 - <LDD 4.3.9> n/a - SDCC 2015 Exclusive - Dagobah Mini Build - by vean - <LDD 4.3.8> SWC2012 - Mini Slave I - by ADHO15 - <LDD 4.3.5> Star Wars / Star Wars Episode 7 75099 - Rey's Speeder - by ChristopherLee - <LDD 4.3.8> 75100 - First Order Snowspeeder - by vean - <LDD 4.3.9> 75101 - First Order Special Forces TIE Fighter - by vean - <LDD 4.3.9> 75102 - Poe's X-Wing Fighter - by vean - <LDD 4.3.9> 75103 - First Order Transporter - by vean - <LDD 4.3.9> 75104 - Kylo Ren's Command Shuttle - by vean - <LDD 4.3.8> 75105 - Millennium Falcon - by vean - <LDD 4.3.8> 75139 - Battle on Takodana - by LegoPegasister2015 - <LDD 4.3.8> 75140 - Resistance Troop Transport - by LegoPegasister2015 - <LDD 4.3.8> 75148 - Encounter on Jakku - by LegoPegasister2015 - <LDD 4.3.9> 75149 - Resistance X-Wing Fighter - by LegoPegasister2015 - <LDD 4.3.9> Star Wars / Star Wars Episode 8 75187 - BB-8 - by Stephan - <LDD 4.3.11> 75188 - Resistance Bomber - by Henni - <LDD 4.3.10> 75197 - First Order Specialists Battle Pack - by Kuramapika1 - <LDD 4.3.11> 75200 - Ahch-To Island Training - by Kuramapika1 - <LDD 4.3.11> 75201 - First Order AT-ST - by Kuramapika1 - <LDD 4.3.11> 75202 - Defense of Crait - by Kuramapika1 - <LDD 4.3.11> 75216 - Snoke's Throne Room - by PicnicBasketSam - <LDD 4.3.11> 75225 - Elite Praetorian Guard Battle Pack - by Kuramapika1 - <LDD 4.3.11> Star Wars / Star Wars Episode 9 75248 - Resistance A-Wing Starfighter - by Bod9nou - <LDD 4.3.11> 75249 - Resistance Y-Wing Starfighter - by Bod9nou - <LDD 4.3.11> - Comment: Extra: Meme'd edition 75257 - Millennium Falcon - by Bod9nou - <LDD 4.3.11> Star Wars / Star Wars Expanded Universe 75079 - Shadow Troopers - by Happy SDE - <LDD 4.3.8> Star Wars / Star Wars Galaxy's Edge 75293 - Resistance I-TS Transport - by vean - <LDD 4.3.11> Star Wars / Star Wars Microfighters Series 2 75072 - ARC-170 Starfighter - by Xenomorph - <LDD 4.3.8> 75072 - ARC-170 Starfighter - by ADHO15 - <LDD 4.3.8> 75073 - Vulture Droid - by ADHO15 - <LDD 4.3.8> 75074 - Snowspeeder - by ADHO15 - <LDD 4.3.8> 75075 - AT-AT - by ADHO15 - <LDD 4.3.8> 75076 - Republic Gunship - by ADHO15 - <LDD 4.3.8> 75077 - Homing Spider Droid - by ADHO15 - <LDD 4.3.8> Star Wars / Star Wars Microfighters Series 3 75125 - Resistance X-wing Fighter - by lipanz - <LDD 4.3.9> 75126 - First Order Snowspeeder - by Kuramapika1 - <LDD 4.3.11> 75127 - The Ghost - by lipanz - <LDD 4.3.9> 75128 - TIE Advanced Prototype - by lipanz - <LDD 4.3.9> 75129 - Wookiee Gunship - by lipanz - <LDD 4.3.9> 75130 - AT-DP - by lipanz - <LDD 4.3.9> Star Wars / Star Wars Microfighters Series 4 75160 - U-Wing Microfighter - by ChristopherLee - <LDD 4.3.10> 75161 - TIE Striker Microfighter - by Kuramapika1 - <LDD 4.3.11> 75162 - Y-Wing Microfighter - by uchuujin - <LDD 4.3.10> 75163 - Krennic's Imperial Shuttle Microfighter - by Kuramapika1 - <LDD 4.3.11> Star Wars / Star Wars Microfighters Series 5 75193 - Millennium Falcon Microfighter - by Kuramapika1 - <LDD 4.3.11> 75194 - First Order TIE Fighter Microfighter - by Kuramapika1 - <LDD 4.3.11> 75195 - Ski Speeder vs. First Order Walker Microfighters - by Kuramapika1 - <LDD 4.3.11> 75196 - A-Wing vs. TIE Silencer Microfighters - by Kuramapika1 - <LDD 4.3.11> Star Wars / Star Wars Microfighters Series 6 75223 - Naboo Starfighter Microfighter - by vean - <LDD 4.3.11> 75224 - Sith Infiltrator Microfighter - by vean - <LDD 4.3.11> 75228 - Escape Pod vs. Dewback Microfighters - by Kuramapika1 - <LDD 4.3.11> Star Wars / Star Wars Old Republic 9497 - Republic Striker-class Starfighter - by ADHO15 - <LDD 4.3.8> 9497 - Republic Striker-class Starfighter - by Jason C. Hand - <LDD 4.3.8> 75001 - Republic Troopers vs. Sith Troopers - by ADHO15 - <LDD 4.3.8> Star Wars / Star Wars Other 7664 - TIE Crawler - by ADHO15 - <LDD 4.3.5> 7667 - Imperial Dropship - by ADHO15 - <LDD 4.3.5> 7667 - Imperial Dropship - by prateek - <LDD 3> 7668 - Rebel Scout Speeder - by ADHO15 - <LDD 4.3.5> 7668 - Rebel Scout Speeder - by prateek - <LDD 3> 7672 - Rogue Shadow - by ADHO15 - <LDD 4.3.5> 7672 - Rogue Shadow - by messiah1 - <LDD 4> 8087 - TIE Defender - by ADHO15 - <LDD 4.3.5> 9500 - Sith Fury-class Interceptor - by ADHO15 - <LDD 4.3.5> 11912 - Parts for Star Wars: Build Your Own Adventure (included in Book 9780241232576) - by Kuramapika1 - <LDD 4.3.11> 75018 - JEK-14ÔÇÖs Stealth Starfighter - by penguinz - <LDD 4.3.8> 75022 - Mandalorian Speeder - by penguinz - <LDD 4.3.8> 75024 - HH-87 Starhopper - by lotrmorgot - <LDD 4.3.6> 75025 - Jedi Defender-class Cruiser - by lotrmorgot - <LDD 4.3.6> 75145 - Eclipse Fighter - by LegoPegasister2015 - <LDD 4.3.9> 75147 - StarScavenger - by LegoPegasister2015 - <LDD 4.3.9> comcon032 - JEK-14 Mini Stealth Starfighter - San Diego Comic-Con 2013 Exclusive - by ADHO15 - <LDD 4.3.8> Star Wars / Star Wars Rebels 75048 - The Phantom - by ADHO15 - <LDD 4.3.8> 75053 - The Ghost - by ADHO15 - <LDD 4.3.8> 75078 - Imperial Troop Transport - by Happy SDE - <LDD 4.3.8> 75106 - Imperial Assault Carrier - by ArmstrongYong - <LDD 4.3.8> 75141 - Kanan's Speeder Bike - by KamalMYafi - <LDD 4.3.9> 75150 - Vader's TIE Advanced vs. A-Wing Starfighter - by LegoPegasister2015 - <LDD 4.3.9> 75157 - Captain Rex's AT-TE - by LegoPegasister2015 - <LDD 4.3.9> 75158 - Rebel Combat Frigate - by TheNerdyOne_ - <LDD 4.3.9> Star Wars / Star Wars Resistance 75242 - Black Ace TIE Interceptor - by Bod9nou - <LDD 4.3.11> Star Wars / Star Wars Rogue One 40268 - R3-M2 polybag - by ChristopherLee - <LDD 4.3.10> 75152 - Imperial Assault Hovertank - by lomis - <LDD 4.3.10> 75153 - AT-ST Walker - by lomis - <LDD 4.3.9> 75154 - Tie Striker - by lomis - <LDD 4.3.9> 75155 - Rebel U-Wing Fighter - by lomis - <LDD 4.3.10> 75156 - Krennic's Imperial Shuttle - by lomis - <LDD 4.3.10> Star Wars / Star Wars Solo 75207 - Imperial Patrol Battle Pack - by Kuramapika1 - <LDD 4.3.11> 75209 - Han Solo's Landspeeder - by Kuramapika1 - <LDD 4.3.11> 75210 - Moloch's Landspeeder - by Kuramapika1 - <LDD 4.3.11> 75211 - Imperial TIE Fighter - by Kuramapika1 - <LDD 4.3.11> 75212 - Kessel Run Millennium Falcon - by Kuramapika1 - <LDD 4.3.11> 75215 - Cloud-Rider Swoop Bikes - by PicnicBasketSam - <LDD 4.3.11> 75217 - Imperial Conveyex Transport - by PicnicBasketSam - <LDD 4.3.11> 75217 - Imperial Conveyex Transport - by pagicence - <LDD 4.3.11> 75219 - Imperial AT-Hauler - by PicnicBasketSam - <LDD 4.3.11> Star Wars / Star Wars The Clone Wars 75280 - 501st Legion Clone Troopers - by vean - <LDD 4.3.11> Star Wars / Star Wars The Mandalorian 75292 - The Razor Crest - by vean - <LDD 4.3.11> Star Wars / Star Wars Yoda Chronicles 75018 - Jek-14's Stealth Starfighter - by ADHO15 - <LDD 4.3.8> 75051 - Jedi Scout Fighter - by ADHO15 - <LDD 4.3.8> Star Wars / Ultimate Collector Series 7181 - UCS TIE Interceptor - by yellost - <LDD 3> 7181 - TIE Interceptor - UCS - by bbqqq - <LDD 4> 7181 - UCS TIE Interceptor - by messiah1 - <LDD 4> 7191 - X-wing Fighter - UCS - by ADHO15 - <LDD 4.3.5> 7191 - UCS X-Wing - by yellost - <LDD 3> 7194 - Yoda - by dluders - <LDD 3> 10018 - Darth Maul - UCS - by corboa - <LDD 4.3.11> 10018 - Darth Maul - by Stephan - <LDD 4> 10019 - UCS Rebel Blockade Runner - by ADHO15 - <LDD 4.3.5> 10019 - Rebel Blockade Runner - UCS - by kcoon - <LDD 4.3.8> 10019 - UCS Rebel Blockade Runner - by yellost - <LDD 3> 10026 - UCS Naboo Fighter - by yellost - <LDD 3> 10026 - UCS Naboo Fighter - by ADHO15 - <LDD 4.3.5> 10030 - Imperial Star Destroyer - UCS - by kcoon - <LDD 4.3.8> 10030 - Imperial Star Destroyer - UCS - by Elog - <LDD 4.3.8> 10030 - Imperial Star Destroyer - UCS - by bbqqq - <LDD 4> 10030 - Imperial Star Destroyer - UCS - by Stephan - <LDD 4.3.5> 10129 - UCS Snowspeeder - by yellost - <LDD 3> 10134 - UCS Y-wing Attack Starfighter - by ADHO15 - <LDD 4.3.5> 10134 - UCS Y-wing Attack Starfighter - by messiah1 - <LDD 4> 10143 - Death Star II - by bbqqq - <LDD 4> 10143 - Death Star II - by yellost - <LDD 3> 10143 - Death Star II - by XENOPHREAK - <LDD 4.3.8> 10174 - Imperial AT-ST - by marco9999 - <LDD 4> 10175 - Vader's TIE Advanced - UCS - by Daedalus304 - <LDD 4> 10175 - Vader's TIE Advanced - UCS - by messiah1 - <LDD 4> 10179 - Millennium Falcon - UCS - by bbqqq - <LDD 3> - [INCOMPLETE] - Comment: NO Universe Mode 10179 - Millennium Falcon - UCS - by DenJansen - <LDD 4.3.5> 10179 - Millennium Falcon - UCS - by kcoon - <LDD 4.3.8> 10179 - Millennium Falcon - UCS - by yellost - <LDD 3> 10186 - General Grievous - by ADHO15 - <LDD 4.3.5> 10186 - General Grievous - by messiah1 - <LDD 3> 10212 - Imperial Shuttle - UCS - by Happy SDE - <LDD 4.3.8> 10212 - UCS Imperial Shuttle - by yellost - <LDD 3> 10212 - UCS Imperial Shuttle - by bbqqq - <LDD 4> - Comment: NO Universe Mode 10215 - Obi-Wan's Jedi Starfighter - UCS - by merman - <LDD 4> 10215 - Obi-Wan's Jedi Starfighter - UCS - by Daedalus304 - <LDD 4> 10215 - Obi-Wan's Jedi Starfighter - UCS - by yellost - <LDD 4> 10221 - Super Star Destroyer - by DenJansen - <LDD 4.3.5> 10221 - Super Star Destroyer - by bbqqq - <LDD 4> 10221 - Super Star Destroyer - UCS - by kcoon - <LDD 4.3.8> 10225 - R2-D2 - by ADHO15 - <LDD 4.3.5> 10225 - R2-D2 - by bbqqq - <LDD 4> 10227 - B-wing Starfighter - UCS - by kcoon - <LDD 4.3.8> 10227 - B-Wing Starfighter - by ADHO15 - <LDD 4.3.5> 10227 - B-Wing Starfighter - by bbqqq - <LDD 4.3.5> 10240 - Red Five X-wing Starfighter - by bbqqq - <LDD 4.3.6> 10240 - Red Five X-wing Starfighter - by XENOPHREAK - <LDD 4.3.8> 10240 - Red Five X-wing Starfighter - by ADHO15 - <LDD 4.3.6> 75060 - Slave I - by bbqqq - <LDD 4.3.8> 75095 - TIE Fighter - UCS - by Stephan - <LDD 4.3.8> 75098 - Assault on Hoth - by Stephan - <LDD 4.3.9> 75098 - Assault on Hoth - by LegoPegasister2015 - <LDD 4.3.9> 75181 - UCS Y-Wing Starfighter - by Stephan - <LDD 4.3.11> 75192 - Millennium Falcon - UCS (2nd edition) - by Kuramapika1 - <LDD 4.3.11> 75192 - Millennium Falcon - UCS (2nd edition) - by Migui94 - <LDD 4.3.10> 75275 - A-wing Starfighter - UCS - by Bod9nou - <LDD 4.3.11> Studios 1349 - Steven Spielberg Moviemaker Set - by Instructions archiver - <LDD 4.3.5> 1351 - Movie Backdrop Studio - by PeabodySam - <LDD 4.3.9> 1352 - Explosion Studio - by PeabodySam - <LDD 4.3.6> 1353 - Car Stunt Studio - by PeabodySam - <LDD 4.3.8> 1354 - Dino Head Attack - by PeabodySam - <LDD 4.3.8> 1355 - Temple of Gloom - by PeabodySam - <LDD 4.3.8> 1356 - Stuntman Catapult - by PeabodySam - <LDD 4.3.8> 1357 - Cameraman - by PeabodySam - <LDD 4.3.8> 1360 - Director's Copter - by PeabodySam - <LDD 4.3.8> 1361 - Camera Car - by PeabodySam - <LDD 4.3.8> 1362 - Air Boat - by PeabodySam - <LDD 4.3.8> 1363 - Stunt Go-Cart - by PeabodySam - <LDD 4.3.8> 1370 - Raptor Rumble Studio - by PeabodySam - <LDD 4.3.9> 1371 - Spinosaurus Attack Studio - by PeabodySam - <LDD 4.3.8> 1380 - Werewolf Ambush - by PeabodySam - <LDD 4.3.6> 1381 - Vampire's Crypt - by PeabodySam - <LDD 4.3.6> 1382 - Scary Laboratory - by PeabodySam - <LDD 4.3.6> 1383 - Curse of the Pharaoh - by PeabodySam - <LDD 4.3.6> 1383 - Curse of the Pharaoh - by petero - <LDD 4> 4056 - Color Light polybag - by Happy SDE - <LDD 4.3.8> 4067 - Buggy - by King of Nynrah - <LDD 4> 4068 - Handy Camera - by King of Nynrah - <LDD 4> 4069 - Katinko and Megaphone - by King of Nynrah - <LDD 4> 4070 - Camera Stand - by King of Nynrah - <LDD 4> 4071 - Bottles - by King of Nynrah - <LDD 4> 4072 - Skeleton - by King of Nynrah - <LDD 4> 4076 - Pteranodon - by PeabodySam - <LDD 4.3.8> 4077 - Plesiosaur - by PeabodySam - <LDD 4.3.8> 4078 - T-Rex - by PeabodySam - <LDD 4.3.8> 1360+1361+1362+1363 - Flying Stunt Copter - by PeabodySam - <LDD 4.3.8> - Comment: Combines multiple sets Super Heroes 4528 - Green Lantern - by Happy SDE - <LDD 4.3.8> 6857 - The Dynamic Duo Funhouse Escape [DC Heroes] - by ADHO15 - <LDD 4.3.6> 6858 - Catwoman City Cycle Chase [DC Heroes] - by ADHO15 - <LDD 4.3.6> 6860 - The Batcave [DC Heroes] - by ADHO15 - <LDD 4.3.6> 6862 - Superman vs Power Armour Lex [DC Heroes] - by Tontus - <LDD 4> 6862 - Superman vs Power Armour Lex [DC Heroes] - by ADHO15 - <LDD 4.3.6> 6863 - Batwing Battle over Gotham City [DC Heroes] - by ADHO15 - <LDD 4.3.6> 6864 - The Batmobile and Two Face Chase [DC Heroes] - by ADHO15 - <LDD 4.3.6> 6865 - Captain America's Avenging Cycle [Marvel Heroes] - by prateek - <LDD 4> 6865 - Captain America's Avenging Cycle [Marvel Heroes] - by ADHO15 - <LDD 4.3.6> 6866 - Wolverine's Chopper Showdown [Marvel Heroes] - by prateek - <LDD 4> 6866 - Wolverine's Chopper Showdown [Marvel Heroes] - by ADHO15 - <LDD 4.3.6> 6867 - Loki's Cosmic Cube Escape [Marvel Heroes] - by ADHO15 - <LDD 4.3.6> 6867 - Loki's Cosmic Cube Escape [Marvel Heroes] - by prateek - <LDD 4> 6868 - Hulk's Helicarrier Breakout [Marvel Heroes] - by ADHO15 - <LDD 4.3.6> 6869 - Quinjet Aerial Battle [Marvel Heroes] - by ADHO15 - <LDD 4.3.6> 6873 - Spider-Man's Doc Ock Ambush - by ADHO15 - <LDD 4.3.6> 10937 - Arkham Asylum Breakout - by ADHO15 - <LDD 4.3.6> 30160 - Batman on Boat [DC Heroes] - by ADHO15 - <LDD 4.3.6> 30161 - Batmobile [DC Heroes] - by AndyC - <LDD 4> 30161 - Batmobile [DC Heroes] - by ADHO15 - <LDD 4.3.6> 30161 - Batmobile [DC Heroes] - by prateek - <LDD 4.3.5> 30162 - Quinjet - by ADHO15 - <LDD 4.3.6> 30163 - Thor and the Cosmic Cube - by ADHO15 - <LDD 4.3.6> 30164 - Lex Luthor [DC Heroes] - by ADHO15 - <LDD 4.3.6> 30165 - Hawkeye with Equipment - by ADHO15 - <LDD 4.3.6> 30166 - Robin and Redbird Cycle polybag - by Happy SDE - <LDD 4.3.8> 30167 - Iron Man vs. Fighting Drone - by ADHO15 - <LDD 4.3.6> 30168 - Gun mounting system - by ADHO15 - <LDD 4.3.6> 30300 - The Batman Tumbler - by Elog - <LDD 4.3.8> 30301 - Batwing - by Elog - <LDD 4.3.8> 30302 - Ultimate Spider-Man - by Elog - <LDD 4.3.8> 30303 - The Joker Bumper Car - by Yooha - <LDD 4.3.8> 30304 - The Avengers Quinjet - by Happy SDE - <LDD 4.3.8> 30305 - Spider-Man Super Jumper - by Happy SDE - <LDD 4.3.8> 30446 - The Batmobile polybag - by lipanz - <LDD 4.3.9> 30447 - Captain America's Motorcycle polybag - by KamalMYafi - <LDD 4.3.9> 30448 - Spider-Man Vs. The Venom Symbiote polybag - by KamalMYafi - <LDD 4.3.9> 30521 - The Mini Batmobile polybag - by KamalMYafi - <LDD 4.3.10> 30522 - Batman in the Phantom Zone polybag - by KamalMYafi - <LDD 4.3.10> 30524 - The Mini Batwing polybag - by KamalMYafi - <LDD 4.3.10> 30525 - The Guardians' Ship polybag - by thecrea1or - <LDD 4.3.11> 70903 - The Riddler Riddle Racer - by Migui94 - <LDD 4.3.10> 70905 - The Batmobile - by vean - <LDD 4.3.10> 70906 - The Joker Notorious Lowrider - by vean - <LDD 4.3.10> 70907 - Killer Croc Tail-Gator - by Migui94 - <LDD 4.3.10> 70911 - The Penguin Arctic Roller - by Migui94 - <LDD 4.3.10> 70918 - The Bat-Dune Buggy - by dephra - <LDD 4.3.11> 70922 - The Joker Manor - by Stephan - <LDD 4.3.11> 76000 - Arctic Batman vs. Mr. Freeze: Aquaman on Ice - by ADHO15 - <LDD 4.3.6> 76001 - The Bat vs. Bane: Tumbler Chase - by ADHO15 - <LDD 4.3.6> 76002 - Superman: Metropolis Showdown - by ADHO15 - <LDD 4.3.6> 76003 - Superman: Battle of Smallville - by ADHO15 - <LDD 4.3.6> 76004 - Spider-Man: Spider-Cycle Chase - by ADHO15 - <LDD 4.3.6> 76005 - Spider-Man: Daily Bugle Showdown - by ADHO15 - <LDD 4.3.6> 76006 - Iron Man: Extremis Sea Port Battle - by ADHO15 - <LDD 4.3.6> 76007 - Iron Man: Malibu Mansion Attack - by Instructions archiver - <LDD 4.3.6> 76007 - Iron Man: Malibu Mansion Attack - by ADHO15 - <LDD 4.3.6> 76008 - Iron Man vs. The Mandarin: Ultimate Showdown - by ADHO15 - <LDD 4.3.6> 76009 - Superman: Black Zero Escape - by ADHO15 - <LDD 4.3.6> 76010 - Batman: The Penguin Face off - by vean - <LDD 4.3.8> 76011 - Batman: Man-Bat Attack - by vean - <LDD 4.3.8> 76012 - Batman: The Riddler Chase - by vean - <LDD 4.3.8> 76013 - Batman: The Joker Steam Roller - by vean - <LDD 4.3.8> 76014 - Spider-Trike vs. Electro - by vean - <LDD 4.3.8> 76015 - Doc Ock Truck Heist - by vean - <LDD 4.3.8> 76016 - Spider-Helicopter Rescue - by vean - <LDD 4.3.8> 76017 - Captain America vs. Hydra - by vean - <LDD 4.3.8> 76018 - Hulk Lab Smash - by Happy SDE - <LDD 4.3.8> 76019 - Starblaster Showdown - by penguinz - <LDD 4.3.8> 76020 - Knowhere Escape Mission - by penguinz - <LDD 4.3.8> 76021 - The Milano Spaceship Rescue - by penguinz - <LDD 4.3.8> 76022 - X-Men vs The Sentinel - by ADHO15 - <LDD 4.3.8> 76023 - The Tumbler UCS - by bbqqq - <LDD 4.3.8> 76025 - Green Lantern vs. Sinestro - by vean - <LDD 4.3.8> 76026 - Gorilla Grodd Goes Bananas - by vean - <LDD 4.3.8> 76027 - Black Manta Deep Sea Strike - by vean - <LDD 4.3.8> 76028 - Darkseid Invasion - by vean - <LDD 4.3.8> 76029 - Iron Man vs. Ultron - by vean - <LDD 4.3.8> 76030 - Avengers Hydra Showdown - by vean - <LDD 4.3.8> 76031 - The Hulk Buster Smash - by vean - <LDD 4.3.8> 76032 - The Avengers Quinjet City Chase - by vean - <LDD 4.3.8> 76038 - Attack on Avengers Tower - by vean - <LDD 4.3.8> 76040 - Brianiac Attack - by vean - <LDD 4.3.8> 76041 - The Hydra Fortress Smash - by vean - <LDD 4.3.8> 76042 - The SHIELD Helicarrier - by Stephan - <LDD 4.3.8> 76050 - Crossbones' Hazard Heist - by PicnicBasketSam - <LDD 4.3.9> 76051 - Super Hero Airport Battle - by PicnicBasketSam - <LDD 4.3.9> 76052 - Batman Classic TV Series - Batcave - by PicnicBasketSam - <LDD 4.3.9> 76052 - Batman Classic TV Series - Batcave - by Stephan - <LDD 4.3.9> 76095 - Aquaman: Black Manta Strike - by PicnicBasketSam - <LDD 4.3.11> 76101 - Outrider Dropship Attack - by thecrea1or - <LDD 4.3.11> 76105 - The Hulkbuster: Ultron Edition - by Stephan - <LDD 4.3.11> 76110 - Batman: The Attack of the Talons - by PicnicBasketSam - <LDD 4.3.11> 76111 - Batman: Brother Eye Takedown - by PicnicBasketSam - <LDD 4.3.11> 76112 - App-Controlled Batmobile - by PicnicBasketSam - <LDD 4.3.11> 76162 - Black Widow's Helicopter Chase - by vean - <LDD 4.3.11> 5004590 - Bat-Pod - by vean - <LDD 4.3.8> comcon037 - Batman Classic TV Series Batmobile - San Diego Comic-Con 2014 Exclusive - by Stephan - <LDD 4.3.8> n/a - The "Emmet" Batmobile - by vean - <LDD 4.3.10> n/a - SDCC 2015 Exclusive Action Comics #1 Superman - by vean - <LDD 4.3.8> Edited March 18, 2021 by Calabar Quote
Calabar Posted April 28, 2010 Author Posted April 28, 2010 Technic 850 - Fork Lift - by Sjuip - <LDD 4.3.8> 850 - Fork Lift (A model) - by LDDtechnician - <LDD 4.3.8> 850 - Fork Lift (B model) - by marco9999 - <LDD 4.3.8> 851 - Tractor - by Sjuip - <LDD 4.3.8> - Comment: Aka 952 851 - Technic Tractor (A model) - by roamingstudio - <LDD 3> - Comment: aka 951 851 - Technic Tractor (B model) - by roamingstudio - <LDD 3> - Comment: aka 951 852 - Helicopter - by LDDtechnician - <LDD 4> 853 - Car Chassis - by LDDtechnician - <LDD 4> 854 - Go Kart - by LDDtechnician - <LDD 4> 855 - Technic Crane (A model) - by roamingstudio - <LDD 4> - Comment: aka 955 855 - Technic Crane (B model) - by roamingstudio - <LDD 3> - Comment: aka 955 856 - Front loader - by LDDtechnician - <LDD 3> 857 - Motorcycle - by LDDtechnician - <LDD 4> 1237 - Honda Promotional Set (Asimo Robot) [Promo] - by Randal - <LDD 3> 1257 - Tricycle - by mzoli - <LDD 4.3.8> 1259 - Motorbike - by Happy SDE - <LDD 4.3.8> 1259 - Motorbike - by KamalMYafi - <LDD 4.3.10> 1290 - Lava Buggy - by Happy SDE - <LDD 4.3.8> 1290 - Lava Buggy - by KamalMYafi - <LDD 4.3.10> 1291 - Power Bike - by Happy SDE - <LDD 4.3.8> 1291 - Power Bike - by KamalMYafi - <LDD 4.3.10> 1292 - Frost Flyer - by Happy SDE - <LDD 4.3.8> 1292 - Frost Flyer - by KamalMYafi - <LDD 4.3.10> 1972 - Go-Kart - by mzoli - <LDD 4.3.8> 2544 - Motorcycle - by mzoli - <LDD 4.3.8> 3054 - Motorcycle - by mzoli - <LDD 4.3.8> 4481 - Hailfire Droid - by BEAVeR - <LDD 4.3.8> 8000 - Pit Droid - by Daedalus304 - <LDD 4> 8000 - Pit Droid (B model) - by marco9999 - <LDD 4.3.8> 8001 - Battle Droid - by Daedalus304 - <LDD 4> 8001 - Battle Droid (B model) - by marco9999 - <LDD 4.3.8> 8002 - Destroyer Droid (A model) - by BEAVeR - <LDD 4.3.8> 8002 - Destroyer Droid (B model) - by BEAVeR - <LDD 4.3.8> 8007 - C-3PO - by BEAVeR - <LDD 4.3.8> 8008 - Stormtrooper (A model) - by BEAVeR - <LDD 4.3.8> 8008 - Stormtrooper (B model) - by BEAVeR - <LDD 4.3.8> 8009 - R2-D2 - by BEAVeR - <LDD 4.3.8> 8011 - Jango Fett - by BEAVeR - <LDD 4.3.6> 8012 - Super Battle Droid - by BEAVeR - <LDD 4.3.8> 8022 - TECHNIC Starter Set (Airplane) - by dluders - <LDD 3> 8041 - Race Truck (A model) - by Tore M - <LDD 4> 8041 - Race Truck (B model) - by marco9999 - <LDD 4> 8043 - Motorized Excavator - by Zblj - <LDD 4> - [INCOMPLETE] - Comment: Bucket Missing 8043 - Motorized Excavator - by marco9999 - <LDD 4.3.8> 8045 - Mini Telehandler (A model) - by Toa_Of_Justice - <LDD 4> 8045 - Mini Telehandler (B model) - by JunkstyleGio - <LDD 3> 8046 - Helicopter - by BrickWild - <LDD 3> 8046 - Helicopter (B model) - by marco9999 - <LDD 4.3.8> 8047 - Compact excavator - by Zblj - <LDD 4> 8047 - Compact Excavator (B model) - by marco9999 - <LDD 4.3.8> 8048 - Buggy (A model) - by PerryMakes - <LDD 4> 8048 - Buggy (B model) - by PerryMakes - <LDD 4> 8049 - Tractor with Log Loader (A model) - by LDDtechnician - <LDD 4> 8049 - Tractor with Log Loader (B model) - by Tore M - <LDD 4> 8051 - Motorbike (A model) - by marco9999 - <LDD 4> 8051 - Motorbike (B model) - by mzoli - <LDD 4.3.8> 8052 - Container Truck (A model) - by BasOne - <LDD 4> 8052 - Container Truck (B model) - by LDDtechnician - <LDD 4> 8053 - Mobile Crane - by Larzs - <LDD 4> 8053 - Mobile Crane (B model) - by marco9999 - <LDD 4.3.8> 8063 - Tractor with Trailer - by drofnas - <LDD 4.3.5> - [INCOMPLETE] - Comment: Trailer and Seed Drill missing (available at post 886393) 8063 - Tractor with Trailer (A model) - by BrickWild - <LDD 4> - [INCOMPLETE] - Comment: Trailer only 8063 - Tractor with Trailer (B model) - by BrickWild - <LDD 4> - [INCOMPLETE] - Comment: Seed Drill only 8065 - Mini Container Truck (A model) - by C3POwen - <LDD 4> 8065 - Mini Container Truck (B model) - by Tore M - <LDD 4> 8066 - Off-Roader - by Tore M - <LDD 4> 8066 - Off-Roader (B model) - by mzoli - <LDD 4.3.8> - Comment: "Cool Buggy" 8067 - Mini Mobile Crane (A model) - by Tore M - <LDD 4> 8067 - Mini Mobile Crane (B model) - by Tore M - <LDD 4> 8068 - Rescue Helicopter (A model) - by Tore M - <LDD 4> 8068 - Rescue Helicopter (B model) - by marco9999 - <LDD 4> 8069 - Backhoe Loader (A model) - by Tore M - <LDD 4> 8069 - Backhoe Loader (B model) - by Tore M - <LDD 4> 8070 - Supercar - by Dromme - <LDD 4.3.8> 8070 - Supercar (B model) - by Balthasar_the_Dark - <LDD 4.3.5> - [INCOMPLETE] - Comment: Hot Rod. Some piece missing. 8070 - Supercar (C model) - by Toa_Of_Justice - <LDD 4> 8071 - Bucket Truck - by Tore M - <LDD 4> 8071 - Bucket Truck (B model) - by marco9999 - <LDD 4.3.8> 8081 - Extreme Cruiser (A model) - by Tore M - <LDD 4> 8081 - Extreme Cruiser (B model) - by marco9999 - <LDD 4.3.8> 8081 - Extreme Cruiser (B model) - by P4trickvH - <LDD 4> 8109 - Flatbed Truck - by P4trickvH - <LDD 4> 8109 - Flatbed Truck (B model) - by mzoli - <LDD 4.3.8> - Comment: "Catering Truck" 8110 - Mercedes-Benz Unimog U400 - by Tore M - <LDD 4.3.5> 8203 - Rover Discovery - by KamalMYafi - <LDD 4.3.9> 8204 - Sky Flyer 1 - by KamalMYafi - <LDD 4.3.9> 8208 - Custom Cruiser - by Toa_Of_Justice - <LDD 4> 8209 - Future F1 - by Happy SDE - <LDD 4.3.8> 8210 - Nitro Bike GTX - by Daedalus304 - <LDD 4> 8215 - Gyro Copter - by KamalMYafi - <LDD 4.3.9> 8215 - Gyro Copter (B model) - by KamalMYafi - <LDD 4.3.9> 8217 - The Wasp - by Happy SDE - <LDD 4.3.8> 8218 - Trike Tourer - by KamalMYafi - <LDD 4.3.9> 8226 - Mud Masher - by marco9999 - <LDD 4.3.8> 8226 - Mud Masher (B model) - by marco9999 - <LDD 4.3.8> 8233 - MC vs Stinger - by Shine - <LDD 4> 8247 - Road Rebel - by KamalMYafi - <LDD 4.3.9> 8251 - Sonic Cycle - by BrickWild - <LDD 4> 8251 - Sonic Cycle - by SNIPE - <LDD 4> 8256 - Go Kart (A model) - by PerryMakes - <LDD 4> 8256 - Super Kart (B model) - by Balthasar_the_Dark - <LDD 4.3.5> - Comment: Mover. 8258 - Crane Truck - by Tore M - <LDD 4> 8258 - Crane Truck - by hrontos - <LDD 4> 8258 - Crane Truck (B model) - by marco9999 - <LDD 4.3.8> 8259 - Mini Bulldozer (A model) - by BasOne - <LDD 4> 8259 - Mini Bulldozer (B model) - by BasOne - <LDD 4> 8260 - Tractor (A model) - by PerryMakes - <LDD 4> 8260 - Tractor (B model) - by PerryMakes - <LDD 4> 8261 - Rally Truck - by LDDtechnician - <LDD 4> 8261 - Rally Truck - by Happy SDE - <LDD 4.3.8> 8261 - Rally Truck (B model) - by mzoli - <LDD 4.3.8> 8262 - Quad Bike - by PerryMakes - <LDD 4> 8262 - Quad Bike (B model) - by mzoli - <LDD 4.3.8> - Comment: "Dune Buggy" 8263 - Snow Groomer - by Zblj - <LDD 4> 8263 - Snow Groomer (B model) - by marco9999 - <LDD 4.3.8> 8264 - Hauler - by Zblj - <LDD 3> 8264 - Hauler (B model) - by mzoli - <LDD 4.3.8> - Comment: "Flatbed Truck" 8265 - Front Loader - by hrontos - <LDD 4> 8265 - Front Loader (B model) - by marco9999 - <LDD 4.3.8> 8268 - Scorpion Attack - by Shine - <LDD 4> 8270 - Rough Terrain Crane (A model) - by Tore M - <LDD 4> 8270 - Rough Terrain Crane (B model) - by Tore M - <LDD 4> 8271 - Wheel Loader (A model) - by PerryMakes - <LDD 4> 8271 - Wheel Loader (B model) - by mzoli - <LDD 4.3.8> - Comment: "Grader" 8272 - Snowmobile - by PerryMakes - <LDD 4> 8272 - Snowmobile (B model) - by mzoli - <LDD 4.3.8> - Comment: "Bulldozer" 8273 - Off-Road Truck - by BasOne - <LDD 4> 8273 - Off Road Truck (B model) - by mzoli - <LDD 4.3.8> - Comment: "Utility Cargo Truck" 8274 - Combine Harvester - by Tore M - <LDD 4> 8274 - Combine Harvester (B model) - by mzoli - <LDD 4.3.8> - Comment: "Dragster" 8275 - Motorised Bulldozer - by Myshkin - <LDD 4> 8275 - Motorized Bulldozer (B model) - by marco9999 - <LDD 4.3.8> 8281 - Mini Tractor (A model) - by Tore M - <LDD 4> 8281 - Mini Tractor (B model) - by Tore M - <LDD 4> 8282 - Quad Bike - by peterski - <LDD 4> 8282 - Quad Bike (B model) - by mzoli - <LDD 4.3.8> 8283 - Telehandler (Front End Loader) - by mzoli - <LDD 4.3.8> 8283 - Telehandler (Front End Loader) (B model) - by mzoli - <LDD 4.3.8> - Comment: "Front Loader" 8284 - Tractor - by Tore M - <LDD 4> 8284 - Dune Buggy / Tractor (B model) - by marco9999 - <LDD 4.3.6> 8285 - Tow Truck (B model) - by marco9999 - <LDD 4.3.8> 8288 - Crawler Crane - by marco9999 - <LDD 4.3.8> 8288 - Crawler Crane (B model) - by marco9999 - <LDD 4.3.8> - Comment: 8289 - Fire Truck - by LDDtechnician - <LDD 4> 8289 - Fire Truck (B model) - by marco9999 - <LDD 4.3.8> 8290 - Mini Forklift (A model) - by AndyC - <LDD 4> 8290 - Mini Forklift (A model) - by ashir - <LDD 4> 8290 - Mini Forklift (B model) - by AndyC - <LDD 4> 8290 - Dragster (B model) - by ashir - <LDD 4> 8291 - Dirt Bike - by BrickWild - <LDD 4> 8291 - Dirt Bike (B model) - by Sjuip - <LDD 4.3.5> 8292 - Cherry Picker - by Tore M - <LDD 4> 8292 - Cherry Picker (B model) - by mzoli - <LDD 4.3.8> - Comment: "Dump Truck" 8294 - Excavator - by laserman - <LDD 4> 8294 - Excavator (B model) - by marco9999 - <LDD 4.3.8> 8295 - Telescopic Handler - by Chilekesh - <LDD 4.3.9> 8295 - Telescopic Handler (B model) - by marco9999 - <LDD 4.3.8> 8296 - Dune Buggy - by Happy SDE - <LDD 4.3.8> 8296 - Dune Buggy - by Daedalus304 - <LDD 4> 8296 - Dune Buggy (B model) - by mzoli - <LDD 4.3.8> - Comment: "Tractor" 8297 - Off Roader - by Gnac - <LDD 4.3.8> 8297 - Off Roader (B model) - by marco9999 - <LDD 4.3.8> 8415 - Dump Truck - by mzoli - <LDD 4.3.8> 8415 - Dump Truck (B model) - by mzoli - <LDD 4.3.8> - Comment: "Street Sweeper" 8416 - Forklift - by Chilekesh - <LDD 4.3.9> 8416 - Forklift (B model) - by marco9999 - <LDD 4.3.8> 8418 - Mini Loader (A model) - by Sjuip - <LDD 4.3.5> 8418 - Mini Loader (B model) - by Sjuip - <LDD 4.3.5> 8419 - Excavator - by mzoli - <LDD 4.3.8> 8419 - Excavator (B model) - by mzoli - <LDD 4.3.8> - Comment: "Bulldozer" 8420 - Street Bike - by marco9999 - <LDD 4.3.8> 8420 - Street Bike (B model) - by marco9999 - <LDD 4.3.8> 8421 - Mobile Crane - by Tore M - <LDD 4> 8425 - Black Hawk - by desrs6 - <LDD 4.3.5> 8425 - Black Hawk (B model) - by marco9999 - <LDD 4.3.8> 8433 - Cool Movers - by mzoli - <LDD 4.3.8> 8433 - Cool Movers (B model) - by mzoli - <LDD 4.3.8> 8433 - Cool Movers (C model) - by mzoli - <LDD 4.3.8> 8433 - Cool Movers (D model) - by mzoli - <LDD 4.3.8> 8433 - Cool Movers (E model) - by mzoli - <LDD 4.3.8> 8433 - Cool Movers (F model) - by mzoli - <LDD 4.3.8> 8433 - Cool Movers (G model) - by mzoli - <LDD 4.3.8> 8434 - Aircraft (A model) - by marco9999 - <LDD 4.3.8> 8434 - Aircraft (B model) - by marco9999 - <LDD 4.3.8> - Comment: "Helicopter" 8435 - 4WD - by mzoli - <LDD 4.3.8> 8435 - 4WD (B model) - by mzoli - <LDD 4.3.8> - Comment: "Quad" 8436 - Truck - by BrickWild - <LDD 4> - [INCOMPLETE] - Comment: Implements missing 8441 - Forklift Truck (A model) - by marco9999 - <LDD 4.3.5> 8441 - Forklift Truck (B model) - by marco9999 - <LDD 4.3.5> 8451 - Dumper - by LDDtechnician - <LDD 3> 8451 - Dumper - by Happy SDE - <LDD 4.3.8> 8451 - Dumper (B model) - by marco9999 - <LDD 4.3.8> 8453 - Front-End Loader, Black Box (A model) - by marco9999 - <LDD 4.3.8> 8453 - Front-End Loader, Black Box (B model) - by marco9999 - <LDD 4.3.8> 8454 - Rescue Truck - by Kuramapika1 - <LDD 4.3.11> 8454 - Rescue Truck (B model) - by Kuramapika1 - <LDD 4.3.11> 8458 - Silver Champion - by Kuramapika1 - <LDD 4.3.11> 8458 - Silver Champion (B model) - by Kuramapika1 - <LDD 4.3.11> 8458 - Silver Champion (C model) - by Kuramapika1 - <LDD 4.3.11> 8465 - Extreme Off-Roader (A model) - by marco9999 - <LDD 4.3.8> 8465 - Extreme Off-Roader (B model) - by marco9999 - <LDD 4.3.8> 8466 - 4 X 4 Off-Roader - by marco9999 - <LDD 4.3.8> 8466 - 4 X 4 Off-Roader (B model) - by marco9999 - <LDD 4.3.8> 8479 - Barcode Multi-Set - by peca89 - <LDD 4.3.6> 8480 - Space Shuttle - by Zazck - <LDD 4.3.5> 8480 - Space Shuttle (B model) - by marco9999 - <LDD 4.3.8> - Comment: "Submarine" 8620 - Snow Scooter - by AndyC - <LDD 4> 8640 - Polar Copter (A model) - by AndyC - <LDD 4> 8640 - Polar Copter (B model) - by AndyC - <LDD 4> 8660 - Arctic Rescue Unit - by AndyC - <LDD 4> 8680 - Arctic Rescue Base - by AndyC - <LDD 4> 8812 - Eagle Patrol (Helicopter) - by BrickWild - <LDD 3> - Comment: aka 8429 8824 - Hovercraft - by marco9999 - <LDD 4.3.9> 8824 - Hovercraft (B model) - by marco9999 - <LDD 4.3.9> 8826 - ATX Sport Cycle - by marco9999 - <LDD 4.3.9> 8826 - ATX Sport Cycle (B model) - by marco9999 - <LDD 4.3.9> 8835 - Forklift - by Chilekesh - <LDD 4.3.9> 8835 - Forklift (B model) - by Chilekesh - <LDD 4.3.9> - Comment: "Plower" 8836 - Sky Ranger - by marco9999 - <LDD 4.3.9> 8836 - Sky Ranger (B model) - by marco9999 - <LDD 4.3.9> 8838 - Shock Cycle - by marco9999 - <LDD 4.3.9> 8838 - Shock Cycle - by mistahfreshone - <LDD 4.3.8> 8838 - Shock Cycle (B model) - by marco9999 - <LDD 4.3.9> 8838 - Shock Cycle (B model) - by mistahfreshone - <LDD 4.3.8> 8842 - Go-Kart - by mzoli - <LDD 4.3.8> 8842 - Go-Kart (B model) - by mzoli - <LDD 4.3.8> 8849 - Tractor - by Bering - <LDD 4.3.8> 8849 - Tractor (A model) - by corboa - <LDD 4.3.11> 8849 - Tractor (B model) - by corboa - <LDD 4.3.11> 8852 - Robot (A model) - by Kerilk - <LDD 4.3.8> 8852 - Robot (B model) - by Kerilk - <LDD 4.3.8> 8855 - Prop Plane (A model) - by Kerilk - <LDD 4.3.6> 8855 - Prop Plane (B model) - by Kerilk - <LDD 4.3.6> 8860 - Car Chassis - by S_Bartfast - <LDD 4.3.8> 8865 - Test Car - by Kingston - <LDD 4.3.6> - [INCOMPLETE] 8868 - Air Tech Claw Rig - by Grosse Kind - <LDD 4.3.9> 8880 - Super Car - by Sjuip - <LDD 4.3.8> 8880 - Super Car (B model) - by Sjuip - <LDD 4.3.8> 9390 - Mini Tow Truck (A model) - by P4trickvH - <LDD 4> 9390 - Mini Tow Truck (B model) - by P4trickvH - <LDD 4> 9391 - Mini Crane (A model) - by Tore M - <LDD 4> 9391 - Mini Crane (B model) - by Tore M - <LDD 4> 9392 - Quad Bike (A model) - by Tore M - <LDD 4> 9392 - Quad Bike (B model) - by Tore M - <LDD 4> 9393 - Tractor (A model) - by P4trickvH - <LDD 4.3.5> 9393 - Tractor (B model) - by P4trickvH - <LDD 4> 9394 - Jet Plane (A model) - by marco9999 - <LDD 4.3.5> 9394 - Jet Plane (B model) - by marco9999 - <LDD 4.3.5> 9395 - Pick-Up Tow Truck (A model) - by peterski - <LDD 4> 9395 - Pick-Up Tow Truck (B model) - by peterski - <LDD 4.3.5> 9396 - Helicopter - by P4trickvH - <LDD 4> 9396 - Helicopter (B model) - by mzoli - <LDD 4.3.8> - Comment: "Twin-Rotor Helicopter" 9397 - Logging Truck (A model) - by peterski - <LDD 4.3.5> 9397 - Logging Truck (B model) - by Tore M - <LDD 4> 9398 - 4 x 4 Crawler (A model) - by P4trickvH - <LDD 4> 9398 - 4 x 4 Crawler (B model) - by P4trickvH - <LDD 4> 41999 - 4 x 4 Crawler Exclusive Edition - by Zblj - <LDD 4.3.6> 42000 - Grand Prix Racer - by XENOPHREAK - <LDD 4.3.8> 42000 - Grand Prix Racer (B model) - by marco9999 - <LDD 4.3.8> 42001 - Mini Off-Roader - by peterski - <LDD 4.3.6> 42001 - Mini Off-Roader (B model) - by mzoli - <LDD 4.3.8> - Comment: "Mini Buggy" 42002 - Hovercraft - by mzoli - <LDD 4.3.8> 42002 - Hovercraft (B model) - by mzoli - <LDD 4.3.8> - Comment: "Propel Plane" 42004 - Mini Backhoe - by marco9999 - <LDD 4.3.5> 42004 - Mini Backhoe (B model) - by mzoli - <LDD 4.3.8> - Comment: "Telehandler" 42005 - Monster Truck - by peterski - <LDD 4.3.6> 42006 - Excavator - by mzoli - <LDD 4.3.8> 42006 - Excavator (B model) - by marco9999 - <LDD 4.3.8> 42007 - Moto Cross Bike - by bbqqq - <LDD 4.3.5> 42007 - Moto Cross Bike (B model) - by mzoli - <LDD 4.3.8> - Comment: "Speedway Motorbike" 42008 - Service Truck (A model) - by JGW3000 - <LDD 4.3.8> 42008 - Service Truck (B model) - by marco9999 - <LDD 4.3.8> 42009 - Mobile Crane Mk II - by marco9999 - <LDD 4.3.8> 42009 - Mobile Crane Mk II (B model) - by marco9999 - <LDD 4.3.8> 42010 - Off-Road Racer - by mistahfreshone - <LDD 4.3.8> 42011 - Race Car - by marco9999 - <LDD 4.3.8> 42020 - Twin-rotor Helicopter - by JunkstyleGio - <LDD 4.3.8> 42020 - Twin-rotor Helicopter (B model) - by mzoli - <LDD 4.3.8> - Comment: "Helicopter" 42021 - Snowmobile - by mzoli - <LDD 4.3.8> 42021 - Snowmobile (B model) - by mzoli - <LDD 4.3.8> - Comment: "Snowbike" 42022 - Hot Rod - by mzoli - <LDD 4.3.8> 42022 - Hot Rod (B model) - by mzoli - <LDD 4.3.8> - Comment: "Rally Racer" 42023 - Construction Crew - by mzoli - <LDD 4.3.8> 42023 - Construction Crew (B model) - by mzoli - <LDD 4.3.8> - Comment: "Scraper" 42024 - Container Truck - by efferman - <LDD 4.3.8> 42024 - Container Truck (B model) - by marco9999 - <LDD 4.3.8> 42025 - Cargo Plane - by marco9999 - <LDD 4.3.8> 42025 - Cargo Plane (B model) - by marco9999 - <LDD 4.3.8> - Comment: "hovercraft" 42026 - Black Champion Racer - by mistahfreshone - <LDD 4.3.8> 42027 - Desert Racer - by mistahfreshone - <LDD 4.3.8> 42028 - Bulldozer (A model) - by mzoli - <LDD 4.3.8> 42028 - Bulldozer (B model) - by mzoli - <LDD 4.3.8> - Comment: "Trench Digger" 42029 - Customized Pick up Truck - by Zblj - <LDD 4.3.8> 42029 - Customized Pick up Truck - by mzoli - <LDD 4.3.8> 42029 - Customized Pick up Truck (B model) - by mzoli - <LDD 4.3.8> - Comment: "Forrest Skidder" 42030 - Volvo L350F Wheel Loader - by pbat - <LDD 4.3.8> 42030 - Volvo L350F Wheel Loader (B model) - by marco9999 - <LDD 4.3.8> 42031 - Cherry Picker (A model) - by mzoli - <LDD 4.3.8> 42031 - Cherry Picker (B model) - by mzoli - <LDD 4.3.8> - Comment: "Tow Truck" 42032 - Compact Tracked Loader - by mzoli - <LDD 4.3.8> 42032 - Compact Tracked Loader (B model) - by mzoli - <LDD 4.3.8> - Comment: "Snow Groomer" 42033 - Record Breaker - by mistahfreshone - <LDD 4.3.8> 42034 - Quad Bike - by mistahfreshone - <LDD 4.3.8> 42035 - Mining Truck - by mzoli - <LDD 4.3.8> 42035 - Mining Truck (B model) - by mzoli - <LDD 4.3.8> - Comment: "Wheel Dozer" 42036 - Street Motorcycle - by mistahfreshone - <LDD 4.3.8> 42036 - Street Motorcycle (B model) - by mistahfreshone - <LDD 4.3.8> - Comment: "Retro Bike" 42037 - Formula Off-Roader - by mzoli - <LDD 4.3.8> 42037 - Formula Off-Roader (B model) - by mzoli - <LDD 4.3.8> - Comment: "Muscle Racer" 42038 - Arctic Truck - by mzoli - <LDD 4.3.8> 42038 - Arctic Truck (B model) - by mzoli - <LDD 4.3.8> - Comment: "Tracked Pickup Truck" 42039 - 24 Hours Race Car - by JGW3000 - <LDD 4.3.9> 42040 - Fire Plane - by JunkstyleGio - <LDD 4.3.8> 42040 - Fire Plane - by mzoli - <LDD 4.3.8> 42040 - Fire Plane (B model) - by mzoli - <LDD 4.3.8> - Comment: "Jet Plane" 42041 - Race Truck - by mistahfreshone - <LDD 4.3.8> 42041 - Race Truck (B model) - by mistahfreshone - <LDD 4.3.8> - Comment: "Race Car" 42042 - Crawler Crane - by KamalMYafi - <LDD 4.3.9> 42043 - Mercedes-Benz Arocs 3245 - by JGW3000 - <LDD 4.3.9> 42044 - Display Team Jet - by mzoli - <LDD 4.3.8> 42044 - Display Team Jet (B model) - by mzoli - <LDD 4.3.8> - Comment: "Stunt Plane" 42045 - Hydroplane Racer - by mzoli - <LDD 4.3.8> 42045 - Hydroplane Racer (B model) - by mzoli - <LDD 4.3.8> - Comment: "Race Boat" 42046 - Getaway Racer - by JC75 - <LDD 4.3.8> 42047 - Police Interceptor - by JC75 - <LDD 4.3.8> 42048 - Race Kart - by JunkstyleGio - <LDD 4.3.8> 42048 - Race Kart (B model) - by KamalMYafi - <LDD 4.3.9> - Comment: "Track Car" 42049 - Mine Loader - by LegoPegasister2015 - <LDD 4.3.8> 42049 - Mine Loader - by KamalMYafi - <LDD 4.3.9> 42050 - Drag Racer - by mistahfreshone - <LDD 4.3.8> 42050 - Drag Racer - by KamalMYafi - <LDD 4.3.9> 42052 - Heavy Lift Helicopter - by JunkstyleGio - <LDD 4.3.8> 42054 - Claas Xerion 5000 Trac VC - by Henni - <LDD 4.3.9> - Comment: Image oversized and uncropped. 42055 - Bucket Wheel Excavator - by Kuramapika1 - <LDD 4.3.11> 42056 - Porsche 911 GT3 RS - by pagicence - <LDD 4.3.11> 42057 - Ultralight Helicopter - by t12ung - <LDD 4.3.10> 42057 - Ultralight Helicopter - by JunkstyleGio - <LDD 4.3.10> 42057 - Ultralight Helicopter (B model) - by JunkstyleGio - <LDD 4.3.10> 42058 - Stunt Bike - by Migui94 - <LDD 4.3.10> 42059 - Stunt Truck - by Migui94 - <LDD 4.3.10> 42060 - Roadwork Crew - by Migui94 - <LDD 4.3.10> 42060 - Roadwork Crew (B model) - by t12ung - <LDD 4.3.10> 42061 - Telehandler - by Migui94 - <LDD 4.3.10> 42061 - Telehandler (B model) - by Migui94 - <LDD 4.3.10> 42062 - Container Yard - by t12ung - <LDD 4.3.10> 42062 - Container Yard (B model) - by Migui94 - <LDD 4.3.10> 42063 - BMW R 1200 GS Adventure - by Migui94 - <LDD 4.3.10> 42063 - BMW R 1200 GS Adventure (B model) - by t12ung - <LDD 4.3.10> 42064 - Ocean Explorer - by Migui94 - <LDD 4.3.10> 42064 - Ocean Explorer (B model) - by Migui94 - <LDD 4.3.10> 42065 - RC Tracked Racer - by Migui94 - <LDD 4.3.10> 42066 - Air Race Jet - by Migui94 - <LDD 4.3.10> 42066 - Air Race Jet (B model) - by Migui94 - <LDD 4.3.11> 42068 - Airport Rescue Vehicle - by Bod9nou - <LDD 4.3.11> 42068 - Airport Rescue Vehicle - by Henni - <LDD 4.3.10> 42068 - Airport Rescue Vehicle (B model) - by Migui94 - <LDD 4.3.10> 42069 - Extreme Adventure - by Migui94 - <LDD 4.3.10> - Comment: entry built by PicnicBasketSam 42070 - 6x6 All Terrain Tow Truck - by Migui94 - <LDD 4.3.10> - Comment: entry built by PicnicBasketSam 42071 - Dozer Compactor - by Migui94 - <LDD 4.3.10> 42071 - Dozer Compactor (B model) - by Migui94 - <LDD 4.3.10> 42072 - WHACK! - by Migui94 - <LDD 4.3.10> 42073 - BASH! - by Bod9nou - <LDD 4.3.11> 42074 - Racing Yacht - by Migui94 - <LDD 4.3.10> 42075 - First Responder - by Migui94 - <LDD 4.3.10> 42075 - First Responder (B model) - by Migui94 - <LDD 4.3.10> - Comment: "Fire Racer" 42076 - Hovercraft - by Migui94 - <LDD 4.3.11> 42076 - Hovercraft (B model) - by Migui94 - <LDD 4.3.11> - Comment: "Jet Boat" 42077 - Rally Car - by Migui94 - <LDD 4.3.11> 42077 - Rally Car (B model) - by Migui94 - <LDD 4.3.11> 42078 - Mack Anthem - by efferman - <LDD 4.3.10> 42078 - Mack Anthem (B model) - by Migui94 - <LDD 4.3.11> 42079 - Heavy Duty Forklift - by M_longer - <LDD 4.3.11> 42079 - Heavy Duty Forklift - by PicnicBasketSam - <LDD 4.3.11> 42080 - Forest Machine - by PicnicBasketSam - <LDD 4.3.11> 42081 - Volvo Concept Wheel Loader ZEUX - by PicnicBasketSam - <LDD 4.3.11> 42081 - Volvo Concept Wheel Loader ZEUX - by pagicence - <LDD 4.3.11> 42081 - Volvo Concept Wheel Loader ZEUX (B model) - by pagicence - <LDD 4.3.11> 42082 - Rough Terrain Crane - by PicnicBasketSam - <LDD 4.3.11> 42082 - Rough Terrain Crane - by Bod9nou - <LDD 4.3.11> 42082 - Rough Terrain Crane (B model) - by Bod9nou - <LDD 4.3.11> 42083 - Bugatti Chiron - by Migui94 - <LDD 4.3.11> 42084 - Hook Loader - by Migui94 - <LDD 4.3.10> 42084 - Hook Loader (B model) - by Migui94 - <LDD 4.3.10> 42088 - Cherry Picker - by Bod9nou - <LDD 4.3.11> 42088 - Cherry Picker (B model) - by Bod9nou - <LDD 4.3.11> 42089 - Power Boat - by Bod9nou - <LDD 4.3.11> 42089 - Power Boat (B model) - by Bod9nou - <LDD 4.3.11> 42093 - Chevrolet Corvette ZR1 - by Migui94 - <LDD 4.3.11> 42093 - Chevrolet Corvette ZR1 (B model) - by Migui94 - <LDD 4.3.11> 42094 - Tracked Loader - by Bod9nou - <LDD 4.3.11> 42096 - Porsche 911 RSR - by Migui94 - <LDD 4.3.11> 42107 - Ducati Panigale V4 R - by Migui94 - <LDD 4.3.11> 42111 - Dom's Dodge Charger - by Migui94 - <LDD 4.3.11> 42026+42027 - Race Truck - by mistahfreshone - <LDD 4.3.8> - Comment: Combines multiple sets 42033+42034 - Extreme Off Roader - by mistahfreshone - <LDD 4.3.8> - Comment: Combines multiple sets 42046+42047 - Extreme Police Racer - by JC75 - <LDD 4.3.8> - Comment: Combines multiple sets 42057+42061+42063 - 40 year anniversary model - by Henni - <LDD 4.3.10> 42072+42073 - Whack! 'n' Bash! - by Migui94 - <LDD 4.3.10> - Comment: Combines multiple sets Teenage Mutant Ninja Turtles 30270 - Kraang's Turtle Target Practice - by CM4S - <LDD 4.3.6> 30271 - Mikey's Mini-Shellraiser polybag - by ChristopherLee - <LDD 4.3.8> 79100 - Kraang Lab Escape - by penguinz - <LDD 4.3.8> 79100 - Kraang Lab Escape - by Stephan - <LDD 4.3.6> 79101 - Shredder's Dragon Bike - by penguinz - <LDD 4.3.8> 79101 - Shredder's Dragon Bike - by Stephan - <LDD 4.3.8> 79102 - Stealth Shell in Pursuit - by Stephan - <LDD 4.3.6> 79102 - Stealth Shell in Pursuit - by penguinz - <LDD 4.3.8> 79103 - Turtle Lair Attack - by penguinz - <LDD 4.3.8> 79104 - The Shellraiser Street Chase - by Stephan - <LDD 4.3.6> 79104 - The Shellraiser Street Chase - by penguinz - <LDD 4.3.8> 79105 - Baxter Robot Rampage - by penguinz - <LDD 4.3.8> 79105 - Baxter Robot Rampage - by Stephan - <LDD 4.3.6> 79116 - Big Rig Snow Getaway - by Flobnomdob - <LDD 4.3.8> 79121 - Turtle Sub Undersea Chase - by Elog - <LDD 4.3.8> 79121 - Turtle Sub Undersea Chase - by Elog - <LDD 4.3.8> The Angry Birds Movie 75821 - Piggy Car Escape - by PicnicBasketSam - <LDD 4.3.9> 75822 - Piggy Plane Attack - by PicnicBasketSam - <LDD 4.3.9> 75823 - Bird Island Egg Heist - by PicnicBasketSam - <LDD 4.3.9> 75824 - Pig City Teardown - by PicnicBasketSam - <LDD 4.3.9> 75825 - Piggy Pirate Ship - by PicnicBasketSam - <LDD 4.3.9> 75826 - King Pig's Castle - by PicnicBasketSam - <LDD 4.3.9> The Hobbit and the Lord of the Rings 9469 - Gandalf Arrives - by ADHO15 - <LDD 4.3.11> 9470 - Shelob Attacks - by ADHO15 - <LDD 4.3.11> 9471 - Uruk-hai Army - by ADHO15 - <LDD 4.3.11> 9472 - Attack on Weathertop - by ADHO15 - <LDD 4.3.11> 9473 - The Mines of Moria - by ADHO15 - <LDD 4.3.11> 9474 - The Battle of Helm's Deep - by ADHO15 - <LDD 4.3.11> 9476 - The Orc Forge - by ADHO15 - <LDD 4.3.11> 10237 - The Tower of Orthanc - by Stephan - <LDD 4.3.11> 10237 - The Tower of Orthanc - by ADHO15 - <LDD 4.3.11> 30210 - Frodo with Cooking Corner polybag - by ADHO15 - <LDD 4.3.11> 30211 - Uruk-hai with Ballista polybag - by ADHO15 - <LDD 4.3.11> 30212 - Mirkwood Elf Guard polybag - by Happy SDE - <LDD 4.3.11> 30213 - Gandalf at Dol Guldur polybag - by Jason C. Hand - <LDD 4.3.11> 30215 - Legolas Greenleaf polybag - by penguinz - <LDD 4.3.11> 30216 - Lake-town Guard polybag - by penguinz - <LDD 4.3.11> 79000 - Riddles for The Ring - by ADHO15 - <LDD 4.3.11> 79001 - Escape from Mirkwood Spiders - by ADHO15 - <LDD 4.3.11> 79002 - Attack of the Wargs - by ADHO15 - <LDD 4.3.11> 79003 - An Unexpected Gathering - by penguinz - <LDD 4.3.11> 79003 - An Unexpected Gathering - by ADHO15 - <LDD 4.3.11> 79004 - Barrel Escape - by ADHO15 - <LDD 4.3.11> 79005 - The Wizard Battle - by penguinz - <LDD 4.3.11> 79006 - The Council of Elrond - by penguinz - <LDD 4.3.11> 79007 - Battle at the Black Gate - by penguinz - <LDD 4.3.11> 79008 - Pirate Ship Ambush - by penguinz - <LDD 4.3.11> 79010 - The Goblin King Battle - by ADHO15 - <LDD 4.3.11> 79011 - Dol Guldur Ambush - by penguinz - <LDD 4.3.11> 79011 - Dol Guldur Ambush - by penguinz - <LDD 4.3.11> 79012 - Mirkwood Elf Army - by penguinz - <LDD 4.3.11> 79013 - Lake-town Chase - by penguinz - <LDD 4.3.11> 79014 - Dol Guldur Battle - by Happy SDE - <LDD 4.3.11> 79015 - Witch-king Battle - by ADHO15 - <LDD 4.3.11> 79016 - Attack on Lake-town - by ADHO15 - <LDD 4.3.11> 79017 - The Battle of Five Armies - by ADHO15 - <LDD 4.3.11> 79018 - The Lonely Mountain - by ADHO15 - <LDD 4.3.11> SDCC033 - Micro Scale Bag End - by C3POwen - <LDD 4.3.11> The Lego Movie 30280 - The Piece of Resistance [Promo] - by vean - <LDD 4.3.8> 30281 - Micro Manager Battle [Promo] - by vean - <LDD 4.3.8> 30282 - Super Secret Police Enforcer [Promo] - by vean - <LDD 4.3.8> 70800 - Getaway Glider - by Stephan - <LDD 4.3.8> 70801 - Melting Room - by Stephan - <LDD 4.3.8> 70802 - Bad Cop's Pursuit - by Stephan - <LDD 4.3.8> 70803 - Cloud Cuckoo Palace - by Stephan - <LDD 4.3.8> 70804 - Ice Cream Machine (A model) - by Stephan - <LDD 4.3.8> 70804 - Ice Cream Machine (B model) - by Stephan - <LDD 4.3.8> 70805 - Trash Chomper (A model) - by vean - <LDD 4.3.8> 70805 - Trash Chomper (B model) - by vean - <LDD 4.3.8> 70806 - Castle Cavalry (A model) - by Stephan - <LDD 4.3.8> 70806 - Castle Cavalry (B model) - by Stephan - <LDD 4.3.8> 70807 - MetalBeard's Duel - by Stephan - <LDD 4.3.8> 70808 - Super Cycle Chase - by Stephan - <LDD 4.3.8> 70809 - Lord Business' Evil Lair - by Stephan - <LDD 4.3.8> - [INCOMPLETE] - Comment: Many missing parts not replaced. 70810 - MetalBeard's Sea Cow - by penguinz - <LDD 4.3.8> 70811 - The Flying Flusher (A model) - by Stephan - <LDD 4.3.8> 70811 - The Flying Flusher (B model) - by Stephan - <LDD 4.3.8> 70812 - Creative Ambush - by Stephan - <LDD 4.3.8> 70813 - Rescue Reinforcements - by vean - <LDD 4.3.8> 70814 - Emmet's Construct - o - Mech - by penguinz - <LDD 4.3.8> 70815 - Super Secret Police Dropship - by penguinz - <LDD 4.3.8> 70815 - Super Secret Police Dropship (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Police Mech" 70816 - Benny's Spaceship, Spaceship, SPACESHIP! - by Canticleer blues - <LDD 4.3.8> 70816 - Benny's Spaceship, Spaceship, SPACESHIP! - by penguinz - <LDD 4.3.8> 70817 - Batman & Super Angry Kitty Attack - by Stephan - <LDD 4.3.8> 70818 - Double-Decker Couch - by Stephan - <LDD 4.3.8> 70819 - Bad Cop Car Chase - by Stephan - <LDD 4.3.8> EMMETSCAR - Emmet's Car/Fly Car [Promo] (A model) - by Stephan - <LDD 4.3.8> EMMETSCAR - Emmet's Car/Fly Car [Promo] (B model) - by Stephan - <LDD 4.3.8> The LEGO Movie 2 30340 - Emmet's 'Piece' Offering polybag - by vean - <LDD 4.3.11> 30527 - Lucy vs. Alien Invader polybag - by vean - <LDD 4.3.11> 30528 - Mini Master-Building MetalBeard polybag - by vean - <LDD 4.3.11> 30620 - Star-Stuck Emmet polybag - by vean - <LDD 4.3.11> 70821 - Emmet and Benny's 'Build and Fix' Workshop! - by vean - <LDD 4.3.11> 70823 - Emmet's Thricycle! - by vean - <LDD 4.3.11> 70830 - Sweet Mayhem's Systar Starship! - by Four_Lokos_Basilisk - <LDD 4.3.11> 70840 - Welcome to Apocalypseburg! - by vean - <LDD 4.3.11> 70841 - Benny's Space Squad - by vean - <LDD 4.3.11> 853865 - LegoThe LEGO Movie 2 Accessory Set - by vean - <LDD 4.3.11> The LEGO Ninjago Movie 70606 - Spinjitzu Training - by PicnicBasketSam - <LDD 4.3.10> 70607 - Ninjago City Chase - by PicnicBasketSam - <LDD 4.3.10> 70608 - Master Falls - by PicnicBasketSam - <LDD 4.3.10> 70609 - Manta Ray Bomber - by PicnicBasketSam - <LDD 4.3.10> 70611 - Water Strider - by PicnicBasketSam - <LDD 4.3.10> 70612 - Green Ninja Mech Dragon - by PicnicBasketSam - <LDD 4.3.10> 70614 - Lightning Jet - by PicnicBasketSam - <LDD 4.3.10> 70615 - Fire Mech - by PicnicBasketSam - <LDD 4.3.10> 70617 - Temple of the Ultimate Ultimate Weapon - by PicnicBasketSam - <LDD 4.3.10> 70618 - Destiny's Bounty - by PicnicBasketSam - <LDD 4.3.10> 70620 - NINJAGO City - by Stephan - <LDD 4.3.11> 70620 - NINJAGO City - by iSware - <LDD 4.3.11> The Lone Ranger 30260 - Lone Ranger’s Pump Car - by Sjuip - <LDD 4.3.6> 79106 - Cavalry Builder Set - by penguinz - <LDD 4.3.8> 79107 - Comanche Camp - by penguinz - <LDD 4.3.8> 79108 - Stagecoach Escape - by penguinz - <LDD 4.3.8> 79109 - Colby City Showdown - by penguinz - <LDD 4.3.8> 79110 - Silver Mine Shootout - by penguinz - <LDD 4.3.8> 79111 - Constitution Train Chase - by Sjuip - <LDD 4.3.9> The Simpsons 71006 - The Simpsons House - by bbqqq - <LDD 4.3.8> 71016 - The Kwik-E-Mart - by Stephan - <LDD 4.3.8> Time Cruisers 6491 - Rocket Racer - by ilulz - <LDD 4.3.5> 6492 - Hypno Cruiser - by ilulz - <LDD 4.3.5> 6493 - Flying Time Vessel - by ilulz - <LDD 4.3.5> 6494 - Mystic Mountain Time Lab - by ilulz - <LDD 4.3.5> 6495 - Time Tunnelator - by ilulz - <LDD 4.3.5> 6496 - Whirling Time Warper - by ilulz - <LDD 4.3.5> 6497 - Twisted Time Train - by ilulz - <LDD 4.3.5> Town 105 - Mail Van - by AndyC - <LDD 4> 106 - UNICEF Van - by vean - <LDD 4.3.6> 107 - Mail Truck - by AndyC - <LDD 4> 361 - Garage - by BrickWild - <LDD 3> 374 - Fire Station - by buddy - <LDD 4> 374 - Fire Station - by AndyC - <LDD 4> 376 - House with Garden - by buddy - <LDD 4> 376 - Town House with Garden - by vean - <LDD 4.3.8> - Comment: aka 560 376 - House with Garden - by AndyC - <LDD 4> 377 - Shell Station - by AndyC - <LDD 4> 379 - Bus Station - by AndyC - <LDD 4> 381 - Police Station - by AndyC - <LDD 4> - Comment: aka 588 381 - Police Headquarters - by Danver - <LDD 4.3.6> - Comment: aka 588 381 - Police Station - by Calabar - <LDD 4> - Comment: aka 588 540 - Police Units - by vean - <LDD 4.3.8> 542 - Street Crew - by vean - <LDD 4.3.8> 554 - Fuel Pumper - by AndyC - <LDD 4> 556 - Emergency Van (Fire Engine) - by AndyC - <LDD 4> - Comment: aka 672 Fire Engine 558 - Road Crane - by vean - <LDD 4.3.8> 600 - Police Patrol - by buddy - <LDD 4> 601 - Shell Gas Pump - by buddy - <LDD 4> 602 - Fire Chief's Car - by buddy - <LDD 4> 602 - Fire Chief's Car - by C3POwen - <LDD 4> 603 - Sidecar - by vean - <LDD 4.3.6> 604 - Shell Service Car - by vean - <LDD 4.3.6> 605 - Street Sweeper - by vean - <LDD 4.3.6> 606 - Ambulance - by marco9999 - <LDD 3> 607 - Mini Loader - by vean - <LDD 4.3.6> 608 - Taxi - by marco9999 - <LDD 3> 621 - Police Car - by vean - <LDD 4.3.8> 622 - Tipper Truck - by vean - <LDD 4.3.8> 623 - Medic's Car - by vean - <LDD 4.3.8> 625 - Tractor - by vean - <LDD 4.3.8> 626 - Red Cross Helicopter - by vean - <LDD 4.3.8> 640 - Fire Truck and Trailer - by C3POwen - <LDD 4> 641 - Excavator - by vean - <LDD 4.3.8> 642 - Tow Truck and Car - by vean - <LDD 4.3.8> 643 - Flatbed Truck - by vean - <LDD 4.3.8> 645 - Police Helicopter - by vean - <LDD 4.3.8> 646 - Auto Service Truck - by vean - <LDD 4.3.8> 671 - Shell Petrol Tanker - by C3POwen - <LDD 4> 672 - Fire Engine and Trailer - by C3POwen - <LDD 4> 673 - Rally Repair Crew - by vean - <LDD 4.3.8> 674 - Forklift & Truck - by vean - <LDD 4.3.8> 675 - Snack Bar - by Captain Tamamono - <LDD 4> 675 - Snack Bar - by AndyC - <LDD 4> 1029 - Milk Delivery Truck - by professor flitwick - <LDD 3> 1068 - Air Patrol - by vean - <LDD 4.3.8> 1069 - Speedboat - by ashir - <LDD 4.3.6> 1070 - Stunt Flyer - by vean - <LDD 4.3.8> 1088 - Road Burner (Formula 1 Racing Car) - (2886) - by Aanchir - <LDD 4> - Comment: aka 2886 1100 - Sky Pirates [Promo] - by Toa_Of_Justice - <LDD 4> 1149 - Air Police - by Costy - <LDD 4> 1188 - Fire Formula - by vean - <LDD 4.3.8> 1189 - Rocket Boat - by vean - <LDD 4.3.8> 1190 - Retro Buggy - by vean - <LDD 4.3.8> 1191 - Try Bird - by vean - <LDD 4.3.8> 1196 - Telecom Race - by Costy - <LDD 4> 1197 - Telecom Race Cyclist and Television Motorbike - by Costy - <LDD 4> 1198 - Service Team - 2 Bikers with Service Tools - by vean - <LDD 4.3.8> 1199 - Telecom Cyclists and Finish Podium - by Costy - <LDD 4> 1246 - Helicopter - by Costy - <LDD 4> 1247 - Patrol Car - by vean - <LDD 4.3.8> 1248 - Fire Boat - by Costy - <LDD 4> 1249 - Tri-motorbike - by Captain Becker - <LDD 4> 1250 - Dragster - by Costy - <LDD 4> 1251 - Go-Cart - by Costy - <LDD 4> 1252 - Shell Tanker [Promo] - by BrickWild - <LDD 4> 1253 - Shell Race Car Transporter [Promo] - by BrickWild - <LDD 4> 1253 - Shell Race Car Transporter [Promo] - by AndyC - <LDD 4> 1254 - Shell Select Store [Promo] - by professor flitwick - <LDD 3> 1254 - Shell Select Store [Promo] - by BrickWild - <LDD 4> 1254 - Shell Select Store [Promo] - by AndyC - <LDD 4> 1255 - Shell Car Wash [Promo] - by BrickWild - <LDD 4> 1255 - Shell Car Wash - by lotrmorgot - <LDD 4.3.6> 1256 - Shell Gas Pumps [Promo] - by BrickWild - <LDD 4> 1265 - Moon Buggy - by Costy - <LDD 4> 1266 - Space Probe - by vean - <LDD 4.3.8> 1284 - Green Buggy - by vean - <LDD 4.3.8> 1285 - Yellow Tiger - by Costy - <LDD 4> 1294 - Fire Helicopter - by vean - <LDD 4.3.8> 1295 - Water Rider - by Costy - <LDD 4> 1296 - Land Scooper - by vean - <LDD 4.3.8> 1297 - Speed Patroller - by vean - <LDD 4.3.8> 1461 - Turbo Force - by vean - <LDD 4.3.8> 1467 - Race Car - by AndyC - <LDD 4> 1468 - Petrol Tanker - by AndyC - <LDD 4> 1470 - Petrol Pumps with Garage Staff - by AndyC - <LDD 4> 1475 - Airport Security Squad - by vean - <LDD 4.3.6> 1484 - Houses - by prateek - <LDD 3> 1489 - Mobile Car Crane - by vean - <LDD 4.3.8> 1490 - Town Bank - by marco9999 - <LDD 4> 1496 - Rally Car - by BrickWild - <LDD 4> 1497 - Pitstop and Crew - by AndyC - <LDD 4> 1517 - Race Car - by vean - <LDD 4.3.6> 1518 - Race Car Repair - by vean - <LDD 4.3.8> 1525 - Container Lorry - by vean - <LDD 4.3.8> 1528 - Dragster - by AndyC - <LDD 4> 1552 - Maersk Line Container Truck - by vean - <LDD 4.3.6> 1560 - Glory Glider [Promo] - by ashir - <LDD 4> 1561 - Stunt Chopper [Promo] - by ashir - <LDD 4> 1562 - Wave Jumper [Promo] - by ashir - <LDD 4> 1563 - Track Blaster [Promo] - by ashir - <LDD 4> 1572 - Super Tow Truck - by vean - <LDD 4.3.8> 1581 - Delivery Truck - by vean - <LDD 4.3.8> 1589 - TCS Breakdown Assistance - by vean - <LDD 4.3.8> 1589 - Town Square - by vean - <LDD 4.3.6> 1590 - ANWB Breakdown Assistance - by vean - <LDD 4.3.8> 1591 - Danone Truck - by vean - <LDD 4.3.8> 1592 - Town Square - by ok13 - <LDD 4> 1610 - Police Car - by vean - <LDD 4.3.8> 1611 - Dune Buggy - by pbat - <LDD 4.3.6> 1612 - Race Car - by vean - <LDD 4.3.6> 1620 - Factory - by vean - <LDD 4.3.6> - Comment: (1620-2) 1630 - Helicopter - by vean - <LDD 4.3.8> 1631 - Black Racer - by vean - <LDD 4.3.8> 1632 - Motor Boat - by vean - <LDD 4.3.8> 1633 - Loader Tractor - by vean - <LDD 4.3.8> 1651 - Maersk Line Container Truck - by vean - <LDD 4.3.6> - Comment: (1651-2) 1656 - Evacuation Team - by vean - <LDD 4.3.8> 1665 - Dual FX Racers - by vean - <LDD 4.3.8> 1682 - Space Shuttle - by Lego Otaku - <LDD 4.3.8> 1687 - Midnight Transport - by lotrmorgot - <LDD 4.3.6> 1702 - Fire Fighter 4x4 - by EM4CZ - <LDD 4> 1710 - Snowmobile - by vean - <LDD 4.3.8> 1720 - Cactus Canyon Value Pack - by lotrmorgot - <LDD 4.3.6> 1750 - Renault Formula 1 Racer - by vean - <LDD 4.3.8> 1760 - Go-Cart - by vean - <LDD 4.3.8> 1761 - Paradisa Speedboat - by AndyC - <LDD 4> 1772 - Airport Container Truck - by vean - <LDD 4.3.8> 1773 - Airline Maintenance Vehicle with Trailer - by vean - <LDD 4.3.8> 1774 - Aircraft - by vean - <LDD 4.3.8> 1775 - Jet - by vean - <LDD 4.3.8> 1782 - Discovery Station - by ilulz - <LDD 4.3.5> 1786 - Jailbreak Joe - by vean - <LDD 4.3.8> 1790 - Shark Fisherman - by Captain Tamamono - <LDD 4> 1791 - Windsurfer & Van - by vean - <LDD 4.3.8> 1792 - Pleasure Cruiser - by vean - <LDD 4.3.8> 1808 - Light Aircraft and Ground Support - by ashir - <LDD 4> 1808 - Light Aircraft and Ground Support - by AndyC - <LDD 4> 1815 - Paradisa Lifeguard - by AndyC - <LDD 4> 1817 - Sea Plane with Hut and Boat - by ok13 - <LDD 4> 1818 - Aircraft and Ground Support Equipment and Vehicle - by vean - <LDD 4.3.6> 1821 - Rally Racers - by vean - <LDD 4.3.8> 1831 - Maersk Line Container Lorry - by vean - <LDD 4.3.6> 1854 - House with Roof Windows [Promo] - by AndyC - <LDD 4> 1876 - Soil Scooper - by vean - <LDD 4.3.8> 1890 - Octan Racer - by vean - <LDD 4.3.8> 1895 - Sky Patrol - by vean - <LDD 4.3.8> 1896 - Trauma Team - by vean - <LDD 4.3.8> 1898 - Weetabix Dragster - by vean - <LDD 4.3.6> 1899 - Weetabix Racer - by vean - <LDD 4.3.6> 1952 - Dairy Tanker - by vean - <LDD 4.3.8> 1959 - Ultra-Light - by vean - <LDD 4.3.8> 1966 - Car Repair Shop - by vean - <LDD 4.3.8> 1974 - Flyercracker USA - by vean - <LDD 4.3.6> 1990 - F1 Race Car - by vean - <LDD 4.3.8> 1991 - Racing Pickup - by vean - <LDD 4.3.8> 1992 - Dragsters - by vean - <LDD 4.3.8> 2140 - ANWB Roadside Assistance Crew - by vean - <LDD 4.3.8> 2147 - Dragon Fly - by BrickWild - <LDD 4> 2148 - Lego Truck - by AndyC - <LDD 4> - Comment: aka 10156 2149 - Color Line Container Lorry - by vean - <LDD 4.3.8> 2234 - Police Chase - by vean - <LDD 4.3.8> 2531 - Rescue Helicopter and Jeep - by vean - <LDD 4.3.8> 2532 - Aircraft and Ground Crew - by Inferno986return - <LDD 4.3.5> - Comment: Similar to 2718 2535 - Formula 1 Racing Car - by vean - <LDD 4.3.8> 2536 - Divers Jet Ski - by vean - <LDD 4.3.8> 2537 - Extreme Team Raft - by vean - <LDD 4.3.8> 2554 - Formula 1 Pit Stop - by vean - <LDD 4.3.8> 2584 - Biker Bob [Promo] - by Aanchir - <LDD 4> 2769 - Aircraft and Boat - by vean - <LDD 4.3.6> 2774 - Airshow (Red Tiger) - by vean - <LDD 4.3.8> 2870 - Paradisa Barbeque - by AndyC - <LDD 4> 2880 - Open-Top Jeep - by vean - <LDD 4.3.8> 2881 - Parking Gate Attendant - by vean - <LDD 4.3.8> 2885 - Ice Cream Seller - by vean - <LDD 4.3.8> 2887 - Petrol Station Attendant and Pump - by vean - <LDD 4.3.8> 2962 - Res-Q Lifeguard - by vean - <LDD 4.3.8> 2963 - Extreme Racer - by vean - <LDD 4.3.8> 3056 - Go Kart [Promo] - by ashir - <LDD 4> 3059 - Mars Mission - Master Builders (Masterbuilders) (A model) - by PeabodySam - <LDD 4.3.8> - Comment: "Astronaut Buggy" 3059 - Mars Mission - Master Builders (Masterbuilders) (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Mission Control" 3059 - Mars Mission - Master Builders (Masterbuilders) (C model) - by PeabodySam - <LDD 4.3.8> - Comment: "Repair Center" 3059 - Mars Mission - Master Builders (Masterbuilders) (D model) - by PeabodySam - <LDD 4.3.8> - Comment: "Shuttle Transporter" 3059 - Mars Mission - Master Builders (Masterbuilders) (E model) - by PeabodySam - <LDD 4.3.8> - Comment: "Space Shuttle" 3059 - Mars Mission - Master Builders (Masterbuilders) (F model) - by PeabodySam - <LDD 4.3.8> - Comment: "COMSAT" 3059 - Mars Mission - Master Builders (Masterbuilders) (G model) - by PeabodySam - <LDD 4.3.8> - Comment: "Orbiter" 3059 - Mars Mission - Master Builders (Masterbuilders) (H model) - by PeabodySam - <LDD 4.3.8> - Comment: "METSAT" 3059 - Mars Mission - Master Builders (Masterbuilders) (I model) - by PeabodySam - <LDD 4.3.8> - Comment: "Space Station" 3059 - Mars Mission - Master Builders (Masterbuilders) (J model) - by PeabodySam - <LDD 4.3.8> - Comment: "Hover Scout" 3059 - Mars Mission - Master Builders (Masterbuilders) (K model) - by PeabodySam - <LDD 4.3.8> - Comment: "Descent Module" 3059 - Mars Mission - Master Builders (Masterbuilders) (L model) - by PeabodySam - <LDD 4.3.8> - Comment: "Astro Lab" 3059 - Mars Mission - Master Builders (Masterbuilders) (M model) - by PeabodySam - <LDD 4.3.8> - Comment: "Rock Rover" 3059 - Mars Mission - Master Builders (Masterbuilders) (N model) - by PeabodySam - <LDD 4.3.8> - Comment: "Drilling Robot" 3059 - Mars Mission - Master Builders (Masterbuilders) (O model) - by PeabodySam - <LDD 4.3.8> - Comment: "Planet Probe" 3438 - McDonald's Restaurant - by vean - <LDD 4.3.6> 3439 - Spy Runner - by vean - <LDD 4.3.8> 3442 - Legoland California Truck, Limited Edition - by vean - <LDD 4.3.6> 4032 - Passenger Plane [Promo] - by AndyC - <LDD 3> 4778 - Desert Biplane - by Happy SDE - <LDD 4.3.8> 4778 - Desert Biplane - by BrickWild - <LDD 3> 4778 - Desert Biplane - by prateek - <LDD 3> 4999 - Vestas Wind Turbine - by ILikePi - <LDD 3> 6331 - Patriot Jet - by vean - <LDD 4.3.8> 6332 - Command Post Central - by PeabodySam - <LDD 4.3.5> - Comment: aka 6636 6333 - Race and Chase - by vean - <LDD 4.3.8> 6334 - Wave Jump Racers - by Canticleer blues - <LDD 4.3.6> 6334 - Wave Jump Racers - by PeabodySam - <LDD 4.3.5> 6335 - Indy Transport - by vean - <LDD 4.3.6> 6336 - Launch Response Unit - by EM4CZ - <LDD 4> 6337 - Fast Track Finish - by Canticleer blues - <LDD 4> 6338 - Hurricane Harbor - by vean - <LDD 4.3.6> 6339 - Shuttle Launch Pad - by BrickWild - <LDD 4> 6340 - Hook & Ladder - by vean - <LDD 4.3.8> 6341 - Gas N' Go Flyer - by ashir - <LDD 4> 6342 - Beach Rescue Chopper - by ashir - <LDD 4> 6344 - Jet Speed Justice - by vean - <LDD 4.3.8> 6345 - Aerial Acrobats - by vean - <LDD 4.3.8> 6346 - Shuttle Launching Crew - by vean - <LDD 4.3.6> 6348 - Surveillance Squad - by vean - <LDD 4.3.8> 6349 - Holiday Villa - by AndyC - <LDD 4> 6349 - Vacation House - by vean - <LDD 4.3.6> - Comment: Update of AndyC's work 6350 - Pizza To Go - by vean - <LDD 4.3.8> - Comment: aka 10036 6351 - Surf N' Sail Camper - by vean - <LDD 4.3.6> 6352 - Cargomaster Crane - by vean - <LDD 4.3.8> 6353 - Coastal Cutter - by vean - <LDD 4.3.6> 6354 - Pursuit Squad - by Vatharian - <LDD 4.3.5> 6355 - Derby Trotter - by AndyC - <LDD 4> 6356 - Med-Star Rescue Plane - by AndyC - <LDD 4> 6357 - Stunt 'Copter N' Truck - by Vatharian - <LDD 4.3.5> 6357 - Stunt 'Copter N' Truck - by vean - <LDD 4.3.6> 6358 - Snorkel Squad - by vean - <LDD 4.3.6> 6359 - Horse Trailer - by AndyC - <LDD 4> 6360 - Weekend Cottage - by Calabar - <LDD 4> 6360 - Weekend Cottage - by AndyC - <LDD 4> 6361 - Mobile Crane - by vean - <LDD 4.3.6> 6362 - Post Office - by vean - <LDD 4.3.6> 6363 - Auto Service Station - by vean - <LDD 4.3.8> 6364 - Paramedic Unit - by AndyC - <LDD 4> 6365 - Summer Cottage - by AndyC - <LDD 4> 6365 - Summer Cottage - by markg - <LDD 3> 6366 - Fire and Rescue Squad - by EM4CZ - <LDD 4> 6367 - Truck - by primitiv - <LDD 4> 6368 - Jet Airliner - by primitiv - <LDD 4> - [INCOMPLETE] - Comment: No substituted parts 6369 - Garage - by vean - <LDD 4.3.6> - Comment: Update of Brickwild's work 6369 - Auto Workshop - by BrickWild - <LDD 4> 6370 - Weekend Home - by AndyC - <LDD 4> 6371 - Service Station - by vean - <LDD 4.3.8> 6372 - Town House - by AndyC - <LDD 4> 6372 - Town House - by vean - <LDD 4.3.8> 6372 - Town House - by vean - <LDD 4.3.6> 6373 - Motorcycle Shop - by Nebsirob - <LDD 4> 6374 - Holiday Home - by AndyC - <LDD 4> 6374 - Holiday Home - by vean - <LDD 4.3.6> - Comment: Update of AndyC's work 6375 - Gas Station - by AndyC - <LDD 4> 6376 - Breezeway Cafe - by AndyC - <LDD 4> - Comment: aka 10037 6377 - Delivery Center - by AndyC - <LDD 4> 6378 - Service Station - by vean - <LDD 4.3.8> 6379 - Riding Stable - by AndyC - <LDD 4> 6380 - Emergency Treatment Centre - by AndyC - <LDD 4> 6380 - Emergency Treatment Center - by vean - <LDD 4.3.6> 6381 - Motor Speedway - by vean - <LDD 4.3.6> 6382 - Fire Station - by Calabar - <LDD 4> 6382 - Fire Station - by AndyC - <LDD 4> 6383 - Public Works Center - by vean - <LDD 4.3.8> 6384 - Police Station - by AndyC - <LDD 4> 6385 - Fire House - by EM4CZ - <LDD 4> 6386 - Police Command Base - by Danver - <LDD 4.3.6> 6387 - Coastal Rescue Base - by vean - <LDD 4.3.6> 6388 - Holiday Home with Caravan - by prateek - <LDD 3> 6388 - Holiday Home with Caravan - by AndyC - <LDD 4> 6389 - Fire Control Center - by vean - <LDD 4.3.8> 6391 - Cargo Center - by vean - <LDD 4.3.8> 6392 - Airport - by vean - <LDD 4.3.6> 6393 - Big Rig Truck Stop - by Johan J - <LDD 4.3.5> 6394 - Metro Park & Service Tower - by vean - <LDD 4.3.8> 6395 - Victory Lap Raceway - by vean - <LDD 4.3.6> 6396 - International Jetport - by vean - <LDD 4.3.6> 6397 - Gas N' Wash Express - by vean - <LDD 4.3.6> 6398 - Central Precinct HQ - by Danver - <LDD 4.3.6> 6399 - Airport Shuttle - by TheMagician - <LDD 4> 6400 - Go-Kart - by vean - <LDD 4.3.8> - Comment: aka 6406, aka 1096 6401 - Seaside Cabana - by AndyC - <LDD 4> 6402 - Sidewalk Cafe - by AndyC - <LDD 4> 6403 - Paradise Playground - by AndyC - <LDD 4> 6404 - Carriage Ride - by AndyC - <LDD 4> 6405 - Sunset Stables - by AndyC - <LDD 4> 6407 - Fire Chief - by EM4CZ - <LDD 4> 6409 - Island Arcade - by AndyC - <LDD 4> 6410 - Cabana Beach - by AndyC - <LDD 4> 6411 - Sand Dollar Café - by AndyC - <LDD 4> 6414 - Dolphin Point - by AndyC - <LDD 4> 6415 - Res-Q Jet Ski/Wave Saver - by Sjuip - <LDD 4.3.5> - Comment: aka 6428 Wave Saver 6416 - Poolside Paradise - by AndyC - <LDD 4> 6417 - Show Jumping Event - by AndyC - <LDD 4> 6418 - Country Club - by penguinz - <LDD 4.3.6> 6418 - Country Club - by AndyC - <LDD 4> 6419 - Rolling Acres Ranch - by AndyC - <LDD 4> 6420 - Mail Carrier - by Sjuip - <LDD 4.3.5> 6422 - Telephone Repair - by vean - <LDD 4.3.8> 6423 - Mini Tow Truck - by vean - <LDD 4.3.8> 6424 - Rig Racers - by vean - <LDD 4.3.8> 6425 - TV Chopper - by vean - <LDD 4.3.8> 6426 - Super Cycle Center - by vean - <LDD 4.3.8> 6429 - Blaze Responder - by vean - <LDD 4.3.8> 6430 - Night Patroller - by vean - <LDD 4.3.8> 6431 - Road Rescue - by vean - <LDD 4.3.8> 6432 - Speedway Transport - by vean - <LDD 4.3.8> 6433 - Coast Watch - by vean - <LDD 4.3.8> 6434 - Roadside Repair - by vean - <LDD 4.3.8> 6435 - Coast Guard HQ - by vean - <LDD 4.3.8> 6436 - Go-Kart - by vean - <LDD 4.3.8> 6437 - Beach Buggy - by pbat - <LDD 4.3.6> 6439 - Mini Dumper - by vean - <LDD 4.3.8> 6440 - Jetport Fire Squad - by AndyC - <LDD 4> 6441 - Deep Reef Refuge - by ilulz - <LDD 4.3.5> 6442 - Sting Ray Explorer - by ilulz - <LDD 4.3.5> 6444 - Outback Airstrip - by AndyC - <LDD 4> 6445 - Emergency Evac - by Instructions archiver - <LDD 4.3.6> 6446 - Crane Truck - by vean - <LDD 4.3.8> 6447 - Dumper - by vean - <LDD 4.3.8> 6450 - Mobile Police Truck - by vean - <LDD 4.3.8> 6451 - River Response - by vean - <LDD 4.3.8> 6452 - Mini Rocket Launcher - by vean - <LDD 4.3.8> 6453 - Com-Link Cruiser - by vean - <LDD 4.3.8> 6454 - Countdown Corner - by marco9999 - <LDD 4.3.5> 6455 - Space Simulation Station.lxf - by Daedalus304 - <LDD 4> 6456 - Mission Control - by marco9999 - <LDD 4.3.5> 6458 - Satellite with Astronaut - by vean - <LDD 4.3.8> 6459 - Fuel Truck - by AndyC - <LDD 4> 6461 - Surveillance Chopper - by vean - <LDD 4.3.8> 6462 - Aerial Recovery - by vean - <LDD 4.3.8> 6463 - Lunar Rover - by Canticleer blues - <LDD 4> 6464 - Super Rescue Complex - by vean - <LDD 4.3.8> 6465 - Space Port Jet - by Toa_Of_Justice - <LDD 4> 6467 - Power Pitstop - by vean - <LDD 4.3.8> 6468 - Tow-n-Go Value Pack - by vean - <LDD 4.3.8> 6470 - Mini Dump Truck - by vean - <LDD 4.3.8> 6471 - 4WD Police Patrol - by vean - <LDD 4.3.8> 6473 - Res-Q Cruiser - by vean - <LDD 4.3.8> 6474 - Wheeled Front Shovel - by vean - <LDD 4.3.8> 6477 - Fire Fighter's Lift Truck - by vean - <LDD 4.3.8> 6478 - Fire Fighters' HQ - by vean - <LDD 4.3.8> 6479 - Emergency Response Center - by PeabodySam - <LDD 4.3.8> 6480 - Hook and Ladder Truck - by vean - <LDD 4.3.8> 6481 - Construction Crew - by vean - <LDD 4.3.8> 6482 - Rescue Helicopter - by AndyC - <LDD 4> 6483 - Coastal Patrol - by Instructions archiver - <LDD 4.3.6> 6484 - F1 Hauler - by vean - <LDD 4.3.8> 6486 - Fire Engine - by EM4CZ - <LDD 4> 6487 - Mountain Rescue - by vean - <LDD 4.3.8> 6489 - Seasonal Holiday Cottage - by AndyC - <LDD 4> 6490 - Amazon Crossing - by vean - <LDD 4.3.8> 6501 - Sport Convertible - by Man with a hat - <LDD 4> 6502 - Turbo Racer - by vean - <LDD 4.3.6> 6503 - Sprint Racer - by vean - <LDD 4.3.6> 6504 - Tractor - by vean - <LDD 4.3.8> 6505 - Fire Chief's Car - by EM4CZ - <LDD 4> 6506 - Precinct Cruiser - by AndyC - <LDD 4> 6507 - Mini Dumper - by pbat - <LDD 4.3.6> 6508 - Wave Racer - by pbat - <LDD 4.3.6> 6509 - Red Racer - by KielDaMan - <LDD 4> 6510 - Mud Runner - by pbat - <LDD 4.3.6> 6511 - Rescue Runabout - by EM4CZ - <LDD 4> 6512 - Landscape Loader - by vean - <LDD 4.3.8> 6513 - Glade Runner - by ashir - <LDD 4> 6513 - Glade Runner - by AndyC - <LDD 4> 6514 - Trail Ranger - by pbat - <LDD 4.3.6> 6515 - Stunt Copter - by ashir - <LDD 4> 6516 - Moon Walker - by vean - <LDD 4.3.8> 6517 - Water Jet - by buddy - <LDD 4> 6518 - Baja Buggy - by Canticleer blues - <LDD 4.3.5> 6518 - Baja Buggy - by buddy - <LDD 4> 6520 - Mobile Outpost - by pbat - <LDD 4.3.6> 6520 - Mobile Outpost - by vean - <LDD 4.3.6> 6521 - Emergency Repair Truck - by BrickWild - <LDD 4> 6521 - Emergency Repair Truck - by KielDaMan - <LDD 4> 6523 - Red Cross - by AndyC - <LDD 4> 6524 - Blizzard Blazer - by vean - <LDD 4.3.6> 6525 - Blaze Commander - by EM4CZ - <LDD 4> 6525 - Blaze Commander - by vean - <LDD 4.3.8> 6526 - Red Line Racer - by vean - <LDD 4.3.8> 6527 - Tipper Truck - by vean - <LDD 4.3.8> 6528 - Sand Storm Racer - by vean - <LDD 4.3.8> 6529 - Ultra Light I - by vean - <LDD 4.3.8> 6530 - Sport Coupe - by vean - <LDD 4.3.8> 6530 - Sport Coupe - by Instructions archiver - <LDD 4.3.6> 6531 - Flame Chaser - by vean - <LDD 4.3.8> 6532 - Diesel Dumper - by vean - <LDD 4.3.8> 6533 - Police 4x4 - by vean - <LDD 4.3.8> 6534 - Beach Bandit - by Yooha - <LDD 4> 6535 - Dumper - by vean - <LDD 4.3.8> 6536 - Aero Hawk - by KielDaMan - <LDD 4> 6537 - Hydro Racer - by vean - <LDD 4.3.8> 6538 - Rebel Roadster - by vean - <LDD 4.3.6> 6539 - Victory Cup Racers - by vean - <LDD 4.3.8> 6540 - Pier Police - by vean - <LDD 4.3.8> 6541 - Intercoastal Seaport - by roamingstudio - <LDD 4> 6542 - Load Launch Seaport - by roamingstudio - <LDD 4> 6543 - Sail N' Fly Marina - by vean - <LDD 4.3.6> 6544 - Shuttle Transcon 2 - by vean - <LDD 4.3.8> 6545 - Search N' Rescue - by vean - <LDD 4.3.6> 6546 - Slick Racer - by PsyKater - <LDD 4.3.5> 6547 - Fun Fair - by AndyC - <LDD 4> 6548 - Octan Gas Station - by vean - <LDD 4.3.8> 6549 - Roadblock Runners - by vean - <LDD 4.3.8> 6550 - Outback Racer - by Instructions archiver - <LDD 4.3.6> 6551 - Checkered Flag 500 - by vean - <LDD 4.3.6> 6552 - Rocky River Retreat - by vean - <LDD 4.3.6> 6553 - Crisis News Crew - by vean - <LDD 4.3.8> 6554 - Blaze Brigade - by vean - <LDD 4.3.8> 6555 - Sea Hunter - by ilulz - <LDD 4.3.5> 6555 - Sea Hunter - by prateek - <LDD 3> 6556 - Scuba Squad - by ilulz - <LDD 4.3.5> 6558 - Shark Cage Cove - by ilulz - <LDD 4.3.5> 6559 - Deep Sea Bounty - by ilulz - <LDD 4.3.5> 6560 - Diving Expedition Explorer - by ilulz - <LDD 4.3.5> 6561 - Hot Rod Club - by vean - <LDD 4.3.8> 6562 - Gas Stop Shop - by vean - <LDD 4.3.8> 6563 - Gator Landing - by BrickWild - <LDD 4> 6564 - Recycle Truck - by vean - <LDD 4.3.8> 6565 - Construction Crew - by vean - <LDD 4.3.8> 6566 - Bank - by vean - <LDD 4.3.8> 6567 - Speed Splasher - by vean - <LDD 4.3.8> 6568 - Drag Race Rally - by vean - <LDD 4.3.8> 6569 - Polar Explorer - by Giovanne - <LDD 4> 6570 - Snowmobile - by vean - <LDD 4.3.6> 6571 - Flame Fighters - by vean - <LDD 4.3.8> 6572 - Wind Runners - by PeabodySam - <LDD 4.3.8> 6573 - Arctic Expedition - by vean - <LDD 4.3.6> 6575 - Polar Base - by vean - <LDD 4.3.6> - Comment: Update of Megaloptus's work 6575 - Polar Base - by Megaloptus - <LDD 4.3.5> 6576 - Sledge - by vean - <LDD 4.3.6> 6577 - Snow Scooter - by vean - <LDD 4.3.6> 6578 - Polar Explorer - by vean - <LDD 4.3.6> 6578 - Polar Explorer - by Costy - <LDD 4> 6579 - Ice Surfer - by Happy SDE - <LDD 4.3.8> 6580 - Land Jet 7 - by vean - <LDD 4.3.6> 6581 - Dig 'N' Dump - by vean - <LDD 4.3.8> 6582 - Daredevil Flight Squad - by vean - <LDD 4.3.8> 6584 - Extreme Team Challenge - by penguinz - <LDD 4.3.6> 6585 - Hang-Glider - by Instructions archiver - <LDD 4.3.5> 6586 - Polar Scout - by vean - <LDD 4.3.6> 6589 - Radical Racer - by vean - <LDD 4.3.8> 6590 - Vacation Camper - by AndyC - <LDD 4> 6591 - Nitro Dragsters - by vean - <LDD 4.3.6> 6592 - Vacation Hideaway - by AndyC - <LDD 4> 6593 - Blaze Battler - by EM4CZ - <LDD 4> 6594 - Gas Transit - by vean - <LDD 4.3.8> 6595 - Surf Shack - by Instructions archiver - <LDD 4.3.6> 6596 - Wave Master - by Instructions archiver - <LDD 4.3.6> 6597 - Century Skyway - by Instructions archiver - <LDD 4.3.6> 6598 - Metro PD Station - by Canticleer blues - <LDD 4> 6600 - Highway Construction - by vean - <LDD 4.3.8> 6601 - Ice Cream Cart - by AndyC - <LDD 4> 6602 - Scorpion Buggy - by vean - <LDD 4.3.8> 6603 - Shovel Truck - by marco9999 - <LDD 4.3.8> 6604 - Formula-I Racer - by vean - <LDD 4.3.8> 6605 - Road Racer - by vean - <LDD 4.3.8> 6606 - Road Repair - by AndyC - <LDD 4> 6607 - Service Truck - by vean - <LDD 4.3.6> 6608 - Tractor - by mzoli - <LDD 4.3.8> 6609 - Race Car - by AndyC - <LDD 4> 6610 - Gas Pumps - by AndyC - <LDD 4> 6611 - Fire Chief's Car - by EM4CZ - <LDD 4> 6612 - Fire Chief's Car - by EM4CZ - <LDD 4> 6613 - Telephone Booth - by AndyC - <LDD 4> 6614 - Launch Evac 1 - by vean - <LDD 4.3.6> 6615 - Eagle Stunt Flyer - by AndyC - <LDD 4> 6615 - Eagle Stunt Flyer - by Toa_Of_Justice - <LDD 4> 6616 - Rocket Dragster - by vean - <LDD 4.3.8> 6618 - Blue Racer - by Costy - <LDD 4> 6619 - Red Four Wheel Drive - by Costy - <LDD 4> 6621 - Fire Truck - by EM4CZ - <LDD 4> 6623 - Police Car - by AndyC - <LDD 4> 6624 - Delivery Van - by AndyC - <LDD 4> 6626 - Snow Scooter - by Costy - <LDD 4> 6627 - Convertible - by vean - <LDD 4.3.6> 6628 - Shell Tow Truck - by vean - <LDD 4.3.8> 6629 - Ambulance - by AndyC - <LDD 4> 6631 - Steam Shovel - by vean - <LDD 4.3.8> 6632 - Tactical Patrol Truck - by AndyC - <LDD 4> 6633 - Family Car - by vean - <LDD 4.3.6> 6634 - Stock Car - by AndyC - <LDD 4> 6641 - 4-Wheelin' Truck - by vean - <LDD 4.3.6> 6642 - Police Helicopter - by vean - <LDD 4.3.6> 6643 - Fire Chief's Truck - by AndyC - <LDD 4> 6644 - Road Rebel - by vean - <LDD 4.3.8> 6645 - Street Sweeper - by vean - <LDD 4.3.6> 6646 - Screaming Patriot/Texas Tornado - by BrickWild - <LDD 4> 6647 - Highway Repair - by AndyC - <LDD 4> 6648 - Mag Racer - by KielDaMan - <LDD 4> 6649 - Street sweeper - by marco9999 - <LDD 4> 6650 - Fire and Rescue Van - by AndyC - <LDD 4> 6651 - Mail Truck - by AndyC - <LDD 4> 6652 - Construction Truck - by vean - <LDD 4.3.6> 6653 - Highway Emergency Van - by vean - <LDD 4.3.6> 6654 - Motorcycle Transport - by vean - <LDD 4.3.6> 6655 - Auto & Tire Repair - by vean - <LDD 4.3.6> 6656 - Tow Truck - by vean - <LDD 4.3.8> 6657 - Fire Patrol Copter - by vean - <LDD 4.3.8> 6658 - Bulldozer - by vean - <LDD 4.3.6> 6659 - TV Camera Crew - by vean - <LDD 4.3.6> 6660 - Hook & Haul Wrecker - by vean - <LDD 4.3.8> 6661 - Mobile TV Studio - by Giovanne - <LDD 4> 6662 - Backhoe - by Vatharian - <LDD 4.3.5> 6663 - Wave Rebel - by vean - <LDD 4.3.8> 6665 - River Runners - by AndyC - <LDD 4> 6666 - Ambulance - by AndyC - <LDD 4> 6667 - Pothole Patcher - by vean - <LDD 4.3.6> 6668 - Recycle Truck - by roamingstudio - <LDD 4> 6669 - Diesel Daredevil - by BrickWild - <LDD 4> 6670 - Rescue Rig - by vean - <LDD 4.3.8> 6671 - Utility Repair Lift - by AndyC - <LDD 4> 6671 - Utility Repair Lift - by vean - <LDD 4.3.6> - Comment: Update of AndyC's work 6672 - Safari Off-Road Vehicle - by KielDaMan - <LDD 4> 6673 - Solo Trainer - by AndyC - <LDD 4> 6674 - Crane Truck - by vean - <LDD 4.3.8> 6675 - Road & Trail 4x4 - by vean - <LDD 4.3.6> 6676 - Mobile Command Unit - by AndyC - <LDD 4> 6677 - Motocross Racing - by vean - <LDD 4.3.8> 6678 - Pneumatic Crane - by mzoli - <LDD 4.3.8> 6679 - Exxon Tow Truck - by vean - <LDD 4.3.8> 6679 - Dark Shark - by vean - <LDD 4.3.8> 6680 - Ambulance - by AndyC - <LDD 4> 6681 - Police Van - by AndyC - <LDD 4> 6682 - Cement Mixer - by marco9999 - <LDD 4.3.8> 6683 - Hamburger Stand - by AndyC - <LDD 4> 6683 - Hamburger Stand - by primitiv - <LDD 4> 6683 - Hamburger Stand - by BrickWild - <LDD 4> 6684 - Police Patrol Squad - by vean - <LDD 4.3.8> 6685 - Fire Copter 1 - by vean - <LDD 4.3.6> 6686 - Backhoe - by vean - <LDD 4.3.8> 6687 - Turbo Prop I - by AndyC - <LDD 4> 6688 - Ambulance - by Giovanne - <LDD 4> 6688 - Ambulance - by AndyC - <LDD 4> 6689 - Post Station - by AndyC - <LDD 4> 6689 - Post Station - by BrickWild - <LDD 4> 6690 - Snorkel Pumper - by C3POwen - <LDD 4> 6691 - Red Cross Helicopter - by vean - <LDD 4.3.8> 6692 - Tractor Trailer - by mzoli - <LDD 4.3.8> 6693 - Refuse Collection Truck - by vean - <LDD 4.3.6> 6694 - Car with Camper - by AndyC - <LDD 4> 6695 - Tanker Truck - by AndyC - <LDD 4> 6696 - Exxon Fuel Tanker - by vean - <LDD 4.3.8> 6697 - Rescue-I Helicopter - by vean - <LDD 4.3.6> 6698 - RV with Speedboat - by AndyC - <LDD 4> 6698 - RV with Speedboat - by vean - <LDD 4.3.6> - Comment: Update of AndyC's work 6699 - Cycle Fix-It Shop - by vean - <LDD 4.3.6> 6707 - Green Buggy - by Costy - <LDD 4> 6714 - Speed Dragster - by vean - <LDD 4.3.8> 7023 - Police 4WD and Undercover Van - by pbat - <LDD 4.3.6> 7030 - Squad Car - by ChristopherLee - <LDD 4.3.8> 7035 - Police HQ - by AndyC - <LDD 4> 7042 - Dune Patrol - by Sjuip - <LDD 4.3.5> 7044 - Rescue Chopper - by Holodoc - <LDD 4> 7046 - Fire Command Craft - by penguinz - <LDD 4.3.6> 8401 - City Minifigure Collection - by KielDaMan - <LDD 4> 10036 - Pizza-To-Go - by professor flitwick - <LDD 3> - Comment: aka 6350 10037 - Breezeway Café - by Lego Otaku - <LDD 4> - Comment: aka 6376 10041 - Main Street - by AndyC - <LDD 4> - Comment: aka 6390 10159 - City Airport - by AndyC - <LDD 4> - Comment: aka 6597 10184 - Town Plan - by prateek - <LDD 3> 10184 - Town Plan - by Gunman - <LDD 3> - [INCOMPLETE] - Comment: Cinema Only 40154 - Pencil Pot - by mzoli - <LDD 4.3.8> Toy Story 7591 - Construct A Zurg - by roamingstudio - <LDD 4> 7592 - Construct-A-Buzz - by roamingstudio - <LDD 4> 7593 - Buzz's Star Command Spaceship - by roamingstudio - <LDD 4> 7595 - Army men on patrol - by Lego lover - <LDD 3> 7595 - Army men on patrol - by prateek - <LDD 3> 7597 - Western Train Chase - by roamingstudio - <LDD 4> 7598 - Pizza Planet Truck Rescue - by C3POwen - <LDD 4> 7599 - Garbage Truck Getaway - by JunkstyleGio - <LDD 3> 30071 - Army Jeep - by ILikePi - <LDD 3> 30072 - Woody's Camp Out - by prateek - <LDD 3> 30073 - Buzz's Mini Ship - by prateek - <LDD 3> Toys R Us Exclusive Build Instructions TRU03 - Star Wars - JEK-14 Stealth Fighter - by Kuramapika1 - <LDD 4.3.11> TRU03-1 - Star Wars - Mini Jek-14 Stealth Fighter (May The 4th in-Store Promotion) - by Stephan - <LDD 4.3.11> TRUBAT - DC Super Heroes - Batman Bat-Signal - by Stephan - <LDD 4.3.11> TRUBB8 - Star Wars - BB-8 - by Kuramapika1 - <LDD 4.3.11> TRUFALCON - Star Wars - Millennium Falcon - by Kuramapika1 - <LDD 4.3.11> TRUFALCON - Star Wars - Millennium Falcon - by KamalMYafi - <LDD 4.3.11> TRUGHOST - Star Wars - The Ghost micro-model - by Kuramapika1 - <LDD 4.3.11> - Comment: Star Wars Rebels TRULEIA - Star Wars - Princess Leia - by Kuramapika1 - <LDD 4.3.11> TRUPCAR - City - Father's Day Police Car (Toys"R"Us building event 2013) - by Stephan - <LDD 4.3.11> TRUTIE - Star Wars - TIE Fighter [Promo] - by Stephan - <LDD 4.3.11> TRUTIE - Star Wars - TIE Fighter - by Kuramapika1 - <LDD 4.3.11> TRUWOOKIEE - Star Wars - Wookiee Gunship - by Kuramapika1 - <LDD 4.3.11> TRUXWING - Star Wars - X-Wing Fighter - by Kuramapika1 - <LDD 4.3.11> TRUXWING - Star Wars - X-Wing Fighter [Promo] - by Stephan - <LDD 4.3.11> TRUXWING-2 - Star Wars - Poe's X-Wing - by Kuramapika1 - <LDD 4.3.11> Train 119 - Super Train Set - by marco9999 - <LDD 3> 126 - Steam Locomotive (Push) - by vean - <LDD 4.3.10> 130 - Wagon with Double Tippers - by vean - <LDD 4.3.10> 131 - Passenger Coach - by roamingstudio - <LDD 4> 164 - Passenger Wagon (A model) - by vean - <LDD 4.3.8> 164 - Passenger Wagon (B model) - by vean - <LDD 4.3.8> 164 - Passenger Wagon (C model) - by vean - <LDD 4.3.8> 165 - Cargo Station - by vean - <LDD 4.3.8> 165 - Cargo Station - by BrickWild - <LDD 4> 166 - Flat Wagon - by vean - <LDD 4.3.8> 167 - Loading Ramp and Car Transport Wagon - by vean - <LDD 4.3.8> 723 - Diesel Locomotive - by vean - <LDD 4.3.10> 726 - 12V Western Train with 2 Wagons and Cowboys - by vean - <LDD 4.3.10> 2126 - Train Cars - by Sjuip - <LDD 4.3.8> 2150 - Train Station - by AndyC - <LDD 4> 2585 - Handcar [Promo] - by Aanchir - <LDD 4> 3225 - Classic Train - by AndyC - <LDD 4> 3225 - Classic Train - by Sjuip - <LDD 4.3.6> 3677 - Red Cargo Train - by roamingstudio - <LDD 4> 3740 - Small Locomotive - by Johnnhiszippy3 - <LDD 3> 3741 - Large Locomotive - by Johnnhiszippy3 - <LDD 3> 3742 - Tender - by AndyC - <LDD 4> 3742 - Tender - by Johnnhiszippy3 - <LDD 3> 4511 - High Speed Train - by Sjuip - <LDD 4> 4512 - Cargo Train - by roamingstudio - <LDD 4> 4513 - Grand Central Station - by ChristopherLee - <LDD 4.3.8> 4513 - Grand Central Station - by Holodoc - <LDD 4> 4514 - Cargo Crane - by mred - <LDD 4> 4525 - Road and Rail Repair - by Sjuip - <LDD 4> 4532 - Level Crossing - by BrickWild - <LDD 4> 4532 - Level Crossing - by AndyC - <LDD 4> 4533 - Train Track Snow Remover - by AndyC - <LDD 4> 4534 - LEGO Express - by Sjuip - <LDD 4.3.6> 4535 - LEGO Express Deluxe - by Sjuip - <LDD 4.3.6> 4536 - Blue Hopper Car - by AndyC - <LDD 4> 4536 - Blue Hopper Car - by Sjuip - <LDD 4> 4537 - Twin-tank Transport - by AndyC - <LDD 4> 4541 - Rail and Road Service Truck - by Sjuip - <LDD 4.3.8> 4544 - Car Transport Wagon - by Sjuip - <LDD 4.3.5> 4546 - Road and Rail Maintenance - by Sjuip - <LDD 4.3.8> 4547 - Club Car - by AndyC - <LDD 4> - Comment: aka 10002 4547 - Club Car - by BrickWild - <LDD 3> - Comment: aka 10002 4549 - Container Double Stack - by Sjuip - <LDD 4.3.6> 4551 - Crocodile Locomotive (A model) - by AndyC - <LDD 4> 4551 - Crocodile Locomotive (A model) - by roamingstudio - <LDD 4> 4551 - Crocodile Locomotive (B model) - by AndyC - <LDD 4> 4552 - Cargo Crane - by Sjuip - <LDD 4.3.8> 4553 - Train Wash - by Sjuip - <LDD 4> 4554 - Metro Station - by Holodoc - <LDD 4> 4555 - Cargo Station - by Sjuip - <LDD 4.3.8> 4556 - Train Station - by Sjuip - <LDD 4> 4557 - Freight Loading Station - by Sjuip - <LDD 4.3.8> 4558 - Metroliner - by AndyC - <LDD 4> - Comment: aka 10001 4560 - Railway Express - by roamingstudio - <LDD 4> - Comment: Similar to 4561 4561 - Railway Express - by AndyC - <LDD 4> - Comment: Similar to 4560 4561 - Railway Express - by roamingstudio - <LDD 4> - Comment: Similar to 4560 4563 - Load N Haul Railroad (A model) - by roamingstudio - <LDD 4> 4563 - Load N Haul Railroad (B model) - by roamingstudio - <LDD 4> 4564 - Freight Rail Runner (A model) - by roamingstudio - <LDD 4> 4564 - Freight Rail Runner (B model) - by roamingstudio - <LDD 4.3.5> 4565 - Freight and Crane Railway - by Sjuip - <LDD 4.3.8> 7710 - Push Along Passenger Steam Train - by roamingstudio - <LDD 4> 7710 - Push-Along Passenger Steam Train - by vean - <LDD 4.3.11> 7715 - Push Along Passenger Steam Train - by roamingstudio - <LDD 4> 7722 - Steam Cargo Train - by roamingstudio - <LDD 4> 7725 - Electric Passenger Train Set (A model) - by AndyC - <LDD 4> 7725 - Electric Passenger Train Set (B model) - by AndyC - <LDD 4> 7740 - Inter-City Passenger Train - by AndyC - <LDD 4> - [INCOMPLETE] - Comment: Tracks missing 7745 - High Speed Passenger Express (A model) - by AndyC - <LDD 4> 7745 - High Speed Passenger Express (B model) - by AndyC - <LDD 4> 7750 - Steam Engine with Tender (A model) - by AndyC - <LDD 4> 7750 - Steam Engine with Tender (B model) - by AndyC - <LDD 4> 7760 - Diesel Shunter Locomotive (A model) - by AndyC - <LDD 4> 7760 - Diesel Shunter Locomotive (B model) - by AndyC - <LDD 4> 7813 - Shell Wagon (A model) - by AndyC - <LDD 4> 7813 - Shell Wagon (B model) - by AndyC - <LDD 4> 7815 - Sleeping Car - by roamingstudio - <LDD 4> 7816 - Shell Tanker Wagon - by AndyC - <LDD 4> 7818 - Passenger Coach - by roamingstudio - <LDD 4> 7819 - Postal Container Wagon Covered (A model) - by AndyC - <LDD 4> 7819 - Postal Container Wagon Covered (A model) - by roamingstudio - <LDD 4> 7819 - Postal Container Wagon Covered (B model) - by AndyC - <LDD 4> 7820 - Mail Van (A model) - by Sjuip - <LDD 4.3.5> 7820 - Mail Van (B model) - by Sjuip - <LDD 4.3.5> 7822 - Railway Station - by AndyC - <LDD 4> 7824 - Train Station - by BrickWild - <LDD 4> 7834 - Level Crossing Manual - by vean - <LDD 4.3.6> - Comment: Update of Brickwild's work 7835 - Manual Road Crossing - by vean - <LDD 4.3.6> 7839 - Car Transport Depot - by AndyC - <LDD 4> 7897 - Passenger Train - by Sjuip - <LDD 4.3.8> 7898 - Cargo Train Deluxe - by Sjuip - <LDD 4.3.8> 7936 - Level Crossing - by Jay Sathe - <LDD 3> 7937 - Train Station - by prateek - <LDD 4> 7938 - Passenger Train - by roamingstudio - <LDD 4> 7938 - Passenger Train - by SpeedySC1978 - <LDD 4.3.11> 7939 - Cargo Train - by AndyC - <LDD 4> 7939 - Cargo Train - by roamingstudio - <LDD 4> 7997 - Train Station - by prateek - <LDD 3> 10013 - Open Freight Wagon - by Johnnhiszippy3 - <LDD 3> 10014 - Caboose - by Johnnhiszippy3 - <LDD 3> 10015 - Passenger Wagon - by Johnnhiszippy3 - <LDD 3> 10016 - Tanker - by Johnnhiszippy3 - <LDD 3> 10017 - Hopper Wagon - by Johnnhiszippy3 - <LDD 3> 10020 - Santa Fe Super Chief - by Johnnhiszippy3 - <LDD 3> 10020 - Santa Fe Super Chief - by AndyC - <LDD 4> 10022 - Santa Fe Cars - Set II (A model) - by AndyC - <LDD 4> 10022 - Santa Fe Cars - Set II (A model) - by Johnnhiszippy3 - <LDD 3> 10022 - Santa Fe Cars - Set II (B model) - by AndyC - <LDD 4> 10022 - Santa Fe Cars - Set II (B model) - by Johnnhiszippy3 - <LDD 3> 10022 - Santa Fe Cars - Set II (C model) - by AndyC - <LDD 4> 10022 - Santa Fe Cars - Set II (C model) - by Johnnhiszippy3 - <LDD 3> 10025 - Santa Fe Cars - Set I - by Johnnhiszippy3 - <LDD 3> 10025 - Santa Fe Cars - Set I (A model) - by AndyC - <LDD 4> 10025 - Santa Fe Cars - Set I (B model) - by AndyC - <LDD 4> 10027 - Train Shed - by BrickWild - <LDD 4> 10128 - Level Crossing - by Holodoc - <LDD 4> 10133 - Burlington Northern Santa Fe (BNSF) GP-38 Locomotive - by Johnnhiszippy3 - <LDD 3> 10133 - Burlington Northern Santa Fe (BNSF) GP-38 Locomotive - by AndyC - <LDD 4> 10157 - High Speed Train Locomotive - by Sjuip - <LDD 4.3.5> 10158 - High Speed Train Car - by Sjuip - <LDD 4.3.5> 10170 - TTX Intermodal Double-Stack Car - by Johnnhiszippy3 - <LDD 3> 10170 - TTX Intermodal Double-Stack Car - by AndyC - <LDD 4> 10173 - Holiday Train - by Sjuip - <LDD 4.3.8> 10194 - Emerald Night - by ILikePi - <LDD 3> 10194 - Emerald Night - by Lego Otaku - <LDD 4.3.6> - Comment: Update of ILikePi's work 10205 - Black Locomotive - by prateek - <LDD 4> 10219 - MAERSK Container Train - by BrickWild - <LDD 4> 10233 - Horizon Express - by Sjuip - <LDD 4.3.6> 10254 - Winter Holiday Train - by Migui94 - <LDD 4.3.10> 10254 - Winter Holiday Train - by Stephan - <LDD 4.3.9> 10277 - Crocodile Locomotive - by Sjuip - <LDD 4.3.11> 40370 - Steam Engine (7810 Reissue) - by vean - <LDD 4.3.11> 60050 - Train Station - by vean - <LDD 4.3.8> 60051 - High-speed Passenger Train - by marco9999 - <LDD 4.3.8> 60052 - Cargo Train - by Sjuip - <LDD 4.3.9> 60098 - Heavy-Haul Train - by Stephan - <LDD 4.3.8> 60198 - Cargo Train - by Sjuip - <LDD 4.3.11> Ultra Agents 70160 - Riverside Raid - by penguinz - <LDD 4.3.8> 70160 - Riverside Raid - by PeabodySam - <LDD 4.3.8> 70160 - Riverside Raid (B model) - by PeabodySam - <LDD 4.3.8> 70161 - Tremor Track Infiltration - by penguinz - <LDD 4.3.8> 70161 - Tremor Track Infiltration (B model) - by PeabodySam - <LDD 4.3.8> 70162 - Infearno Interception - by PeabodySam - <LDD 4.3.8> 70162 - Infearno Interception - by penguinz - <LDD 4.3.8> 70162 - Infearno Interception (B model) - by PeabodySam - <LDD 4.3.8> 70163 - Toxikita's Toxic Meltdown - by penguinz - <LDD 4.3.8> 70163 - Toxikita's Toxic Meltdown (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Mini-Build" 70164 - Hurricane Heist - by penguinz - <LDD 4.3.8> 70164 - Hurricane Heist (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Mini-Build" 70165 - Ultra Agents Mission HQ - by penguinz - <LDD 4.3.8> 70165 - Ultra Agents Mission HQ (B model) - by PeabodySam - <LDD 4.3.8> - Comment: "Mini-Build" 70166 - Spyclops Infiltration - by vean - <LDD 4.3.8> 70166 - Spyclops Infiltration (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 1" 70167 - Invizable Gold Getaway - by vean - <LDD 4.3.8> 70167 - Invizable Gold Getaway (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 2" 70168 - Drillex Diamond Job - by vean - <LDD 4.3.8> 70168 - Drillex Diamond Job (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 3" 70169 - Agent Stealth Patrol - by vean - <LDD 4.3.8> 70169 - Agent Stealth Patrol (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 4" 70170 - UltraCopter vs. AntiMatter - by vean - <LDD 4.3.8> 70170 - UltraCopter vs. AntiMatter (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 5" 70171 - Ultrasonic Showdown - by vean - <LDD 4.3.9> 70171 - Ultrasonic Showdown (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 6" 70172 - AntiMatter's Portal Hideout - by vean - <LDD 4.3.9> 70172 - AntiMatter's Portal Hideout (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 7" 70173 - Ultra Agents Ocean HQ - by vean - <LDD 4.3.9> 70173 - Ultra Agents Ocean HQ (B model) - by PeabodySam - <LDD 4.3.10> - Comment: "Mini-Build 8" Unikitty! 40314 - Dr. Fox Magnifying Machine - by PicnicBasketSam - <LDD 4.3.11> Universal Building Set 145 - Universal Building Set - Airport - by liran1 - <LDD 4.3.8> 400 - Universal Building Set (A model) - by thomasmain - <LDD 4> 610 - Rescue Helicopter - by vean - <LDD 4.3.8> 611 - Air Canada Jet Plane - by C3POwen - <LDD 4> 611 - Air Canada Jet Plane - by AndyC - <LDD 4> 1054 - Stena Line Ferry [Promo] - by moop2000 - <LDD 4> 1469 - Helicopter - by vean - <LDD 4.3.8> 1548 - Stena Line Ferry [Promo] - by marco9999 - <LDD 4> 1554 - Silja Line Ferry [Promo] - by AndyC - <LDD 4> 1575 - Finnjet Ferry [Promo] - by marco9999 - <LDD 4> 1580 - Silja Line Ferry (A model) - by vean - <LDD 4.3.10> 1580 - Silja Line Ferry (B model) - by vean - <LDD 4.3.10> 1580 - Silja Line Ferry (C model) - by vean - <LDD 4.3.10> 1581 - Silja Line Ferry [Promo] - by AndyC - <LDD 4> 1588 - Mobile Command Trailer - by zinfinion - <LDD 4> 1606 - Car (A model) - by AndyC - <LDD 4> 1606 - Car (B model) - by AndyC - <LDD 4> 1607 - Helicopter - by pbat - <LDD 4.3.6> 1655 - Viking Line Ferry [Promotional] - by Stephan - <LDD 4.3.5> 1656 - Viking Line Ferry [Promo] - by AndyC - <LDD 4> 1660 - Kronprins Frederik Ferry [Promo] - by marco9999 - <LDD 4> 1924 - Viking Line Ferry [Promo] - by moop2000 - <LDD 4> 1953 - Mouse - by AndyC - <LDD 4> 1955 - Color Line Ferry [Promotional] - by Stephan - <LDD 4.3.5> 2132 - Cow - by AndyC - <LDD 4> 2134 - Bison - by AndyC - <LDD 4> 2998 - Stena Line Ferry [Promotional] (A model) - by Stephan - <LDD 4.3.5> 2998 - Stena Line Ferry [Promotional] (B model) - by Stephan - <LDD 4.3.5> 2998 - Stena Line Ferry [Promotional] (C model) - by Stephan - <LDD 4.3.5> 2998 - Stena Line Ferry [Promotional] (D model) - by Stephan - <LDD 4.3.5> 3333 - Helicopter - by pbat - <LDD 4.3.6> Universe 55001 - Universe Rocket - by Commander Uno - <LDD 4> Value Packs 1843 - Space / Castle Value Pack - by vean - <LDD 4.3.8> Vikings 7015 - Viking Warrior challenges the Fenris Wolf - by Toa_Of_Justice - <LDD 4.3.5> 7016 - Viking Boat against the Wyvern Dragon - by PeabodySam - <LDD 4.3.8> 7017 - Viking Catapult versus the Nidhogg Dragon - by PeabodySam - <LDD 4.3.10> 7018 - Viking Ship challenges The Midguard Serpent - by penguinz - <LDD 4.3.8> 7019 - Viking Fortress against the Fafnir Dragon - by Elog - <LDD 4.3.8> 7020 - Army of Vikings with Heavy Artillery Wagon - by PeabodySam - <LDD 4.3.8> 7021 - Viking Double Catapult versus the Armored Ofnir Dragon - by PeabodySam - <LDD 4.3.10> Western 2845 - Indian Chief - by ADHO15 - <LDD 4.3.5> 2846 - Indian Kayak - by ADHO15 - <LDD 4.3.5> 6706 - Frontier Patrol - by ADHO15 - <LDD 4.3.5> 6709 - Tribal Chief - by ADHO15 - <LDD 4.3.5> 6712 - Sheriff's Showdown - by ADHO15 - <LDD 4.3.5> 6716 - Covered Wagon - by ADHO15 - <LDD 4.3.5> 6718 - Raindance Ridge - by ADHO15 - <LDD 4.3.5> 6746 - Chief's Tepee - by ADHO15 - <LDD 4.3.5> 6748 - Boulder Cliff Canyon - by ADHO15 - <LDD 4.3.5> 6755 - Sheriff's Lock-Up - by ADHO15 - <LDD 4.3.5> - Comment: aka 6764 6755 - Sheriff's Lock-Up - by Instructions archiver - <LDD 4.3.6> - Comment: aka 6764 6761 - Bandit's Secret Hide-Out - by ADHO15 - <LDD 4.3.5> 6762 - Fort Legoredo - by ADHO15 - <LDD 4.3.5> - Comment: aka 6769 6762 - Fort Legoredo - by AndyC - <LDD 4> - Comment: aka 6769 6763 - Rapid River Village - by ADHO15 - <LDD 4.3.5> - Comment: aka 6766 6765 - Gold City Junction - by ADHO15 - <LDD 4.3.5> 6790 - Bandit's Wheelgun (Boxed) - by ADHO15 - <LDD 4.3.5> - Comment: aka 6791 (polybag) 6799 - Showdown Canyon - by ADHO15 - <LDD 4.3.5> X-Pod 4335 - Black Robots Pod (A model) - by P4trickvH - <LDD 4> 4335 - Black Robots Pod (B model) - by P4trickvH - <LDD 4> 4335 - Black Robots Pod (C model) - by PeabodySam - <LDD 4.3.10> 4335 - Black Robots Pod (D model) - by PeabodySam - <LDD 4.3.10> 4337 - Dragon Pod (A model) - by P4trickvH - <LDD 4> 4337 - Dragon Pod (B model) - by P4trickvH - <LDD 4> 4337 - Dragon Pod (C model) - by PeabodySam - <LDD 4.3.10> 4338 - Monster Pod (A model) - by P4trickvH - <LDD 4> 4338 - Monster Pod (B model) - by P4trickvH - <LDD 4> 4338 - Monster Pod (C model) - by PeabodySam - <LDD 4.3.10> 4339 - Aqua Pod (A model) - by P4trickvH - <LDD 4> 4339 - Aqua Pod (B model) - by P4trickvH - <LDD 4> 4339 - Aqua Pod (C model) - by PeabodySam - <LDD 4.3.10> 4346 - Robo Pod (A model) - by P4trickvH - <LDD 4> 4346 - Robo Pod (B model) - by P4trickvH - <LDD 4> 4346 - Robo Pod (C model) - by PeabodySam - <LDD 4.3.10> 4347 - Auto Pod (A model) - by P4trickvH - <LDD 4> 4347 - Auto Pod (B model) - by P4trickvH - <LDD 4> 4347 - Auto Pod (C model) - by PeabodySam - <LDD 4.3.10> 4348 - Aero Pod (A model) - by P4trickvH - <LDD 4> 4348 - Aero Pod (B model) - by P4trickvH - <LDD 4> 4348 - Aero Pod (Toy Fair Nuernberg Promotion) (C model) - by PeabodySam - <LDD 4.3.10> 4349 - Wild Pod (A model) - by P4trickvH - <LDD 4> 4349 - Wild Pod (B model) - by P4trickvH - <LDD 4> 4349 - Wild Pod (C model) - by PeabodySam - <LDD 4.3.10> 4413 - Arachno Pod (A model) - by P4trickvH - <LDD 4> 4413 - Arachno Pod (B model) - by P4trickvH - <LDD 4> 4413 - Arachno Pod (C model) - by PeabodySam - <LDD 4.3.10> 4415 - Auto Pod (A model) - by P4trickvH - <LDD 4> 4415 - Auto Pod (A model) - by marco9999 - <LDD 4> 4415 - Auto Pod (B model) - by marco9999 - <LDD 4> 4415 - Auto Pod (B model) - by P4trickvH - <LDD 4> 4415 - Auto Pod (C model) - by PeabodySam - <LDD 4.3.10> 4416 - Robo Pod (A model) - by marco9999 - <LDD 4> 4416 - Robo Pod (B model) - by marco9999 - <LDD 4> 4416 - Robo Pod (C model) - by PeabodySam - <LDD 4.3.10> 4417 - Aero Pod (A model) - by P4trickvH - <LDD 4> 4417 - Aero Pod (B model) - by P4trickvH - <LDD 4> 4417 - Aero Pod (C model) - by PeabodySam - <LDD 4.3.10> 4418 - Dino Pod (A model) - by P4trickvH - <LDD 4> 4418 - Dino Pod (B model) - by P4trickvH - <LDD 4> 4418 - Dino Pod (C model) - by PeabodySam - <LDD 4.3.10> 4337+4338 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4337+4339 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4338+4413 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4339+4413 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4346+4348 - n/a - by PeabodySam - <LDD 4.3.10> 4346+4349 - n/a - by PeabodySam - <LDD 4.3.10> 4347+4348 - n/a - by PeabodySam - <LDD 4.3.10> 4348+4349 - n/a - by PeabodySam - <LDD 4.3.10> 4415+4417 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4415+4418 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4416+4417 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets 4416+4418 - n/a - by PeabodySam - <LDD 4.3.10> - Comment: Combines multiple sets (Other) 30029 - LEGO Pudsey Bear polybag - by Happy SDE - <LDD 4.3.8> 40118 - Buildable Brick Box 2x2 - by Stephan - <LDD 4.3.8> - Comment: Series 2 40225 - Rio 2016 Mascots - by lipanz - <LDD 4.3.9> 50011 - BR LEGO Minifigure - by penguinz - <LDD 4.3.6> 850426 - MonthPencil Holder - by vean - <LDD 4.3.6> 852786 - Red Rose (Glued) - by KamalMYafi - <LDD 4.3.9> 4000002 - LOM 2011 Moulding - by Stephan - <LDD 4> 4000002 - LOM 2011 Moulding - by Lego Otaku - <LDD 4> 4000005 - Kornmarken Factory 2012 - by Stephan - <LDD 4.3.5> 4000006 - Production Kladno Campus - by Stephan - <LDD 4> 4000007 - Ole Kirk's House - by noppin - <LDD 4.3.10> 4000008 - LEGO Inside Tour (LIT) Exclusive 2013 Edition ÔÇô Villy Thomsen Truck - by Akeyzerr - <LDD 4.3.8> 4000008 - Villy Thomsen Truck (LEGO Inside Tour Exclusive) - by Stephan - <LDD 4.3.9> 4000014 - The Legoland Train - LEGO Fan Weekend Exclusive Edition - by Stephan - <LDD 4.3.8> 4000015 - LOM Building B - by Stephan - <LDD 4.3.8> 4000018 - Production Kladno Campus 2015 - by Gnac - <LDD 4.3.8> 4000018 - Production Kladno Campus 2015 - by mzoli - <LDD 4.3.8> 4000018 - Production Kladno Campus 2015 - by Stephan - <LDD 4.3.8> 4000019 - Brand Identity and Experience - by Gnac - <LDD 4.3.8> 6168272 - LEGO House Pre-Opening Fan Set - by Stephan - <LDD 4.3.10> lfv1 - Le Fleuriste Collector Vase - Rapid Flore Pop Color - by Stephan - <LDD 4.3.6> lfv2 - Le Fleuriste Collector Vase - Happy - by Stephan - <LDD 4.3.6> lfv3 - Le Fleuriste Collector Vase - Monceau Fleurs Blue Chic - by Stephan - <LDD 4.3.6> LIT2009 - LEGO Inside Tour (LIT) Exclusive 2009 Edition - Ole Kirk's House - by Stephan - <LDD 4.3.8> - Comment: aka 4000007 lwp07 - LEGO World Utrecht Puzzle Promo 2013 - by Stephan - <LDD 4.3.9> - Comment: aka 9000067 ? n/a - Sarcophagus [2008 LEGOLAND California Ambassadors class] - by Brickdoctor - <LDD 3> n/a - LEGO Heart TRU Mother's Day Event [Promo] - by Stephan - <LDD 4.3.6> n/a - Dong Oil Rig [Promotional] - by Stephan - <LDD 4.3.5> TBD - LEGO House Grand Opening set - by Stephan - <LDD 4.3.10> TBD 9000066 - Ev3MEG - by Stephan - <LDD 4.3.9> WHITEHOUSE - Micro White House - by KamalMYafi - <LDD 4.3.9> Quote
petero Posted April 28, 2010 Posted April 28, 2010 (edited) 5988 - Pharaoh's Forbidden Ruins - Theme: Adventurers (Desert) Missing parts in LDD: Sarcophagus and lid. Calabar has made some excellent brick-built sarcophagi for me, so now the facade looks much better The printed pieces are mostly blank On the very back of the ruins, the door frame and turntable on which the skeleton and jewel sit, as well as the magnets. The car's roof and windshield have been replaced The figures, of course, do not have the correct printing. 5988 Pharaoh's Forbidden Ruins in LDD Peter Edited December 3, 2010 by petero Quote
Calabar Posted April 28, 2010 Author Posted April 28, 2010 (edited) 4996 - Beach house [A Model] Theme: Creator [Brickset] [Peeron] [BrickLink] Download (LDD 4.2.5): - Direct link HERE. - More on my BrickShelf Gallery HERE. - Visual Gallery HERE. - Get the ZipPacks from HERE. Known Inaccuracies: - none Extra: A garage expressly made for the beach house. Here an image of the complete assembly (Beach House + Garage). You can find the garage in a separate lxf file (in two versions, one is slightly modified) and a complete assembly with the house in another one inside the ZipPack. @superkalle Now we can start to make an index already! @petero Did you use universe theme to build you set? Edited January 22, 2016 by Calabar Quote
Calabar Posted April 28, 2010 Author Posted April 28, 2010 (edited) 375/6075 - Yellow Castle Theme: Castle > Classic [Brickset] [Peeron] [BrickLink] Download (LDD 4.2.5): - Direct link HERE. - More on my BrickShelf Gallery HERE. - Visual Gallery HERE. - Get the ZipPacks from HERE. Known Inaccuracies: - Flag on Flagpole (3596) replaced with a custom solution - Winch (73037) replaced with a custom solution - Old 1x1 bricks with headlamp (3087c) are replaced with newer ones. - Minifig Accessory Helmet Visor with Grille and Feather (x105) replaced with classic knight helmet (2446+x126+4502a) - I used minifig head with hollow stud (3626b) instead than old type (3626a) - Impossible to use the rope for the draw bridge. - Many decorations missing, replaced if possible. Extra: A version with custom rear doors and an lxf file where all minifigs are lined up outside the castle. Comments: It far away from the original set, some pieces are missing and overall paintings (or better Stickers, in this case) are not reproducible. But it is it, however! Edited January 22, 2016 by Calabar Quote
Superkalle Posted April 30, 2010 Posted April 30, 2010 And here's the 4483 AT-AT. Theme: Star Wars. You can see some alternative versions and download the LXF-file here: http://www.eurobricks.com/forum/index.php?showtopic=41279 Quote
Calabar Posted May 2, 2010 Author Posted May 2, 2010 (edited) 4956 - House [b Model] Theme: Creator [Brickset] [Peeron] [BrickLink] Download (LDD 4.2.5): - Direct link HERE. - More on my BrickShelf Gallery HERE. - Visual Gallery HERE. - Get the ZipPacks from HERE. Known Inaccuracies: - none Extra: Two modified models with plates for the first floor and separable roof, available in the ZipPack. The models has been built in real bricks taking advantage from the set's extra pieces and adding some other piece too. Comments: This is the Creator House 4956 in its 2° configuration (the house with the portico)! It should be complete in all its parts. Edited January 22, 2016 by Calabar Quote
Johnnhiszippy3 Posted May 4, 2010 Posted May 4, 2010 (edited) Here are a few official sets I made in LDD: 10182 - Cafe Corner.LXF 10190 - Market Street 10197 - Fire Brigade 10211 - Grand Emporium They are all missing some minor things, like printing on the minifig torsos, and I've replaced some parts with others (for example, the awnings on the Grand Emporium). The biggest thing that is missing is the bell tower from the Fire Brigade, as far as I can tell LDD does not have the Bellville arches...yet. Edited May 4, 2010 by Johnnhiszippy3 Quote
Superkalle Posted May 4, 2010 Posted May 4, 2010 (edited) Here are a few official sets I made in LDD:They are all missing some minor things, like printing on the minifig torsos, and I've replaced some parts with others (for example, the awnings on the Grand Emporium). The biggest thing that is missing is the bell tower from the Fire Brigade, as far as I can tell LDD does not have the Bellville arches...yet. That's awsome I thought I put a lot hours putting the AT-AT together, but this is on the next level. I say only one thing - keep up the good work. Personally, I find that the good thing about re-building sets in LDD is that you 1) can look into various techniques and 2) play around with mods (color variations or alternate layouts) that you can later build with physicial bricks. Great job! EDIT: Just spotted a small glitch in the lettering on the the Fire Station. And even if the belville pieces aren't in LDD, I think it'd be OK to use some other pieces to get the look. Just my 5 cents..... Edited May 4, 2010 by Superkalle Quote
Johnnhiszippy3 Posted May 4, 2010 Posted May 4, 2010 That's awsome I thought I put a lot hours putting the AT-AT together, but this is on the next level. I say only one thing - keep up the good work. Personally, I find that the good thing about re-building sets in LDD is that you 1) can look into various techniques and 2) play around with mods (color variations or alternate layouts) that you can later build with physicial bricks. Great job! EDIT: Just spotted a small glitch in the lettering on the the Fire Station. And even if the belville pieces aren't in LDD, I think it'd be OK to use some other pieces to get the look. Just my 5 cents..... Yes, your reason #2 is my motivation for creating all of these in LDD - so that I can modify the offical sets. It's alot easier to play around with them on the computer before I start tearing them apart and changing things. I also like to play with my layout on the computer....to see how different things look next to eachother, or with an extra floor. I fixed the date on the top of the FB, and added an improvised bell tower as you suggested. The original files have been updated. And here are a few more (the last of what I have, for now): 10185 - Green Grocer 4954 - Model Town House 10193 - Medieval Market Quote
Superkalle Posted May 5, 2010 Posted May 5, 2010 (edited) Awesome sets Johnnhiszippy3! The look so cool in LDD. BTW Superkalle, it's two cents, not five cents. Just my two cents But I want it to be 5 cents /crying like a baby/. No, but seriously, thanks for letting me know. English is not my native language! @Johnnizippy3 - With those two last models you're moving on to some sort of admiral class when it comes to reproducing official sets in LDD. What I would really like to know are any porential problems you bump into as you build these massive models (problems with using the software, or things that cannot be done in LDD because of missing bricks or brick geometry errors). The best is to post them here http://www.eurobricks.com/forum/index.php?showtopic=40785 @Calabar - the index is coming Edited May 5, 2010 by Superkalle Quote
JunkstyleGio Posted May 7, 2010 Posted May 7, 2010 (edited) I've been working for a few days now with LDD. Biggest project so far is a parc scene in which the minifig celebrate the liberation of the Netherland. It has sevaral regular set in it, some militairy vehicles from Indiana Jones and more than 40 minifigs. All slighty modified ofcourse... seperate pictures of the militairy models and their LDD files are available on my brickshelf (when edited) My brickshelf if anyone is interrested in any of the other the LDD-files i will post them here aswell. Post edited for correctness Edited May 8, 2010 by JunkstyleGio Quote
Calabar Posted May 7, 2010 Author Posted May 7, 2010 You can post here Official Sets taken from your creation, possibly without modifies! Obviously you are encouraged to do so! If you want to share your whole creation with us, you can post it here: it is the topic where we can show our LDD MOCs to other users! Quote
Superkalle Posted May 7, 2010 Posted May 7, 2010 I agree with Calabar; So, JunkStyleGio, please post your own MOCs in the thread that Calabar mentioned. This thread is only for official Lego sets made in LDD. Thanks. Quote
JunkstyleGio Posted May 8, 2010 Posted May 8, 2010 Sorry, I will place the correct files in the correct thread! Is this better? 7641 - City Corner - Theme: City I think i think i made no mistakes. It only has 1 lamppost extra. (And of course missing stickers and correct minifigfaces and -torsos) LDD file: here Quote
Superkalle Posted May 8, 2010 Posted May 8, 2010 Lots better And a great job on that set. Thanks! Quote
Gunman Posted May 9, 2010 Posted May 9, 2010 Hey guys, yesterday i downloaded LDD and today i made cinema building from 10184 set. Image i tried to attach the .lxf file and it says i am not permitted to upload this type of file. (same if i make it .rar) i guess its because i am noob to site.. Quote
Superkalle Posted May 9, 2010 Posted May 9, 2010 i tried to attach the .lxf file and it says i am not permitted to upload this type of file. (same if i make it .rar)i guess its because i am noob to site.. Great looking model. Keep up the good work. And welcome to the LDD talk. About uploading LXF - either you can upload it directly to the Forum, but the space is VERY limited. If you do, you need to zip it first. You may be able to upload to your image sharing site as a zip. If it doesn't work, there's always BrickShelf where you can create a free account. Quote
Gunman Posted May 9, 2010 Posted May 9, 2010 lol i couldnt upload .rar but i could .zip :) here you go guyz 10184_cinema.zip btw i started organizing my lego city wannabe on LDD. almost all orders are ready to unpack and waiting a camera to start bricking/recording while i built my city pic from my town layout (thanks to Johnnhiszippy3 who uploaded the modular houses, now the town plan looks more realistic ) Image Quote
DLuders Posted May 9, 2010 Posted May 9, 2010 I'm pretty sure that if you add any more buildings to this, your computer will crash. Well, one could always divide-up the existing Town layout in LDD into 2-3 pieces, and keep building inside the "blank" areas of the town. Then, one could "tile" the LDD Screenshots side-by-side to create the same overall Town scene. Quote
