Longhorn Posted March 14, 2014 Posted March 14, 2014 I have a problem with keeping axles from sliding out from UV joints or axle connectors. The wheels and axles fall off vehicles after they are driven just a short time. I know it wouldn't be conventional, but can a set screw be used? Or maybe glue? Thanks for any help. Quote
weavil Posted March 14, 2014 Posted March 14, 2014 New connectors would work and rubber bands on the UV joints. I had that problem too, they are cracked. You might not be able to see it, but its there. Over time that invisible crack gets worse. Quote
Meatman Posted March 14, 2014 Posted March 14, 2014 I think if you have to result to screws or glue, you may want to rethink the build. Quote
Longhorn Posted March 14, 2014 Author Posted March 14, 2014 Actually I am building a Model T as seen on Brickshelf: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=537355 and don't see any alternative to the way axles are attached. Quote
Longhorn Posted March 14, 2014 Author Posted March 14, 2014 No, a 5.5 axle with stop would be too long unless I cut it off which isn't LEGO convention I don't think. Quote
JGW3000 Posted March 14, 2014 Posted March 14, 2014 I've got several MOCs in progress in which axles need to be cut - I say go for it Quote
HorcikDesigns Posted March 14, 2014 Posted March 14, 2014 Glue or knife, both aren't conventional... Hard to say, which one is worse ;) Quote
MrNumbskull13 Posted March 14, 2014 Posted March 14, 2014 I say, it's lego, there's only so much you can do with it but if you want to modify parts then go for it. Quote
Paul P Posted March 14, 2014 Posted March 14, 2014 New connectors would work and rubber bands on the UV joints. I had that problem too, they are cracked. You might not be able to see it, but its there. Over time that invisible crack gets worse. Hi I put small O rings on all my UV Joints they hold better and do not split, they can be had in boxes of assorted sizes in our UK £ Shops. Quote
gmshades Posted March 14, 2014 Posted March 14, 2014 Hard to explain, but is the a 1l space between 2 holes the axle goes through before the wheel? You could put 2 half bushings in the space and it will help hold the axle in place. Quote
Longhorn Posted March 15, 2014 Author Posted March 15, 2014 gmshades- No - no space for half bushes. Think I will use 5.5L axles with stop and cut them off. Am leary of using MEK to weld the ABS as might get a bit of MEK where it's not wanted! Not enough space for set screws either. So cutting the 5.5L axles to length seems like the best resolution. Thanks for all the comments. Quote
allanp Posted March 15, 2014 Posted March 15, 2014 A non permanent option would be to tightly wrap thread like you would use for sewing around it very tightly a few dozen times. Quote
astakos Posted March 17, 2014 Posted March 17, 2014 hi, i have solved that problem cutting axle form a longer one. I used a 4 l to make a 3.1 l... The end justifies the means Quote
Milan Posted March 17, 2014 Posted March 17, 2014 hi, i have solved that problem cutting axle form a longer one. I used a 4 l to make a 3.1 l... The end justifies the means To each his own, of course, but many people would consider this cheating. Its LEGO, you can always find solution, that's the beauty of it. Quote
astakos Posted March 17, 2014 Posted March 17, 2014 some people use modified battery pack, some people print parts with 3d printers.. some people (and I) use non lego tyres... for me the only rule is havin fun ! Quote
