I had some downtime at work today, and thankfully I had a LEGO set on-hand to mess with. Perhaps it's the Exo-Force influence, but I whipped this Deep Sea Mech up out of parts from the Sea Machines Designer set. (4505) I'm calling it the Trench Stalker deino.gif
You're probably thinking the legs look a little fragile and unsturdy...well you're right, but because of the small pieces I had to work with for the legs, I was also able to add a little rotational articulation to them at the hips, so it's not all bad.
Pretty much your basic "hunchbacked" mech up top, although I like how I was able to make "fingers" out of the antenna.
And, from all the junk I had to stack up to make the torso, I put in a little auxiliary cockpit in the rear.
Yeah, not that impressive, but not bad for using limited parts just to kill time deino.gif
