MINDSTORMS HUB-TO-HUB COMMUNICATION
INTRODUCTION
A while ago I started my Big Robot V2 project. In order for that project to succeed, I need to be able to sort out hub to hub communications. Back in the good old EV3 days, there was something called daisy-chaining allowing four hubs to be connected. Unfortunately this functionality isn't supported by the new Mindstorms hub. In order to do brick to brick communication, we need to rely on broadcasting messages. Thanks to TLG I got another Mindstorms hub in order to experiment and demonstrate hub-to-hub communications.
PICTURES
Pictures can be clicked to view hi-res versions. My Flickr album contains all the photos taken for this review.
DISCLAIMER
The CEE Team of TLG has provided these elements. It's not my goal to promote these elements. It's my goal to give you an honest opinion about them. Therefore, the opinion in this review is my own and is in no way linked to TLG.
PREREQUISITES
What do we need for hub-to-hub communication? Obviously, we need at least two hubs. And we need a programming environment. This is where things already start to get iffy. There are two applications which support the new Mindstorms hub. The Mindstorms app and the Spike Prime app. Before we can start using Communication blocks, we need to add extra blocks to the templates.
The extra blocks are apparently considered "experimental". We can see the hub-to-hub communications block in the list of extensions.
After adding the communication blocks, we get three extra blocks to handle communications:
  • A block for transmitting a signal
  • A block for receiving a signal
  • A block for the value being received
At this point you would think that you can add these blocks in the Spike environment as well. That would have made way too much sense, so you can't. LEGO Electronics work in mysterious ways. Hub to hub might not be part of the curriculum, but why not add these blocks to Spike anyway. That way enthusiastic students can do more than follow the curriculum.
SETUP
I have created a setup with two hubs and each hub has two motors connected. When I turn the first motor on one hub the second motor will match it's position. The hub will also broadcast a signal which the second hub is listening too. When the second hub received the signal, both connected motors will match the position of the other motors.
VERSION 1
In order to establish hub-to-hub communication, I will create a sender and a receiver program. Let's start with the sender. This program consists of a simple loop that will run forever. When I turn the right wheel, the left wheel will go the same position. And the program will broadcast a message with the position (rotation) of the wheel.
The receiver is listening to any messages being broadcast. When it receives a message, it will turn both wheels to the same position.
The video below demonstrates the setup.
The most noticeable thing is that both motors on the second block don't move in parallel. Movement is sequential, so the second motor doesn't start moving until movement of the first one is complete.
Another observation is that the first motor on the second hub seems to be rotating more or less simultaneously with the motor on the first hub. I expected the motor on the second to start moving after the motor on the first hub had finished. Apparently, the broadcast is done in parallel and it doesn't need to wait for the motor block to finish its movement.
VERSION 2
Let's make some adjustments to the programs. First of all we will do the broadcast before rotating the second motor (even though this doesn't seem to matter). And we will change the receiver that we will move both motors using a single block.
Below is the video demonstrating the second setup.
If there is a difference between the first and second setup regarding the start of the motors, it's not visible to me. The difference between the parallel and sequential movement is clearly visible in this setup. Both motors on the second will start moving simultaneously. For me, this is very important since I want to do a four wheel setup in my Robot project. In order to test the feasibility of my desired setup, I have created a simple prototype robot, which we will test next.
PROTOTYPE ROBOT
So we have concluded that in order to move motors simultaneously, we need to start them using the same block. This won't pose a problem for me, since I need to run all four wheels simulaneously anyway. With our preliminary testing out of the way, I'd like to see if my setup will work using an actual robot. The picture below shows the simple prototype I have created for this purpose.
It uses two hubs and 8 motors. 4 steering motors connected to one hub and 4 driving motors connected to the other hub. I figured it's best to separate the functions, because I need to use a single block for driving. Being able to let one brick focus on one function allows me to have better control over driving and steering.
At this point I wanted to connect the Spike hubs to the Mindstorms app, but this didn't work because I needed to update the firmware. The Spike and Mindstorms firmware aren't interchangeable. I had some issues connecting the Spike hubs to my laptops. This was caused by the fact that I had installed Pybricks firmware on both of them. If you visit the Pybvricks website you can easily "downgrade" to Spike firmware again and after that, I could install the 51515 firmware.
The video below demonstrates the steering mechanism. This does seem to work properly. At the end of the video you see the limitations of the "nearest path" principle. Some of the wheels turn the other way around. This can easily be solved in the software. For now, test succeeded!
CONCLUSION
So what did I learn of this demonstration and can the Mindstorms software be used to program my big robot project? Right off the bat, I need to mention that the Mindstorms software is end of life and it won't be supported by TLG in a year or two. The Spike Prime software doesn't support hub-to-hub communication (at the moment), so that is of no use either. This leaves with a bit of a predicament. At this point I am not sure what to do, because it's unclear what the future of Spike and Mindstorms will bring. Obviously, I am disappointed that the Mindstorms software is terminated, but maybe TLG will move the communication blocks to the Spike software and it won't be an issue. But there is very little information available if this might happen.
In order to create more sophisticated robots and have more control over the motors it might be better to switch to Python using Pybricks anyway. So, in the near future I will do some tests with Pybricks with the same setup and choose the desired solution. Being a software engineer myself, it's to be expected that Pybricks will be my favorite, but it doesn't hurt to do a proof of concept. To be continued...
INTERESTING LINKS
When I was looking into my motor sync issues, I found two interesting sources:
Motor sync issues by Antons Mindstorms
Mindstorms Hub to Hub Robot Arm by Creator Academy Australia
Thanks you for reading this review. All pictures can be found here.
Thank @Jim very nice work! Great way to multiplex sensors / actuators and make a modular interconnected system! I guess that should also be doable for the other hubs!
Nice work and looking forward to the Pybricks tryout! Also tried to use Pybricks for TC24 with a Mindstorms hub but couldn't flash the Firmware because USB was not showing on multiple computers (Mac and Windows) and tried two USB cables. I suspect (hope) it was a cable issue so will try more cables on my next attempt. Goal is to control a vehicle proportionally by tilting and turning the 2nd hub. Pybricks has already shown this is possible with two PU hubs.
With Pybricks you can use almost every hub. This is obviously a plus for simple functions.
It should be fairly simple. Hopefully you will get it to work.
Absolutely!!
Unfortunately, I don't think TLG is ever going to do that, Jim. LEGO Education Spike Prime was specifically designed for students and teachers to use in classrooms, as well as for robotics teams to use in FLL Competitions. As the FLL Competition Rulebook expressly prohibits daisy-chaining of multiple hubs in competition, I do not believe TLG would openly provide teams with the tools required to break these rules. In fact, TLG recently updated the Spike Prime firmware in such a way that it has become impossible to flash the Robot Inventor hubs' firmware onto Spike Prime Hubs, and only the Robot Inventor firmware permitted daisy-chaining. This is obviously a business strategy, and as such, I am afraid that our only hope for daisy chaining, at least for the foreseeable future, lies with the other Powered UP hardware and mobile app.
I'm sorry, Jim, but this is what companies do. They come out with some brand new product and then they either stop supporting that product or introduce a new product so that you are tempted to buy more from them. It is obvious that this is what TLG is willfully doing here. I have no doubts at all they canceled Mindstorms just so that people would be forced to purchase the more expensive Spike Prime system, and then the super-expensive Control+ hardware if they are not satisfied with the limited capabilities of Spike Prime. No matter how long you bake the cake, all they want at the end of the day is their money, and these are the consumer-facing consequences of that. So, unfortunately, I do believe an implementation of daisy-chaining in the Spike Prime environment anytime soon is very unlikely, at least until there is some major breakthrough in the Powered UP System that costs even more money.
The next best thing we can hope for that might happen is an expansion of the Powered UP mobile app that supports the low-energy Bluetooth connectivity of Spike Prime Hubs. But then again, such an update was never listed as an upcoming milestone on the Powered UP Roadmap, so even this is still not likely to happen anytime soon. And whether or not TLG will ever decide to modify this timeline in response to the discontinuation of LEGO Mindstorms remains to be seen by the surrounding community.
Edited by HydroWorld Outlook
Limitations, limitations and more limitations. I'm afraid you are right.
I am not entirely sure that is the reason why TLG cancelled Mindstorms. As a consumer it's hard to get Spike Prime, so why cancel Mindstorms?!
Well, granted TLG did say the primary reason was to focus their energy on their Education lineup, which makes sense because schools pay a lot more money than general consumers to purchase their products. This is purely speculation, but the TLG might be planning a major expansion of their Education line, and if that is actually true, then the cancellation of Mindstorms could be financially justified under the circumstances.
