Last year I bought Tamiya's Hot Shot RC model.
I think it's design is very good since when I was very young so I wanted to buy it and did in Christmas in last year.
Of course not just for build and control this model, I wanted to build it as lego model so main reason is for comparison with model I will make.
I started few week ago but posted in here now.
At first I started on chassis. Surprisingly original model's rear tire can fit in medium racing wheel so I bought 2 set of those tire.
I use BW3 and 2 BW motor for 4WD drive. And like original model, both front and rear use mono shock. I know this shock is more accurate with original model but I use those yellow hard shock which is little more common because I want make instruction and post on rebrickable. In this version, drive gear ratio is 16-28, 16-28 3.06:1
But when I test chassis gear starting to skipping on both front and rear. So I rebuilt gear train and make gear ratio 24-24, 20-28 1.4:1 but can change gear ratio to 8-8-24, 20-28 4.2:1 or 28-20-28 1:1 too.
And add one more shock in rear for better stability.
After fix gear skipping, I built remain body without bumper, wing and light.
But now I stopped build more. Cause BW3 keep turn off when I drive model 1m. After lot of trying to fix this, I throw BW3 away and change to PF system with Sbrick.(2 L, 1 Servo, 1 rechargeable battery) Now it can drive more but to much slow and don't have much torque.(gear ratio is same 1.4:1)
I need to find other way for drive this thing. Than I will finish it's bodywork.
Edited by msk6003
Cool rebuild, you kept the spirit of the original nicely. I like the suspension especially.
It's a pity that it shuts down so fast. Have you tried what happens with say 80% power? As far as I remember that helped for others with a similar gear ratio. Or just experiment with decreasing power until it does not shut down. It should definitely work at some point of the power curve.
Nice MOC!
I like the style of the retro RC buggys and truggys too; I recently finished 2 truggys.
 I first went with a 4x4 - I still need to take the rest of the motors for it, then I wanted to do something more simple.
For the 2nd variant of the simple truggy, I was inspired by the Kyosho Optima Mid.
Anyway, keep up with the good work!
Edited by Lixander
Thanks for comment everyone.
3 hours ago, mla2 said:
Really nice! It's a shame the BW3 doesn't work for this. Perhaps a CaDa white top battery box will?
I also thinking that cada's battery/motor combo but I don't have that. Second, I think use BW2 but I can't believe it anymore. Than I made it PF version but now I thinking use C+ hub with 2 large angular / spike large motor with 1:1.29 gear up or keep same 1.4:1 reduction. C+ large is to big to keep both 1.4:1 ratio and side '3' plate.
  • 5 weeks later...
Progress 4
BW3 is keep turn off after drive just 1m straight due to low current limit so I change to Cada's motor and battery now work very well. I tested C+ motors also but it is to much slow. Original 1.4:1 gear reduction is also work but it also make turn off after 30 sec free drive so I reduce ratio to 4.2:1 and it's work fine.
After that, I changed roof to use tile and add headlight, bumper and wing. Still need to tweak but now I can say it is 95% finish.
Edited by msk6003
Progress 5
CADA's battery work very well but I found it has low capacity.
So remove cada's battery and keep for other use, I back to BW3.
But this time, I use 2 BW3 insted 1. Now I can't finish Hyundai N74 due to use my all BW3 on this but hot shot is more important project than N74.
So, I drive it with 8-8-24, 20-28 gear reduction but suddenly car don't move.
I disassemble and find this happen...
Yes. Second 8t's axle is melted and stick to beam. I'm very suprised because this is first time I seen melted axle.
Anyway, I think this happen because 8-8 gear is spin to fast, I change to 20-28, 20-28 gear reduction.
And it works very well! Even can change gear to 12-36, 20-28!
Than I starting make this on studio for make instruction.
Due to original tire don't have in studio, I use landrover's tire.
I found front bumper I made before is to low than original so I remove it. It will make soon again.
54 minutes ago, msk6003 said:
I'm very suprised
Are you really surprised? Don't think though :pir-wink:
LEGO MOCs using nothing but LEGO/3rd party ABS elements translates to non-lubed, full friction ABS on ABS surfaces. And when you spin things much faster than the lame original LEGO components allow you to do, well - meltdown is around the corner, isn't it?
I'd go lubed full metal jacket to spin things as fast as possible, to be honest.
Best,
Thorsten
If you want more realistic renders, you can paint the tires in ”Rubber black” (it is in the black/white colors, but it is a little lower than the standard colors)
