What's up everyone? I created another motorcycle which I call the "Big Thumper". Why? Because this bike has the biggest cylinder ever seen in a Lego Technic motorcycle! Here is a picture of this monstrosity:
When you push the motorcycle forward, you can actually hear the distinctive "thumping" sound characteristic of big-bore cruisers!
Despite its size, the cylinder fits nicely inside a hard-tail frame:
As you can see, the other main feature is the steering mechanism, which allows the ape-hanger handlebars to be placed on top of the fuel tank. Combined with the engine-mounted floorboards this provides the ideal feet-forward riding position!
As always, the building instructions are available for free on my website and on Rebrickable.
3 minutes ago, jorgeopesi said:
Cool bike and rear wheel :thumbup: .
Thanks! I'm particularly proud of the way it's mounted using two angular swingarms:
It leaves exactly as much room as is needed for the wheel, the gear, and the chain to spin freely.
Interesting build.
Those chains are really for balls of steel.
What provides structural stability to rear axle? I checked instructions, it definately will move side to side, and do some kind of steering. Maybe I missed something?
It's a original looking ride, and the colorsceme looks good. I like the engine idea. :thumbup:
But some of the building techniques, especially the way the rear swingarm is constructed, is what I would call "questionable". Did you build this irl too?
Nice motorcycle :)
How do you prevent the cylinder engine from dropping? In the steps of page 11 I see a few tiles being placed to hold the cylinder, but that is at the top. I see nothing on the bottom to prevent it from scraping the floor.
Don't worry, of course I built this in real life first and I took great care to make sure everything is legal and sturdy.
13 minutes ago, Lira_Bricks said:
Nice motorcycle :)
The cylinder is 4 studs wide, but the opening on the bottom is only 3 studs wide. It's impossible to fall out!
2 hours ago, Jurss said:
Interesting build.
The secret lies in this little Technic Pin 1/2:
It brushes up against the rim of the wheel. Not so much to cause any friction, but enough to prevent the wheel from moving side-to-side.
