Hello everybody! I hasten to introduce you to a new job:
Pneumatic Disc Brakes Lego Technic.
In work details were modified.
Try to bet on Chiron. Disks I have no)
Subscribe to the Shannel / Подписывайтесь на Канал
YouTube - Subscribe
Edited by Nikolay
looks very good!
could you try using a craft-knife to slice a small amount from the top of each rubber stopper, so they are thinner, so you can mount them to both sides?
might only have to use 2?
omg ths is awesome!
I have start try to do this like only 2 days and then i give up. It is so hard and so limited space.
this is what i have done so far.
i think you may try to use Different colours of the 0.5x5L arms too, it works well.
On 11/4/2018 at 2:59 AM, RohanBeckett said:
looks very good!
Experiment, and then tell us about the results) do not have time.
On 11/5/2018 at 11:22 AM, Homersapien said:
I like your idea but being all electric motors maybe not very usefull. but hey, maybe your just ahead of your time :D
Let's see, I'm very interested)
On 11/5/2018 at 9:54 PM, Aleh said:
How about using bar instead of this 5l brown axle?
What part is that? don't quite understand
On 11/5/2018 at 5:10 PM, SamuelYsc said:
omg ths is awesome!
I totally understand. Yeah, that's not easy. Good thing those the hub and the drives appeared.
Continue and succeed.
On 11/5/2018 at 7:06 PM, technic_addict said:
Nice design.
Why didn't rubber inserts work on both sides?
Was there any room left to fit a tile or sloped piece to cover it all so it looks better through the wheel?
The hose bends the caliper. The inner pad is always fitted to the disc diagonally
I thought to put smooth tiles. But except to glue them on two-sided tape did not come up
I think if you rotate the pneumatic cylenders 90 degrees so that the pinholes are facing the floor then the cylender will be able to pivot with the steering, whiich means its more compact and there is not as many parts moving with the steering.
Cool design though.
regards, Snipe
Edited by SNIPE
I made this idea in the likeness of the original mechanism. Thank you for your look
Cool design though.
regards, Snipe
My idea for the fun of it:
Only possible problem is it might brake slightly when turning.
Edited by SNIPE
Push.
I have reference your idea and try to put on my Bugatti MOC update, it is ultimate hard to do with.
I have to concern about does is work with the steering and Suspension?
I hope it should be work.
Post link: here
Yes, such a problem exists. Decision somewhere near)
On 11/27/2018 at 5:31 PM, SamuelYsc said:
Push.
Post link: here
Your work with bugatti is impressive! Scale. With the steering knot, in tests, everything is quite good
