Murdoch17 Posted June 29, 2017 Posted June 29, 2017 (edited) Here we see my MOD of the Brick City Depot (Winter Village) Fire station. I redid the color scheme in some places & added a different Fire Engine. I remodeled the top level (no tower) and put pillars in the corners of the building, plus I added a back wall with inside details. The garage doors open to allow the fire truck to back in. (it does fit, I checked!) The 4 x 4 bonnet right above the doors should feature this print. As you can see, here is the back wall with the chimney flue for the oven and roof top water storage barrel. The inside now features two bunk beds. a oven, table, chairs, reception area and rotary-dial phone. The fireman's pole goes from the upper floor to the bottom level, and stairs allow for you to return to the top. I was inspired to build this by set 9484, Red's Water Rescue. I replaced the eyes with window parts, while adding a grille where the mouth was. I also beefed up the rear, and removed the flick-fire missiles. The sides of the truck should have two of this print under the hoses where the blank 2 x 2 tiles are. The side of the truck features two hoses (one for each side) and the roof has a ladder. (The ladder can rotate 360 degrees and can go up and down.) The doors to get into the crew cab also open and close while the sides feature 4 hose hookups (that's the pearl gold 1x1 round studs) and two identical pump controls. The LDD for both the station and truck can be downloaded here. Comments, Questions & Complaints are welcome, and this model is on the to-be-built short list... maybe by December of this year(?) alongside the town hall. Any thoughts? Edited June 29, 2017 by Murdoch17 Quote
