After not playing with LEGO for a few years, I've recently taken some of it from my parents place with me and started building my first MOC.
I'm happy with the proportions so far, but I'll probably redo the front and cabin.
The fifth-wheel coupling should be working and is manually lockable, but I haven't tested this with a trailer yet.
The cabin is tiltable and stays in place once opened.
The Truck is currently powered by two hard-coupled XL motors connected to the center axle. I'm not sure yet whether to use two motors and an adder or just one. I only have a single differential right now, otherwise both axles would be powered.
Steering isn't controllable right now, I need to get a PF servo first.
You can't really see it in this picture, but the ground clearance is only about 1/4 stud.
I've also build a simple ramp for use in the trailer, which is controlled by a mini-LA.
Photos are taken with my phone, so the quality is not the best.
I'd rebuild fifth wheel, because now it is strong as that connection between grey and black connectors. 2L axle has chances to slip from the one of them.
  • 1 year later...
I agree, is there enough room to mod it to connect beneath?
It looks good, welcome!
Just now, Aventador2004 said:
Edited by Aventador2004
Quote won't remove!
Looking at the pictures my mind immediately started thinking: It's time to play EuroTruck Simulator :)  Hope to see how this MOC develops over time. Welcome to EuroBricks
